Voice Controlled Smart Bulbs for Dynamic Light Scenes
Transform your living space with voice-controlled smart bulbs designed to create vibrant, dynamic light scenes that match your mood, occasion, or daily routine. Whether you want to set a relaxing ambiance, energize your workspace, or throw a colorful party, these smart lighting solutions offer seamless control, rich colors, and smart integrations to elevate your home lighting experience.
Wyze Bulb Color: The Ultimate 16 Million Color Smart Bulb
Experience the pinnacle of smart lighting with the Wyze Bulb Color, the greatest 16 million color smart bulb on earth. This bulb is perfect for creating dynamic light scenes that respond to your voice commands and app controls.
Key Features:
  • Vibrant Color Range: Choose from 16 million colors to customize your lighting exactly how you want it.
  • Dimmable & Tunable White: Adjust brightness from 30 to 1100 lumens and color temperature from warm 1800K to cool 6500K.
  • High Color Rendering: With a CRI of 90+, colors appear vivid and natural.
  • Voice Control: Compatible with Alexa, Google Assistant, and IFTTT for effortless voice commands.
  • Connectivity: Supports 2.4GHz WiFi and Bluetooth for reliable smart home integration.
  • Long Life: Rated for 25,000 hours of use.
  • Suitable for Damp Locations: Perfect for kitchens, bathrooms, and other humid areas.
  • Energy Efficient: Consumes only 12 watts while delivering extra bright lighting.
"Wyze Bulb Color is an insufferable snob, but it's tough to get excited when you're the greatest 16 million color smart bulb on earth."
Wyze Bulb Color in Living Room Create vibrant, dynamic lighting scenes with Wyze Bulb Color
Wyze Light Strip: Brilliant LED Accent Lighting for Any Space
Add a splash of color and ambiance with the Wyze Light Strip, perfect for accentuating your home with brilliant LED lighting that you can control by voice or app.
Highlights:
  • 16 Million Colors: Customize your environment with a full spectrum of colors.
  • Flexible Lengths: Available in 16.4 feet and 32.8 feet options to fit any room or project.
  • Cuttable & Adhesive Backing: Easily mount and shape the strip to your desired layout.
  • Music Sync Feature: Lights pulse and change with the beat using the built-in microphone.
  • Voice & App Control: Works with Alexa, Google Assistant, and Bluetooth/WiFi connectivity.
  • Long Lifespan: Rated for 25,000 hours of vibrant lighting.
  • Indoor Use: Ideal for kitchens, living rooms, gaming setups, or home theaters.
"Color your world with brilliant LED accent lighting."
Wyze Light Strip Under Cabinet Enhance your home ambiance with Wyze Light Strip
Wyze Switch: Turn Any Light into a Voice-Controlled Smart Light
For those who want to upgrade existing lighting fixtures without replacing bulbs, the Wyze Switch offers a smart solution to control your lights with voice commands and app automation.
Features:
  • Smart Control Anywhere: Turn normal lights into smart lights controllable from anywhere via the Wyze app.
  • Multi-Tap Customization: Set single, double, or triple taps to control other Wyze devices like cameras, locks, or vacuums.
  • Automation & Scheduling: Create lighting automations, timers, and vacation modes to simulate presence.
  • Voice Assistant Integration: Compatible with Alexa and Google Assistant for hands-free control.
  • Power Loss Recovery: Automatically restores settings after power outages.
  • Easy Installation: Fits standard wall switch boxes and works with most home wiring setups.
"Turn normal lights into smart lights and control them from anywhere."
Wyze Switch in Kitchen Control your home lighting effortlessly with Wyze Switch
Why Choose Voice Controlled Smart Bulbs for Dynamic Scenes?
Voice-controlled smart bulbs like the Wyze Bulb Color and Wyze Light Strip allow you to effortlessly create immersive lighting environments. Whether you want to set a cozy warm white for reading, energize your morning with bright daylight tones, or paint your room with vibrant colors for a party, these bulbs respond instantly to your voice commands or app settings. The Wyze ecosystem, including the Wyze Switch, plugs, and other smart devices, ensures your entire home lighting and automation system works harmoniously. With integrations for Alexa, Google Assistant, and IFTTT, you can build complex scenes and routines that fit your lifestyle.
Summary of Voice Controlled Smart Lighting Products
ProductColors & BrightnessVoice ControlSpecial Features
Wyze Bulb Color16 million colors, 1100 lumensAlexa, Google, IFTTTTunable white, damp location ready
Wyze Light Strip16 million colors, LED stripAlexa, Google, BluetoothMusic sync, cuttable, adhesive mount
Wyze SwitchControls existing lightsAlexa, GoogleMulti-tap, automation, power recovery
Elevate your home lighting with these smart, voice-controlled solutions designed for dynamic, personalized light scenes.
FeatureWyze Bulb ColorWyze Light StripWyze Switch
TypeSmart LightingConnected HomeConnected Home
Variants2 Pack, 4 Pack, 6 Pack16.4 Feet, 32.8 Feet1 Pack, 3 Pack
Price Range$26.26 - $64.98$19.99 - $35.99$14.99 - $41.98
Brightness (Lumens)30 lm (dimmest) to 1100 lm (brightest)Not specified (LED accent lighting)N/A (Switch device)
Color Options16 million colors16 million colorsN/A
DimmableYes (but "takes offense" if used)Yes (implied via app control)N/A
White Light TemperatureYes, tunable whiteYes, Sun Match featureN/A
CRI Rating90+Not specifiedN/A
Voice ControlYes (Alexa, Google Assistant)Yes (Alexa, Google Assistant)Yes (via Wyze app integration)
App ControlYesYesYes
Music ModeYes (when grouped with Wyze Light Strip)YesN/A
Vacation ModeYesYesYes
Sleep RoutinesYesYesYes
GroupingYes (with other Wyze Bulbs and Light Strips)Yes (with Wyze Bulb Color and Light Strip Pro)N/A
Automation & TimersYesYesYes
Multi-tap ControlN/AN/AYes (custom actions for single, double, triple presses)
Integration with Wyze EcosystemYesYesYes
Power SourceStandard bulb socket (E26)Plug-in LED stripWired switch
Suitable ForIndoor, damp locationsIndoorIndoor
What are voice-controlled smart bulbs and how do they enhance home lighting?Voice-controlled smart bulbs are advanced lighting solutions that allow you to control your lights using voice commands or a mobile app. They enable you to create dynamic light scenes, adjust brightness and color, and integrate with smart home systems like Alexa and Google Assistant, making it easy to set the perfect ambiance for any occasion.
What makes the Wyze Bulb Color the best smart bulb for dynamic light scenes?The Wyze Bulb Color offers 16 million vibrant colors, adjustable brightness from 30 to 1100 lumens, and tunable white temperatures from 1800K to 6500K. With a high color rendering index (CRI 90+), voice control compatibility, and energy efficiency, it is ideal for creating personalized, dynamic lighting scenes in any room.
Can I control Wyze smart bulbs and light strips with Alexa or Google Assistant?Yes, both the Wyze Bulb Color and Wyze Light Strip are compatible with Alexa and Google Assistant, allowing you to control your lighting with simple voice commands. They also support IFTTT and app-based controls for seamless smart home integration.
What are the key features of the Wyze Light Strip for home accent lighting?The Wyze Light Strip features 16 million customizable colors, flexible lengths (16.4 ft and 32.8 ft), cuttable and adhesive backing for easy installation, a music sync feature that pulses lights to the beat, and compatibility with Alexa, Google Assistant, Bluetooth, and WiFi. It is perfect for accentuating kitchens, living rooms, gaming setups, and home theaters.
How does the Wyze Switch turn regular lights into smart lights?The Wyze Switch replaces your standard wall switch, allowing you to control existing lights via the Wyze app or voice assistants like Alexa and Google Assistant. It supports multi-tap customization, automation, scheduling, and power loss recovery, making it easy to upgrade your home lighting without changing bulbs.
Are Wyze smart lighting products energy efficient and long-lasting?Yes, Wyze smart lighting products like the Wyze Bulb Color and Wyze Light Strip are energy efficient, consuming only 12 watts for bright illumination and are rated for up to 25,000 hours of use, ensuring long-lasting performance and reduced energy costs.
Can Wyze smart bulbs and light strips be used in damp locations?The Wyze Bulb Color is suitable for damp locations such as kitchens and bathrooms, making it versatile for various home environments. The Wyze Light Strip is designed for indoor use and is ideal for accent lighting in living spaces.
What smart home integrations are available with Wyze lighting products?Wyze lighting products integrate with Alexa, Google Assistant, and IFTTT, allowing you to create complex scenes, routines, and automations that fit your lifestyle. The Wyze ecosystem also includes switches, plugs, and other smart devices for a fully connected home.
How easy is it to install Wyze smart lighting products?Wyze smart lighting products are designed for easy installation. The Wyze Bulb Color fits standard light sockets, the Wyze Light Strip features adhesive backing for quick mounting, and the Wyze Switch fits standard wall switch boxes and works with most home wiring setups.
What is the difference between Wyze Bulb Color, Wyze Light Strip, and Wyze Switch?The Wyze Bulb Color is a smart bulb offering 16 million colors and tunable white light. The Wyze Light Strip is a flexible LED strip for accent lighting with music sync and customizable lengths. The Wyze Switch is a smart wall switch that turns existing lights into smart lights with app and voice control, multi-tap customization, and automation features.
What are the key features of the Wyze Bulb Color?How does the voice control feature work with the Wyze Bulb Color?Do you have any deals, ongoing sales, discounts, or promotions?
