DIY Hardwired Outdoor Floodlight Cameras with Dual Band WiFi and AP Setup
Looking for a reliable, high-performance outdoor floodlight camera that you can install yourself? Whether you want crystal-clear video, powerful lighting, or seamless WiFi connectivity including dual-band support and easy AP setup, Wyze offers a range of smart floodlight cameras designed for DIY installation. This guide highlights the best Wyze floodlight cameras and accessories that combine security, convenience, and smart home integration.
Wyze Cam Floodlight v2: Bright, Smart, and Easy to Install
Alt: Outdoor driveway illuminated by Wyze Cam Floodlight v2 with person detected
The Wyze Cam Floodlight v2 is a standout choice for those seeking a powerful, hardwired outdoor floodlight camera with simple DIY installation and smart features:
Key Features
- 2800 Lumens LED Floodlights: Bright, adjustable, and motion-activated lights that turn night into day.
- 2K Video with Color Night Vision: Capture crisp, detailed footage with a 160° wide-angle lens.
- Dual-Band WiFi & AP Setup: Connect easily via 2.4 GHz WiFi with Access Point setup—no ladder or QR code scanning needed.
- 24/7 Local Recording: Supports microSD cards up to 256GB for continuous local video storage without subscription.
- AI-Powered Light Control & Motion Detection: 270° PIR motion sensor eliminates blind spots and triggers lights instantly.
- Two-Way Talk & 105dB Siren: Communicate with visitors or deter intruders remotely.
- Dusk-to-Dawn Automation & IP65 Weather Resistance: Automatically turns on/off with daylight and withstands harsh weather.
- Smart Assistant Integration: Works seamlessly with Alexa, Google Assistant, and IFTTT.
DIY Installation Made Simple
No electrician needed! The Floodlight v2 can be installed directly onto your existing outdoor junction box or paired with the optional plug-in mount for outlet power, perfect for renters or those without junction boxes.
Wyze Cam Floodlight Pro: Advanced Security with Dual-Band WiFi
Alt: Side door illuminated by Wyze Cam Floodlight Pro with security alert
For those who want the ultimate in floodlight camera technology, the Wyze Cam Floodlight Pro offers enhanced features and dual-band WiFi support (2.4 & 5 GHz) for faster, more reliable connections.
Pro-Level Specifications
- 2.5K QHD Video Resolution: Ultra-clear video with a 180° ultra-wide field of view to cover your entire yard.
- 3,000 Lumens Adjustable LED Lights: Three independently articulating floodlight panels for customizable lighting.
- Onboard AI Computer Vision: Smarter motion detection that activates lights and notifications only for selected objects like people and vehicles.
- Dual-Band WiFi (2.4 & 5 GHz): Ensures stable connectivity even in crowded wireless environments.
- Motion-Activated Voice Deterrence & 105dB Siren: Plays voice prompts and loud siren to scare off unwanted visitors.
- Ambient Light Mode & Dusk-to-Dawn Automation: Provides constant low-level lighting and automatically adjusts brightness.
- IP65 Weatherproof: Built to withstand rain, snow, and extreme temperatures.
- 24/7 Local Recording: Supports up to 256GB microSD card for continuous video capture.
- Bluetooth Setup: Quick and easy installation without QR codes.
DIY Installation and Power Options
Replace your existing floodlight fixture in under 20 minutes with the included mounting kit. For those without a junction box, the Floodlight Pro can be paired with the Wyze Cam Floodlight Plug-In Mount for a simple plug-and-play solution.
Wyze Cam Floodlight Plug-In Mount: Simplify Your Installation
If you want to avoid the hassle and cost of hardwiring, the
Wyze Cam Floodlight Plug-In Mount is the perfect accessory to power your floodlight camera from a standard outdoor outlet.
Features
- Compatible with Wyze Floodlight v1, v2, and Pro: Versatile plug-in mount works with all major Wyze floodlight cameras.
- 20-Foot Power Cord: Provides flexible placement options around your home.
- Outdoor Safe & Weather Resistant: Rated for temperatures from -22°F to 122°F.
- UL Certified and Durable: Built to meet multiple safety and quality standards.
- Includes Mounting Kit and Quick Start Guide: Everything you need for a fast, DIY setup.
This plug-in mount is ideal for renters or anyone without access to a junction box, enabling you to enjoy the benefits of a hardwired floodlight camera without electrical work.
Why Choose Wyze for Your Outdoor Floodlight Camera?
"Wyze floodlight cameras combine powerful lighting, crystal-clear video, and smart AI features with easy DIY installation and flexible power options. Whether you want a simple 2.4 GHz setup or advanced dual-band WiFi, Wyze has you covered."
- Smart Home Integration: Works with Alexa, Google Assistant, and IFTTT for voice control and automation.
- Flexible Installation: Hardwired or plug-in mount options to fit any home setup.
- Robust Weather Resistance: IP65 rating ensures reliable performance in all seasons.
- Affordable Pricing: High-end features without breaking the bank.
- Local and Cloud Storage: Choose microSD local recording or subscribe to Cam Plus for cloud storage and AI detections.
Summary of Recommended Products
Product | Video Resolution | Field of View | Lighting (Lumens) | WiFi Support | Installation Type | Price Range |
Wyze Cam Floodlight v2 | 2K | 160° | 2800 | 2.4 GHz + AP Setup | Hardwired or Plug-In Mount | $89.98 |
Wyze Cam Floodlight Pro | 2.5K QHD | 180° | 3000 | Dual-Band 2.4/5 GHz | Hardwired or Plug-In Mount | $149.98 |
Wyze Cam Floodlight Plug-In Mount | N/A | N/A | N/A | N/A | Plug-In Power Accessory | $19.98 |
Wyze Cam Floodlight Pro + Plug-In Mount Bundle | 2.5K QHD | 180° | 3000 | Dual-Band 2.4/5 GHz | Plug-In Mount Included | $169.96 |
Enhance Your Outdoor Security Today
With Wyze’s DIY hardwired outdoor floodlight cameras featuring dual-band WiFi and easy AP setup, securing your home has never been easier or more effective. Brighten your nights, deter intruders, and stay connected with smart notifications and voice control — all without complicated installation or expensive electrician fees.
What are the key features of the Wyze Cam Floodlight v2?
The Wyze Cam Floodlight v2 offers 2800 lumens of adjustable LED lighting, 2K video with color night vision, dual-band WiFi with easy AP setup, 24/7 local recording via microSD card, AI-powered motion detection, two-way talk, a 105dB siren, dusk-to-dawn automation, IP65 weather resistance, and smart home integration with Alexa, Google Assistant, and IFTTT.How easy is it to install Wyze outdoor floodlight cameras?
Wyze outdoor floodlight cameras are designed for simple DIY installation. They can be hardwired to an existing outdoor junction box or used with the optional plug-in mount for outlet power, making them suitable for both homeowners and renters. No electrician is required, and setup can be completed in under 20 minutes.What is dual-band WiFi and does Wyze support it?
Dual-band WiFi allows devices to connect to both 2.4 GHz and 5 GHz wireless networks for improved speed and reliability. The Wyze Cam Floodlight Pro supports dual-band WiFi (2.4 & 5 GHz), while the Wyze Cam Floodlight v2 supports 2.4 GHz with easy AP setup.Can I use Wyze floodlight cameras without a junction box?
Yes, you can use Wyze floodlight cameras without a junction box by pairing them with the Wyze Cam Floodlight Plug-In Mount. This accessory allows you to power your camera from a standard outdoor outlet, making installation easy for renters or homes without existing junction boxes.What is the Wyze Cam Floodlight Plug-In Mount and which cameras is it compatible with?
The Wyze Cam Floodlight Plug-In Mount is an accessory that enables you to power your Wyze floodlight camera from a standard outdoor outlet. It is compatible with Wyze Floodlight v1, v2, and Pro models, and includes a 20-foot power cord, mounting kit, and quick start guide.Do Wyze floodlight cameras support local video storage?
Yes, both the Wyze Cam Floodlight v2 and Floodlight Pro support 24/7 local video recording via microSD cards up to 256GB, allowing you to store footage without a subscription.Are Wyze floodlight cameras weatherproof?
Yes, Wyze floodlight cameras are IP65 weather resistant, ensuring reliable performance in rain, snow, and extreme temperatures.Can Wyze floodlight cameras be integrated with smart home systems?
Yes, Wyze floodlight cameras work with Alexa, Google Assistant, and IFTTT, allowing for voice control and smart home automation.What is the difference between Wyze Cam Floodlight v2 and Floodlight Pro?
The Wyze Cam Floodlight v2 features 2K video, 160° field of view, 2800 lumens lighting, and 2.4 GHz WiFi with AP setup. The Floodlight Pro offers 2.5K QHD video, a 180° ultra-wide field of view, 3000 lumens with three adjustable panels, dual-band WiFi (2.4 & 5 GHz), onboard AI computer vision, and motion-activated voice deterrence.Is there a subscription required for Wyze floodlight cameras?
No subscription is required for local video storage using a microSD card. However, you can subscribe to Cam Plus for cloud storage and advanced AI detections if desired.
