Wyze Cam & Lock Replacement Kit: Screws, Cables & Hardware
Wyze Cam and Lock Replacement Kit for Screws, Cables, and Hardware
If you own a Wyze Lock Bolt and are looking for a comprehensive replacement kit for screws, cables, and essential hardware, this guide covers all the compatible parts you need to keep your smart lock functioning flawlessly. Whether you need to replace worn-out screws, battery covers, or metal plates, Wyze offers dedicated replacement parts designed specifically for the Wyze Lock Bolt. Alongside these, the Wyze Lock Bolt itself is a cutting-edge smart lock that combines convenience, security, and smart home integration.
Wyze Lock Bolt: The Smart Lock Revolution
The Wyze Lock Bolt is a Bluetooth-enabled smart lock designed to replace your existing deadbolt with ease. It offers a seamless keyless entry experience with features that enhance home security and convenience.
Key Features:
  • Ultra-Fast Fingerprint Sensor: Unlock your door instantly with a quick fingerprint scan.
  • Backlit Keypad with Anti-Peep: Enter your code discreetly even in low light.
  • Auto-Lock Function: Automatically locks your door if you forget.
  • Built-in Alarm: Detects jams and alerts you immediately.
  • Emergency One-Time Codes: Share temporary access securely.
  • Bluetooth 5.0 Communication: Reliable connection up to 16 feet.
  • Weather Resistance: Rated IPX5, suitable for various climates.
  • Battery Life: Powered by 4 AA batteries lasting 10-12 months.
Specifications:
  • Door Thickness Compatibility: 1-3/8” to 1-3/4”
  • Backset Options: 2-3/8” or 2-3/4”
  • Deadbolt Diameter: 1”
  • Operating Temperature: -13°F to 122°F (keypad), 32°F to 122°F (assembly)
Available in Matte Black and Satin Nickel finishes, the Wyze Lock Bolt blends modern aesthetics with robust security.
Experience the future of home access with Wyze Lock Bolt — secure, smart, and effortless.
Wyze Lock Bolt Lifestyle Secure your home with Wyze Lock Bolt smart lock
Essential Replacement Parts for Wyze Lock Bolt
To maintain your Wyze Lock Bolt in top condition, Wyze offers a variety of replacement parts tailored to the lock’s design. These parts ensure your lock remains reliable without the need for a full replacement.
Wyze Lock Replacement Part Kit
  • Description: A comprehensive replacement kit compatible only with Wyze Lock.
  • Variants: Replacement Part Kit and Adapter Replacement Kit.
  • Price: Starting at $4.99.
  • Return Policy: 30-day hassle-free returns.
This kit is perfect for replacing worn or lost components, ensuring your lock continues to operate smoothly.
Wyze Lock Bolt Screws
  • Description: Set of screws specifically designed for the Wyze Lock Bolt.
  • Compatibility: Fits perfectly with the Wyze Lock Bolt assembly.
  • Price: $2.99.
Replacing screws is essential for maintaining the structural integrity of your lock installation.
Wyze Lock Bolt Interior Assembly Battery Cover
  • Description: Replacement battery cover for the interior assembly of the Wyze Lock Bolt.
  • Price: $9.99.
Keep your batteries protected and your lock powered with this durable cover.
Wyze Lock Bolt Interior Assembly Metal Plate
  • Description: Metal plate used to anchor the interior assembly securely to your door.
  • Price: $4.99.
  • Quantity Options: Available in multiple quantities for convenience.
This metal plate ensures your lock’s interior components stay firmly in place for reliable operation. Wyze Lock Bolt Screws and Parts Replacement screws and parts for Wyze Lock Bolt
Why Choose Wyze Lock Replacement Parts?
Maintaining your Wyze Lock Bolt with genuine replacement parts guarantees compatibility, durability, and continued smart functionality. Avoid the hassle of lock failure or security risks by using parts designed specifically for your device.
  • Easy Installation: Designed to fit perfectly with your existing Wyze Lock Bolt.
  • Affordable: Replacement parts are budget-friendly compared to full lock replacement.
  • Reliable: Backed by Wyze’s 30-day hassle-free return policy.
  • Smart Home Integration: Keep your smart lock working seamlessly with your connected home system.
Enhance Your Home Security with Wyze
While this page focuses on replacement kits and parts for the Wyze Lock Bolt, consider complementing your smart lock with Wyze’s full range of smart home security products. From video doorbells to cameras, Wyze offers solutions that work together to keep your home safe and connected. Wyze Home Security Lifestyle Smart home security for peace of mind
Summary of Wyze Lock Bolt Replacement Products
Product NameTypePriceKey Use
Wyze Lock Replacement Part KitReplacement Parts$4.99+General replacement components
Wyze Lock Bolt ScrewsReplacement Parts$2.99Secure lock assembly
Wyze Lock Bolt Interior Assembly Battery CoverReplacement Parts$9.99Battery protection
Wyze Lock Bolt Interior Assembly Metal PlateReplacement Parts$4.99Anchoring interior assembly
Keep your Wyze Lock Bolt secure and fully functional with these essential replacement parts designed for easy installation and long-lasting performance.
ProductTypePrice (USD)Description / DetailsKey Features / NotesReturn Policy
Wyze Lock Replacement Part KitReplacement Parts19.99Replacement part kit for Wyze Lock. Two variants: Replacement Part Kit (sold out), Adapter Replacement Kit (sold out).Includes screws, cables, and more to make your Wyze product like new again.30-day hassle-free returns
Wyze Lock Bolt ScrewsReplacement Parts2.99Replacement set of screws for Wyze Lock Bolt.Sold individually, quantity selectable.30-day hassle-free returns
Wyze Lock Bolt Interior Assembly Battery CoverReplacement Parts9.99Interior battery cover replacement for Wyze Lock Bolt.Compatible with Wyze Lock Bolt only.30-day hassle-free returns
Wyze Lock Bolt Interior Assembly Metal PlateReplacement Parts4.99Metal plate to anchor the interior assembly to the door.Sold in quantities from 1 to 10.30-day hassle-free returns
Wyze Lock BoltConnected Home79.98Bluetooth smart lock replacing deadbolt with fingerprint reader and backlit keypad.Features: Ultra-fast fingerprint sensor, backlit keypad, auto-lock, built-in alarm, emergency codes.Not specified
What is included in the Wyze Lock Replacement Part Kit?The Wyze Lock Replacement Part Kit includes a comprehensive set of replacement screws, cables, and essential hardware specifically designed for the Wyze Lock Bolt. It is ideal for replacing worn or lost components to keep your smart lock functioning smoothly.
Are Wyze Lock Bolt replacement parts compatible with other smart locks?No, Wyze Lock Bolt replacement parts are designed exclusively for the Wyze Lock Bolt. Using genuine Wyze parts ensures compatibility, durability, and optimal performance for your smart lock.
How much do Wyze Lock Bolt replacement parts cost?Wyze Lock Bolt replacement parts are affordably priced, starting at $2.99 for screws, $4.99 for the metal plate or replacement part kit, and $9.99 for the interior assembly battery cover.
What is the return policy for Wyze Lock Bolt replacement parts?All Wyze Lock Bolt replacement parts come with a 30-day hassle-free return policy, allowing you to shop with confidence.
How do I know if I need to replace my Wyze Lock Bolt screws or hardware?If you notice worn, damaged, or missing screws or hardware on your Wyze Lock Bolt, it is recommended to replace them promptly to maintain the lock’s structural integrity and security.
What are the benefits of using genuine Wyze Lock Bolt replacement parts?Genuine Wyze Lock Bolt replacement parts guarantee perfect fit, easy installation, and continued smart functionality. They help avoid lock failure and security risks by ensuring your device operates as intended.
Is the Wyze Lock Bolt easy to install and maintain?Yes, the Wyze Lock Bolt is designed for easy installation and maintenance. Replacement parts are made to fit seamlessly, making it simple to keep your smart lock in top condition.
What features make the Wyze Lock Bolt a smart choice for home security?The Wyze Lock Bolt offers ultra-fast fingerprint unlocking, a backlit anti-peep keypad, auto-lock function, built-in alarm, emergency one-time codes, Bluetooth 5.0 connectivity, weather resistance, and long battery life, making it a secure and convenient smart lock solution.
Can I purchase Wyze Lock Bolt replacement parts in different quantities?Yes, certain replacement parts like the Wyze Lock Bolt Interior Assembly Metal Plate are available in multiple quantities for added convenience.
How do I keep my Wyze Lock Bolt powered and protected?You can keep your Wyze Lock Bolt powered and protected by using the replacement interior assembly battery cover, which safeguards the batteries and ensures reliable operation.
What are the key features of the Wyze Lock Bolt?How do I initiate a return for a Wyze product?Can you tell me more about the return policy for Wyze products?
