Wyze Cam Floodlight Pro vs 2K QHD Models: Which One Suits You Best?
When choosing a smart floodlight camera, resolution and features matter a lot. The Wyze Cam Floodlight Pro stands out with its 2.5K QHD video quality, offering sharper and more detailed footage compared to traditional 2K cameras. Let’s explore how the Wyze Cam Floodlight Pro compares to other Wyze floodlight cameras, especially focusing on the 2K vs 2.5K QHD resolution debate.
Wyze Cam Floodlight Pro: Superior 2.5K QHD Security Lighting
Crystal Clear 2.5K QHD Video Quality
The Wyze Cam Floodlight Pro delivers stunning 2.5K QHD resolution (2560 x 1440), providing crystal-clear video that captures every detail in your yard. This is a significant upgrade over 2K (2304 x 1296) cameras, ensuring you don’t miss any important activity.
Wide 180° Field of View
With a 180° diagonal field of view, this camera covers a broad area, letting you monitor your entire yard or driveway without blind spots.
Powerful 3000 Lumens LED Lighting
Equipped with three dimmable LED light panels producing a total of 3000 lumens at 5000K color temperature, the Floodlight Pro brightly illuminates your property, enhancing night visibility and security.
Intelligent AI Motion Detection
The onboard AI computer vision detects motion from specific objects like people and vehicles, reducing false alerts. The lights activate only when necessary, acting like a vigilant home security guard.
Dual-Band WiFi & Smart Home Integration
Supports both 2.4 GHz and 5 GHz WiFi bands for reliable connectivity. It integrates seamlessly with Alexa, Google Assistant, and IFTTT for voice control and automation.
Durable and Weather Resistant
Rated IP65 for water resistance and built to operate in temperatures from -4°F to 140°F, it’s designed to withstand harsh outdoor conditions.
Installation & Compatibility
Hardwired with 110-120V AC power supply, it mounts easily on walls or ceilings. Compatible with Android 9.0+ and iOS 15.0+ devices.
“A high-powered security camera with bright lights that thinks and responds like a personal home security guard—no donuts required.”
Wyze Cam Floodlight Pro in action illuminating a home exterior with a woman and dog nearby.
Wyze Cam Floodlight Pro + Plug-In Mount: Easy Installation with 2.5K QHD
Plug-and-Play Convenience
This bundle includes the Wyze Cam Floodlight Pro paired with a plug-in mount, eliminating the need for complex junction box installation. Perfect for renters or those who want a hassle-free setup.
Same High-Quality Specs
- 2.5K QHD resolution with color night vision
- 180° ultra-wide field of view
- 3000 lumens bright LED lighting
- AI motion detection and smart integrations
Extended Power Cord
Comes with a 20-foot power cord (18 AWG cable) rated for outdoor use, providing flexible placement options.
Weatherproof & Durable
IP65 water resistance and operating temperature range from -22°F to 122°F ensure reliable performance year-round.
Wyze Cam Floodlight Pro with plug-in mount offers flexible, easy outdoor security.
Wyze Cam Floodlight v2: Reliable 2K Video with Bright Lighting
Crisp 2K Video Quality
The Floodlight v2 offers 2K resolution (2304 x 1296) with color night vision, delivering clear images but slightly less detailed than the 2.5K QHD models.
Wide 160° Field of View
Covers a broad area with a 160° diagonal view, slightly narrower than the Floodlight Pro’s 180°.
Bright 2800 Lumens LED Lighting
Two dimmable LED panels provide 2800 lumens at 5000K color temperature, enough to light up your driveway or backyard effectively.
Smart Features
- AI-powered light control and motion-activated voice deterrence
- Two-way audio with built-in speaker and microphone
- Dusk-to-dawn automation for effortless lighting control
Connectivity & Compatibility
Supports 2.4 GHz WiFi and integrates with Alexa, Google Assistant, and IFTTT.
IP65 rating and operating temperature from -4°F to 140°F make it suitable for outdoor use.
The Wyze Cam Floodlight v2 is a budget-friendly option for those who want solid 2K video and bright lighting without the premium 2.5K resolution.
Wyze Cam Floodlight v2 illuminating a driveway with clear 2K video capture.
Summary: 2K vs 2.5K QHD Wyze Floodlight Cameras
Feature | Wyze Cam Floodlight Pro (2.5K) | Wyze Cam Floodlight Pro + Plug-In (2.5K) | Wyze Cam Floodlight v2 (2K) |
Video Resolution | 2.5K QHD (2560 x 1440) | 2.5K QHD (2560 x 1440) | 2K (2304 x 1296) |
Field of View | 180° diagonal | 180° ultra-wide | 160° diagonal |
LED Brightness (Lumens) | 3000 | 3000 | 2800 |
Night Vision | Color Night Vision | Color Night Vision | Color Night Vision |
AI Motion Detection | Yes | Yes | Yes |
Power Supply | Hardwired 110-120V AC | Plug-in Mount with 20 ft cord | Hardwired 110-120V AC |
WiFi Support | 2.4 & 5 GHz dual-band | 2.4 GHz only | 2.4 GHz |
Smart Home Integration | Alexa, Google Assistant, IFTTT | Alexa, Google Assistant, IFTTT | Alexa, Google Assistant, IFTTT |
Weather Resistance | IP65 | IP65 | IP65 |
Price Range | $149.98 | $169.96 | $89.98 |
Which Wyze Floodlight Camera Should You Choose?
- Choose Wyze Cam Floodlight Pro (2.5K QHD) if you want the highest video clarity, widest field of view, and powerful lighting with hardwired installation.
- Choose Wyze Cam Floodlight Pro + Plug-In Mount if you want the same premium features but prefer an easy plug-and-play setup without electrical work.
- Choose Wyze Cam Floodlight v2 (2K) if you want a budget-friendly floodlight camera with solid 2K video and bright lighting for basic home security needs.
Conclusion
The Wyze Cam Floodlight Pro series with 2.5K QHD resolution offers a noticeable upgrade in video quality and field of view compared to the 2K Wyze Cam Floodlight v2. Whether you prefer hardwired or plug-in installation, the Floodlight Pro models provide advanced AI motion detection, bright 3000 lumen lighting, and smart home compatibility to keep your home safe and well-lit.
Investing in a 2.5K QHD floodlight camera means clearer images, better identification of people and vehicles, and a more comprehensive view of your property — essential for modern home security.
What is the difference between Wyze Cam Floodlight Pro and Wyze Cam Floodlight v2?
The Wyze Cam Floodlight Pro features a higher 2.5K QHD resolution (2560 x 1440), a wider 180° field of view, and brighter 3000 lumens LED lighting compared to the Wyze Cam Floodlight v2, which offers 2K resolution (2304 x 1296), a 160° field of view, and 2800 lumens lighting. The Floodlight Pro also supports dual-band WiFi (2.4 GHz & 5 GHz), while the v2 supports only 2.4 GHz.How does 2.5K QHD video quality improve home security compared to 2K?
2.5K QHD video quality (2560 x 1440) provides sharper, more detailed footage than 2K (2304 x 1296), making it easier to identify people, vehicles, and important activity around your property. This higher resolution is especially beneficial for capturing clear evidence and monitoring larger areas.What are the installation options for Wyze Cam Floodlight Pro?
The Wyze Cam Floodlight Pro is available in two installation options: a hardwired version that connects to a 110-120V AC power supply, and a plug-in mount version that comes with a 20-foot outdoor-rated power cord for easy, tool-free setup. The plug-in option is ideal for renters or those seeking hassle-free installation.Is the Wyze Cam Floodlight Pro weatherproof?
Yes, the Wyze Cam Floodlight Pro is rated IP65 for water resistance and is designed to operate in temperatures ranging from -4°F to 140°F (hardwired) or -22°F to 122°F (plug-in mount), making it suitable for year-round outdoor use.Does the Wyze Cam Floodlight Pro support smart home integration?
Yes, the Wyze Cam Floodlight Pro integrates seamlessly with Alexa, Google Assistant, and IFTTT, allowing for voice control and smart home automation.What is the field of view for Wyze Cam Floodlight Pro compared to Floodlight v2?
The Wyze Cam Floodlight Pro offers a 180° diagonal field of view, providing broader coverage and reducing blind spots. In comparison, the Wyze Cam Floodlight v2 has a 160° diagonal field of view.What type of motion detection does Wyze Cam Floodlight Pro use?
The Wyze Cam Floodlight Pro uses advanced AI computer vision to detect motion from specific objects such as people and vehicles, reducing false alerts and ensuring the lights activate only when necessary.Which Wyze floodlight camera is best for renters?
The Wyze Cam Floodlight Pro + Plug-In Mount is ideal for renters, as it offers plug-and-play convenience without the need for complex electrical installation. The included 20-foot power cord allows for flexible placement.What are the power supply options for Wyze floodlight cameras?
The Wyze Cam Floodlight Pro and Floodlight v2 are available as hardwired models requiring a 110-120V AC power supply. The Floodlight Pro also comes in a plug-in version with a 20-foot outdoor-rated power cord for easy installation.Are Wyze floodlight cameras compatible with both Android and iOS devices?
Yes, Wyze floodlight cameras are compatible with Android devices running version 9.0 or higher and iOS devices running version 15.0 or higher.How bright are the Wyze Cam Floodlight Pro and Floodlight v2?
The Wyze Cam Floodlight Pro features three dimmable LED panels producing a total of 3000 lumens, while the Floodlight v2 has two panels providing 2800 lumens. Both offer bright, 5000K color temperature lighting for enhanced night visibility.Which Wyze floodlight camera is the most budget-friendly?
The Wyze Cam Floodlight v2 is the most budget-friendly option, offering solid 2K video quality and bright lighting at a lower price point compared to the 2.5K QHD Floodlight Pro models.
