Where to Buy Wyze Cam OG Stack Kit for Dual Recording
If you're looking to set up dual recording with Wyze cameras, the
Wyze Cam OG Stack Kit and the
Wyze Cam OG Stack Kit Bundle are your best options. These products are designed specifically to enable stacking and powering two Wyze Cam OG or Wyze Cam OG Telephoto cameras, giving you versatile dual-angle surveillance.
Wyze Cam OG Stack Kit: The Perfect Accessory for Dual Recording
Key Features
- Compatibility: Designed for Wyze Cam OG and Wyze Cam OG Telephoto models.
- Stackable Design: The kit includes a stack mount that allows you to securely stack two cameras vertically, saving space and providing multiple viewing angles.
- Power Solution: Comes with a dual micro USB power cable (6ft) and a 5V/1.5A indoor power adapter to power both cameras simultaneously.
- Complete Package: Includes a USB cable splitter, power brick, stack mount, and a quick start guide for easy setup.
- Color & Finish: Matte white finish that blends seamlessly with most home environments.
The Wyze Cam OG Stack Kit is an essential accessory if you want to maximize your Wyze Cam OG setup for dual recording without clutter or complicated wiring.
Wyze Cam OG Stack Kit Bundle: Dual Cameras for Comprehensive Coverage
What’s Included
- 1x Wyze Cam OG Standard (Wide-angle lens)
- 1x Wyze Cam OG Telephoto (3x zoom lens)
- 1x Wyze Cam OG Stack Kit (stack mount, dual power cable, power adapter)
- 1x 32GB MicroSD card for local storage
- Mounting hardware and quick start guides
Standout Features
- Dual Views: Combine a wide-angle camera with a telephoto camera to capture both broad and detailed views simultaneously.
- 1080p Full HD Video: Crisp video quality with 20 FPS during the day and 15 FPS at night.
- Color Night Vision: Enhanced night vision with 4 IR LEDs for clear images in low light.
- Two-Way Audio: Built-in speaker and microphone with noise and echo cancellation.
- Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT for voice control and automation.
- Weather Resistance: Rated IP65 for indoor and outdoor use, suitable for various environments.
- Local Storage: Supports up to 256GB microSD cards, with a 32GB card included for immediate use.
- Built-in Siren & Spotlights: Motion-activated spotlights and a siren to deter intruders.
This bundle is ideal for users who want a ready-to-go dual camera system with all necessary accessories included for seamless dual recording.
Why Choose Wyze Cam OG Stack Kit for Dual Recording?
Space-Saving and Efficient Setup
The stack kit allows you to mount two cameras vertically, reducing the footprint on walls or shelves. This is perfect for tight spaces or when you want to monitor different angles from the same location.
Simplified Power Management
With the included USB cable splitter and power adapter, you only need one power outlet to run both cameras, eliminating the hassle of multiple cords and adapters.
Enhanced Surveillance Capabilities
Using the stack kit with the OG and OG Telephoto cameras gives you the flexibility to monitor wide areas and zoomed-in details simultaneously, improving your home or office security.
Summary
For anyone searching
where to buy Wyze Cam OG Stack Kit for dual recording, the Wyze Cam OG Stack Kit and the Wyze Cam OG Stack Kit Bundle are the definitive solutions. Whether you want just the accessory kit to stack and power your existing cameras or a complete bundle with two cameras and all accessories, these products provide excellent value and functionality.
Product Highlights
Stack and power two Wyze Cam OG or OG Telephoto cameras with ease.
Price: $9.99 USD
Dual camera system with wide-angle and telephoto lenses, plus stack kit and 32GB microSD card.
Price: $89.99 USD (discounted from $95.92)
Elevate your home security with dual recording capabilities using the Wyze Cam OG Stack Kit and Bundle — smart, efficient, and easy to install.
What is the Wyze Cam OG Stack Kit and what does it include?
The Wyze Cam OG Stack Kit is an accessory designed to stack and power two Wyze Cam OG or Wyze Cam OG Telephoto cameras for dual recording. The kit includes a stack mount, a dual micro USB power cable (6ft), a 5V/1.5A indoor power adapter, a USB cable splitter, and a quick start guide.Which Wyze cameras are compatible with the Wyze Cam OG Stack Kit?
The Wyze Cam OG Stack Kit is compatible with Wyze Cam OG and Wyze Cam OG Telephoto models, allowing you to stack and power two cameras for versatile surveillance.What is included in the Wyze Cam OG Stack Kit Bundle?
The Wyze Cam OG Stack Kit Bundle includes one Wyze Cam OG Standard (wide-angle lens), one Wyze Cam OG Telephoto (3x zoom lens), one Wyze Cam OG Stack Kit (stack mount, dual power cable, power adapter), a 32GB microSD card for local storage, mounting hardware, and quick start guides.What are the benefits of using the Wyze Cam OG Stack Kit for dual recording?
The Wyze Cam OG Stack Kit allows you to mount two cameras vertically, saving space and providing multiple viewing angles. It simplifies power management by using a single power outlet for both cameras and enhances surveillance by enabling simultaneous wide-angle and zoomed-in monitoring.Does the Wyze Cam OG Stack Kit support local video storage?
Yes, the Wyze Cam OG Stack Kit Bundle includes a 32GB microSD card for local storage, and the cameras support up to 256GB microSD cards for extended recording.Is the Wyze Cam OG Stack Kit suitable for outdoor use?
Yes, the Wyze Cam OG Stack Kit and the cameras in the bundle are rated IP65 for weather resistance, making them suitable for both indoor and outdoor use.What smart home integrations are available with the Wyze Cam OG Stack Kit Bundle?
The Wyze Cam OG Stack Kit Bundle is compatible with Alexa, Google Assistant, and IFTTT, allowing for voice control and smart home automation.How much does the Wyze Cam OG Stack Kit and Stack Kit Bundle cost?
The Wyze Cam OG Stack Kit is priced at $9.99 USD, while the Wyze Cam OG Stack Kit Bundle, which includes two cameras and all necessary accessories, is available for $89.99 USD (discounted from $95.92).Where can I buy the Wyze Cam OG Stack Kit for dual recording?
You can purchase the Wyze Cam OG Stack Kit and the Wyze Cam OG Stack Kit Bundle directly from the official Wyze website or authorized retailers.What features make the Wyze Cam OG Stack Kit Bundle ideal for home security?
The Wyze Cam OG Stack Kit Bundle offers dual camera views (wide-angle and telephoto), 1080p Full HD video, color night vision, two-way audio, motion-activated spotlights, a built-in siren, weather resistance, and local storage, making it a comprehensive solution for home security.
