Wyze Switch: Remote Home Automation for Lights & Devices
Wyze Switch: Smart Home Automation for Lights and Devices
Transform your home lighting and device control with the Wyze Switch, a smart WiFi light switch designed to turn your ordinary lights into smart lights you can control from anywhere. Whether you're at work, on vacation, or just relaxing on the couch, the Wyze Switch lets you manage your home lighting and other Wyze devices effortlessly through the Wyze app.
Key Features of Wyze Switch
  • Remote Control: Turn your lights on or off from anywhere using the Wyze app.
  • Multi-Tap Customization: Use single, double, triple taps, or press-and-hold actions to control other Wyze devices like Wyze Cams, Wyze Lock, and Wyze Robot Vacuum.
  • Smart Control with Wyze Bulbs: Unlike traditional switches that cut power to bulbs, Wyze Switch supports Smart Control mode to keep Wyze Bulbs powered for seamless automations.
  • Automations & Schedules: Set timers, schedules, and Vacation Mode to simulate occupancy and enhance home security.
  • Power Loss Recovery: Automatically reconnects to Wi-Fi and restores previous settings after power outages.
  • Easy Installation: Designed for quick and straightforward installation in any room.
Upgrade your home with a smart switch that integrates perfectly into your Wyze ecosystem, making your home smarter and more responsive to your lifestyle. Wyze Switch in Kitchen Lifestyle Control your kitchen lights and devices with Wyze Switch and voice assistants.
Wyze Plug: Remote Control for Any Outlet
The Wyze Plug is your gateway to smart home convenience for any device plugged into a standard outlet. From lamps and fans to coffee makers and air purifiers, Wyze Plug lets you control your everyday devices remotely with ease.
Why Choose Wyze Plug?
  • Control from Anywhere: Turn devices on or off remotely via the Wyze app without needing a hub.
  • Scheduling & Energy Savings: Create schedules to automate device usage and save energy effortlessly.
  • Voice Assistant Compatible: Works seamlessly with Amazon Alexa and Google Assistant for hands-free control.
  • Vacation Mode: Randomly turns devices on and off to make it look like someone’s home, enhancing security.
  • Group Control: Manage multiple plugs together with a single tap in the app.
  • No Hub Required: Simple plug-and-play setup with Wi-Fi connectivity.
Wyze Plug is perfect for making your existing devices smart without replacing them, adding convenience and energy efficiency to your home automation setup. Wyze Plug Lifestyle Manage your home appliances remotely with Wyze Plug.
Wyze Bulb Color: Brilliant Smart Lighting with 16 Million Colors
Add vibrant, customizable lighting to your home with the Wyze Bulb Color, a smart bulb that offers 16 million colors and tunable white light to set the perfect mood in any room.
Features of Wyze Bulb Color
  • 16 Million Colors: Choose from a vast palette to create the perfect ambiance for any occasion.
  • Dimmable & Tunable White: Adjust brightness and color temperature from warm to cool whites.
  • High Brightness: Up to 1100 lumens for clear, bright lighting.
  • Smart Control: Control via Wyze app, voice commands (Alexa, Google Assistant), or automations.
  • Long Life: Rated for 25,000 hours of use.
  • Suitable for Damp Locations: Safe for use in bathrooms and covered outdoor areas.
Pair Wyze Bulb Color with Wyze Switch to unlock advanced smart lighting control that keeps your home lively and energy-efficient. Wyze Bulb Color in Living Room Create colorful lighting scenes with Wyze Bulb Color.
Why Choose Wyze for Home Automation?
Wyze offers a comprehensive ecosystem of smart home products designed to work together seamlessly. The Wyze Switch, Wyze Plug, and Wyze Bulb Color empower you to control lights and devices remotely, create personalized automations, and enhance your home’s security and comfort — all from a single app.
"With Wyze, your home automation is simple, affordable, and powerful. Control your lights, locks, cameras, and more with just a tap or voice command."
Start your smart home journey today with Wyze and experience the convenience of controlling your home lighting and devices remotely.
Summary of Featured Products
FeatureWyze SwitchWyze PlugWyze Bulb Color
TypeConnected HomeConnected HomeSmart Lighting
DescriptionTurn normal lights into smart lights; multi-tap controls for other Wyze devicesMake normal devices smart16 million color smart bulb; dimmable option
Control MethodWyze appWyze appWyze app
Smart FeaturesMulti-tap custom actions, automations, timers, vacation mode, power loss recoveryScheduling, energy monitoring, voice controlCustom presets, white light temp control, sleep routines, music mode
IntegrationWyze ecosystemAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
ConnectivityNot specified (assumed WiFi)2.4GHz WiFi802.11 b/g/n WiFi, 2.4GHz, Bluetooth
Sizes/Variants1 Pack, 3 Pack2 Pack, 4 Pack2 Pack, 4 Pack, 6 Pack
Price Range$14.99 - $41.98$24.98 - $39.98$26.26 - $64.98
Power ConsumptionNot specifiedInput: 100-120 VAC, 60Hz12 watts
DimensionsNot specified2.7" x 2.0" x 1.5"2.5" x 2.5" x 5"
WeightNot specified5.3 oz0.31 lbs
Special FeaturesPower loss recovery, multi-tap control of Wyze devicesEnergy monitoring, indoor use only1100 lumens max brightness, tunable white, 25,000 hours life expectancy
Operating TemperatureNot specified-4°F to 104°F (-20°C to 40°C)-4°F to 104°F
WarrantyNot specified1 YearNot specified
What is the Wyze Switch and how does it work?The Wyze Switch is a smart WiFi light switch that transforms your ordinary lights into smart lights. It allows you to control your home lighting and other Wyze devices remotely through the Wyze app, offering features like multi-tap customization, automations, and easy installation.
Can I control Wyze Switch from anywhere?Yes, you can control the Wyze Switch from anywhere using the Wyze app on your smartphone, whether you're at home, at work, or on vacation.
What devices can I control with Wyze Switch multi-tap actions?With Wyze Switch's multi-tap customization, you can use single, double, triple taps, or press-and-hold actions to control other Wyze devices such as Wyze Cams, Wyze Lock, and Wyze Robot Vacuum.
Does Wyze Switch support smart bulbs like Wyze Bulb Color?Yes, Wyze Switch supports Smart Control mode, which keeps Wyze Bulbs powered for seamless automations, unlike traditional switches that cut power to the bulbs.
What happens to Wyze Switch settings after a power outage?Wyze Switch features power loss recovery, which means it automatically reconnects to Wi-Fi and restores your previous settings after a power outage.
Is Wyze Switch easy to install?Yes, Wyze Switch is designed for quick and straightforward installation in any room, making it easy to upgrade your home lighting.
What is Wyze Plug and what can it control?Wyze Plug is a smart plug that allows you to control any device plugged into a standard outlet, such as lamps, fans, coffee makers, and air purifiers, remotely via the Wyze app.
Do I need a hub to use Wyze Plug?No, Wyze Plug does not require a hub. It connects directly to your Wi-Fi for simple plug-and-play setup.
Can I schedule devices with Wyze Plug?Yes, you can create schedules and automations with Wyze Plug to turn devices on or off at specific times, helping you save energy and add convenience.
Is Wyze Plug compatible with voice assistants?Yes, Wyze Plug works seamlessly with Amazon Alexa and Google Assistant, allowing for hands-free voice control of your devices.
What is Vacation Mode on Wyze Switch and Wyze Plug?Vacation Mode randomly turns your lights or devices on and off to simulate occupancy, enhancing your home security when you're away.
What are the features of Wyze Bulb Color?Wyze Bulb Color offers 16 million colors, dimmable and tunable white light, up to 1100 lumens brightness, smart control via app or voice, long life (25,000 hours), and is suitable for damp locations like bathrooms and covered outdoor areas.
Can I control Wyze Bulb Color with my voice?Yes, Wyze Bulb Color is compatible with Amazon Alexa and Google Assistant, allowing you to control your lighting with voice commands.
How do Wyze products work together for home automation?Wyze products like the Switch, Plug, and Bulb Color are designed to work seamlessly together within the Wyze ecosystem, allowing you to control lights and devices remotely, set up personalized automations, and enhance your home’s security and comfort from a single app.
Why should I choose Wyze for smart home automation?Wyze offers an affordable, easy-to-use ecosystem of smart home products that integrate seamlessly, providing powerful control over your lights, devices, and security—all from one app or with voice commands.
How does the Wyze Switch integrate with other Wyze devices?Can I use the Wyze Switch with voice assistants like Alexa or Google Assistant?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Switch?
