Top Outdoor Cameras for Package Detection & Floodlight Security
Best Outdoor Cameras for Package Detection and Floodlight Integration
When it comes to securing your home’s exterior, especially for package detection and integrating floodlight features, choosing the right outdoor camera is crucial. The ideal camera should offer high-resolution video, reliable night vision, smart detection zones, and seamless floodlight integration to deter theft and ensure clear visibility. Below, we explore the top Wyze outdoor cameras designed to meet these needs with advanced specs and smart features.
Wyze Cam v3 Pro: The Ultimate Outdoor Security Camera with Built-in Spotlight
Superior Video Quality and Smart Detection
The Wyze Cam v3 Pro stands out with its impressive 2.5K resolution (2560x1440), delivering crystal-clear video footage that captures every detail of your packages and visitors. Equipped with Edge AI, it intelligently distinguishes between people, packages, and vehicles, reducing false alerts and ensuring you only get notified when it matters.
Integrated Spotlight and Siren for Enhanced Security
This model features a built-in spotlight and an integrated siren, providing active deterrence against potential intruders. The spotlight automatically activates upon motion detection, illuminating your porch or driveway to scare off unwanted guests and improve video clarity at night with Color Night Vision.
Weather-Resistant and Flexible Installation
Rated IP65 for weather resistance, the Wyze Cam v3 Pro is built to withstand harsh outdoor conditions. It supports multiple mounting methods including magnetic, screw, and tape mounts, allowing you to install it wherever you need optimal coverage. Note that for outdoor use, it requires the Wyze Outdoor Power Adapter v2 (sold separately).
Additional Features
  • Two-way audio with noise and echo cancellation for clear communication.
  • Supports up to 256 GB microSD local storage.
  • 116° field of view with 8x digital zoom.
  • Compatible with Android 9.0+ and iOS 15.0+.
  • Push notifications and customizable detection zones.
Wyze Cam v3 Pro lifestyle Stay connected with two-way audio and clear video day or night.
Wyze Cam Floodlight v2: Powerful Floodlight with 2K Video and AI-Powered Light Control
Bright and Smart Lighting for Maximum Visibility
The Wyze Cam Floodlight v2 is designed to dominate the dark with 2800 lumens of dimmable LED light panels, providing bright illumination for your driveway, porch, or backyard. Its 160° wide-angle view ensures broad coverage, perfect for monitoring packages and detecting motion across large outdoor areas.
Crisp 2K Video with Color Night Vision
Capture every moment in sharp 2K resolution (2304 x 1296) with Color Night Vision, ensuring you never miss a detail regardless of lighting conditions. The camera supports 24/7 local recording and features AI-powered light control that adjusts brightness based on ambient light and motion.
Smart Features and Seamless Integration
  • Two-way audio with built-in speaker and microphone for real-time communication.
  • 105dB siren to deter intruders.
  • Dusk-to-dawn automation for hassle-free lighting.
  • IP65 weather resistance for reliable outdoor performance.
  • Compatible with Alexa, Google Assistant, and IFTTT for smart home integration.
Installation and Power
This camera is hardwired (110-120V AC), making it a permanent and powerful security solution for your home’s exterior. Wyze Cam Floodlight v2 lifestyle Brighten your outdoor space with smart floodlight security.
Wyze Cam Pan v3: 360° Pan and Tilt Outdoor Camera with Weather Resistance
Full Coverage with Pan and Tilt
The Wyze Cam Pan v3 offers a 360° horizontal and 180° vertical field of view, allowing you to remotely pan and tilt the camera to cover every angle of your porch or yard. This makes it ideal for tracking package deliveries or suspicious activity without blind spots.
Reliable Outdoor Performance
With an IP65 weather rating, this camera is built to endure rain, snow, and heat. It features 1080p HD video resolution and 4 IR LEDs for night vision, ensuring clear footage day and night.
Smart Home Compatibility and Storage
  • Integrates with Alexa, Google Assistant, and IFTTT.
  • Two-way audio with noise and echo cancellation.
  • Push notifications for instant alerts.
Power and Mounting
Requires the Wyze Outdoor Power Adapter (sold separately) for safe outdoor use. The camera mounts securely with a screw mount and has a durable polycarbonate body. Wyze Cam Pan v3 lifestyle Weather-resistant design for year-round outdoor security.
Wyze Cam v4: Advanced 2.5K QHD Outdoor Camera with Motion-Activated Spotlight
High-Resolution Video and Enhanced Night Vision
Wyze Cam v4 delivers 2.5K QHD video with a CMOS Starlight Sensor, providing vivid and detailed footage. Its enhanced Color Night Vision combined with motion-activated spotlights ensures your packages and surroundings are well-lit and visible even in low light.
Smart Features for Package Detection
  • 115.8° diagonal field of view covers wide areas.
  • Built-in 99dB waterproof siren and two-way talk.
  • Supports Wi-Fi 6 for faster and more reliable connectivity.
  • Local storage up to 512 GB microSD and cloud options.
  • Compatible with Alexa, Google Assistant, and IFTTT.
Flexible Mounting Options
Includes stand, wall, ceiling, and magnetic mounts for versatile installation outdoors. Rated IP65 for weather resistance, it withstands temperatures from -4°F to 122°F.
Summary: Which Camera is Best for You?
Camera ModelResolutionFloodlightField of ViewSpecial FeaturesWeather Rating
Wyze Cam v3 Pro2.5KBuilt-in116°Edge AI, Integrated siren, SpotlightIP65
Wyze Cam Floodlight v22K2800 Lumens160° diagonalAI Light Control, 105dB siren, Dusk-to-dawnIP65
Wyze Cam Pan v31080pNo360° pan / 180° tiltPan & tilt, Alexa/Google/IFTTT integrationIP65
Wyze Cam v42.5K QHDMotion-activated spotlight115.8° diagonalWi-Fi 6, 99dB siren, multiple mountsIP65
For the best all-in-one solution with built-in floodlight and package detection, Wyze Cam v3 Pro and Wyze Cam Floodlight v2 are top choices. If you want full panoramic coverage with pan and tilt, the Wyze Cam Pan v3 is ideal. For advanced connectivity and spotlight features, the Wyze Cam v4 offers cutting-edge technology.
Protect your packages and home with smart outdoor cameras that combine high-resolution video, floodlight integration, and intelligent detection to keep your property safe day and night.
Product Highlights
This selection of Wyze outdoor cameras ensures you have the best tools for package detection and floodlight integration, enhancing your home security with smart, reliable technology.
FeatureWyze Cam v3 ProWyze Cam Pan v3Wyze Cam v4Wyze Cam Floodlight v2
Resolution2.5K (2560x1440)Not explicitly stated (2K approx.)2.5K QHD (2560x1440)2K (2304x1296)
Field of ViewNot specified360° pan, 180° tiltDFOV 115.8°, HFOV 98.5°, VFOV 53.1°160° diagonal
Night VisionColor Night VisionColor Night Vision (Starlight Sensor)Enhanced Color Night VisionColor Night Vision
SpotlightBuilt-in 70 lumen motion-activatedNoBuilt-in 2 white spotlight LEDs (72 lumens)No
SirenIntegrated 89 dB user-activated sirenNot specifiedBuilt-in siren (99 dB, waterproof)Built-in siren (105 dB)
Two-way AudioYesYesYesYes
AI FeaturesEdge AI with free person detectionMotion tracking, sound detectionPerson detectionAI-Powered Light Control
Weather ResistanceIP65 (requires Outdoor Power Adapter)IP65 (requires Outdoor Power Adapter)IP65IP65
Local StoragemicroSD ready (up to 128 GB recommended)Supports microSD cardsmicroSD card up to 512 GBSupports up to 256 GB microSD
Cloud StorageNo subscription required for person detectionOptional Cam Plus subscriptionSubscription plan availableSubscription plan available
ConnectivityWiredWiredWiredHardwired
Wi-Fi SupportNot specified2.4 GHz2.4 GHz Wi-Fi, Wi-Fi 62.4 GHz
DimensionsNot specifiedNot specified2in x 2in x 2 3/8in9.5in x 7.7in x 7.0in
WeightNot specifiedNot specified0.49 lb (222 g)2.76 lbs (1.25 kg)
Mounting OptionsNot specifiedNot specifiedStand, Wall, Ceiling, Magnetic mountWall, Ceiling
Power AdapterRequires Wyze Outdoor Power Adapter v2 (sold separately) for outdoor useRequires Wyze Outdoor Power Adapter (sold separately)Indoor 5V/1A adapter included; Outdoor adapter sold separatelyHardwired 110-120V AC
Price (single pack)$34.98 (sold out)$39.98$35.98$89.98
What are the best Wyze outdoor cameras for package detection and floodlight integration?The best Wyze outdoor cameras for package detection and floodlight integration are the Wyze Cam v3 Pro, Wyze Cam Floodlight v2, Wyze Cam Pan v3, and Wyze Cam v4. These models offer high-resolution video, smart detection features, and floodlight or spotlight integration to enhance home security and package monitoring.
Does the Wyze Cam v3 Pro have a built-in spotlight and siren?Yes, the Wyze Cam v3 Pro features a built-in spotlight and an integrated siren. The spotlight activates automatically upon motion detection, improving night visibility and deterring intruders, while the siren provides an additional layer of security.
Is the Wyze Cam Floodlight v2 suitable for large outdoor areas?Absolutely. The Wyze Cam Floodlight v2 offers 2800 lumens of dimmable LED lighting and a 160° wide-angle view, making it ideal for illuminating and monitoring large outdoor spaces such as driveways, porches, and backyards.
Can Wyze outdoor cameras detect packages and reduce false alerts?Yes, models like the Wyze Cam v3 Pro use Edge AI to intelligently distinguish between people, packages, and vehicles, reducing false alerts and ensuring you receive notifications only when important activity is detected.
Are Wyze outdoor cameras weather-resistant?All featured Wyze outdoor cameras, including the Cam v3 Pro, Floodlight v2, Pan v3, and v4, are rated IP65 for weather resistance. This means they are designed to withstand rain, snow, and extreme temperatures for reliable year-round outdoor use.
What are the storage options for Wyze outdoor cameras?Wyze outdoor cameras support local storage via microSD cards (up to 256 GB for most models and up to 512 GB for Wyze Cam v4) and offer cloud storage options for continuous or event-based video recording.
Do Wyze outdoor cameras support two-way audio?Yes, all the highlighted Wyze outdoor cameras feature two-way audio with noise and echo cancellation, allowing you to communicate clearly with visitors or delivery personnel from your mobile device.
Are Wyze outdoor cameras compatible with smart home systems?Yes, Wyze outdoor cameras are compatible with Alexa, Google Assistant, and IFTTT, enabling seamless integration with your smart home ecosystem for voice control and automation.
What is the difference between Wyze Cam v3 Pro and Wyze Cam Floodlight v2?The Wyze Cam v3 Pro offers 2.5K resolution, built-in spotlight, Edge AI detection, and flexible mounting options. The Wyze Cam Floodlight v2 features a powerful 2800-lumen floodlight, 2K video, AI-powered light control, and is hardwired for permanent installation, making it ideal for large area illumination and security.
Does the Wyze Cam Pan v3 provide full coverage for outdoor monitoring?Yes, the Wyze Cam Pan v3 offers 360° horizontal and 180° vertical pan and tilt capabilities, allowing you to remotely adjust the camera to monitor every angle of your outdoor space without blind spots.
What power options are available for Wyze outdoor cameras?The Wyze Cam Floodlight v2 is hardwired (110-120V AC), while the Wyze Cam v3 Pro, Pan v3, and v4 require the Wyze Outdoor Power Adapter (sold separately) for safe and reliable outdoor use.
Which Wyze camera is best for advanced connectivity and spotlight features?The Wyze Cam v4 is the best choice for advanced connectivity and spotlight features, offering 2.5K QHD video, Wi-Fi 6 support, motion-activated spotlights, and a built-in 99dB waterproof siren.
What are the key features of the Wyze Cam v3 Pro?How does the Wyze Cam Floodlight v2 compare to the Wyze Cam v3 Pro?Are there any ongoing promotions or discounts for Wyze cameras?
