Top Smart Plugs for Remote Device Control and Automation
Best Smart Plugs for Remote Device Control
Looking for the best smart plug to turn your devices on and off remotely? Whether you want to automate your indoor appliances or control outdoor lighting and equipment, smart plugs offer convenience, energy savings, and seamless integration with your smart home ecosystem. Below, we highlight top smart plugs designed to meet various needs, from indoor use to rugged outdoor environments.
Wyze Plug Outdoor: Rugged Smart Plug for Outdoor Control
Power up your outdoor devices with the Wyze Plug Outdoor, a smart plug built to withstand the elements while giving you full control from your smartphone.
Key Features:
  • Weather-Resistant Design: Rated IP64, it handles rain, dust, and temperatures from -4°F to 120°F, perfect for garden lights, holiday inflatables, or backyard parties.
  • Dual Outlets: Control two devices independently with a single plug.
  • Energy Monitoring: Track power usage to optimize energy consumption.
  • Connectivity: Uses 2.4GHz WiFi and Bluetooth V4.2 with a range up to 300 feet.
  • Voice Control: Compatible with Alexa for hands-free operation.
  • Compact and Durable: Measures 4.0” x 2.8” x 1.4” and weighs 7.2 ounces.
  • Easy Scheduling: Set timers and schedules via the Wyze app for effortless automation.
Take full control of your outdoor space, rain or shine, and make your garden smarter and more energy-efficient.
Outdoor smart plug in backyard setting Enjoy smart outdoor lighting and device control with Wyze Plug Outdoor.
Wyze Plug: Compact Indoor Smart Plug for Everyday Use
For indoor device automation, the Wyze Plug is a reliable and affordable choice that transforms your regular appliances into smart devices.
Key Features:
  • Indoor Use: Designed for indoor environments with operating temperatures from -4°F to 104°F.
  • Compact Size: Small footprint (2.7" x 2.0" x 1.5") fits easily into any outlet without blocking adjacent sockets.
  • Connectivity: Connects via 2.4GHz WiFi and supports Android 5.0+ and iOS 9.0+.
  • Voice Assistant Integration: Works with Alexa, Google Assistant, and IFTTT for versatile voice and automation control.
  • Energy Efficient: Supports up to 15A max output with ETL certification.
  • Scheduling & Remote Control: Use the Wyze app to turn devices on/off remotely, set schedules, and create automation rules.
  • Available in Multi-Packs: Choose from 2-pack or 4-pack options for whole-home smart control.
Make your everyday devices smarter and more energy-conscious with easy app control and voice commands.
Indoor smart plug controlling home devices Control your indoor appliances remotely with Wyze Plug.
Why Choose a Smart Plug for Remote Device Control?
Smart plugs are the simplest way to add intelligence to your home without rewiring or replacing devices. They allow you to:
  • Turn devices on/off remotely from anywhere using your smartphone.
  • Set schedules and timers to automate daily routines.
  • Monitor energy usage to reduce electricity bills.
  • Integrate with voice assistants for hands-free control.
  • Enhance home security by controlling lights and appliances while away.
Whether you want to automate your coffee maker, control holiday lights, or manage outdoor equipment, smart plugs like the Wyze Plug and Wyze Plug Outdoor provide reliable, easy-to-use solutions.
Summary of Best Smart Plugs for Remote Control
ProductIndoor/OutdoorConnectivityVoice ControlSpecial Features
Wyze Plug OutdoorOutdoorWiFi + BluetoothAlexaDual outlets, energy monitor, IP64 weather rating
Wyze PlugIndoorWiFiAlexa, Google, IFTTTCompact, multi-pack options, energy monitoring
Invest in a smart plug today to simplify your life and gain full control over your devices anytime, anywhere.
FeatureWyze Plug OutdoorWyze Plug
ColorBlackWhite
Weight7.2 Ounces5.3 oz
Dimensions4.0” x 2.8” x 1.4”2.7" x 2.0" x 1.5"
Weather ResistanceIP64 (Outdoor rated)Indoor use only
Operating EnvironmentIndoor, OutdoorIndoor only
Operating Temperature-4°F to 120°F-4°F to 104°F (-20°C to 40°C)
Input Voltage120V~, 60Hz100-120 VAC, 60Hz
Output15A Max with Overload Protection15A Max
Outlets21 (per plug)
Connectivity2.4GHz WiFi, Bluetooth V4.22.4GHz WiFi
WiFi RangeUp to 300 feetNot specified
Voice CommandsAlexaAlexa, Google Assistant, IFTTT
Energy MonitoringYesNo
Compatibility (OS)Android 5.0+, iOS 9.0+Android 5.0+, iOS 9.0+
CertificationsFCC, IC, ETLETL
Warranty1 Year1 Year
Pack Sizes & Price1 Pack - $15.99, 2 Pack - $34.982 Pack - $24.98, 4 Pack - $39.98
What are the best smart plugs for remote device control?The best smart plugs for remote device control include the Wyze Plug Outdoor for outdoor use and the Wyze Plug for indoor use. Both offer convenient remote control, scheduling, and energy monitoring features, making them ideal for automating and managing your devices from anywhere.
What features does the Wyze Plug Outdoor offer?The Wyze Plug Outdoor features a weather-resistant IP64 design, dual independently controlled outlets, energy monitoring, 2.4GHz WiFi and Bluetooth V4.2 connectivity, Alexa compatibility for voice control, and easy scheduling through the Wyze app. It is built to withstand rain, dust, and extreme temperatures, making it perfect for outdoor device automation.
Is the Wyze Plug Outdoor suitable for all weather conditions?Yes, the Wyze Plug Outdoor is rated IP64, making it resistant to rain and dust. It operates in temperatures ranging from -4°F to 120°F, ensuring reliable performance in various outdoor environments.
Can I control multiple devices with the Wyze Plug Outdoor?Yes, the Wyze Plug Outdoor has dual outlets that can be controlled independently, allowing you to manage two outdoor devices with a single smart plug.
What are the key benefits of using the Wyze Plug for indoor automation?The Wyze Plug is compact, energy efficient, and easy to install. It supports remote control, scheduling, and automation via the Wyze app, and integrates with Alexa, Google Assistant, and IFTTT for voice and smart home control. It is available in multi-pack options for whole-home coverage.
Does the Wyze Plug work with voice assistants?Yes, the Wyze Plug is compatible with Alexa, Google Assistant, and IFTTT, allowing you to control your indoor devices using voice commands or automation routines.
How do smart plugs help save energy?Smart plugs like the Wyze Plug and Wyze Plug Outdoor offer energy monitoring features that track power usage. This allows you to identify high-consumption devices and optimize their usage, helping to reduce electricity bills.
Can I schedule devices to turn on or off automatically with Wyze smart plugs?Yes, both the Wyze Plug and Wyze Plug Outdoor allow you to set schedules and timers through the Wyze app, enabling automatic control of your devices based on your daily routines.
What is the difference between Wyze Plug and Wyze Plug Outdoor?The Wyze Plug is designed for indoor use, is compact, and supports multiple voice assistants. The Wyze Plug Outdoor is built for outdoor environments, features a weather-resistant design, dual outlets, and energy monitoring, and is compatible with Alexa for voice control.
Why should I use a smart plug for remote device control?Smart plugs provide an easy way to automate and control your devices remotely, set schedules, monitor energy usage, integrate with voice assistants, and enhance home security by managing lights and appliances while you are away.
What are the key features of the Wyze Plug Outdoor?How does the energy monitoring feature work on the Wyze Plug?Are there any discounts or promotions currently available for smart plugs?
