Wyze Cam Pan v3 Comparison: Features, Bundles, and Accessories
When it comes to versatile home security, the
Wyze Cam Pan v3 stands out as a top choice for both indoor and outdoor surveillance. This page provides a detailed comparison of the Wyze Cam Pan v3 product variants, bundles, and accessories to help you find the perfect fit for your security needs.
Wyze Cam Pan v3: Core Features and Specifications
The Wyze Cam Pan v3 is a redesigned, weather-resistant security camera that offers comprehensive coverage with its 360° horizontal pan and 180° vertical tilt capabilities. It is ideal for monitoring large areas both inside and outside your home.
- Video Quality: Full HD 1080p resolution with H.264 video encoding.
- Field of View: 120° wide-angle lens.
- Pan & Tilt Range: 360° horizontal rotation and 180° vertical tilt with rotation speeds up to 110° per second.
- Night Vision: Color night vision supported by 4 IR LEDs (850 nm).
- Audio: Built-in speaker and microphone with two-way audio, noise, and echo cancellation.
- Connectivity: 2.4 GHz Wi-Fi (802.11 b/g/n), compatible with Android 9.0+ and iOS 15.0+.
- Storage: Supports up to 256 GB microSD card (ExFAT format) for local recording.
- Weather Resistance: IP65 rating, suitable for outdoor use with the Wyze Outdoor Power Adapter (sold separately).
- Smart Home Integration: Works with Alexa, Google Assistant, and IFTTT.
- Dimensions & Weight: 124mm (H) x 60mm (W) x 63mm (D), weighing 320g.
- Warranty: 1 year.
This camera is perfect for users who want a reliable, weatherproof security solution with advanced motion tracking and color night vision.
"Wyze Cam Pan v3 offers 360° coverage and color night vision, making it a versatile choice for any home."
Wyze Cam Pan v3 - Weather-resistant outdoor security
Bundles Featuring Wyze Cam Pan v3
Essential Security Bundle
This all-in-one package is designed for comprehensive home protection, combining multiple Wyze devices for a layered security approach:
- Wyze Cam Pan v3: Full 360° pan and 180° tilt coverage with automatic motion tracking and two-way audio.
- Wyze Video Doorbell v2: Crisp 1080p HD video with two-way audio and person detection.
- Wyze Lock Bolt: Smart lock with fingerprint sensor and backlit keypad for keyless entry.
- 2× Wyze Cam OG: Plug-in cameras with motion-activated spotlights and color night vision for indoor/outdoor use.
Price: $199.99 (compare at $224.90)
This bundle is perfect for users looking to secure multiple points of entry and large areas with a combination of cameras and smart locks.
Pan v3 + Lamp Socket v2 Bundle
This bundle pairs the Wyze Cam Pan v3 with the innovative Lamp Socket v2, allowing you to power your Pan v3 camera directly from a lamp socket without needing an outlet.
- Wyze Cam Pan v3: Available in black or white, with all core features.
- Lamp Socket v2: Compatible with E26 sockets, supports CFL or LED bulbs under 20W (incandescent bulbs not recommended), suitable for damp locations but not fully weatherproof.
Price: $53.96 (compare at $56.96)
This bundle is ideal for users who want to install the Pan v3 camera outdoors or in locations where power outlets are limited.
Wyze Cam Pan v3 + 30-Day Cam Plus Bundle
This bundle includes the Wyze Cam Pan v3 along with a 30-day trial of Cam Plus, Wyze’s subscription service that enhances your camera’s capabilities with advanced AI detection and cloud storage.
- Includes all standard Pan v3 features.
- Comes with power adapter, mounting kit, and quick start guide.
Price: $39.98
Great for users who want to try out enhanced cloud features and AI-powered alerts.
Accessories for Wyze Cam Pan v3
Wyze Cam Pan v3 Skins by dBrand
Customize and protect your Wyze Cam Pan v3 with stylish vinyl skins available in Green Camo and Triple Black. These skins offer:
- Scratch protection.
- Precision-cut for a flawless fit.
- Easy application with a hair dryer.
Price: $11.98
Wyze Cam Pan v3 USB Cable
A replacement USB cable designed specifically for the Pan v3 camera, ensuring you always have a reliable power connection.
Price: $1.99
Why Choose Wyze Cam Pan v3?
- Versatile Installation: Suitable for indoor and outdoor use with IP65 weather resistance.
- Comprehensive Coverage: 360° pan and 180° tilt with automatic motion tracking.
- Clear Communication: Two-way audio with noise and echo cancellation.
- Smart Home Ready: Integrates seamlessly with Alexa, Google Assistant, and IFTTT.
- Expandable Storage: Supports large microSD cards for local recording.
- Affordable Bundles: Multiple bundle options to fit different security needs and budgets.
Stay connected with two-way audio, perfect for checking on pets or family
Summary Table of Wyze Cam Pan v3 Options
Product / Bundle | Key Features | Price (USD) |
Wyze Cam Pan v3 (Single) | 360° pan, 180° tilt, color night vision, IP65 | From $39.98 |
Essential Security Bundle | Pan v3 + Doorbell v2 + Lock Bolt + 2x Cam OG | $199.99 |
Pan v3 + Lamp Socket v2 Bundle | Pan v3 + Lamp Socket for outlet-free power | $53.96 |
Pan v3 + 30-Day Cam Plus Bundle | Pan v3 + 30-day AI cloud service trial | $39.98 |
Pan v3 Skins by dBrand | Protective, stylish vinyl skins | $11.98 |
Pan v3 USB Cable | Replacement USB cable | $1.99 |
Enhance your home security with the Wyze Cam Pan v3 and its versatile bundles and accessories. Whether you want full home coverage, smart lighting integration, or advanced cloud features, Wyze offers a solution tailored to your needs.
What are the main features of the Wyze Cam Pan v3?
The Wyze Cam Pan v3 offers 360° horizontal pan, 180° vertical tilt, full HD 1080p video, color night vision, two-way audio with noise and echo cancellation, IP65 weather resistance, and compatibility with Alexa, Google Assistant, and IFTTT. It supports up to 256 GB microSD cards for local storage and is suitable for both indoor and outdoor use.Is the Wyze Cam Pan v3 suitable for outdoor use?
Yes, the Wyze Cam Pan v3 is IP65 weather-resistant, making it suitable for outdoor installation when used with the Wyze Outdoor Power Adapter (sold separately).What bundles are available with the Wyze Cam Pan v3?
Available bundles include the Essential Security Bundle (Pan v3, Video Doorbell v2, Lock Bolt, 2x Cam OG), the Pan v3 + Lamp Socket v2 Bundle (for outlet-free power), and the Pan v3 + 30-Day Cam Plus Bundle (includes a trial of Wyze’s AI-powered cloud service).What is included in the Essential Security Bundle?
The Essential Security Bundle includes the Wyze Cam Pan v3, Wyze Video Doorbell v2, Wyze Lock Bolt, and two Wyze Cam OG cameras. This bundle is designed for comprehensive home protection and covers multiple entry points.How does the Pan v3 + Lamp Socket v2 Bundle work?
The Pan v3 + Lamp Socket v2 Bundle allows you to power your Wyze Cam Pan v3 directly from a standard E26 lamp socket, making it ideal for locations without nearby power outlets. The Lamp Socket v2 supports CFL or LED bulbs under 20W and is suitable for damp locations.What is the Wyze Cam Pan v3 + 30-Day Cam Plus Bundle?
This bundle includes the Wyze Cam Pan v3 and a 30-day trial of Cam Plus, Wyze’s subscription service that adds advanced AI detection and cloud storage features. It also comes with a power adapter, mounting kit, and quick start guide.What accessories are available for the Wyze Cam Pan v3?
Accessories for the Wyze Cam Pan v3 include dBrand vinyl skins (Green Camo and Triple Black) for protection and customization, and a replacement USB cable designed specifically for the Pan v3.Does the Wyze Cam Pan v3 support local video storage?
Yes, the Wyze Cam Pan v3 supports local video recording with microSD cards up to 256 GB (ExFAT format).What smart home platforms does the Wyze Cam Pan v3 work with?
The Wyze Cam Pan v3 is compatible with Alexa, Google Assistant, and IFTTT for seamless smart home integration.What is the price of the Wyze Cam Pan v3 and its bundles?
The Wyze Cam Pan v3 starts at $39.98. The Essential Security Bundle is $199.99, the Pan v3 + Lamp Socket v2 Bundle is $53.96, and the Pan v3 + 30-Day Cam Plus Bundle is $39.98. Accessories like dBrand skins are $11.98 and the USB cable is $1.99.What warranty does the Wyze Cam Pan v3 come with?
The Wyze Cam Pan v3 comes with a 1-year warranty.What are the dimensions and weight of the Wyze Cam Pan v3?
The Wyze Cam Pan v3 measures 124mm (H) x 60mm (W) x 63mm (D) and weighs 320g.
