Affordable Wyze Cam V2/V3 & Lock Replacement Screws & Cables Kit
Affordable Replacement Screws and Cables Kit for Wyze Cam V2, V3, and Wyze Lock DIY Repair
If you're looking to maintain or repair your Wyze Cam V2, V3, or Wyze Lock without breaking the bank, having the right replacement screws and cables kit is essential. These kits help you extend the life of your devices, ensuring your home security system stays reliable and functional. Below, we highlight the best Wyze products that complement your DIY repair needs, focusing on affordability, compatibility, and ease of use.
Wyze Cam v4: The Ultimate Upgrade for Your Security Camera
The Wyze Cam v4 is the latest in Wyze’s lineup, offering superior features that make it a perfect replacement or upgrade for older models like the V2 and V3. While it doesn't come with a dedicated screws and cables kit, its design supports easy mounting and repair with standard accessories.
Key Features:
  • 2.5K Quad High Definition (QHD) Clarity: Capture crystal-clear images and videos with enhanced detail.
  • Color Night Vision: See vibrant colors even in low-light conditions, surpassing traditional black-and-white night vision.
  • IP65 Weather Resistance: Perfect for indoor and outdoor use, resistant to rain and dust.
  • Screw-Free Magnetic Mount: Simplifies installation and replacement without the need for power tools.
  • Advanced Two-Way Talk & Siren: Communicate clearly and deter intruders with a loud siren.
  • Wi-Fi 6 Support: Ensures a stronger, more reliable connection.
  • MicroSD Card Support: Local 24/7 recording up to 512GB without subscription fees.
Why It Matters for DIY Repairs:
The Wyze Cam v4’s modular design and magnetic mount make it easier to replace screws and cables if needed. Its compatibility with standard micro USB cables and mounts means you can find affordable replacement parts easily, making DIY repairs straightforward and cost-effective. Wyze Cam v4 Mounted Outdoors Wyze Cam v4 providing reliable home security in any weather
Wyze Cam v4 Outdoor Bundle: Complete Kit for Outdoor Security
For those who want a ready-to-go solution with everything included, the Wyze Cam v4 Outdoor Bundle is an excellent choice. It comes with the camera, an outdoor power adapter, and a 128GB microSD card, making it ideal for continuous outdoor monitoring.
Bundle Highlights:
  • All Features of Wyze Cam v4: Including 2.5K QHD resolution, color night vision, and motion-activated spotlight.
  • Outdoor Power Adapter: Designed specifically for outdoor use, ensuring your camera stays powered in all conditions.
  • 128GB MicroSD Card: Enables continuous local recording without monthly fees.
  • Wi-Fi 6 Support & Smart Assistant Compatibility: Works seamlessly with Alexa and Google Assistant.
DIY Repair and Replacement Benefits:
This bundle includes durable cables and power adapters designed for outdoor environments, reducing the need for frequent replacements. However, if you need to replace screws or cables, the components are compatible with standard parts, making DIY fixes affordable and hassle-free.
Wyze Lock Bolt: Smart Lock with Easy Installation and Maintenance
If your DIY repair needs extend to smart locks, the Wyze Lock Bolt is a top choice. It replaces your existing deadbolt and offers smart features with simple installation and maintenance.
Features for Easy DIY Repair:
  • Ultra-Fast Fingerprint Sensor: Quick and secure access without keys.
  • Backlit Keypad with Anti-Peep: Enter codes discreetly, even in low light.
  • Auto-Lock Function: Automatically locks your door for peace of mind.
  • Bluetooth 5.0 Connectivity: Reliable wireless control within 16 feet.
  • Weather Resistance (IPX5): Durable for various climates.
  • Battery Powered (4x AA Batteries Included): Easy to replace batteries with long life (10-12 months).
Repair and Replacement Insights:
The Wyze Lock Bolt is designed for easy installation and replacement of parts like screws and batteries. Its modular design means you can find affordable replacement screws and cables kits compatible with the lock, making DIY repairs straightforward and cost-effective. Wyze Lock Bolt Lifestyle Wyze Lock Bolt installed on a front door, combining security and convenience
Why Choose Affordable Replacement Kits for Wyze Devices?
Maintaining your Wyze Cam or Lock with affordable replacement screws and cables kits not only saves money but also extends the life of your devices. DIY repairs empower you to keep your home secure without waiting for professional service or costly replacements.
Benefits:
  • Cost-Effective: Avoid buying new devices by replacing only worn or broken parts.
  • Easy to Install: Most kits come with standard screws and cables compatible with Wyze products.
  • Reliable Performance: Keep your cameras and locks functioning optimally.
  • Sustainability: Reduce electronic waste by repairing instead of replacing.
Summary
For affordable DIY repair of your Wyze Cam V2, V3, or Wyze Lock, consider the following:
  • Wyze Cam v4 and Outdoor Bundle: Modern, feature-rich cameras with easy mounting and compatible with standard replacement parts.
  • Wyze Lock Bolt: Smart lock with simple installation and durable components, ideal for quick repairs.
  • Replacement Screws and Cables Kits: Essential for maintaining your devices, these kits ensure your Wyze products stay secure and functional without high costs.
Investing in these Wyze products and compatible replacement parts is the smart way to keep your home security system running smoothly and affordably.
FeatureWyze Cam v4Wyze Cam v4 Outdoor BundleWyze Lock Bolt
Product TypeCameraCamera Bundle (Wyze Cam v4 + Outdoor Power Adapter + 128GB microSD Card)Smart Lock
Price$35.98 (single)$69.99$79.98
Video Resolution2.5K QHD (2560x1440)2.5K QHD (2560x1440)N/A
Color Night VisionYesYesN/A
Motion-Activated SpotlightYesYesN/A
AudioEnhanced Two-Way Talk, 99dB SirenEnhanced Two-Way Talk, 99dB SirenN/A
Wi-Fi SupportWi-Fi 6Wi-Fi 6N/A
Local RecordingmicroSD card support (up to 256GB)Includes 128GB microSD cardN/A
Cloud StorageOptional with subscriptionOptional with subscriptionN/A
Weather ResistanceIP65IP65IPX5
Power SourceWired (requires power adapter)Wired (includes Outdoor Power Adapter)4x AA Batteries (included)
Outdoor UseYes (requires Outdoor Power Adapter)Yes (includes Outdoor Power Adapter)N/A
CompatibilityAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTBluetooth 5.0, Wyze App
Special FeaturesMotion & Sound Detection, Smoke & CO Alerts, Motion Detection Zones, Auto-Zoom with AISame as Wyze Cam v4 plus Outdoor Power Adapter and 128GB microSD CardUltra-Fast Fingerprint Sensor, Backlit Keypad with Anti-Peep, Auto-lock, Jam Detection Alarm, Emergency Codes
Dimensions2in x 2in x 2 3/8inSame as Wyze Cam v4N/A
Weight0.49 lb (222 g)Same as Wyze Cam v42.75 lbs
Warranty1 Year1 YearNot specified
What devices are compatible with affordable replacement screws and cables kits for Wyze products?Affordable replacement screws and cables kits are compatible with Wyze Cam V2, Wyze Cam V3, and Wyze Lock. These kits help you maintain and repair your devices easily and cost-effectively.
Can I use standard screws and cables for DIY repairs on Wyze Cam v4?Yes, the Wyze Cam v4 is designed with compatibility in mind. It supports standard micro USB cables and mounts, making it easy to find affordable replacement screws and cables for DIY repairs.
What are the benefits of using a replacement screws and cables kit for Wyze devices?Using a replacement screws and cables kit for Wyze devices is cost-effective, extends the life of your cameras and locks, is easy to install, ensures reliable performance, and supports sustainability by reducing electronic waste.
Does the Wyze Cam v4 Outdoor Bundle include replacement screws and cables?The Wyze Cam v4 Outdoor Bundle includes durable cables and a power adapter designed for outdoor use. While it does not come with a dedicated replacement kit, its components are compatible with standard parts, making DIY repairs and replacements easy.
How easy is it to install or replace parts on the Wyze Lock Bolt?The Wyze Lock Bolt is designed for simple installation and maintenance. Its modular design allows for easy replacement of screws, batteries, and other parts, making DIY repairs straightforward and affordable.
Why should I choose affordable replacement kits for my Wyze Cam or Wyze Lock?Affordable replacement kits help you save money by allowing you to repair rather than replace your Wyze devices. They are easy to install, maintain optimal device performance, and contribute to sustainability by reducing electronic waste.
Are replacement screws and cables kits necessary for the Wyze Cam v4?While the Wyze Cam v4 features a screw-free magnetic mount for easy installation, having a replacement screws and cables kit can be helpful for repairs or if you need to replace worn or lost parts.
What features make the Wyze Cam v4 suitable for DIY repairs?The Wyze Cam v4 offers a modular design, screw-free magnetic mount, compatibility with standard accessories, and easy access to replacement parts, making it ideal for DIY repairs and maintenance.
How do replacement kits help extend the life of Wyze security devices?Replacement kits allow you to fix worn or broken parts without replacing the entire device, ensuring your Wyze cameras and locks remain functional and reliable for longer periods.
Can you tell me more about the features of the Wyze Cam v4?What are the benefits of using the Wyze Cam v4 Outdoor Bundle?Do you have any deals, ongoing sales, discounts, or promotions available?
