Wyze App Controlled Lighting Kit with Dynamic Color Changes
Transform your home lighting experience with Wyze’s innovative smart lighting solutions. Whether you want to set the perfect mood, brighten your workspace, or add vibrant accent lighting, Wyze offers a range of app-controlled lighting products featuring dynamic color changes and seamless smart home integration.
Wyze Bulb Color: The Ultimate 16 Million Color Smart Bulb
Brilliant and Vibrant Lighting
Wyze Bulb Color is a standout smart bulb boasting an incredible 16 million colors to choose from. Whether you want to energize your living room with bright, vivid hues or create a cozy ambiance with soft pastels, this bulb delivers unmatched color accuracy and brightness.
- Brightness: 1100 Lumens for powerful illumination
- Color Options: 16 million colors plus tunable white light
- Color Rendering Index: 90+ for true-to-life colors
- Dimensions: Compact 2.5 x 2.5 x 5 inches
- Dimmable: Yes, with fine control via the Wyze app
Smart Features
Control your lighting effortlessly through the Wyze app. Set schedules, create custom scenes, or sync your lights with music for immersive experiences. The bulb also supports voice control with popular assistants, making it easy to adjust lighting hands-free.
"Wyze Bulb Color is the greatest 16 million color smart bulb on earth."
Experience vibrant color lighting in your living room with Wyze Bulb Color.
Wyze Light Strip: Brilliant LED Accent Lighting
Flexible and Colorful Accent Lighting
Add a splash of color to any space with the Wyze Light Strip. Perfect for under cabinets, behind sofas, or along shelves, this LED strip offers dynamic color changes controlled directly from your phone.
- Available Lengths: 16.4 feet and 32.8 feet options
- Color Control: Full RGB spectrum for millions of colors
- Easy Installation: Flexible strip with adhesive backing for versatile placement
Enhance Your Home Ambiance
Use the Wyze app to customize colors, brightness, and lighting effects. Whether you want subtle mood lighting or a vibrant party atmosphere, the Wyze Light Strip adapts to your lifestyle.
Create stunning accent lighting in your kitchen or living space with Wyze Light Strip.
Wyze Bulb Color BR30: Smart Recessed Lighting with Color Control
Perfect for Recessed Fixtures
The Wyze Bulb Color BR30 is designed to fit seamlessly into your existing recessed lighting fixtures, bringing smart color-changing capabilities to your ceiling lights.
- Color Range: 16 million ultra-accurate colors
- Brightness: Adjustable from 30 to 950 lumens
- Color Temperature: 1800K to 6500K tunable white
- Wattage Equivalent: 75W incandescent
- Dimmable: Yes, but not compatible with traditional dimmer switches
Smart Lighting Modes
Set the mood with custom lighting scenes, sleep routines, vacation mode, and music sync. Control your lights via the Wyze app or voice assistants for hands-free convenience.
"Light up your life with a dimmable, color-changing smart BR30 bulb."
Why Choose Wyze for Your Smart Lighting Needs?
Wyze smart lighting products combine affordability, advanced features, and easy app control to deliver a superior smart home lighting experience. With millions of colors, dimmable options, and seamless integration with voice assistants, Wyze lighting kits are perfect for anyone looking to upgrade their home ambiance with dynamic color changes.
Summary of Wyze App Controlled Lighting Products
Product | Key Features | Price Range |
Wyze Bulb Color | 16 million colors, 1100 lumens, dimmable | From $26.26 (2-pack) |
Wyze Light Strip | Flexible LED strip, multiple lengths | From $19.99 |
Wyze Bulb Color BR30 | Recessed fixture compatible, 16M colors, dimmable | From $27.98 (2-pack) |
Elevate your home lighting with Wyze’s dynamic color-changing smart bulbs and strips, all controllable through the intuitive Wyze app.
What is the Wyze App Controlled Lighting Kit?
The Wyze App Controlled Lighting Kit is a collection of smart lighting products from Wyze, including smart bulbs and LED light strips. These products feature dynamic color changes, app control, and seamless integration with smart home systems, allowing you to customize your home lighting experience easily.How many colors can the Wyze Bulb Color display?
The Wyze Bulb Color can display up to 16 million colors, offering a wide range of vibrant hues and tunable white light to suit any mood or occasion.What are the brightness and color rendering features of the Wyze Bulb Color?
The Wyze Bulb Color delivers 1100 lumens of powerful illumination and has a Color Rendering Index (CRI) of 90+, ensuring true-to-life and vivid colors in your home.Can I control Wyze smart lighting products with my phone?
Yes, all Wyze smart lighting products can be controlled through the Wyze app on your smartphone. The app allows you to adjust colors, brightness, set schedules, create custom scenes, and even sync your lights with music.Are Wyze lighting products compatible with voice assistants?
Yes, Wyze lighting products support popular voice assistants, enabling hands-free control of your lights using simple voice commands.What is the Wyze Light Strip and how is it used?
The Wyze Light Strip is a flexible LED accent lighting solution available in 16.4 and 32.8 feet lengths. It offers millions of color options and can be easily installed under cabinets, behind furniture, or along shelves using its adhesive backing. Control and customize the lighting effects directly from the Wyze app.What makes the Wyze Bulb Color BR30 suitable for recessed lighting?
The Wyze Bulb Color BR30 is specifically designed to fit into standard recessed lighting fixtures. It offers 16 million color options, adjustable brightness from 30 to 950 lumens, and tunable white light from 1800K to 6500K, making it ideal for ceiling installations.Are Wyze smart bulbs and light strips dimmable?
Yes, Wyze smart bulbs and light strips are dimmable through the Wyze app, allowing you to fine-tune the brightness to your preference. However, the Wyze Bulb Color BR30 is not compatible with traditional dimmer switches.What are the price ranges for Wyze smart lighting products?
Wyze smart lighting products are affordably priced. The Wyze Bulb Color starts from $26.26 for a 2-pack, the Wyze Light Strip starts from $19.99, and the Wyze Bulb Color BR30 starts from $27.98 for a 2-pack.Why should I choose Wyze for smart home lighting?
Wyze offers affordable, feature-rich smart lighting solutions with millions of color options, easy app control, dimmable settings, and compatibility with voice assistants. Their products are designed to enhance your home ambiance with dynamic color changes and seamless smart home integration.
