Refurbished Wyze Smart LED Bulbs – IFTTT & Automation Ready
Refurbished Smart LED Bulbs Compatible with Wyze, IFTTT, and Automation
Looking to upgrade your home lighting with smart LED bulbs that seamlessly integrate with Wyze, IFTTT, and other automation platforms? Discover the best refurbished Wyze smart bulbs designed to bring vibrant colors, customizable scenes, and smart home convenience to your living space. Whether you want full color control, recessed lighting options, or simple white light bulbs, these Wyze smart bulbs offer excellent compatibility and features to enhance your smart home ecosystem.
Wyze Bulb Color: The Ultimate 16 Million Color Smart Bulb
Experience the brightest and most versatile smart bulb on the market with the Wyze Bulb Color. This refurbished smart LED bulb supports Wyze app control, voice assistants like Alexa and Google Assistant, and IFTTT automation, making it a perfect fit for your connected home.
Key Features:
  • 16 Million Colors & White Temperature Control: Customize your lighting with precise color control or adjust white light temperature from warm to cool to suit any mood or activity.
  • Wide Lumen Range: Brightness ranges from a subtle 30 lumens to a powerful 1100 lumens (equivalent to 75W), allowing you to dim or brighten your space effortlessly.
  • Advanced 90+ CRI: See true, vibrant colors in your home with a high Color Rendering Index, perfect for accurate color perception.
  • Smart Automations & Notifications: Use Wyze sensors or time-based triggers to create visual alerts or automate lighting routines like sunrise/sunset wake-ups.
  • Voice & App Control: Compatible with Alexa, Google Assistant, and IFTTT for hands-free and automated control.
  • Grouping & Music Sync: Group multiple bulbs or pair with Wyze Light Strips to sync lighting effects to your favorite music.
Available in 2, 4, or 6 packs, the Wyze Bulb Color is ideal for living rooms, bedrooms, or any space where you want to add a splash of color and smart convenience. Wyze Bulb Color in Living Room Brighten your living space with vibrant Wyze Bulb Color smart lighting.
Wyze Bulb Color BR30: Smart Recessed Lighting with Brilliant Colors
If you prefer recessed lighting fixtures, the Wyze Bulb Color BR30 is your go-to smart LED bulb. Designed to fit standard E26 recessed/can lighting sockets, this bulb delivers directional, soft-edged light with full color control.
Highlights:
  • Dimmable & Color Changing: Choose from 16 million colors and a wide brightness range from 30 to 950 lumens.
  • Sun Match Technology: Automatically adjusts color temperature throughout the day to support your natural circadian rhythm.
  • 90+ CRI Rating: Ensures colors appear vivid and true to life.
  • Smart Features: Compatible with Wyze app, Alexa, Google Assistant, and IFTTT for seamless voice and automation control.
  • Custom Scenes & Notifications: Save and switch between custom lighting presets and use lighting alerts for reminders or security.
  • Sleep Routines & Music Sync: Create gradual light changes for better sleep or sync lights to music beats when paired with Wyze Light Strip Pro.
Available in 2 or 4 packs, the Wyze Bulb Color BR30 is perfect for kitchens, hallways, or any recessed lighting setup.
Wyze Bulb White: Simple, Bright, and Smart White Lighting
For those who prefer classic white lighting with smart features, the Wyze Bulb White offers a bright, dimmable LED bulb with excellent smart home compatibility.
Features:
  • Brightness & Color Temperature: Adjustable brightness from 30 to 800 lumens with color temperatures ranging from warm 2700K to cool 6500K.
  • High CRI (90+): Provides clear, natural white light for everyday use.
  • Smart Controls: Works with Wyze app, Alexa, Google Assistant, and IFTTT for voice commands and automation.
  • Long Life & Energy Efficient: Rated for 25,000 hours with only 9.5 watts power consumption.
  • Wide Compatibility: Supports 2.4GHz Wi-Fi and Bluetooth, suitable for damp locations, and works with Android 9.0+ and iOS 15.0+ devices.
Available in 2, 4, or 6 packs, this bulb is ideal for bedrooms, bathrooms, or any space needing reliable white light with smart control. Wyze Bulb White in Cozy Bedroom Create cozy, warm lighting with Wyze Bulb White smart bulbs.
Smart Lighting Kits: Bundles for Enhanced Ambiance
For a complete smart lighting experience, consider the Smart Lighting Kits that bundle Wyze Bulb Color or BR30 bulbs with the Wyze Light Strip Pro. These kits offer brilliant LED accent lighting with full color customization and smart automation.
Smart Lighting Kit - Bulb Color + Light Strip Pro
  • Includes 2 or 4 Wyze Bulb Color bulbs plus a 16.4-foot Wyze Light Strip Pro.
  • 16 million colors with customizable zones on the light strip.
  • Compatible with Wyze app, Alexa, Google Assistant, and IFTTT.
  • Perfect for creating immersive lighting scenes in living rooms or entertainment areas.
Smart Lighting Kit - Bulb Color BR30 + Light Strip Pro
  • Combines 2 or 4 Wyze Bulb Color BR30 bulbs with a 16.4-foot Light Strip Pro.
  • Ideal for recessed lighting setups with added accent lighting.
  • Supports all smart features including voice control, automation, and music sync.
These bundles provide a versatile and stylish way to elevate your home lighting with smart LED technology.
Why Choose Wyze Refurbished Smart Bulbs?
Wyze smart bulbs offer exceptional value with their rich feature set, including millions of colors, high CRI for true color accuracy, and seamless integration with popular smart home platforms like Wyze, Alexa, Google Assistant, and IFTTT. Refurbished options provide an eco-friendly and budget-conscious way to upgrade your home lighting without compromising on quality or functionality.
Summary
For smart LED bulbs compatible with Wyze, IFTTT, and automation, the following refurbished products stand out:
  • Wyze Bulb Color: Best for vibrant, full-color lighting with advanced smart features.
  • Wyze Bulb Color BR30: Ideal for recessed lighting with directional color control.
  • Wyze Bulb White: Perfect for bright, dimmable white light with smart integration.
  • Smart Lighting Kits: Bundles combining bulbs and light strips for immersive lighting setups.
Upgrade your home lighting today with these smart, energy-efficient, and highly customizable Wyze bulbs that fit perfectly into your smart home automation ecosystem.
FeatureWyze Bulb ColorWyze Bulb Color BR30Wyze Bulb WhiteSmart Lighting Kit - Bulb Color + Light Strip Pro BundleSmart Lighting Kit - Bulb Color BR30 + Light Strip Pro Bundle
Bulb ShapeA19BR30A19A19 (Bulb Color)BR30 (Bulb Color BR30)
Base TypeE26E26E26E26E26
Lumen Output30 - 1100 lm30 - 950 lm30 - 800 lm30 - 1100 lm30 - 950 lm
Wattage Equivalent75W75W9.5W actual power12W (Bulb Color)11.5W (Bulb Color BR30)
Color Options16 million colors16 million colorsWhite light only16 million colors16 million colors
Color Temperature Range1800K - 6500K1800K - 6500K2700K - 6500K1800K - 6500K1800K - 6500K
CRI Rating90+90+90+90+90+
DimmableYes (but "takes offense" if used)Yes (not for use in dimmer switches)YesYesYes
Smart FeaturesVoice control, Vacation Mode, GroupingVoice control, Vacation Mode, GroupingVoice control, Vacation Mode, GroupingVoice control, Vacation Mode, GroupingVoice control, Vacation Mode, Grouping
Connectivity802.11 b/g/n, 2.4GHz, Bluetooth802.11 b/g/n, 2.4GHz, Bluetooth802.11 b/g/n, 2.4GHz, Bluetooth802.11 b/g/n, 2.4GHz, Bluetooth802.11 b/g/n, 2.4GHz, Bluetooth
Phone CompatibilityAndroid 9.0+, iOS 15.0+Android 9.0+, iOS 15.0+Android 9.0+, iOS 15.0+Android 9.0+, iOS 15.0+Android 9.0+, iOS 15.0+
Life Expectancy25,000 hours25,000 hours25,000 hours25,000 hours25,000 hours
Suitable for Damp LocationsYesYesYesYesYes
Operating Temperature-4°F to 104°F-4°F to 104°F-4°F to 104°F-4°F to 104°F-4°F to 104°F
Included in BoxBulbs onlyBulbs onlyBulbs onlyWyze Bulb Color (2 or 4 pack), Wyze Light Strip Pro (16.4 ft), Controller, Power Adapter, Adhesive Clips, Quick Start GuideWyze Bulb Color BR30 (2 or 4 pack), Wyze Light Strip Pro (16.4 ft)
Price (2-Pack)$26.26$27.98$23.99$52.98$53.98
Price (4-Pack)$44.44$49.98$39.99$74.97$77.97
What are refurbished Wyze smart LED bulbs?Refurbished Wyze smart LED bulbs are pre-owned bulbs that have been professionally restored to like-new condition. They offer the same features and compatibility as new bulbs, including integration with Wyze, IFTTT, Alexa, and Google Assistant, but at a more affordable and eco-friendly price.
Are Wyze smart bulbs compatible with IFTTT and other automation platforms?Yes, Wyze smart bulbs are fully compatible with IFTTT, allowing you to automate your lighting with custom triggers and routines. They also work seamlessly with the Wyze app, Alexa, Google Assistant, and other popular smart home platforms.
What features does the Wyze Bulb Color offer?The Wyze Bulb Color offers 16 million colors, adjustable white temperature, a wide brightness range from 30 to 1100 lumens, advanced 90+ CRI for true color accuracy, smart automations, voice and app control, grouping, and music sync capabilities.
What is the difference between Wyze Bulb Color and Wyze Bulb Color BR30?The Wyze Bulb Color is a versatile smart bulb suitable for most fixtures, offering full color control and a wide brightness range. The Wyze Bulb Color BR30 is specifically designed for recessed or can lighting, providing directional, soft-edged light with the same color and smart features, plus Sun Match technology for circadian rhythm support.
Can I control Wyze smart bulbs with my voice?Yes, Wyze smart bulbs are compatible with voice assistants like Alexa and Google Assistant, allowing you to control your lighting hands-free with simple voice commands.
What is Sun Match technology in Wyze Bulb Color BR30?Sun Match technology automatically adjusts the color temperature of your Wyze Bulb Color BR30 throughout the day to mimic natural sunlight, supporting your natural circadian rhythm and enhancing comfort.
Are Wyze smart bulbs energy efficient?Yes, Wyze smart bulbs are energy efficient. For example, the Wyze Bulb White uses only 9.5 watts and is rated for 25,000 hours of use, making it a cost-effective and eco-friendly lighting solution.
What is the Color Rendering Index (CRI) of Wyze smart bulbs?Wyze smart bulbs feature a high CRI of 90+, ensuring that colors appear vivid and true to life in your home.
Can I use Wyze smart bulbs in damp locations?Yes, Wyze Bulb White is suitable for damp locations, making it ideal for use in bathrooms and other areas with higher humidity.
What smart lighting kits are available with Wyze bulbs?Wyze offers smart lighting kits that bundle Wyze Bulb Color or BR30 bulbs with the Wyze Light Strip Pro. These kits provide full color customization, smart automation, and immersive lighting scenes for living rooms, entertainment areas, and recessed lighting setups.
How do I automate Wyze smart bulbs?You can automate Wyze smart bulbs using the Wyze app, IFTTT, or voice assistants. Set up routines based on time, Wyze sensors, or custom triggers to control your lighting automatically.
What devices and platforms are Wyze smart bulbs compatible with?Wyze smart bulbs are compatible with the Wyze app, Alexa, Google Assistant, IFTTT, 2.4GHz Wi-Fi, and Bluetooth. They work with Android 9.0+ and iOS 15.0+ devices.
Why should I choose refurbished Wyze smart bulbs?Refurbished Wyze smart bulbs offer the same advanced features and compatibility as new bulbs but at a lower price. They are an eco-friendly and budget-conscious way to upgrade your home lighting without sacrificing quality or functionality.
What are the key features of the Wyze Bulb Color?Can you tell me more about the Wyze Bulb Color BR30 and its benefits?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze smart bulbs?
