Wyze Cam v4 Compatibility with Wyze Lamp Socket
If you're looking to enhance your home security setup with the Wyze Cam v4 and wondering about its compatibility with the Wyze Lamp Socket, this guide covers everything you need to know. The Wyze Cam v4 is a powerful, feature-rich security camera designed for both indoor and outdoor use, while the Wyze Lamp Socket offers a smart, convenient way to power your camera without relying on traditional plugs.
Wyze Cam v4: Advanced Security Camera Features
The Wyze Cam v4 is one of the clearest and most versatile cameras Wyze has ever produced. It offers:
- 2.5K Quad High Definition (QHD) Resolution: Capture crystal-clear images and videos with four times the detail of 1080p HD.
- Enhanced Color Night Vision: See vibrant colors even in low-light conditions, thanks to advanced hardware that outperforms traditional night vision.
- Wide Dynamic Range (WDR): Enjoy richer, more vibrant colors and better image quality in challenging lighting environments.
- IP65 Weather Resistance: Perfect for outdoor use, the camera withstands rain, snow, and dust.
- Motion-Activated Spotlight and 99 dB Siren: Deter intruders and light your way home with built-in safety features.
- Advanced Two-Way Talk: Clearer conversations with improved audio hardware.
- Continuous 24/7 Local Recording: Supports microSD cards up to 512GB for uninterrupted video capture without subscription fees.
- Wi-Fi 6 Support: Ensures a stronger, more reliable connection.
- Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT for seamless automation.
- Easy Setup: Bluetooth-enabled for hassle-free installation without QR codes.
- Mounting Flexibility: Magnetic base and multiple mounting options including wall, ceiling, and stand.
This camera is ideal for anyone wanting a high-quality, reliable security solution that works day and night, indoors or outdoors.
Wyze Cam v4 providing security with color night vision
Wyze Lamp Socket: Smart Power Solution for Wyze Cam v4
The Wyze Lamp Socket is designed to make your exterior lighting smart and to power Wyze Cam v3 and v4 cameras without needing a traditional plug outlet. Here’s why it’s a perfect companion for your Wyze Cam v4:
- Compatibility: Specifically made to power Wyze Cam v3 and v4 models.
- Convenient Power Source: Converts any standard E26 lamp socket into a power source for your camera.
- Motion-Activated Lights: Adds smart lighting that activates with motion detection.
- Dusk to Dawn Scheduling: Automatically controls lighting based on ambient light levels.
- Linkability: Can be linked with other Wyze devices for synchronized smart home control.
- Compact and Lightweight: Measures 56.5mm x 56.5mm x 65mm and weighs only 80 grams.
- Power Input: Standard 120V, 60Hz power supply.
- USB Type-A Port: Provides 5W/5V1A output for powering the camera.
- Connectivity: Supports 2.4GHz Wi-Fi and Bluetooth for easy setup and control.
- Operating Temperature: Suitable for damp locations with a range from -4°F to 120°F (-20°C to 50°C).
- Certifications: ETL, CETL, and UL certified for safety and reliability.
The Wyze Lamp Socket is not weatherproof or waterproof, so it’s best used in covered or damp locations rather than fully exposed outdoor environments.
This socket is an excellent solution if you want to power your Wyze Cam v4 in places where plug outlets are unavailable or inconvenient.
How Wyze Cam v4 and Wyze Lamp Socket Work Together
The Wyze Cam v4 and Wyze Lamp Socket are fully compatible, making it easy to set up your camera in new locations without worrying about power access. The lamp socket powers the camera directly from a standard light bulb socket, eliminating the need for additional wiring or outlets.
- Plug-and-Play Setup: Simply screw the Wyze Lamp Socket into your existing lamp fixture, then connect your Wyze Cam v4 to the socket’s USB port.
- Smart Lighting Integration: The motion-activated light feature of the lamp socket complements the camera’s security functions by illuminating areas when motion is detected.
- Ideal for Porches and Covered Outdoor Areas: Use this combo to secure entryways, patios, or garages where power outlets are scarce but lamp sockets are available.
This pairing enhances your home security system’s flexibility and convenience, allowing you to place your Wyze Cam v4 exactly where you need it most.
Wyze Cam v4 mounted outdoors, powered conveniently
Summary: Why Choose Wyze Cam v4 with Wyze Lamp Socket?
- Seamless Compatibility: Designed to work perfectly together for easy installation and reliable power.
- Enhanced Security: High-resolution video, color night vision, and motion-activated spotlight keep your home safe.
- Smart Power Solution: The lamp socket provides a flexible, smart way to power your camera without extra wiring.
- Weather-Ready Camera: IP65 rating means the camera can handle outdoor conditions, while the lamp socket is suited for damp, covered areas.
- Smart Home Integration: Both products support Alexa, Google Assistant, and Bluetooth for a connected home experience.
Upgrade your home security with the Wyze Cam v4 and power it smartly using the Wyze Lamp Socket for a hassle-free, effective setup.
Product Highlights
Wyze Cam v4
- 2.5K QHD video resolution
- IP65 weather resistance
- Motion-activated spotlight and siren
- Wi-Fi 6 and Bluetooth 5.2 support
- MicroSD card support up to 512GB
- Alexa, Google Assistant, IFTTT compatible
Wyze Lamp Socket
- Powers Wyze Cam v3 and v4
- Motion-activated lighting
- Dusk to dawn scheduling
- E26 socket connector
- USB Type-A output (5W/5V1A)
- Suitable for damp locations
- ETL, CETL, UL certified
Is the Wyze Cam v4 compatible with the Wyze Lamp Socket?
Yes, the Wyze Cam v4 is fully compatible with the Wyze Lamp Socket. The socket is specifically designed to power both Wyze Cam v3 and v4 models, making it easy to set up your camera in locations without traditional power outlets.How do I power my Wyze Cam v4 using the Wyze Lamp Socket?
To power your Wyze Cam v4 with the Wyze Lamp Socket, simply screw the lamp socket into any standard E26 light fixture, then connect your camera to the socket’s USB Type-A port. This setup eliminates the need for additional wiring or plug outlets.Can the Wyze Lamp Socket be used outdoors?
The Wyze Lamp Socket is suitable for damp or covered outdoor locations, such as porches or garages. However, it is not weatherproof or waterproof and should not be used in fully exposed outdoor environments.What are the main features of the Wyze Cam v4?
The Wyze Cam v4 offers 2.5K QHD video resolution, enhanced color night vision, wide dynamic range, IP65 weather resistance, motion-activated spotlight and siren, advanced two-way talk, continuous 24/7 local recording with microSD support up to 512GB, Wi-Fi 6, Bluetooth 5.2, and smart home integration with Alexa, Google Assistant, and IFTTT.What are the key features of the Wyze Lamp Socket?
The Wyze Lamp Socket powers Wyze Cam v3 and v4, offers motion-activated lighting, dusk to dawn scheduling, E26 socket compatibility, USB Type-A output (5W/5V1A), 2.4GHz Wi-Fi and Bluetooth support, and is ETL, CETL, and UL certified for safety. It is compact, lightweight, and suitable for damp locations.Can I use the Wyze Cam v4 and Wyze Lamp Socket for smart home automation?
Yes, both the Wyze Cam v4 and Wyze Lamp Socket support smart home integration. They are compatible with Alexa, Google Assistant, and IFTTT, allowing you to automate and control your security setup seamlessly.What is the installation process for the Wyze Cam v4 with the Wyze Lamp Socket?
Installation is simple: screw the Wyze Lamp Socket into your existing E26 lamp fixture, plug your Wyze Cam v4 into the socket’s USB port, and follow the Bluetooth-enabled setup process for the camera. No QR codes or complex wiring are required.Where is the best place to use the Wyze Cam v4 with the Wyze Lamp Socket?
The Wyze Cam v4 and Wyze Lamp Socket combination is ideal for covered outdoor areas such as porches, patios, entryways, and garages where power outlets are limited but lamp sockets are available.Does the Wyze Cam v4 require a subscription for continuous recording?
No, the Wyze Cam v4 supports continuous 24/7 local recording to a microSD card (up to 512GB) without the need for a subscription.What safety certifications does the Wyze Lamp Socket have?
The Wyze Lamp Socket is ETL, CETL, and UL certified, ensuring it meets high safety and reliability standards.
