Wyze Cam Pan vs Wyze Cam v4: Key Differences & Features
Understanding the Difference Between Wyze Cam Pan and Wyze Cam v4 (Standard)
When choosing a Wyze security camera, it's essential to understand the key differences between the Wyze Cam Pan and the Wyze Cam v4, including the standard and outdoor bundles. This guide will help you compare their features, capabilities, and ideal use cases to find the perfect fit for your home security needs.
Wyze Cam v4: The Latest in Clear, Smart Security
Crystal-Clear 2.5K QHD Resolution with Enhanced Color Night Vision
The Wyze Cam v4 delivers stunning 2.5K Quad High Definition video quality, providing crystal-clear images and videos that capture every detail. Its enhanced color night vision technology allows you to see vibrant colors even in low-light conditions, surpassing traditional black-and-white night vision cameras.
"It's like giving your camera superhero vision!" — Wyze
Advanced Features for Ultimate Convenience
  • Motion-Activated Spotlight & Siren: The built-in spotlight activates when motion is detected, illuminating your property and deterring intruders. The siren can be triggered remotely for added security.
  • Wi-Fi 6 Support: Enjoy a stronger, more reliable connection with Wi-Fi 6 compatibility, ensuring your camera stays connected even at greater distances.
  • 24/7 Local Recording: With a microSD card slot supporting up to 512GB, you can record continuously without missing a moment.
  • Smart Detection & Alerts: Receive notifications for motion, sound, smoke, and CO alarms. Advanced AI detection (with subscription) can identify people, pets, packages, and vehicles.
  • Weather Resistant (IP65): Designed for both indoor and outdoor use, the Wyze Cam v4 withstands rain, snow, and extreme temperatures.
Easy Setup and Integration
  • Bluetooth Setup: Hassle-free installation without scanning QR codes.
  • Magnetic Mount: Screw-free mounting options for walls, ceilings, or metal surfaces.
  • Smart Home Compatibility: Works seamlessly with Alexa, Google Assistant, and IFTTT for voice control and automation.
Wyze Cam v4 in outdoor lifestyle setting Wyze Cam v4 with motion-activated spotlight protecting your home at night
Wyze Cam Pan: Dynamic Pan, Tilt, and Zoom for Full Coverage
360° Pan and 93° Tilt for Complete Room Monitoring
Unlike the fixed lens on the Wyze Cam v4, the Wyze Cam Pan offers motorized pan and tilt capabilities, allowing you to remotely control the camera’s view to cover an entire room or area. This makes it ideal for indoor use where you want to monitor multiple angles without blind spots.
Key Features of Wyze Cam Pan
  • 1080p HD Resolution: While it offers full HD clarity, it does not match the 2.5K resolution of the Wyze Cam v4.
  • Two-Way Audio: Communicate clearly with family or pets through the built-in speaker and microphone.
  • Motion Tracking: Automatically follows moving objects to keep them in frame.
  • Night Vision: Infrared night vision provides clear black-and-white images in the dark.
  • Magnetic Mounting: Easy to install on walls or metal surfaces.
Ideal Use Cases
The Wyze Cam Pan is perfect for indoor environments where you want flexible viewing angles and active tracking, such as living rooms, nurseries, or offices.
Comparing Wyze Cam v4 and Wyze Cam Pan: Which One Should You Choose?
FeatureWyze Cam v4 (Standard/Outdoor)Wyze Cam Pan
Resolution2.5K QHD (2560x1440)1080p HD
Field of View115.9° diagonal, wide dynamic range (WDR)120° horizontal, pan 360°, tilt 93°
Night VisionEnhanced Color Night Vision + IR LEDsInfrared Night Vision (B&W)
Pan & TiltFixed lensMotorized pan and tilt
Spotlight & SirenYes, motion-activated spotlight and sirenNo spotlight, siren available
Weather ResistanceIP65 (Indoor/Outdoor)Indoor only
ConnectivityWi-Fi 6 support, Bluetooth setupWi-Fi (2.4 GHz), Bluetooth setup
Local StoragemicroSD up to 512GBmicroSD up to 32GB
Smart DetectionPerson, pet, package, vehicle (with subscription)Basic motion detection
AudioEnhanced two-way talk, 99dB sirenTwo-way talk
Wyze Cam v4 Outdoor Bundle: Ready for All Weather Conditions
The Wyze Cam v4 Outdoor Bundle includes everything you need for outdoor security:
  • Wyze Cam v4 camera with IP65 weather resistance
  • Wyze Outdoor Power Adapter for continuous power outdoors
  • 128GB microSD card for local 24/7 recording
This bundle is perfect for monitoring your front yard, backyard, or any outdoor space with crystal-clear 2.5K video and vibrant color night vision. Outdoor lifestyle with Wyze Cam v4 Experience vibrant colors and clear security footage outdoors with Wyze Cam v4
Summary: Which Wyze Camera Fits Your Needs?
  • Choose Wyze Cam Pan if you want flexible indoor coverage with pan, tilt, and motion tracking at 1080p resolution.
  • Choose Wyze Cam v4 if you want the highest video quality (2.5K), enhanced color night vision, spotlight, siren, and outdoor-ready weather resistance.
  • The Wyze Cam v4 Outdoor Bundle is ideal for those needing a complete outdoor security solution with power adapter and local storage included.
By understanding these differences, you can confidently select the Wyze camera that best secures your home, indoors or outdoors, with the features you need.
FeatureWyze Cam v4 (P i=1/4)Wyze Cam v4 Outdoor BundleWyze Cam v4
Price$35.98 (single), $71.96 (2-pack), $107.94 (3-pack)$69.99$100.00
Color OptionsBlack, Grey, White, Clear (Clear sold out)Black, Grey, WhiteDefault (no color variants)
Resolution2.5K QHD (2560x1440)2.5K QHD2.5K Quad HD
Night VisionEnhanced Color Night VisionEnhanced Color Night VisionEnhanced Color Night Vision
Weather ResistanceIP65IP65IP65
Motion-Activated SpotlightYesYesYes
Siren99 dBNot explicitly statedYes
AudioEnhanced Two-Way TalkNot explicitly statedAdvanced Audio Coding (AAC), enhanced mic & amp
Local Recording24/7 recording to microSD up to 256GB24/7 recording to microSD (128GB included)24/7 recording to microSD up to 512GB
MicroSD Card IncludedNoYes (128GB included)No
Wi-Fi SupportWi-Fi 6Wi-Fi 6Wi-Fi 6
CompatibilityAlexa, Google Assistant, IFTTTAlexa, Google AssistantAlexa, Google Assistant, IFTTT
Motion & Sound DetectionYesYesYes
Motion Detection ZonesYesYesYes
Smoke & CO AlertsYesYesYes
Power SourceWiredWiredWired
Outdoor UseYesYesNo (not made in America, but supports outdoor use with adapter)
Included AccessoriesNoneWyze Outdoor Power Adapter, 128GB MicroSD CardNone
Mounting OptionsMagnetic base, metal plateNot specifiedMagnetic base, metal plate
AI FeaturesAuto-zoom with AI, Smart FocusNot specifiedNot specified
WarrantyNot specifiedNot specifiedNot specified
Special NotesRequires microSD card (sold separately)Includes microSD card and outdoor power adapterSupports American worker fund program ($64.02 per sale)
What is the main difference between Wyze Cam Pan and Wyze Cam v4?The main difference is that Wyze Cam Pan offers motorized pan and tilt for 360° room coverage and motion tracking, making it ideal for flexible indoor monitoring. Wyze Cam v4 features a fixed lens with superior 2.5K QHD resolution, enhanced color night vision, weather resistance for outdoor use, and advanced smart detection features.
Does Wyze Cam v4 have better video quality than Wyze Cam Pan?Yes, Wyze Cam v4 provides 2.5K Quad High Definition (QHD) video quality, delivering crystal-clear images and videos. In comparison, Wyze Cam Pan offers 1080p HD resolution.
Can Wyze Cam v4 be used outdoors?Yes, Wyze Cam v4 is IP65 weather resistant, making it suitable for both indoor and outdoor use. It can withstand rain, snow, and extreme temperatures.
Is Wyze Cam Pan suitable for outdoor use?No, Wyze Cam Pan is designed for indoor use only and does not have weather resistance features.
What night vision capabilities do Wyze Cam v4 and Wyze Cam Pan offer?Wyze Cam v4 features enhanced color night vision, allowing you to see vibrant colors even in low-light conditions. Wyze Cam Pan uses infrared night vision, providing clear black-and-white images in the dark.
Does Wyze Cam v4 support smart detection and alerts?Yes, Wyze Cam v4 offers smart detection and alerts for motion, sound, smoke, and CO alarms. With a subscription, it can also identify people, pets, packages, and vehicles.
What is included in the Wyze Cam v4 Outdoor Bundle?The Wyze Cam v4 Outdoor Bundle includes a Wyze Cam v4 camera with IP65 weather resistance, a Wyze Outdoor Power Adapter for continuous outdoor power, and a 128GB microSD card for local 24/7 recording.
How much local storage do Wyze Cam v4 and Wyze Cam Pan support?Wyze Cam v4 supports microSD cards up to 512GB for continuous local recording, while Wyze Cam Pan supports microSD cards up to 32GB.
Can I control Wyze Cam Pan remotely to view different areas?Yes, Wyze Cam Pan allows you to remotely pan 360° and tilt 93°, giving you full control to monitor different areas of a room.
Is Wyze Cam v4 compatible with smart home systems?Yes, Wyze Cam v4 works with Alexa, Google Assistant, and IFTTT, allowing for voice control and smart home automation.
Which Wyze camera is best for flexible indoor monitoring?Wyze Cam Pan is best for flexible indoor monitoring due to its motorized pan, tilt, and motion tracking features.
Which Wyze camera should I choose for the highest video quality and outdoor use?Choose Wyze Cam v4 for the highest 2.5K QHD video quality, enhanced color night vision, and weather resistance for outdoor use.
What are the key features of the Wyze Cam v4 Outdoor Bundle?Can you explain the benefits of the enhanced color night vision in the Wyze Cam v4?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze cameras?
