Wyze Cam v4 vs Wyze Cam v3 Pro: Key Differences and Features
When choosing a smart security camera, understanding the differences between the Wyze Cam v4 and the Wyze Cam v3 Pro is essential. Both models offer impressive features, but the Wyze Cam v4 brings several upgrades that make it stand out as the latest and most advanced option from Wyze.
Wyze Cam v4: The Latest in Smart Home Security
Superior Video Quality and Night Vision
Wyze Cam v4 delivers crystal-clear 2.5K Quad High Definition (QHD) resolution, providing sharper and more detailed images compared to previous models. It features
Enhanced Color Night Vision, which uses upgraded hardware to capture vibrant colors even in low-light conditions—something traditional night vision cannot achieve.
Advanced Image Processing
Thanks to an upgraded image processor, the v4 supports
Wide Dynamic Range (WDR), which enhances the camera’s ability to handle varying lighting conditions. This results in more vibrant colors and better image quality, whether indoors or outdoors.
Weather Resistance and Outdoor Use
With an
IP65 weather resistance rating, the Wyze Cam v4 is built to withstand rain, dust, and other outdoor elements, making it a versatile choice for both indoor and outdoor security.
Enhanced Audio and Safety Features
The camera includes
Advanced Audio Coding (AAC) for clearer two-way talk, a louder
99 dB siren, and a
motion-activated spotlight to deter intruders or light your path at night.
Smart Connectivity and Convenience
Wyze Cam v4 supports
Wi-Fi 6, ensuring a stronger and more reliable connection. It also integrates seamlessly with smart assistants like
Amazon Alexa,
Google Assistant, and
IFTTT for voice control and automation.
Local Storage and Continuous Recording
The camera supports
24/7 local recording to a microSD card up to 512GB (sold separately), allowing continuous video capture without a subscription.
"Wyze Cam v4 is the clearest Wyze Cam ever, with superhero vision in the dark."
Alt text: Family using Wyze Cam v4 for home security at night
Wyze Cam v3 Pro: Reliable Performance with Great Features
High-Resolution Video
Wyze Cam v3 Pro also offers
2.5K resolution, matching the clarity of the v4, but without some of the latest enhancements in image processing.
Color Night Vision and Spotlight
It features
Color Night Vision and a
motion-activated spotlight, similar to the v4, but the spotlight and siren are slightly less powerful (89 dB siren compared to 99 dB on v4).
Weatherproof Design
The v3 Pro is designed for outdoor use with weather resistance, though the v4’s IP65 rating provides a more robust protection level.
Storage and Connectivity
Supports microSD cards up to 256GB for local storage and offers advanced motion and sound detection. However, it lacks Wi-Fi 6 support, which means the connection may not be as strong or future-proof as the v4.
Additional Accessories to Enhance Your Wyze Cam Experience
Wyze Cam USB Extension Cable - 20ft
Extend your camera’s reach with this 20ft USB extension cable compatible with both Wyze Cam v4 and v3 Pro. It allows flexible placement without worrying about proximity to power outlets.
Lamp Socket v2 Bundle
Power your Wyze Cam v4 or v3 Pro directly from a lamp socket with this smart accessory. It supports motion-activated lighting and dusk-to-dawn scheduling, making your exterior lighting smarter and more convenient.
Which Should You Choose?
Feature | Wyze Cam v4 | Wyze Cam v3 Pro |
Resolution | 2.5K QHD with WDR | 2.5K QHD |
Night Vision | Enhanced Color Night Vision | Color Night Vision |
Weather Resistance | IP65 (better for outdoors) | Weather-resistant |
Spotlight | Motion-activated, brighter (99 dB siren) | Motion-activated, 89 dB siren |
Audio | Advanced Audio Coding (AAC) | Two-Way Talk |
Wi-Fi Support | Wi-Fi 6 | Wi-Fi 5 (no Wi-Fi 6) |
MicroSD Card Support | Up to 512GB | Up to 256GB |
Smart Assistant Integration | Alexa, Google Assistant, IFTTT | Alexa, Google Assistant, IFTTT |
If you want the latest technology with superior night vision, stronger connectivity, and more robust weather resistance, the
Wyze Cam v4 is the best choice. For a solid, reliable camera with great features at a potentially lower price point, the
Wyze Cam v3 Pro remains a strong contender.
Summary
Both Wyze Cam v4 and Wyze Cam v3 Pro offer excellent 2.5K video quality and color night vision, but the v4 pushes the envelope with enhanced image processing, Wi-Fi 6 support, a louder siren, and better weatherproofing. Accessories like the USB extension cable and lamp socket bundle further enhance flexibility and convenience for your smart home setup.
Investing in the Wyze Cam v4 means getting the clearest, most feature-rich Wyze camera yet, designed to keep your home safe day and night with cutting-edge technology.
Alt text: Wyze Cam v4 Outdoor Bundle installed on a porch
Alt text: Smart home devices including Wyze Cam and accessories in living room
What are the main differences between Wyze Cam v4 and Wyze Cam v3 Pro?
The Wyze Cam v4 features 2.5K QHD resolution with Wide Dynamic Range (WDR), enhanced color night vision, IP65 weather resistance, Wi-Fi 6 support, a louder 99 dB siren, advanced audio coding (AAC), and supports microSD cards up to 512GB. The Wyze Cam v3 Pro also offers 2.5K resolution and color night vision but lacks WDR, has a less powerful 89 dB siren, supports microSD cards up to 256GB, and does not support Wi-Fi 6.Does Wyze Cam v4 have better night vision than Wyze Cam v3 Pro?
Yes, Wyze Cam v4 offers enhanced color night vision with upgraded hardware, allowing it to capture vibrant colors even in low-light conditions. This provides clearer and more detailed images at night compared to the Wyze Cam v3 Pro.Is Wyze Cam v4 weatherproof for outdoor use?
Yes, Wyze Cam v4 has an IP65 weather resistance rating, making it suitable for both indoor and outdoor use. It is designed to withstand rain, dust, and other outdoor elements.What is the maximum microSD card size supported by Wyze Cam v4 and v3 Pro?
Wyze Cam v4 supports microSD cards up to 512GB for continuous 24/7 local recording, while Wyze Cam v3 Pro supports microSD cards up to 256GB.Does Wyze Cam v4 support Wi-Fi 6?
Yes, Wyze Cam v4 supports Wi-Fi 6, providing a stronger and more reliable wireless connection compared to previous models. Wyze Cam v3 Pro does not support Wi-Fi 6.Can I use smart assistants with Wyze Cam v4 and v3 Pro?
Both Wyze Cam v4 and Wyze Cam v3 Pro are compatible with Amazon Alexa, Google Assistant, and IFTTT, allowing for voice control and smart home automation.What accessories are available for Wyze Cam v4 and v3 Pro?
Accessories include a 20ft Wyze Cam USB extension cable for flexible camera placement and the Lamp Socket v2 Bundle, which allows you to power your camera from a lamp socket and supports motion-activated lighting and dusk-to-dawn scheduling. Both accessories are compatible with Wyze Cam v4 and v3 Pro.Which Wyze Cam is better for outdoor security: v4 or v3 Pro?
Wyze Cam v4 is better suited for outdoor security due to its IP65 weather resistance, enhanced color night vision, brighter motion-activated spotlight, and louder 99 dB siren.Does Wyze Cam v4 require a subscription for continuous recording?
No, Wyze Cam v4 supports 24/7 continuous local recording to a microSD card (up to 512GB) without the need for a subscription.What audio features does Wyze Cam v4 offer?
Wyze Cam v4 features Advanced Audio Coding (AAC) for clearer two-way talk and includes a louder 99 dB siren for enhanced security.
