Wyze BR30 Smart Bulb: Colorful Notifications & Sleep Routines
Wyze BR30 Smart Bulb for Colorful Notifications and Sleep Routines
Transform your home lighting experience with the Wyze Bulb Color BR30, designed to bring vibrant, customizable illumination to your recessed lighting fixtures. Whether you want colorful notifications, mood lighting, or gentle sleep routines, this smart bulb offers a versatile and intuitive solution that integrates seamlessly into your smart home ecosystem.
Wyze Bulb Color BR30: The Ultimate Smart Bulb for Colorful Notifications
Brilliant Color Range and Dimmable Control
The Wyze Bulb Color BR30 lights up your space with 16 million ultra-accurate colors, allowing you to set the perfect ambiance for any occasion. From bright, energizing hues to soft, calming tones, this bulb covers a wide color temperature range of 1800K to 6500K and a lumen output from 30 to 950 lumens. Its dimmable feature lets you fine-tune brightness to suit your mood or activity.
Smart Features for Notifications and Routines
  • Colorful Notifications: Use the bulb to visually alert you with different colors for messages, reminders, or smart home events.
  • Sleep Routines: Program gentle lighting transitions that help you wind down and wake up naturally.
  • Voice Control: Compatible with Alexa and Google Assistant for hands-free operation.
  • Custom Lighting Scenes: Create personalized scenes for relaxation, focus, or entertainment.
  • Vacation Mode & Music Mode: Enhance your home’s atmosphere whether you’re away or hosting a party.
Technical Specs at a Glance
  • Power: 11.5W (equivalent to 75W incandescent)
  • Base: E26, BR30 shape fitting recessed fixtures
  • Life Expectancy: 25,000 hours
  • Connectivity: Wi-Fi (802.11 b/g/n 2.4GHz) and Bluetooth
  • Suitable for damp locations (not enclosed fixtures or dimmer switches)
  • Dimensions: 3.74" x 3.74" x 5.24"
  • Color Rendering Index: 90+
Wyze Bulb Color BR30 in cozy living room setting Experience vibrant color-changing smart lighting in your living room
Wyze Bulb Color: Versatile Smart Lighting for Every Room
If you want a more compact bulb with even higher brightness, the Wyze Bulb Color (A19 shape) is a fantastic alternative. It offers the same 16 million colors and dimmable white light with a maximum brightness of 1100 lumens, perfect for table lamps, ceiling fixtures, or accent lighting.
Features That Enhance Your Smart Home
  • Tunable white light from 1800K to 6500K for warm to cool lighting
  • Voice assistant compatibility (Alexa, Google Assistant)
  • Long lifespan of 25,000 hours
  • Suitable for damp locations but not enclosed fixtures
  • Connectivity via Wi-Fi and Bluetooth for easy app control
This bulb is ideal for colorful notifications and sleep routines, just like the BR30, but in a more traditional bulb shape. Wyze Bulb Color brightening a bedroom Create personalized lighting scenes for your bedroom or office
Wyze Bulb White: Simple, Bright, and Dimmable Lighting
For those who prefer classic white lighting with smart controls, the Wyze Bulb White offers a bright, dimmable light with color temperatures of 2700K (warm white) and 6500K (daylight). It’s perfect for everyday use in any room where you want reliable, adjustable white light.
Key Benefits
  • Brightness range: 30 to 800 lumens
  • Dimmable via app or voice commands
  • Compatible with Alexa, Google Assistant, and IFTTT
  • Long life expectancy of 25,000 hours
This bulb supports sleep routines by allowing you to set warm, relaxing light for bedtime and bright, energizing light for mornings. Wyze Bulb White creating cozy bedroom ambiance Perfect warm lighting for sleep routines and relaxation
Wyze Light Strip: Accent Your Space with Colorful LED Lighting
Complement your smart bulbs with the Wyze Light Strip, a flexible LED strip that adds brilliant accent lighting to kitchens, living rooms, or entertainment areas. Available in 16.4 ft and 32.8 ft lengths, it offers:
  • 16 million colors with customizable zones
  • Music mode using a built-in microphone for dynamic lighting effects
  • Easy installation with adhesive backing and cuttable design
  • 25,000 hours lifespan
Use the light strip to enhance notifications or create immersive sleep and relaxation environments with color and brightness control.
Why Choose Wyze Smart Lighting for Your Home?
Wyze smart bulbs and light strips combine affordability, advanced features, and seamless integration to elevate your home lighting experience. Whether you want colorful notifications, customizable sleep routines, or vibrant mood lighting, Wyze offers reliable, easy-to-use solutions that fit your lifestyle.
With a robust app, voice assistant compatibility, and long-lasting bulbs, Wyze smart lighting is the perfect choice for modern connected homes.
Summary of Featured Products
Wyze Bulb Color BR30 Wyze Bulb Color (A19) Wyze Bulb White Wyze Light Strip
Enhance your home with Wyze smart lighting and enjoy colorful notifications, soothing sleep routines, and dynamic lighting scenes tailored to your needs.
FeatureWyze Bulb Color BR30Wyze Bulb ColorWyze Bulb WhiteWyze Light Strip
TypeSmart BR30 BulbSmart A19 BulbSmart White A19 BulbLED Accent Light Strip
Shape/BaseBR30 shape, E26 baseA19 shape, E26 baseA19 shape, E26 baseStrip
Lumen Output30 lm (dim) - 950 lm (max)30 lm (dim) - 1100 lm (max)30 lm - 800 lmNot specified (per LED: Blue 0.8 lm, Red 1.0 lm, Green 2.5 lm per LED)
Wattage Equivalent75W75W9.5W16.4 ft = 18W, 32.8 ft = 36W
Color Options16 million colors16 million colorsWhite light only16 million colors
Color TemperatureTunable white, 1800K - 6500KTunable white, 1800K - 6500K2700K - 6500KRGB + tunable white
DimmableYes (Not for use with dimmer switches)YesYesYes
CRI Rating90+90+90+Not specified
ConnectivityWi-Fi (2.4 GHz), BluetoothWi-Fi (2.4 GHz), BluetoothWi-Fi (2.4 GHz), BluetoothWi-Fi (2.4 GHz), Bluetooth
Voice ControlAlexa, Google AssistantAlexa, Google AssistantAlexa, Google AssistantAlexa, Google Assistant
Special FeaturesSun Match, Brilliant notifications, Music Mode (with Light Strip), Sleep Routines, GroupingBrilliant notifications, Music Mode, Sleep Routines, GroupingDimmable white light, basic smart controlsMusic Mode, Adhesive backing, Cuttable, Indoor use only
Compatible with Wyze AppYesYesYesYes
Suitable for Damp LocationsNot specifiedNot specifiedYesNo
Life ExpectancyNot specifiedNot specified25,000 hours25,000 hours
Pack Variants & Price2-Pack $27.98, 4-Pack $49.982-Pack $26.26, 4-Pack $44.44, 6-Pack $64.982-Pack $23.99, 4-Pack $39.99, 6-Pack $59.9916.4 ft $19.99, 32.8 ft $35.99
What is the Wyze Bulb Color BR30 and what makes it unique?The Wyze Bulb Color BR30 is a smart bulb designed for recessed lighting fixtures, offering 16 million ultra-accurate colors, dimmable control, and a wide color temperature range from 1800K to 6500K. It supports colorful notifications, sleep routines, voice control, and custom lighting scenes, making it a versatile addition to any smart home.
How can I use Wyze smart bulbs for colorful notifications?Wyze smart bulbs, including the Bulb Color BR30 and A19, allow you to set different colors as visual alerts for messages, reminders, or smart home events. You can customize these notifications through the Wyze app to suit your preferences.
Can Wyze smart bulbs help with sleep routines?Yes, Wyze smart bulbs support sleep routines by allowing you to program gentle lighting transitions that help you wind down at night and wake up naturally in the morning. You can set warm, relaxing light for bedtime and bright, energizing light for mornings.
Are Wyze smart bulbs compatible with voice assistants?Wyze smart bulbs are compatible with Alexa and Google Assistant, enabling hands-free voice control for adjusting brightness, color, and turning the bulbs on or off.
What are the technical specifications of the Wyze Bulb Color BR30?The Wyze Bulb Color BR30 features 11.5W power (equivalent to 75W incandescent), an E26 base, BR30 shape, 16 million colors, 1800K–6500K color temperature, 30–950 lumens brightness, 25,000-hour lifespan, Wi-Fi and Bluetooth connectivity, and a color rendering index of 90+.
What is the difference between Wyze Bulb Color BR30 and Wyze Bulb Color (A19)?The Wyze Bulb Color BR30 is designed for recessed fixtures and offers up to 950 lumens, while the Wyze Bulb Color (A19) is a more compact bulb with a maximum brightness of 1100 lumens, suitable for table lamps, ceiling fixtures, or accent lighting. Both offer 16 million colors and dimmable white light.
Is the Wyze Bulb White suitable for smart home use?Yes, the Wyze Bulb White offers bright, dimmable white light with color temperatures from 2700K (warm white) to 6500K (daylight). It is compatible with Alexa, Google Assistant, and IFTTT, making it ideal for smart home integration.
Can Wyze smart bulbs be used in damp locations?Wyze smart bulbs are suitable for damp locations but should not be used in enclosed fixtures or with dimmer switches.
What is the Wyze Light Strip and how can it enhance my home lighting?The Wyze Light Strip is a flexible LED strip available in 16.4 ft and 32.8 ft lengths, offering 16 million colors, customizable zones, music mode, and easy installation. It is perfect for accent lighting in kitchens, living rooms, or entertainment areas, and can be controlled via Wi-Fi and Bluetooth.
How long do Wyze smart bulbs and light strips last?Wyze smart bulbs and light strips have a long lifespan of up to 25,000 hours, providing reliable and long-lasting smart lighting for your home.
What connectivity options do Wyze smart lighting products offer?Wyze smart lighting products connect via Wi-Fi (2.4GHz) and Bluetooth, allowing for easy app control and integration with your smart home ecosystem.
Why should I choose Wyze smart lighting for my home?Wyze smart lighting combines affordability, advanced features, and seamless integration with voice assistants and the Wyze app. Whether you want colorful notifications, customizable sleep routines, or vibrant mood lighting, Wyze offers reliable and easy-to-use solutions for modern connected homes.
What are the different color options available for the Wyze BR30 smart bulb?Can the Wyze BR30 smart bulb be used in outdoor settings?Do you have any ongoing sales or discounts for the Wyze BR30 smart bulb?
