Wireless Smart Switch Compatible with Regular Bulbs and Wyze Bulbs
Upgrade your home lighting effortlessly with a wireless smart switch that works seamlessly with both regular bulbs and Wyze smart bulbs. Whether you want to control your existing lighting or enhance your Wyze smart home ecosystem, the Wyze Switch offers an affordable, versatile, and easy-to-install solution.
Wyze Switch: Smart Control for Every Light
The
Wyze Switch is designed to turn your normal lights into smart lights, giving you full control from anywhere via the Wyze app. It’s the perfect wireless smart switch compatible with both regular bulbs and Wyze bulbs, ensuring your automations stay intact without cutting power to your smart bulbs.
Key Features:
- Multi-tap Control: Customize single, double, triple taps, and press-and-hold actions to control other Wyze devices like Wyze Cams, Wyze Lock, and Wyze Robot Vacuum.
- Smart Control Mode: When paired with Wyze Bulbs, the switch turns bulbs on/off without cutting power, preserving smart bulb automations.
- Remote Access: Control your lights from anywhere using the Wyze app.
- Timers & Schedules: Automate your lighting with schedules or timers for convenience and energy savings.
- Vacation Mode: Simulate occupancy by automatically turning lights on/off when you’re away.
- Power Loss Recovery: Automatically reconnects to Wi-Fi and restores previous settings after power outages.
- Easy Installation: Fits standard wall switch boxes and replaces your existing switch without rewiring your bulbs.
Available Options:
- Single Pack at $14.99
- 3-Pack Bundle (currently sold out)
Smart Wyze Switch in a modern kitchen setting, compatible with voice assistants
Why Choose Wyze Switch for Your Smart Lighting?
Wyze Switch is uniquely designed with Wyze Bulbs in mind, solving a common problem where traditional switches cut power to smart bulbs, breaking automations. With Wyze Switch, your Wyze Bulbs remain powered and connected, allowing you to enjoy full smart control without compromise.
“All your lights just got smarter.”
Upgrade any room with a smart switch that integrates perfectly with your Wyze ecosystem.
Enhance Your Smart Home Ecosystem
The Wyze Switch is not just a light switch; it’s a hub for your smart home actions. Customize your switch presses to trigger multiple Wyze devices:
- Single press: Turn on/off lights
- Double press: Lock/unlock Wyze Lock
- Triple press: Start Wyze Robot Vacuum
- Press and hold: Activate Wyze Sprinkler Controller
This multi-device control makes the Wyze Switch a powerful addition to your connected home.
Additional Wyze Smart Lighting Options
While the Wyze Switch is perfect for controlling your bulbs, consider complementing your setup with the
Wyze Light Strip for vibrant accent lighting.
Wyze Light Strip Highlights:
- Brilliant LED accent lighting with 16 million colors.
- Available in 16.4 ft and 32.8 ft lengths.
- Easy adhesive backing for versatile mounting.
- Music sync feature using built-in microphone.
- Indoor use with 25,000 hours life expectancy.
Create ambiance with Wyze Light Strip behind your sofa or furniture
Summary
For a wireless smart switch compatible with both regular bulbs and Wyze bulbs, the
Wyze Switch stands out as the best choice. It offers smart control, multi-device integration, and preserves your smart bulb automations. Pair it with Wyze Light Strips for a complete smart lighting experience.
What is the Wyze Switch and how does it work?
The Wyze Switch is a wireless smart switch designed to control both regular bulbs and Wyze smart bulbs. It allows you to turn your normal lights into smart lights, offering full control from anywhere using the Wyze app. The switch can be customized with multi-tap actions to control other Wyze devices and preserves smart bulb automations by not cutting power to Wyze Bulbs.Is the Wyze Switch compatible with regular bulbs and Wyze Bulbs?
Yes, the Wyze Switch is fully compatible with both regular bulbs and Wyze smart bulbs. It is designed to work seamlessly with your existing lighting setup as well as enhance your Wyze smart home ecosystem.How does the Wyze Switch preserve smart bulb automations?
When paired with Wyze Bulbs, the Wyze Switch operates in Smart Control Mode, turning bulbs on and off without cutting power. This ensures that your smart bulb automations remain intact and your bulbs stay connected to your smart home system.Can I control the Wyze Switch remotely?
Yes, you can control the Wyze Switch from anywhere using the Wyze app. This allows you to manage your home lighting remotely for convenience and security.What smart home devices can I control with the Wyze Switch?
The Wyze Switch supports multi-tap control, allowing you to customize single, double, and triple taps, as well as press-and-hold actions to control other Wyze devices such as Wyze Cams, Wyze Lock, Wyze Robot Vacuum, and Wyze Sprinkler Controller.Does the Wyze Switch support timers and schedules?
Yes, the Wyze Switch allows you to set timers and schedules through the Wyze app, enabling you to automate your lighting for convenience and energy savings.What is Vacation Mode on the Wyze Switch?
Vacation Mode is a feature that simulates occupancy by automatically turning your lights on and off when you’re away, helping to enhance your home security.Is the Wyze Switch easy to install?
Yes, the Wyze Switch is designed for easy installation. It fits standard wall switch boxes and replaces your existing switch without the need to rewire your bulbs.What happens to the Wyze Switch after a power outage?
The Wyze Switch features Power Loss Recovery, which means it automatically reconnects to Wi-Fi and restores your previous settings after a power outage.What are the available purchasing options for the Wyze Switch?
The Wyze Switch is available as a single pack for $14.99. A 3-pack bundle is also offered, but it may be sold out at times.How can I enhance my smart lighting setup with Wyze products?
In addition to the Wyze Switch, you can complement your smart lighting setup with Wyze Light Strips, which offer vibrant LED accent lighting with 16 million colors, easy installation, and music sync features for creating the perfect ambiance.
