Affordable Wyze Cam v2/v3 Repair Kit with Screws & Cables
Affordable Wyze Cam v2 & v3 Repair Kit with Screws and Cables
If you own a Wyze Cam v2 or v3 and are looking for an affordable, reliable repair kit that includes essential screws and cables, the Wyze Cam v3 Replacement Part Kit is your perfect solution. This kit is designed specifically to keep your Wyze Cam v2 and v3 running smoothly without the need to replace the entire camera.
Wyze Cam v3 Replacement Part Kit: Essential Repairs Made Easy
  • Compatibility: Works seamlessly with Wyze Cam v2 and v3 models.
  • Contents: Includes all necessary screws and cables to fix common issues.
  • Affordability: Priced at just $7.99, it offers a budget-friendly way to extend the life of your camera.
  • Availability: In stock with a 30-day hassle-free return policy for peace of mind.
This kit is ideal for DIY enthusiasts who want to maintain their Wyze cameras without spending on costly replacements. Whether you need to replace a worn-out cable or secure loose screws, this kit has you covered.
Upgrade Your Security with Wyze Cam v4 and Outdoor Bundle
While the repair kit supports older models, consider upgrading to the latest Wyze Cam v4 or the Wyze Cam v4 Outdoor Bundle for enhanced features, better image quality, and more robust security options.
Wyze Cam v4: Cutting-Edge Features for Home Security
  • Resolution: Stunning 2.5K Quad High Definition (2560x1440) for crystal-clear video.
  • Color Night Vision: Enhanced hardware reveals vibrant colors even in low-light conditions.
  • Wide Dynamic Range (WDR): Delivers rich, vibrant colors and improved image quality.
  • Weather Resistance: IP65 rating allows use indoors or outdoors in any weather.
  • Audio & Siren: Advanced two-way talk with noise cancellation and a powerful 99 dB siren.
  • Mounting: Screw-free magnetic mount for easy installation without tools.
  • Connectivity: Supports Wi-Fi 6 for stronger, more reliable connections.
  • Storage: Local microSD card support up to 512GB for continuous 24/7 recording without subscription.
  • Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT.
Wyze Cam v4 Outdoor Bundle: Complete Security Package
  • Includes Wyze Cam v4, Wyze Outdoor Power Adapter, and a 128GB microSD card.
  • Perfect for outdoor use with weatherproof design and continuous power.
  • Motion-activated spotlight and siren enhance nighttime security.
  • Priced affordably at $69.99, offering great value for a full security setup.
"Wyze Cam v4 is the clearest Wyze Cam ever, with superhero vision at night and smart features that keep your home safe around the clock."
Home security with Wyze Cam v4
Why Choose Wyze for Your Camera Repairs and Upgrades?
Wyze offers a range of products and accessories that cater to both repair needs and advanced security solutions:
  • Repair Kits: Affordable and compatible with older models like v2 and v3.
  • Latest Cameras: Wyze Cam v4 delivers superior video quality and smart features.
  • Bundles: Outdoor bundles provide everything needed for reliable outdoor surveillance.
  • Accessories: From spotlight kits to power adapters, Wyze supports your camera’s longevity and performance.
Investing in a repair kit saves money and reduces waste, while upgrading to newer models ensures you benefit from the latest technology and enhanced security.
Summary of Products for Wyze Cam Repair and Upgrade
Product NameCompatibilityPriceKey Features
Wyze Cam v3 Replacement Part KitWyze Cam v2 & v3$7.99Screws and cables for repairs
Wyze Cam v4Latest model$35.98+2.5K QHD, Color Night Vision, IP65, Wi-Fi 6
Wyze Cam v4 Outdoor BundleLatest model + outdoor$69.99Includes power adapter, 128GB microSD, spotlight
Final Thoughts
For those seeking an affordable Wyze Cam v2 or v3 repair kit with screws and cables, the Wyze Cam v3 Replacement Part Kit is the best choice. It’s cost-effective, reliable, and designed specifically for your camera model. If you want to enhance your home security with the latest technology, consider upgrading to the Wyze Cam v4 or the Outdoor Bundle for superior video quality, smart features, and weatherproof durability. Secure your home smartly and affordably with Wyze’s trusted products.
FeatureWyze Cam v3 Replacement Part KitWyze Cam v4Wyze Cam v4 Outdoor Bundle
TypeReplacement PartsCameraBundle
CompatibilityWyze Cam v2 and v3Wyze Cam v4Wyze Cam v4
Price$7.99$35.98 (1 Pack)$69.99
ResolutionN/A (Parts Kit)2.5K QHD (2560x1440)2.5K QHD (2560x1440)
Night VisionN/AEnhanced Color Night VisionEnhanced Color Night Vision
SpotlightNo (sold separately)Motion-activated spotlightMotion-activated spotlight
AudioN/AEnhanced Two-Way TalkEnhanced Two-Way Talk
SirenN/AYesYes
Weather ResistanceN/AIP65IP65
Local RecordingN/A24/7 local recording (microSD card required)24/7 local recording (microSD card included 128GB)
Wi-Fi SupportN/AWi-Fi 6Wi-Fi 6
Smart Assistant CompatibilityN/AAlexa, Google AssistantAlexa, Google Assistant
Motion DetectionN/AYesYes
Sound DetectionN/AYesYes
Motion Detection ZonesN/AYesYes
Smoke & CO AlertsN/AYesYes
Power SourceN/AWiredWired
Outdoor UseN/ARequires Outdoor Power Adapter (sold separately)Included (Outdoor Power Adapter included)
MicroSD Card IncludedNoNoYes (128GB)
WarrantyNot specified1 Year1 Year
What's IncludedReplacement parts kitCamera, power adapter, cable, mounting kitCamera, Outdoor Power Adapter, 128GB MicroSD Card
What is included in the Wyze Cam v3 Replacement Part Kit?The Wyze Cam v3 Replacement Part Kit includes all the essential screws and cables needed to repair common issues with Wyze Cam v2 and v3 models. This kit is designed to help you fix your camera without replacing the entire device.
Is the Wyze Cam v3 Replacement Part Kit compatible with both v2 and v3 models?Yes, the Wyze Cam v3 Replacement Part Kit is fully compatible with both Wyze Cam v2 and v3 models, making it a versatile solution for repairing your older Wyze cameras.
How much does the Wyze Cam v3 Replacement Part Kit cost?The Wyze Cam v3 Replacement Part Kit is affordably priced at $7.99, offering a budget-friendly way to extend the life of your Wyze Cam v2 or v3.
Can I return the Wyze Cam v3 Replacement Part Kit if it doesn’t work for me?Yes, the Wyze Cam v3 Replacement Part Kit comes with a 30-day hassle-free return policy, giving you peace of mind with your purchase.
What are the benefits of using a Wyze Cam repair kit instead of replacing the camera?Using a Wyze Cam repair kit is cost-effective and environmentally friendly. It allows you to fix common issues like worn-out cables or loose screws, extending the life of your camera and reducing electronic waste.
What are the key features of the Wyze Cam v4?The Wyze Cam v4 features 2.5K Quad High Definition video, color night vision, wide dynamic range, IP65 weather resistance, advanced two-way audio with noise cancellation, a 99 dB siren, screw-free magnetic mounting, Wi-Fi 6 support, and local microSD card storage up to 512GB. It also integrates with Alexa, Google Assistant, and IFTTT.
What is included in the Wyze Cam v4 Outdoor Bundle?The Wyze Cam v4 Outdoor Bundle includes the Wyze Cam v4, a Wyze Outdoor Power Adapter, and a 128GB microSD card. It is designed for outdoor use with weatherproof features, continuous power, a motion-activated spotlight, and a siren for enhanced nighttime security.
Why should I consider upgrading to the Wyze Cam v4 or Outdoor Bundle?Upgrading to the Wyze Cam v4 or Outdoor Bundle provides you with superior video quality, advanced smart features, weatherproof durability, and enhanced security options, ensuring your home is protected with the latest technology.
Does Wyze offer accessories to support camera longevity and performance?Yes, Wyze offers a range of accessories such as spotlight kits and power adapters to help maintain and enhance your camera’s performance and longevity.
How does the Wyze Cam v3 Replacement Part Kit help reduce waste?By allowing you to repair your existing Wyze Cam v2 or v3 instead of replacing it, the Wyze Cam v3 Replacement Part Kit helps reduce electronic waste and supports a more sustainable approach to home security.
Can you tell me more about the contents of the Wyze Cam v3 Replacement Part Kit?What are the benefits of upgrading to the Wyze Cam v4?How does the warranty work for the Wyze Cam v3 Replacement Part Kit?
