Best 2K HD Outdoor Floodlight Security Cameras with Color Night Vision
When it comes to securing your home or business, having a reliable outdoor floodlight security camera with vibrant color night vision and high-resolution video is essential. Whether you want to monitor your driveway, backyard, or front porch, these cameras provide crystal-clear footage day and night, enhanced by powerful floodlights to illuminate any suspicious activity. Explore the top Wyze floodlight cameras designed to deliver exceptional 2K HD video quality, wide-angle views, and smart features that make your outdoor security smarter and more effective.
Wyze Cam Floodlight v2: Brilliant 2K Color Night Vision Security
Experience the perfect blend of powerful lighting and sharp video with the Wyze Cam Floodlight v2. This camera is engineered to dominate the dark with its advanced features:
Key Features
  • 2K HD Video Resolution: Capture every detail in stunning 2K clarity, ensuring you never miss a moment.
  • Color Night Vision: Unlike traditional infrared night vision, this camera provides vibrant color footage even in low light.
  • 160° Wide-Angle View: See more of your property with a broad field of view that covers double the area compared to previous models.
  • 2800 Lumens LED Floodlights: Two adjustable, motion-activated floodlights brighten your outdoor space to deter intruders.
  • Ambient Light Mode: Provides a constant low-level light that brightens automatically when motion is detected.
  • AI-Powered Light Control & Motion Detection: Smartly triggers lights and alerts based on movement within a 270° PIR detection area.
  • Two-Way Talk & 105dB Siren: Communicate with visitors or scare off unwanted guests with a loud siren.
  • 24/7 Local Recording: Continuous recording to a microSD card (up to 256GB) without subscription fees.
  • Dusk-to-Dawn Automation: Automatically turns lights on at sunset and off at sunrise.
  • IP65 Weather Resistance: Built to withstand rain, snow, and harsh outdoor conditions.
  • Smart Assistant Integration: Works seamlessly with Alexa and Google Home for voice control and live feed viewing.
Installation & Power Options
  • Easy DIY installation with no junction box required.
  • Optional Plug-In Mount available for flexible power solutions, perfect for renters or those with outdoor outlets.
Wyze Cam Floodlight v2 illuminating driveway at night Brighten and secure your driveway with Wyze Cam Floodlight v2
Wyze Cam Floodlight v2 + Plug-In Mount: Flexible Power, Same Great Features
For those seeking the convenience of plug-in power without complicated wiring, the Wyze Cam Floodlight v2 + Plug-In Mount bundle offers the same powerful 2K HD video and color night vision with added installation flexibility.
Bundle Highlights
  • Includes the Wyze Cam Floodlight v2 and a 20ft plug-in mount cable with velcro strap for cable management.
  • No need for a junction box or electrician—just plug into any outdoor outlet.
  • Retains all features of the Floodlight v2: 2800 lumens LEDs, 160° wide-angle, AI motion detection, two-way talk, and siren.
This option is ideal for renters or anyone wanting a hassle-free setup without sacrificing performance.
Wyze Cam Floodlight Pro: Ultimate 2.5K QHD Security with AI-Powered Lighting
Step up your security game with the Wyze Cam Floodlight Pro, designed for those who want the widest coverage and highest resolution available in the Wyze floodlight lineup.
Pro-Level Features
  • 2.5K QHD Video Resolution: Ultra-clear Quad HD video captures finer details for superior identification.
  • 180° Wide-Angle Lens: The broadest field of view in the category, covering your entire yard with fewer blind spots.
  • Color Night Vision: See vibrant, detailed color footage even in the darkest conditions.
  • 3,000 Lumens Adjustable LED Floodlights: Three independently articulating panels let you customize lighting coverage.
  • Vision AI Motion Detection: Smarter than PIR sensors, it detects people and vehicles to trigger lights and notifications precisely.
  • Motion-Activated Voice Deterrence & 105dB Siren: Play custom voice prompts and sound a loud siren to deter intruders.
  • Dual-Band Wi-Fi (2.4 & 5 GHz): Faster, more reliable connection for smooth live streaming.
  • Dusk-to-Dawn Automation & IP65 Weatherproofing: Automatic lighting control and rugged design for all weather conditions.
  • 24/7 Local Recording: Supports up to 256GB microSD card for continuous video storage.
Easy Installation
  • DIY replacement of existing floodlights in under 20 minutes.
  • Optional plug-in mount available for flexible power solutions.
Wyze Cam Floodlight Pro providing bright security lighting Wyze Cam Floodlight Pro guards your home with powerful AI and bright lights
Why Choose a 2K HD Outdoor Floodlight Security Camera with Color Night Vision?
"Color night vision transforms your security footage from grainy black and white to vivid, detailed images, making it easier to identify faces, vehicles, and other important details at night."
  • Enhanced Security: Bright floodlights combined with high-resolution video deter intruders and provide clear evidence.
  • Wider Coverage: Wide-angle lenses reduce blind spots, covering more area with fewer cameras.
  • Smart Features: AI-powered motion detection and customizable alerts keep you informed without false alarms.
  • Flexible Installation: Options like plug-in mounts make setup easy for any home or rental property.
  • Weatherproof Durability: IP65 rating ensures reliable performance in rain, snow, or shine.
Summary of Top 2K HD Outdoor Floodlight Cameras with Color Night Vision
ProductVideo ResolutionField of ViewFloodlight BrightnessNight Vision TypeSpecial FeaturesPrice Range
Wyze Cam Floodlight v22K HD160°2800 lumensColor Night VisionAI Light Control, Two-Way Talk$89.98
Wyze Cam Floodlight v2 + Plug-In Mount2K HD160°2800 lumensColor Night VisionFlexible Power, Easy Installation$109.96
Wyze Cam Floodlight Pro2.5K QHD180°3000 lumensColor Night VisionVision AI, Voice Deterrence, Dual-Band Wi-Fi$149.98
Invest in a Wyze floodlight security camera today to enjoy peace of mind with crystal-clear 2K HD video and vibrant color night vision that keeps your property safe around the clock.
FeatureWyze Cam Floodlight v2Wyze Cam Floodlight v2 + Plug-In MountWyze Cam Floodlight Pro
Price$89.98$109.96$149.98
Included ItemsFloodlight camera onlyFloodlight camera + Plug-In MountFloodlight Pro camera only
Camera Resolution2K (2560 x 1440)2K (2560 x 1440)2.5K QHD (2560 x 1440)
Field of View160° wide-angle160° wide-angle180° diagonal, 170° horizontal, 95° vertical
LED Lighting2 floodlight heads, 2800 lumens2 floodlight heads, 2800 lumens3 dimmable light panels, 3000 lumens total
Night VisionColor Night VisionColor Night VisionColor Night Vision
Motion Detection270° PIR motion detection area270° PIR motion detection areaAdvanced AI motion detection
AI Detection (with Cam Plus)People, Pets, Vehicle, PackagePeople, Pets, Vehicle, PackagePeople, Pets, Vehicle, Package
Local Recording24/7 local recording (microSD up to 256GB)24/7 local recording (microSD up to 256GB)24/7 local recording (microSD up to 256GB)
Two-Way Talk + SirenYes, 105dB sirenYes, 105dB sirenYes, 105dB siren
Ambient Light ModeYesYesYes
Dusk-to-Dawn AutomationYesYesYes
Weather ResistanceIP65IP65IP65
Power SupplyHardwired 110-120V ACHardwired 110-120V AC + Plug-In Mount (20 ft cable)Hardwired 110-120V AC
Wi-Fi Compatibility2.4 GHz2.4 GHz2.4 & 5 GHz dual-band
Smart Assistant IntegrationAlexa, Google AssistantAlexa, Google AssistantAlexa, Google Assistant, IFTTT
SetupAccess Point Wi-Fi setup, no QR codePlug-n-play mount, no junction box neededStandard hardwired setup
DimensionsNot specifiedNot specified10.2" x 9.1" x 7.8" (25.91 cm x 23.11 cm x 19.81 cm)
WeightNot specifiedNot specified2.9 lbs (1.32 kg)
Warranty1 Year1 Year1 Year
What are the benefits of a 2K HD outdoor floodlight security camera with color night vision?A 2K HD outdoor floodlight security camera with color night vision provides enhanced security by delivering high-resolution, crystal-clear video footage both day and night. The color night vision feature allows you to see vivid, detailed images in low-light conditions, making it easier to identify faces, vehicles, and other important details. Combined with bright floodlights, these cameras deter intruders and provide clear evidence if needed.
What is the difference between Wyze Cam Floodlight v2 and Wyze Cam Floodlight Pro?The Wyze Cam Floodlight v2 offers 2K HD video resolution, a 160° wide-angle view, 2800 lumens LED floodlights, and AI-powered motion detection. The Wyze Cam Floodlight Pro steps up with 2.5K QHD video resolution, a wider 180° field of view, 3000 lumens adjustable LED floodlights, Vision AI motion detection for people and vehicles, dual-band Wi-Fi, and motion-activated voice deterrence. The Pro model is ideal for those seeking the highest resolution and widest coverage.
Does the Wyze Cam Floodlight v2 require professional installation?No, the Wyze Cam Floodlight v2 is designed for easy DIY installation and does not require a junction box. There is also an optional plug-in mount available, making it perfect for renters or anyone who prefers a hassle-free setup using an outdoor outlet.
Can I use Wyze Cam Floodlight cameras without a subscription?Yes, Wyze Cam Floodlight cameras support 24/7 local recording to a microSD card (up to 256GB) without any subscription fees. This allows you to continuously record and access your footage locally.
Are Wyze floodlight security cameras weatherproof?Yes, all Wyze floodlight security cameras, including the Floodlight v2 and Floodlight Pro, are rated IP65 weather resistant. This means they are built to withstand rain, snow, and harsh outdoor conditions, ensuring reliable performance year-round.
What smart features do Wyze floodlight security cameras offer?Wyze floodlight security cameras offer a range of smart features, including AI-powered motion detection, customizable alerts, two-way talk, a 105dB siren, dusk-to-dawn automation, and integration with Alexa and Google Home for voice control and live feed viewing. The Floodlight Pro also features Vision AI for advanced detection and motion-activated voice deterrence.
How bright are the floodlights on Wyze security cameras?The Wyze Cam Floodlight v2 features two adjustable, motion-activated LED floodlights with a combined brightness of 2800 lumens. The Wyze Cam Floodlight Pro offers even brighter lighting with three adjustable panels totaling 3000 lumens, providing customizable and powerful illumination for your property.
Is there a flexible power option for Wyze Cam Floodlight cameras?Yes, the Wyze Cam Floodlight v2 + Plug-In Mount bundle includes a 20ft plug-in mount cable, allowing you to power the camera using any outdoor outlet. This flexible power solution is ideal for renters or those who want to avoid complicated wiring.
What is color night vision and why is it important for security cameras?Color night vision is a feature that allows security cameras to capture full-color video footage even in low-light or nighttime conditions, unlike traditional cameras that only provide black-and-white images at night. This makes it easier to identify important details such as faces, clothing, and vehicles, enhancing the effectiveness of your security system.
Do Wyze floodlight cameras support smart home integration?Yes, Wyze floodlight cameras are compatible with popular smart home assistants like Alexa and Google Home. This allows you to control your cameras with voice commands and view live feeds directly from your smart devices.
What are the key features of the Wyze Cam Floodlight v2?How does the color night vision work on the Wyze Cam Floodlight?Are there any ongoing sales or discounts for the Wyze Cam Floodlight cameras?
