Wyze Cam Pan v2 vs v3: Key Differences & Upgrades Explained
Wyze Cam Pan v2 vs Wyze Cam Pan v3 Differences
When choosing a smart security camera, understanding the key differences between models is essential. The Wyze Cam Pan v2 and the Wyze Cam Pan v3 are both popular options, but the v3 brings significant upgrades that make it a more versatile and powerful choice for home and outdoor security. Below, we break down the main differences and highlight why the Wyze Cam Pan v3 stands out.
Wyze Cam Pan v3: The Next Generation Pan & Tilt Camera
Weatherproof Design for Indoor & Outdoor Use
One of the biggest upgrades from the Pan v2 to the Pan v3 is the weather resistance. The Wyze Cam Pan v3 is fully IP65 rated, meaning it can withstand rain, snow, and other outdoor elements when paired with the Wyze Outdoor Power Adapter (sold separately). This makes it perfect for both indoor and outdoor security monitoring.
Unlike the Pan v2, which is designed primarily for indoor use, the Pan v3 expands your security coverage to the outdoors without worry.
Wyze Cam Pan v3 in snowy outdoor setting Wyze Cam Pan v3 is built to brave the elements with IP65 weather resistance.
Enhanced Pan and Tilt Range
The Pan v3 offers a 360° horizontal pan and an impressive 180° vertical tilt, doubling the tilt range compared to the Pan v2. This means the camera can look straight up and down, covering more angles and eliminating blind spots.
This expanded tilt range allows you to monitor entire rooms or outdoor areas with fewer cameras.
Quieter and Smarter Motion Tracking
Wyze Cam Pan v3 features an upgraded tracking motor that is quieter than the Pan v2, ensuring it won’t disturb sleeping babies or pets. It automatically detects motion, follows the movement, and records it, providing detailed security footage without manual control.
Privacy Mode
A new privacy feature lets you instantly disable the camera’s view by spinning it 180° downward, effectively turning off the lens. This is perfect for moments when you want to relax without being watched.
Color Night Vision with Starlight Sensor
Both cameras offer night vision, but the Pan v3 includes advanced Color Night Vision powered by a Starlight Sensor, delivering clearer and more detailed images in low light conditions compared to the Pan v2’s standard night vision.
Two-Way Audio
The Pan v3 supports two-way audio, allowing you to listen and speak through the camera via the Wyze app. This feature is great for communicating with family members or pets remotely. Two-way audio with Wyze Cam Pan v3 Communicate easily with two-way audio on Wyze Cam Pan v3.
App Features and Smart Alerts
Wyze Cam Pan v3 is packed with smart app features including:
  • Pan Scan™: Set up to 4 custom waypoints for automatic patrol routes.
  • Custom Detection Zones: Receive alerts only from specific areas.
  • Sound and Motion Detection: Instant notifications for movement or sounds.
  • Smoke and Carbon Monoxide Alerts: Get notified if alarms go off.
  • Cam Plus Compatibility: Unlock advanced detection like person, package, and vehicle notifications with a subscription.
Wyze Cam Pan v3 + 30-Day Cam Plus Bundle
For those wanting to maximize their security experience, the Wyze Cam Pan v3 is also available bundled with a 30-day free trial of Cam Plus. This subscription service enhances your camera’s capabilities with unlimited event video cloud storage and smarter notifications.
Summary of Key Differences
FeatureWyze Cam Pan v2Wyze Cam Pan v3
Weather ResistanceIndoor use onlyIP65 rated for indoor/outdoor use
Pan Range360°360°
Tilt Range~90°180° (double tilt coverage)
Motion Tracking MotorStandard noiseQuieter, improved tracking motor
Night VisionBlack & whiteColor Night Vision with Starlight Sensor
Privacy ModeNoYes
Two-Way AudioYesYes
Smart App FeaturesBasicAdvanced with Pan Scan™, custom zones, smoke/CO alerts
Cam Plus CompatibilityYesYes, with bundle option
Accessories for Wyze Cam Pan v3
To complement your Wyze Cam Pan v3, consider these accessories:
  • Wyze Outdoor Power Adapter: Required for safe outdoor use.
  • Wyze Cam Pan v3 Skins by dBrand: Stylish vinyl skins to protect and personalize your camera.
  • Wyze Cam Pan v3 USB Cable: Replacement cable for convenience.
  • Wyze Cam USB Extension Cable (20ft): Extend your camera’s reach for flexible placement.
  • Wyze Lamp Socket v2: Power your camera through exterior lighting fixtures without needing a power outlet.
Conclusion
Upgrading from the Wyze Cam Pan v2 to the Pan v3 means gaining a weatherproof, more versatile camera with enhanced tilt range, quieter motion tracking, and advanced smart features. Whether you want to monitor your home indoors or keep an eye on your property outside, the Wyze Cam Pan v3 offers a comprehensive security solution with excellent value.
FeatureWyze Cam Pan v3Wyze Cam Pan v3 + 30-Day Cam Plus Bundle
Camera TypeIndoor/Outdoor Pan & Tilt Security CamIndoor/Outdoor Pan & Tilt Security Cam
Pan & Tilt Range360° pan, 180° tilt360° pan, 180° tilt
Weather ResistanceIP65 ratedIP65 rated
Outdoor Use RequirementRequires Wyze Outdoor Power Adapter (sold separately)Requires Wyze Outdoor Power Adapter (sold separately)
Motion TrackingAutomatic motion tracking with quiet motorAutomatic motion tracking with quiet motor
Privacy ModeYesYes
Two-Way AudioYesYes
Color Night VisionYes, with Starlight SensorYes, with Starlight Sensor
App FeaturesPan Scan™ waypoints, motion & sound detection, custom detection zones, smoke & CO alertsSame as Wyze Cam Pan v3 plus Cam Plus features
Cam Plus SubscriptionOptional, paid separatelyIncluded free for 30 days, then auto-renews at $2.99/month/cam
Cloud Storage14-day free cloud storageUnlimited event video cloud storage during free trial
Advanced NotificationsBasic motion and sound alertsAdvanced notifications (person, package, vehicle, crying baby, barking pet)
Price$39.98 (single pack)$39.98 (includes 30-day Cam Plus trial)
Color VariantsBlack, WhiteBlack, White
Pack Options1 Pack, 2 Pack, 3 PackSingle unit only
Return Policy30-day hassle-free returns30-day hassle-free returns
What are the main differences between Wyze Cam Pan v2 and Wyze Cam Pan v3?The Wyze Cam Pan v3 offers several upgrades over the Pan v2, including IP65 weather resistance for indoor and outdoor use, a doubled 180° vertical tilt range, quieter and improved motion tracking, advanced color night vision with a Starlight Sensor, a new privacy mode, and enhanced smart app features like Pan Scan™, custom detection zones, and smoke/CO alerts.
Is the Wyze Cam Pan v3 weatherproof?Yes, the Wyze Cam Pan v3 is IP65 rated for weather resistance, making it suitable for both indoor and outdoor use when paired with the Wyze Outdoor Power Adapter (sold separately).
Can I use Wyze Cam Pan v2 outdoors?No, the Wyze Cam Pan v2 is designed primarily for indoor use and does not have weather resistance. For outdoor monitoring, the Wyze Cam Pan v3 is recommended.
How does the tilt range of Wyze Cam Pan v3 compare to Pan v2?The Wyze Cam Pan v3 features a 180° vertical tilt range, which is double the tilt coverage of the Pan v2’s approximately 90°. This allows the v3 to cover more angles and eliminate blind spots.
Does Wyze Cam Pan v3 have color night vision?Yes, the Wyze Cam Pan v3 is equipped with advanced color night vision powered by a Starlight Sensor, providing clearer and more detailed images in low light compared to the Pan v2’s standard black and white night vision.
What is the privacy mode on Wyze Cam Pan v3?The privacy mode on the Wyze Cam Pan v3 allows you to instantly disable the camera’s view by spinning the lens 180° downward, ensuring privacy whenever you need it.
Does Wyze Cam Pan v3 support two-way audio?Yes, the Wyze Cam Pan v3 supports two-way audio, allowing you to listen and speak through the camera using the Wyze app.
What smart features are available on Wyze Cam Pan v3?The Wyze Cam Pan v3 offers advanced smart features such as Pan Scan™ for automatic patrol routes, custom detection zones, sound and motion detection, smoke and carbon monoxide alerts, and compatibility with Cam Plus for enhanced notifications.
What is included in the Wyze Cam Pan v3 + 30-Day Cam Plus Bundle?The Wyze Cam Pan v3 + 30-Day Cam Plus Bundle includes the camera and a 30-day free trial of Cam Plus, which provides unlimited event video cloud storage and smarter notifications like person, package, and vehicle detection.
What accessories are available for Wyze Cam Pan v3?Accessories for the Wyze Cam Pan v3 include the Wyze Outdoor Power Adapter (required for outdoor use), Wyze Cam Pan v3 Skins by dBrand, Wyze Cam Pan v3 USB Cable, Wyze Cam USB Extension Cable (20ft), and the Wyze Lamp Socket v2 for flexible power options.
What are the specific smart app features available with the Wyze Cam Pan v3?Can you explain how the Color Night Vision works on the Wyze Cam Pan v3?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Cam Pan v3?
