How to Set Up Synchronized Dusk to Dawn Wyze Lamp Automation
How to Set Up Synchronized Dusk to Dawn Wyze Lamp Socket Automation
Creating a synchronized dusk to dawn automation with your Wyze Lamp Socket is a smart way to enhance your home’s exterior lighting, improve security, and save energy. Wyze offers several lamp socket models and bundles designed to power Wyze cameras and smart bulbs while enabling advanced automation features like motion-activated lights and dusk to dawn scheduling. This guide will walk you through the setup process and highlight the best Wyze products to achieve seamless dusk to dawn lighting automation.
Wyze Lamp Socket Models for Smart Lighting Automation
Wyze Lamp Socket (Original Model)
The original Wyze Lamp Socket is designed to make your exterior lighting smart by powering Wyze Cam v3 and v4 without needing a plug. It supports dusk to dawn scheduling, motion-activated lights, and device linkability for automation.
  • Compatibility: Wyze Cam v3, Wyze Cam v4
  • Power Input: 120V, 60Hz
  • Max Lamp Power: 30W
  • Connectivity: 2.4GHz Wi-Fi (802.11 b/g/n), Bluetooth
  • Socket Type: E26
  • Materials: Polycarbonate and plastic
  • Weather Resistance: Suitable for damp locations (not waterproof)
  • Dimensions: 56.5mm x 56.5mm x 65mm
Features:
  • Dusk to dawn scheduling for automatic on/off at sunset and sunrise
  • Motion-activated lighting for enhanced security
  • Linkability with other Wyze devices for triggered actions
This lamp socket is ideal if you want a reliable, straightforward solution to power your Wyze cameras and automate your outdoor lighting.
Wyze Lamp Socket v2 – Enhanced Compatibility and Safety
The Wyze Lamp Socket v2 builds on the original with broader device compatibility and improved safety features. It supports powering Wyze Cam v3, v3 Pro, v4, Cam OG, and Pan v3 models without a power outlet.
  • Compatibility: Wyze Cam v3, v3 Pro, v4, Cam OG, Pan v3
  • Power Input: 120V~, 60Hz
  • Max Lamp Power: 20W (recommended CFL or LED bulbs only)
  • Socket Type: E26
  • Certifications: FCC, IC, UL496, CA65, TSCA, RoHS
Features:
  • Dusk to dawn scheduling for automatic lighting control
  • Motion-activated lights for security and convenience
  • Linkability with Wyze cameras and other smart devices
  • Thermal safety limits prevent use with incandescent bulbs
This version is perfect for users who want to power multiple Wyze camera models and ensure safe, energy-efficient lighting automation.
Wyze Lamp Socket Bundles for Complete Solutions
For those looking to get started quickly, Wyze offers bundles that combine lamp sockets with compatible cameras:
  • Wyze Lamp Socket Bundle: Includes 4 lamp sockets and 2 Wyze Cam v3 units.
  • Cam v4 + Lamp Socket v2 Bundle: Powers Wyze Cam v4 with the latest lamp socket, featuring dusk to dawn scheduling and motion-activated lights.
  • Pan v3 + Lamp Socket v2 Bundle: Powers Wyze Cam Pan v3 with the latest lamp socket, offering the same smart features.
These bundles provide a convenient way to set up synchronized dusk to dawn lighting and security cameras in your front or backyard.
Setting Up Synchronized Dusk to Dawn Automation with Wyze Lamp Socket
Wyze’s app makes it easy to create automations that turn your lamp sockets on at dusk and off at dawn, synchronized perfectly with local sunset and sunrise times.
Step-by-Step Automation Setup
1. Open the Wyze App: Ensure your Wyze Lamp Socket and compatible Wyze cameras are connected and online. 2. Navigate to Automations: Tap the plus sign (+) in the Home tab, then select Automation > Schedule. 3. Create a New Schedule:
  • Name your schedule (e.g., "Dusk to Dawn Lighting").
  • Tap Add Action, select your Wyze Lamp Socket device, and choose Turn On.
4. Set Start Time:
  • Choose Sunset as the start time.
  • Optionally, adjust the time offset (minutes before or after sunset).
5. Add Another Action:
  • Add a second action to Turn Off the lamp socket.
  • Set the stop time to Sunrise with optional offset.
6. Save the Schedule: Your lamp socket will now automatically turn on at dusk and off at dawn every day.
Advanced Automation Tips
  • Device & Service Triggers: Link your lamp socket to motion sensors or Wyze cameras to turn on lights only when motion is detected during nighttime hours.
  • Shortcuts: Create shortcuts in the Wyze app for quick manual control of your lamp sockets.
  • Linkability: Combine multiple Wyze devices to trigger complex automations, such as turning on lights and cameras simultaneously.
Using these automations, you can ensure your outdoor lighting is energy-efficient, secure, and perfectly timed with natural light cycles.
Enhance Your Setup with Wyze Bulb Color
For customizable lighting, consider pairing your Wyze Lamp Socket with the Wyze Bulb Color. This smart bulb offers:
  • 16 Million Colors and tunable white light (1800K - 6500K)
  • Dimmable brightness up to 1100 lumens
  • Compatibility: Works seamlessly with Wyze Lamp Socket and Wyze app automations
  • Connectivity: 2.4GHz Wi-Fi and Bluetooth
Suitable for Damp Locations
This combination allows you to create vibrant, synchronized dusk to dawn lighting scenes that enhance your home’s curb appeal and security. Wyze Bulb Color in Living Room
Summary: Best Wyze Products for Dusk to Dawn Automation
ProductKey FeaturesCompatibilityMax Lamp PowerPrice (USD)
Wyze Lamp Socket (Original)Dusk to dawn scheduling, motion-activatedWyze Cam v3, v430W$16.98
Wyze Lamp Socket v2Supports more cameras, safer with LED/CFLWyze Cam v3, v3 Pro, v4, OG, Pan v320W$16.98
Cam v4 + Lamp Socket v2 BundlePower Cam v4, motion-activated, linkabilityWyze Cam v420W$49.96
Pan v3 + Lamp Socket v2 BundlePower Pan v3, dusk to dawn schedulingWyze Cam Pan v320W$53.96
Wyze Bulb Color16M colors, dimmable, smart app controlE26 socket compatible12WFrom $26.26 (2-pack)
Wyze Cam v4 Mounted Outdoor
Final Tips for Optimal Automation
  • Use LED or CFL bulbs under 20W with the Lamp Socket v2 to avoid overheating.
  • Confirm your location in the Wyze app for accurate sunset and sunrise times.
  • Regularly update your Wyze app and device firmware for the latest features and security.
  • Combine motion sensors and camera triggers for smarter, event-based lighting control.
By following these steps and choosing the right Wyze products, you can easily set up synchronized dusk to dawn lighting automation that enhances your home’s security and convenience.
FeatureWyze Lamp SocketWyze Lamp Socket v2Cam v4 + Lamp Socket v2 BundleWyze Bulb Color
TypeCamerasAccessoriesBundleSmart Lighting
Compatible DevicesWyze Cam v3, v4Wyze Cam v3, v3 Pro, v4, Cam OG, Pan v3, Duo Cam PanWyze Cam v3, v3 Pro, v4, Cam OG, Pan v3N/A
Power SourceOutdoor light fixture (no plug)Outdoor light fixture (no plug)Outdoor light fixture (no plug)AC 120V~60Hz
Max Lamp PowerNot specified20W (incandescent bulbs not supported)20W (incandescent bulbs not supported)12W
Socket Connector TypeE26E26E26E26
FeaturesMotion-activated lights, Dusk to Dawn, Link up to 5 socketsMotion-activated lights, AI activated lighting, Dusk to Dawn, Unlimited linkingMotion-activated lights, Dusk to Dawn, Unlimited linking16 million colors, dimmable, tunable white, voice control
InstallationScrew in like a light bulbScrew in like a light bulbScrew in like a light bulbScrew in like a light bulb
ConnectivityN/AN/AWi-Fi 802.11 b/g/n 2.4GHz, BluetoothWi-Fi 802.11 b/g/n 2.4GHz, Bluetooth
DimensionsNot specifiedNot specified56.5mm x 56.5mm x 65mm2.5 x 2.5 x 5 inches
WeightNot specifiedNot specified80 g0.31 lbs
Operating TemperatureNot specifiedNot specified-4°F to 120°F (-20°C to 50°C)-4°F to 104°F
Weather ResistanceSuitable for damp locationsSuitable for damp locationsNot weatherproof or waterproof, suitable for damp locationsSuitable for damp locations
Phone CompatibilityN/AAndroid 7.0+, iOS 12.0+Android 7.0+, iOS 12.0+Android 9.0+, iOS 15.0+
Warranty30-day hassle-free returns30-day hassle-free returns1-YearNot specified
Price$16.98 (1 Pack)$16.98$49.96$26.26 (2 Pack)
NotesOriginal model, link up to 5 socketsLatest model, AI lighting for security plan subscribers, unlimited linkingBundle includes Cam v4 and Lamp Socket v2Recommended LED or CFL bulbs under 20W
What is a Wyze Lamp Socket and how does it work for dusk to dawn automation?A Wyze Lamp Socket is a smart device that allows you to automate your exterior lighting by powering Wyze cameras and smart bulbs. It supports dusk to dawn scheduling, which automatically turns your lights on at sunset and off at sunrise, enhancing home security and energy efficiency.
Which Wyze Lamp Socket models support dusk to dawn scheduling?Both the original Wyze Lamp Socket and Wyze Lamp Socket v2 support dusk to dawn scheduling. These models allow you to automate your outdoor lighting to turn on at dusk and off at dawn using the Wyze app.
What Wyze cameras are compatible with Wyze Lamp Socket v2?Wyze Lamp Socket v2 is compatible with Wyze Cam v3, v3 Pro, v4, Cam OG, and Pan v3. This makes it a versatile choice for powering and automating multiple Wyze camera models.
How do I set up synchronized dusk to dawn automation with my Wyze Lamp Socket?To set up dusk to dawn automation, open the Wyze app, go to Automations, and create a new schedule. Set your Wyze Lamp Socket to turn on at sunset and off at sunrise. You can also adjust the timing with offsets for more precise control.
Can I use incandescent bulbs with Wyze Lamp Socket v2?No, Wyze Lamp Socket v2 is designed for use with LED or CFL bulbs only, with a maximum lamp power of 20W. Using incandescent bulbs is not recommended due to thermal safety limits.
Are Wyze Lamp Sockets weatherproof?Wyze Lamp Sockets are suitable for damp locations but are not fully waterproof. They are designed for outdoor use in covered areas where they are protected from direct exposure to water.
What are the benefits of using Wyze Lamp Socket bundles?Wyze Lamp Socket bundles combine lamp sockets with compatible Wyze cameras, providing a convenient and cost-effective way to set up synchronized dusk to dawn lighting and security in your home’s exterior spaces.
How can I enhance my dusk to dawn lighting setup with Wyze Bulb Color?Pairing your Wyze Lamp Socket with Wyze Bulb Color allows you to customize your outdoor lighting with 16 million colors, tunable white light, and dimmable brightness. The Wyze Bulb Color works seamlessly with Wyze app automations for vibrant, energy-efficient dusk to dawn lighting.
Can I link Wyze Lamp Sockets with other Wyze devices for advanced automation?Yes, Wyze Lamp Sockets can be linked with Wyze cameras, motion sensors, and other smart devices to create advanced automations, such as turning on lights when motion is detected or triggering multiple devices simultaneously.
What tips can help optimize my Wyze dusk to dawn automation setup?For optimal performance, use LED or CFL bulbs under 20W with Lamp Socket v2, confirm your location in the Wyze app for accurate scheduling, keep your app and device firmware updated, and consider integrating motion sensors or camera triggers for smarter, event-based lighting control.
What are the key features of the Wyze Lamp Socket v2?Can I use the Wyze Lamp Socket with other smart devices?How do I link my Wyze Lamp Socket to motion sensors for automation?
