Wyze Cam v3 vs Wyze Cam v4 Differences: Comprehensive Comparison
When choosing between the Wyze Cam v3 and the newer Wyze Cam v4, understanding their key differences is essential to pick the right security camera for your home or business. Both models offer excellent features, but the Wyze Cam v4 introduces several upgrades that enhance performance, connectivity, and versatility.
Below, we break down the main specifications and features of the Wyze Cam v4 and highlight how it compares to the Wyze Cam v3, helping you make an informed decision.
Wyze Cam v4: Advanced Features and Specifications
The Wyze Cam v4 is a significant upgrade over the v3, designed to deliver superior video quality, smarter connectivity, and enhanced night vision capabilities.
Key Specifications of Wyze Cam v4
- Video Resolution: 2.5K QHD (2560x1440) for crystal-clear footage, surpassing the 1080p HD of Wyze Cam v3.
- Sensor: CMOS Starlight Sensor, optimized for low-light environments.
- Field of View: Wide angles with 115.8° diagonal, 98.5° horizontal, and 53.1° vertical.
- Night Vision: Enhanced Color Night Vision with 4 IR LEDs (850 nm) plus 2 white spotlight LEDs (72 lumens), enabling vivid color footage even in darkness.
- Video Frame Rate: 20 FPS during daytime and 15 FPS at night.
- Connectivity: Supports both 2.4 GHz Wi-Fi and Wi-Fi 6, offering faster and more reliable connections.
- Audio: 99dB waterproof speaker with simultaneous two-way talk and built-in siren.
- Mounting Options: Versatile mounting including stand, wall, ceiling, and magnetic adhesive mounts.
- Weather Resistance: Rated IP65, suitable for indoor and outdoor use.
- Storage: Supports microSD cards up to 512 GB for local storage, plus optional cloud storage with subscription.
- Compatibility: Works seamlessly with Alexa, Google Assistant, and IFTTT.
- Power: Powered via a 6-foot flat micro USB to USB-A cable; outdoor power adapter sold separately.
The Wyze Cam v4 is designed to provide unmatched security with enhanced video clarity and smart features, making it ideal for both indoor and outdoor surveillance.
Enhanced outdoor security with Wyze Cam v4
What’s New in Wyze Cam v4 Compared to Wyze Cam v3?
1. Superior Video Quality and Night Vision
Wyze Cam v4 upgrades the video resolution to 2.5K QHD, delivering sharper and more detailed images than the 1080p HD of the v3. The addition of enhanced color night vision with spotlight LEDs allows the v4 to capture vibrant color footage even in low-light or nighttime conditions, a feature that the v3 lacks.
2. Improved Connectivity with Wi-Fi 6 Support
While Wyze Cam v3 supports 2.4 GHz Wi-Fi, the v4 adds Wi-Fi 6 compatibility, providing faster data transfer, reduced latency, and better performance in congested networks.
3. Enhanced Audio and Security Features
The v4 includes a louder 99dB waterproof speaker, improved two-way talk with noise and echo cancellation, and a built-in siren for deterrence. These audio improvements offer clearer communication and stronger security alerts.
4. Weather Resistance and Mounting Flexibility
Both cameras are weather-resistant, but the v4’s IP65 rating ensures better protection against dust and water, making it more reliable for outdoor use. The v4 also offers multiple mounting options including magnetic mounts for easier installation.
5. Smarter Integration and Storage Options
Wyze Cam v4 supports local microSD storage up to 512 GB and cloud storage with subscription plans, similar to the v3 but with expanded capacity. It also integrates smoothly with Alexa, Google Assistant, and IFTTT for smart home automation.
Wyze Cam v4 Bundles: Outdoor and Home Security Solutions
For users looking for complete security setups, Wyze offers specialized bundles featuring the Wyze Cam v4.
Wyze Cam v4 Outdoor Bundle
- Includes Wyze Cam v4, Wyze Outdoor Power Adapter, and a 128GB microSD card.
- Designed specifically for outdoor use with wired power for continuous operation.
- Features motion and sound detection, motion detection zones, and smoke/CO alerts.
- Supports Wi-Fi 6 and smart assistant compatibility.
- Price-friendly option for robust outdoor security.
- Combines multiple Wyze Cam v4 units with enhanced 2-way audio.
- Suitable for both indoor and outdoor use with IP65 weather resistance.
- Includes motion-activated spotlight and person detection for smarter alerts.
- Comes with a 128GB Class 10 UHS-3 microSD card for extensive local recording.
- Ideal for comprehensive home security coverage.
Wyze Cam v4 monitoring an indoor playroom
Summary: Should You Upgrade to Wyze Cam v4?
If you currently own a Wyze Cam v3 and are considering an upgrade, the v4 offers meaningful improvements in video quality, night vision, connectivity, and audio features. Its enhanced weather resistance and flexible mounting options make it a versatile choice for both indoor and outdoor security.
For new buyers, the Wyze Cam v4 provides a future-proof security camera with Wi-Fi 6 support and smart home integrations, ensuring reliable performance and convenience.
Additional Accessories for Wyze Cam v3 and v4
To maximize your Wyze Cam experience, consider these accessories:
- Wyze Lamp Socket: Powers Wyze Cam v3 and v4 without a plug, adding motion-activated lighting and dusk-to-dawn scheduling for smarter exterior lighting.
- Wyze Cam USB Extension Cable (20ft): Extends your camera’s reach for flexible placement indoors or outdoors.
Wyze continues to innovate with the Cam v4, delivering enhanced security features and smart home compatibility that outshine the v3, making it the preferred choice for modern home surveillance.
What are the main differences between Wyze Cam v3 and Wyze Cam v4?
The Wyze Cam v4 offers several upgrades over the Wyze Cam v3, including higher 2.5K QHD video resolution, enhanced color night vision with spotlight LEDs, Wi-Fi 6 support for faster connectivity, a louder 99dB waterproof speaker with improved two-way talk, and more flexible mounting options. The v4 also supports larger microSD cards (up to 512GB) and has an improved IP65 weather resistance rating.Does Wyze Cam v4 have better video quality than Wyze Cam v3?
Yes, Wyze Cam v4 features a 2.5K QHD (2560x1440) video resolution, which provides sharper and more detailed footage compared to the 1080p HD resolution of the Wyze Cam v3.How does night vision compare between Wyze Cam v3 and v4?
Wyze Cam v4 offers enhanced color night vision with 4 IR LEDs and 2 white spotlight LEDs, allowing it to capture vivid color footage even in low-light or nighttime conditions. This is a significant improvement over the night vision capabilities of the Wyze Cam v3.What connectivity options does Wyze Cam v4 support?
Wyze Cam v4 supports both 2.4 GHz Wi-Fi and Wi-Fi 6, providing faster data transfer, reduced latency, and better performance in congested networks. Wyze Cam v3 only supports 2.4 GHz Wi-Fi.Is Wyze Cam v4 suitable for outdoor use?
Yes, Wyze Cam v4 is rated IP65 for weather resistance, making it suitable for both indoor and outdoor use. It is designed to withstand dust and water, ensuring reliable performance in various environments.What are the audio features of Wyze Cam v4?
Wyze Cam v4 includes a 99dB waterproof speaker, improved two-way talk with noise and echo cancellation, and a built-in siren for security alerts. These features provide clearer communication and stronger deterrence compared to the v3.What storage options are available for Wyze Cam v4?
Wyze Cam v4 supports local storage with microSD cards up to 512GB and offers optional cloud storage through subscription plans. This allows for extensive local recording and flexible storage solutions.Does Wyze Cam v4 work with smart home assistants?
Yes, Wyze Cam v4 is compatible with Alexa, Google Assistant, and IFTTT, allowing for seamless integration with your smart home devices and automation routines.What mounting options are available for Wyze Cam v4?
Wyze Cam v4 offers versatile mounting options, including stand, wall, ceiling, and magnetic adhesive mounts, making installation easy and flexible for different locations.What is included in the Wyze Cam v4 Outdoor Bundle?
The Wyze Cam v4 Outdoor Bundle includes a Wyze Cam v4, Wyze Outdoor Power Adapter, and a 128GB microSD card. It is designed for outdoor use with continuous wired power and features motion and sound detection, motion detection zones, smoke/CO alerts, and Wi-Fi 6 support.What is included in the Wyze Cam v4 Home Security Bundle?
The Wyze Cam v4 Home Security Bundle combines multiple Wyze Cam v4 units with enhanced two-way audio, motion-activated spotlight, person detection, and a 128GB Class 10 UHS-3 microSD card. It is suitable for both indoor and outdoor use, providing comprehensive home security coverage.Are there accessories available for Wyze Cam v3 and v4?
Yes, accessories such as the Wyze Lamp Socket (for motion-activated lighting and dusk-to-dawn scheduling) and the Wyze Cam USB Extension Cable (20ft) are available to enhance the functionality and placement flexibility of both Wyze Cam v3 and v4.Should I upgrade from Wyze Cam v3 to Wyze Cam v4?
If you want improved video quality, enhanced night vision, better connectivity with Wi-Fi 6, superior audio features, and more flexible mounting options, upgrading to Wyze Cam v4 is recommended. It offers future-proof features and better performance for both indoor and outdoor security.
