Make Home Appliances Smart Without a Hub: Easy Wyze Solutions
How to Make Home Appliances Smart Without a Hub
Transforming your home appliances into smart devices without the need for a central hub is easier than ever. With Wi-Fi and Bluetooth-enabled smart products, you can control lighting, locks, plugs, and more directly from your smartphone or voice assistant. Below, discover a selection of Wyze smart devices designed to bring convenience, security, and energy efficiency to your home—all without requiring a separate hub.
Smart Lighting: Wyze Bulb Color
Vibrant, Versatile Lighting Control
The Wyze Bulb Color is a powerful smart lighting solution that offers up to 16 million colors and tunable white light, allowing you to customize your home ambiance effortlessly. Whether you want bright, energizing light or a cozy, dimmed atmosphere, this bulb adapts to your mood and needs.
  • Brightness: Extra bright at 1100 lumens
  • Color Range: 16 million colors with tunable white (1800K - 6500K)
  • Connectivity: Dual-band Wi-Fi (2.4GHz) and Bluetooth for seamless control
  • Compatibility: Works with Alexa, Google Assistant, and IFTTT
  • Energy Efficient: Consumes only 12 watts with a lifespan of 25,000 hours
  • Installation: Fits standard E26 sockets, perfect for lamps and ceiling fixtures
  • Suitable for Damp Locations: Ideal for kitchens and bathrooms (not enclosed luminaires)
Control your lighting directly from your phone or voice commands without any hub, making it a simple upgrade for any room. Wyze Bulb Color in Living Room
Secure Your Home: Wyze Lock Bolt
Keyless Entry with Ultra-Fast Fingerprint Access
Say goodbye to fumbling for keys with the Wyze Lock Bolt, a Bluetooth smart lock that replaces your existing deadbolt. It features a backlit keypad and an ultra-fast fingerprint reader for quick, secure access.
  • Access Methods: Fingerprint, keypad code, or app control
  • Auto-Lock: Automatically locks your door if you forget
  • Security Features: Built-in alarm for jam detection and lock/unlock history tracking
  • Battery Life: Powered by 4 AA batteries lasting 10-12 months
  • Weather Resistance: IPX5 rating for durability in various climates
  • Installation: Fits standard door thicknesses and backsets, replacing your deadbolt easily
  • Range: Bluetooth 5.0 with up to 16 feet connectivity
Control and monitor your door remotely without a hub, ensuring your home is both smart and secure. Wyze Lock Bolt Lifestyle
Smart Power Control: Wyze Plug & Wyze Plug Outdoor
Indoor and Outdoor Smart Plugs for Effortless Automation
Make any appliance smart with the Wyze Plug and Wyze Plug Outdoor. These plugs connect directly to your Wi-Fi network, allowing you to control devices from anywhere via the Wyze app or voice assistants.
Wyze Plug (Indoor)
  • Connectivity: 2.4GHz Wi-Fi
  • Compatibility: Android 5.0+, iOS 9.0+, Alexa, Google Assistant, IFTTT
  • Power Rating: 15A max output
  • Use Case: Ideal for lamps, fans, coffee makers, and other indoor appliances
  • Size Options: Available in 2-pack or 4-pack sets
  • Operating Temperature: -4°F to 104°F
Wyze Plug Outdoor
  • Weatherproof: IP64 rating for rain or shine use
  • Connectivity: 2.4GHz Wi-Fi and Bluetooth V4.2
  • Power Rating: 15A max with overload protection
  • Range: Wi-Fi up to 300 feet
  • Features: Energy monitoring, scheduling, and voice control via Alexa
  • Use Case: Perfect for garden lights, holiday decorations, and outdoor appliances
Both plugs enable you to schedule, monitor energy usage, and control devices remotely without a hub, making your home smarter and more energy-efficient. Wyze Plug Indoor Lifestyle
Enhance Air Quality: Wyze Air Filter
Customizable Air Purification for Your Home
Breathe easier with the Wyze Air Filter, designed to fit Wyze Air Purifiers and tailored to your specific air quality needs. Choose from allergen, formaldehyde, or wildfire filters to combat pollutants, odors, and harmful gases.
  • Filter Types: Allergen (HEPA 13), Formaldehyde (Premium), Wildfire (Special Use)
  • Efficiency: Removes up to 99% of viruses and bacteria
  • Activated Carbon: Included for odor and gas absorption
  • Service Life: 4 to 12 months depending on filter type
  • Dimensions: Compact and easy to replace
This smart air filter works seamlessly with your Wyze Air Purifier, controllable via app without any hub, ensuring your indoor air stays fresh and healthy.
Clean Smarter: Wyze Cordless Vacuum S
Powerful, Cord-Free Cleaning with Smart Features
Upgrade your cleaning routine with the Wyze Cordless Vacuum S, a lightweight and powerful vacuum that offers smart convenience without a hub.
  • Suction Power: Up to 20,000 Pa in Turbo Mode
  • Battery Life: Up to 40 minutes in ECO mode with interchangeable lithium-ion battery
  • Weight: Only 2.8 lbs for easy maneuverability
  • Features: Dual motors, LED screen, 3-stage filtration, and 6 LED lights on brush head
  • Attachments: Includes crevice tool, floor brush, HEPA filter, and more
Control your vacuum with the Wyze app for scheduling and monitoring, making home cleaning smarter and more efficient. Wyze Cordless Vacuum Lifestyle
Conclusion
Making your home appliances smart without a hub is simple with Wyze’s range of Wi-Fi and Bluetooth-enabled devices. From vibrant smart bulbs and secure locks to versatile plugs and air filters, these products offer direct app and voice control, eliminating the need for additional hubs. Upgrade your home today with smart solutions that are easy to install, affordable, and designed to enhance your lifestyle.
FeatureWyze Bulb ColorWyze Lock BoltWyze PlugWyze Plug Outdoor
TypeSmart LightingConnected Home (Smart Lock)Connected Home (Smart Plug)Connected Home (Outdoor Smart Plug)
Price Range$26.26 (2 Pack) - $64.98 (6 Pack)$79.98$24.98 (2 Pack) - $39.98 (4 Pack)$15.99 (1 Pack) - $34.98 (2 Pack)
ColorWhiteMatte Black, Satin NickelWhiteBlack
ConnectivityWiFi (2.4GHz), BluetoothBluetoothWiFi (2.4GHz)WiFi (2.4GHz), Bluetooth V4.2
Voice ControlAlexa, Google AssistantNo Alexa/Google supportAlexa, Google Assistant, IFTTTAlexa
DimmableYesN/AN/AN/A
Color Options16 million colorsN/AN/AN/A
Lumen Output30 lm - 1100 lmN/AN/AN/A
Power75W equivalent4 AA Batteries (up to 12 months battery life)100-120 VAC, 60Hz input, 15A max output120V~, 60Hz input, 15A max output with overload protection
Weather ResistanceIndoor onlyIPX5 (weatherproof)Indoor use onlyIP64 (weather resistant)
Operating Temperature-4°F to 104°FNot specified-4°F to 104°F-4°F to 120°F
Special FeaturesCustom presets, white light control, music sync, notifications, sleep routinesFingerprint sensor, backlit keypad, auto-lock, anti-peep tech, pick-proofMake devices smart, app controlOutdoor use, energy monitoring, app control, scheduling
DimensionsNot specifiedNot specified2.7" x 2.0" x 1.5"4.0" x 2.8" x 1.4"
Warranty30-day hassle-free returns30-day hassle-free returns1 Year1 Year
How can I make my home appliances smart without a hub?You can make your home appliances smart without a hub by using Wi-Fi and Bluetooth-enabled devices like Wyze smart bulbs, locks, plugs, air filters, and vacuums. These products connect directly to your smartphone or voice assistant, allowing you to control and automate your home without the need for a central hub.
What is the Wyze Bulb Color and how does it work?The Wyze Bulb Color is a smart LED bulb that offers up to 16 million colors and tunable white light (1800K - 6500K). It connects via dual-band Wi-Fi (2.4GHz) and Bluetooth, allowing you to control lighting directly from your phone or with voice assistants like Alexa and Google Assistant. No hub is required for setup or operation.
Is the Wyze Bulb Color energy efficient?Yes, the Wyze Bulb Color is energy efficient, consuming only 12 watts while providing up to 1100 lumens of brightness. It also has a long lifespan of up to 25,000 hours, making it a cost-effective smart lighting solution.
Can I control Wyze smart devices with Alexa or Google Assistant?Yes, most Wyze smart devices, including the Wyze Bulb Color and Wyze Plug, are compatible with Alexa and Google Assistant. This allows you to control your devices using simple voice commands without needing a hub.
What features does the Wyze Lock Bolt offer for home security?The Wyze Lock Bolt is a Bluetooth-enabled smart lock that provides keyless entry via fingerprint, keypad code, or app control. It features an ultra-fast fingerprint reader, auto-lock function, built-in alarm for jam detection, and lock/unlock history tracking. It is weather-resistant and easy to install, replacing your existing deadbolt.
How do Wyze smart plugs work for indoor and outdoor appliances?Wyze Plug (indoor) and Wyze Plug Outdoor connect directly to your Wi-Fi network, allowing you to control, schedule, and monitor energy usage of your appliances from anywhere using the Wyze app or voice assistants. The outdoor version is weatherproof (IP64 rated) and ideal for garden lights and outdoor devices.
Do Wyze smart plugs require a hub to operate?No, Wyze smart plugs do not require a hub. They connect directly to your Wi-Fi network, enabling remote control and automation through the Wyze app or compatible voice assistants.
What types of air filters are available for the Wyze Air Purifier?Wyze offers three types of air filters for its air purifier: Allergen (HEPA 13), Formaldehyde (Premium), and Wildfire (Special Use). Each filter is designed to target specific air quality concerns, removing up to 99% of viruses and bacteria and absorbing odors and harmful gases with activated carbon.
How long do Wyze Air Filters last?Wyze Air Filters have a service life of 4 to 12 months, depending on the filter type and usage. They are easy to replace and help maintain clean indoor air quality.
What are the key features of the Wyze Cordless Vacuum S?The Wyze Cordless Vacuum S is a lightweight, powerful vacuum with up to 20,000 Pa suction in Turbo Mode, a 40-minute battery life in ECO mode, dual motors, an LED screen, 3-stage filtration, and 6 LED lights on the brush head. It includes multiple attachments and can be controlled and monitored via the Wyze app.
Can I control Wyze devices remotely without a hub?Yes, Wyze devices such as bulbs, plugs, locks, air filters, and vacuums can be controlled remotely through the Wyze app or compatible voice assistants, all without the need for a separate hub.
Are Wyze smart devices easy to install?Yes, Wyze smart devices are designed for easy installation. For example, the Wyze Bulb Color fits standard E26 sockets, the Wyze Lock Bolt replaces standard deadbolts, and Wyze Plugs simply plug into existing outlets. No hub or complex setup is required.
What are the installation requirements for the Wyze Bulb Color?Can the Wyze Lock Bolt be controlled remotely through an app?How does the Wyze Plug help in energy monitoring?
