Upgrade Regular Lights to Smart with Wyze Switch & Bulbs
How to Upgrade Regular Lights to Smart with Wyze Switch
Transforming your home lighting from ordinary to smart is easier than ever with the Wyze Switch and complementary Wyze smart lighting products. Whether you want to control your lights remotely, create custom automations, or add vibrant colors to your space, Wyze offers a seamless upgrade path that fits any room and lifestyle.
Wyze Switch: The Smart Hub for Your Lights
The Wyze Switch is the cornerstone product to convert your regular lights into smart lights without rewiring your entire home. It replaces your existing wall switch and connects to your Wi-Fi network, allowing you to control your lights from anywhere using the Wyze app.
Key Features of Wyze Switch
  • Remote Control: Turn your lights on or off from anywhere via the Wyze app.
  • Multi-Tap Actions: Customize single, double, or triple taps to control other Wyze devices like Wyze Cams, Wyze Lock, and Wyze Robot Vacuum.
  • Automations & Schedules: Set timers, schedules, and vacation modes to automate your lighting effortlessly.
  • Power Loss Recovery: Automatically restores your light settings after a power outage.
  • Seamless Integration: Works perfectly within the Wyze ecosystem for a unified smart home experience.
Available in 1-pack or 3-pack options, the Wyze Switch is an affordable and versatile upgrade for any room. Wyze Switch in Kitchen Lifestyle Upgrade your kitchen lighting with Wyze Switch and voice assistants
Enhance Your Smart Lighting with Wyze Bulbs
Once your lights are connected via the Wyze Switch, you can elevate your lighting experience with Wyze smart bulbs. Choose from vibrant color bulbs or classic white bulbs to suit your mood and décor.
Wyze Bulb Color: 16 Million Colors at Your Fingertips
The Wyze Bulb Color is a premium smart bulb offering 16 million colors and tunable white light, perfect for setting the ambiance in any room.
  • Brightness: Up to 1100 lumens for vivid illumination.
  • Color Range: 16 million colors plus adjustable white temperature (1800K - 6500K).
  • Connectivity: Wi-Fi (2.4GHz) and Bluetooth for reliable control.
  • Compatibility: Works with Alexa, Google Assistant, and IFTTT.
  • Durability: 25,000 hours life expectancy and suitable for damp locations.
Use the Wyze app to create custom lighting scenes, sync with music, or schedule your bulbs to turn on and off automatically. Wyze Bulb Color in Living Room Bring vibrant color and life to your living room with Wyze Bulb Color
Wyze Bulb White: Bright, Dimmable, and Reliable
For those who prefer classic white lighting, the Wyze Bulb White offers bright, dimmable light with excellent color rendering.
  • Brightness: Up to 800 lumens with adjustable color temperature (2700K to 6500K).
  • Beam Angle: Wide 230° beam for even room coverage.
  • Connectivity: Wi-Fi and Bluetooth for easy control.
  • Compatibility: Alexa, Google Assistant, and IFTTT integration.
  • Durability: 25,000 hours lifespan and suitable for damp locations.
Perfect for bedrooms, offices, or any space where you want reliable, adjustable white light.
Add Accent Lighting with Wyze Light Strip
For accent lighting that adds style and personality, the Wyze Light Strip is an excellent choice. It offers brilliant LED lighting with millions of colors to highlight your kitchen counters, shelves, or entertainment areas.
  • Length Options: 16.4 feet or 32.8 feet with adhesive backing for easy installation.
  • Color Options: 16 million colors with customizable zones.
  • Music Sync: Built-in microphone lets the lights dance to your music.
  • Connectivity: Wi-Fi and Bluetooth.
  • Life Expectancy: 25,000 hours.
Use the Wyze app to create dynamic lighting effects and bring your space to life.
Why Upgrade to Wyze Smart Lighting?
Upgrading your regular lights to smart lights with Wyze products not only adds convenience but also enhances your home's ambiance, security, and energy efficiency.
  • Control lights remotely and never come home to a dark house.
  • Automate lighting to save energy and create the perfect mood.
  • Integrate with other Wyze smart devices for a connected home ecosystem.
  • Easy installation with no complicated wiring or professional help needed.
Summary of Wyze Smart Lighting Products
ProductKey BenefitsPrice Range
Wyze SwitchSmart control, multi-tap, automations$14.99 - $41.98
Wyze Bulb Color16 million colors, bright, tunable white$26.26 - $64.98
Wyze Bulb WhiteBright white, dimmable, wide beam$23.99 - $59.99
Wyze Light StripLED accent lighting, music sync$19.99 - $35.99
Upgrade your home lighting today with Wyze and enjoy smart control, vibrant colors, and seamless automation.
FeatureWyze SwitchWyze Bulb ColorWyze Bulb White
TypeConnected HomeSmart LightingConnected Home
Price (Single Pack)$14.99N/A (2 Pack $26.26)$23.99 (2 Pack)
Price (Multi Pack)$41.98 (3 Pack)$26.26 (2 Pack), $44.44 (4 Pack), $64.98 (6 Pack)$39.99 (4 Pack), $59.99 (6 Pack)
DescriptionTurns normal lights into smart lights; multi-tap controls other Wyze devicesBrightest 16 million color smart bulb; dimmable; color controlBrighter white smart bulb with dimmable controls
Control MethodWyze app, multi-tap, automationsWyze app, voice control (Alexa, Google Assistant)Wyze app, voice control (Alexa, Google Assistant)
ConnectivityWi-Fi (2.4 GHz)Wi-Fi (802.11 b/g/n 2.4 GHz), BluetoothWi-Fi (802.11 b/g/n 2.4 GHz), Bluetooth
LumensN/A (switch controls power)30 lm - 1100 lm30 lm - 800 lm
Color OptionsN/A16 million colorsWhite light (2700K - 6500K)
Color TemperatureN/A1800K - 6500K2700K - 6500K
DimmableN/AYesYes
Special FeaturesMulti-tap for other Wyze devices; power loss recovery; vacation modeCustom presets, sleep routines, music mode, brilliant notificationsDimmable, suitable for damp locations
IntegrationWyze ecosystemAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
InstallationEasy installStandard bulb installation (E26 base)Standard bulb installation (E26 base)
PowerN/A (switch)9.5 watts9.5 watts
Life ExpectancyN/A25,000 hours25,000 hours
CompatibilityWorks with Wyze Cams, Locks, Robot Vacuum, Sprinkler ControllerAndroid 9.0+, iOS 15.0+Android 9.0+, iOS 15.0+
How do I upgrade my regular lights to smart lights with Wyze Switch?You can upgrade your regular lights to smart lights by replacing your existing wall switch with the Wyze Switch. The Wyze Switch connects to your Wi-Fi network, allowing you to control your lights remotely through the Wyze app, set automations, and integrate with other Wyze smart devices—all without rewiring your home.
What are the main features of the Wyze Switch?The Wyze Switch offers remote control via the Wyze app, customizable multi-tap actions to control other Wyze devices, automations and schedules, power loss recovery, and seamless integration with the Wyze ecosystem. It is available in 1-pack or 3-pack options for flexible installation.
Can I control Wyze Switch and smart bulbs with voice assistants?Yes, Wyze Switch and Wyze smart bulbs are compatible with popular voice assistants like Amazon Alexa and Google Assistant, as well as IFTTT, allowing you to control your lighting with simple voice commands.
What is the difference between Wyze Bulb Color and Wyze Bulb White?Wyze Bulb Color offers 16 million colors, tunable white light (1800K - 6500K), and up to 1100 lumens of brightness, making it ideal for creating vibrant lighting scenes. Wyze Bulb White provides bright, dimmable white light with adjustable color temperature (2700K - 6500K) and up to 800 lumens, perfect for classic, reliable lighting.
How do I install Wyze Light Strip for accent lighting?The Wyze Light Strip comes in 16.4-foot or 32.8-foot lengths with adhesive backing for easy installation. Simply peel and stick the strip to your desired surface, connect it to Wi-Fi or Bluetooth, and use the Wyze app to customize colors, set zones, and sync with music.
What are the benefits of upgrading to Wyze smart lighting?Upgrading to Wyze smart lighting allows you to control your lights remotely, automate schedules for energy savings, enhance your home's ambiance and security, and integrate with other Wyze smart devices. Installation is easy and does not require professional help or complicated wiring.
Are Wyze smart lighting products suitable for damp locations?Yes, both Wyze Bulb Color and Wyze Bulb White are designed to be suitable for damp locations, making them versatile for use in bathrooms, kitchens, and other areas with higher humidity.
How long do Wyze smart bulbs and light strips last?Wyze Bulb Color, Wyze Bulb White, and Wyze Light Strip all have a life expectancy of up to 25,000 hours, ensuring long-lasting performance and reliability.
Can I automate my lighting with Wyze products?Yes, Wyze products support automations and schedules through the Wyze app. You can set timers, create custom scenes, enable vacation mode, and sync your lighting with music or other Wyze devices for a fully automated smart home experience.
What is the price range for Wyze smart lighting products?Wyze smart lighting products are affordably priced: Wyze Switch ($14.99 - $41.98), Wyze Bulb Color ($26.26 - $64.98), Wyze Bulb White ($23.99 - $59.99), and Wyze Light Strip ($19.99 - $35.99).
What are the installation steps for the Wyze Switch?Can I use the Wyze Switch with existing light fixtures?How does the Wyze app work with the Wyze Switch?
