Wyze Cam v3 Pro vs v4: Full Feature & Specs Comparison
Wyze Cam v3 Pro vs Wyze Cam v4: Comprehensive Comparison
When choosing between the Wyze Cam v3 Pro and the Wyze Cam v4, understanding their key features, specifications, and performance differences is essential. Both cameras offer excellent home security solutions, but they cater to slightly different needs and preferences. This guide breaks down the specs and highlights to help you decide which Wyze camera fits your lifestyle best.
Wyze Cam v3 Pro: Reliable and Versatile Security
Design and Build
The Wyze Cam v3 Pro features a robust polycarbonate body with a matte finish, designed for both indoor and outdoor use. It weighs approximately 320 grams (11.29 oz) and measures 124mm (H) x 60mm (W) x 63mm (D), making it compact yet sturdy.
Video Quality and Night Vision
  • Resolution: Full HD 1080p (1920 x 1080)
  • Frame Rate: 20 fps during daytime, 15 fps at night
  • Night Vision: Equipped with 4 IR LEDs (850 nm) for clear black-and-white night vision
  • Color Night Vision: Yes, providing vivid nighttime footage
  • Lens: Glass and plastic combination with a 121° diagonal field of view and 180° vertical range
Features
  • Motion Tracking: Automatically follows movement within the frame
  • Two-Way Audio: Communicate through the camera with built-in mic and speaker
  • Local Storage: Supports 32GB MicroSDHC cards (Class 10, UHS-1)
  • Weather Resistance: Rated IP65, suitable for outdoor environments
  • Smart Assistant Compatibility: Works with Alexa, Google Assistant, and IFTTT
  • Operating Temperature: From -20°C to 45°C (-5°F to 113°F)
Included Accessories
The Wyze v3 Bundle includes a mounting kit, power adapter, 6-foot micro USB cable, and a 32GB MicroSD card, making setup straightforward and convenient.
Wyze Cam v4: Advanced Features and Enhanced Resolution
Design and Build
The Wyze Cam v4 sports a sleek polycarbonate body available in white or grey, weighing 222 grams (0.49 lb) with compact dimensions of 2in x 2in x 2 3/8in. It offers multiple mounting options including stand, wall, ceiling, and magnetic mounts for versatile placement.
  • Resolution: 2.5K QHD (2560 x 1440) for sharper, more detailed images
  • Frame Rate: 20 fps daytime, 15 fps nighttime
  • Night Vision: Features 4 IR LEDs (850 nm) plus 2 white spotlight LEDs (72 lumens) for superior color night vision
  • Digital Zoom: Up to 8x zoom for close-up views without losing clarity
  • Field of View: 115.8° diagonal, 98.5° horizontal, 53.1° vertical
Features
  • Built-in Siren: Loud 99dB siren for deterrence
  • Two-Way Talk: Simultaneous communication with noise and echo cancellation
  • Connectivity: Supports Wi-Fi 6 and Bluetooth 5.2 for faster, more reliable connections
  • Storage: Supports microSD cards up to 512GB and cloud storage options
  • Weather Resistance: IP65 rating for outdoor durability
  • Smart Assistant Integration: Compatible with Alexa, Google Assistant, and IFTTT
  • Operating Temperature: -20°C to 50°C (-4°F to 122°F)
The package includes the Wyze Cam v4, quick start guide, wall mount plate with tape, screw kit, indoor USB power adapter, and a 6-foot flat micro USB to USB-A cable.
Key Differences at a Glance
FeatureWyze Cam v3 ProWyze Cam v4
Video Resolution1080p Full HD2.5K QHD (2560 x 1440)
Night Vision4 IR LEDs (850 nm), color night vision4 IR LEDs + 2 white spotlight LEDs, enhanced color night vision
Field of View121° diagonal115.8° diagonal
Digital ZoomNo8x digital zoom
Built-in SirenNoYes (99dB)
ConnectivityWi-Fi 2.4 GHzWi-Fi 6 + Bluetooth 5.2
Storage CapacityUp to 32GB MicroSDUp to 512GB MicroSD + Cloud
Weight320 g (11.29 oz)222 g (0.49 lb)
Weather ResistanceIP65IP65
PriceAround $93 (v3 Bundle)$100
Which Should You Choose?
Choose Wyze Cam v3 Pro if: You want a reliable, budget-friendly camera with solid 1080p video, motion tracking, and good night vision for both indoor and outdoor use. Choose Wyze Cam v4 if: You prefer higher resolution video, enhanced color night vision with spotlights, built-in siren for security alerts, and the latest connectivity options like Wi-Fi 6.
Enhance Your Setup with Accessories
To maximize your Wyze Cam experience, consider the following accessories compatible with both v3 Pro and v4: Wyze Cam USB Extension Cable - 20ft Extend your camera’s reach with a durable, weather-resistant 20-foot USB extension cable, perfect for flexible placement indoors or outdoors. Wyze Cam Mounting Kit Includes a mounting bracket, adhesive, screws, and a longer micro USB cable to securely install your camera wherever you need it.
Home Security Camera in Use Capture every moment with Wyze Cam in your home environment
Both Wyze Cam v3 Pro and v4 offer excellent security features tailored to different needs. Whether you prioritize higher resolution and advanced features or a trusted, budget-friendly option, Wyze has you covered.
FeatureWyze v3 BundleWyze Cam v4
Price$92.94$100.00
Camera Types1x Wyze Cam Pan v3, 1x Wyze Cam v3Wyze Cam v4
Resolution1080p HD2.5K QHD (2560x1440)
Field of ViewWyze Cam v3: 121° (D) x 102° (H) x 54° (V)115.8° (D) x 98.5° (H) x 53.1° (V)
Pan/TiltWyze Cam Pan v3: 360° pan, 180° tiltFixed angle
Night VisionColor Night VisionEnhanced Color Night Vision
AudioTwo-way audioEnhanced two-way talk with noise/echo cancellation
SpotlightNo (sold separately)Yes, motion-activated spotlight
SirenNoYes, built-in siren
Local Recording2x 32GB microSD cards includedSupports microSD up to 512GB (card sold separately)
Continuous RecordingYesYes
Motion TrackingAutomatic motion tracking (Pan v3)Auto-zoom with AI tracking
Motion Detection ZonesYesYes
Sound DetectionYesYes
Smoke & CO AlertsNoYes
ConnectivityWorks with Alexa, Google Assistant, IFTTTWorks with Alexa, Google Assistant, IFTTT
SetupSimple plug-in setup, magnetic mountBluetooth setup, magnetic mount
Power SourceWiredWired
Dimensions (Wyze Cam v3)Not specified2in x 2in x 2 3/8in
Weight (Wyze Cam v3)Not specified0.49 lb (222 g)
WarrantyNot specified1 Year
What are the main differences between Wyze Cam v3 Pro and Wyze Cam v4?The Wyze Cam v3 Pro offers 1080p Full HD resolution, motion tracking, and supports up to 32GB microSD cards. The Wyze Cam v4 features a higher 2.5K QHD resolution, 8x digital zoom, built-in 99dB siren, Wi-Fi 6 and Bluetooth 5.2 connectivity, and supports up to 512GB microSD cards plus cloud storage. Both have IP65 weather resistance, but the v4 provides enhanced color night vision with spotlights.
Which Wyze camera is better for outdoor use: v3 Pro or v4?Both Wyze Cam v3 Pro and v4 are rated IP65 for weather resistance, making them suitable for outdoor use. However, the Wyze Cam v4 offers enhanced features like a built-in siren, improved color night vision with spotlights, and higher resolution, making it a better choice for advanced outdoor security.
Does Wyze Cam v4 have better video quality than Wyze Cam v3 Pro?Yes, the Wyze Cam v4 delivers superior video quality with its 2.5K QHD (2560 x 1440) resolution compared to the Wyze Cam v3 Pro's 1080p Full HD. The v4 also offers 8x digital zoom for detailed close-ups.
What is the maximum microSD card size supported by Wyze Cam v3 Pro and v4?The Wyze Cam v3 Pro supports microSD cards up to 32GB (Class 10, UHS-1), while the Wyze Cam v4 supports microSD cards up to 512GB, providing much greater local storage capacity.
Do both Wyze Cam v3 Pro and v4 support smart home integration?Yes, both Wyze Cam v3 Pro and v4 are compatible with Alexa, Google Assistant, and IFTTT, allowing for seamless smart home integration.
What night vision features do Wyze Cam v3 Pro and v4 offer?The Wyze Cam v3 Pro uses 4 IR LEDs for clear black-and-white night vision and supports color night vision. The Wyze Cam v4 enhances this with 4 IR LEDs plus 2 white spotlight LEDs (72 lumens) for superior color night vision, even in low-light conditions.
Does Wyze Cam v4 have a built-in siren?Yes, the Wyze Cam v4 includes a built-in 99dB siren for security alerts and deterrence, a feature not available on the Wyze Cam v3 Pro.
What connectivity options are available on Wyze Cam v3 Pro and v4?The Wyze Cam v3 Pro supports Wi-Fi 2.4 GHz, while the Wyze Cam v4 offers advanced connectivity with Wi-Fi 6 and Bluetooth 5.2 for faster and more reliable connections.
What accessories are compatible with Wyze Cam v3 Pro and v4?Both Wyze Cam v3 Pro and v4 are compatible with accessories such as the Wyze Cam USB Extension Cable (20ft) for extended reach and the Wyze Cam Mounting Kit, which includes a mounting bracket, adhesive, screws, and a longer micro USB cable for flexible installation.
Which Wyze camera should I choose for higher resolution and advanced features?If you prioritize higher video resolution, enhanced color night vision with spotlights, a built-in siren, and the latest connectivity options, the Wyze Cam v4 is the better choice.
Is the Wyze Cam v3 Pro a good budget-friendly security camera?Yes, the Wyze Cam v3 Pro is a reliable and budget-friendly option, offering solid 1080p video, motion tracking, and good night vision for both indoor and outdoor use.
What are the key features of the Wyze Cam v3 Pro?Can you explain the night vision capabilities of the Wyze Cam v4?Do you have any deals, ongoing sales, discounts, or promotions?
