Smart LED Bulbs with Voice Control for Alexa & Google Assistant – Color & White Options, Easy Home Automation
Smart LED Bulbs with Voice Integration for Alexa and Google Assistant
Discover the perfect smart LED bulbs that seamlessly integrate with Alexa and Google Assistant, bringing convenience, vibrant lighting, and smart home automation to your fingertips. Whether you want to set the mood with millions of colors or simply control your lighting hands-free, these smart bulbs offer the ultimate lighting experience.
Wyze Bulb Color – 16 Million Colors, Alexa & Google Compatible
Wyze Bulb Color in Living Room Alt: Colorful smart bulb lighting a cozy living room The Wyze Bulb Color is a standout smart LED bulb boasting 1100 lumens of brightness and an astonishing 16 million colors to choose from. Perfect for any occasion, this bulb lets you customize your lighting with precise color control and tunable white light, all accessible via voice commands through Alexa or Google Assistant.
Key Features:
  • Ultra Bright & Dimmable: Ranges from 30 lumens (soft glow) to 1100 lumens (bright light), adjustable to your preference.
  • 16 Million Colors & Tunable White: Create the perfect ambiance for game nights, relaxing evenings, or focused work.
  • 90+ CRI Rating: See true, vibrant colors in your home with high color accuracy.
  • Smart Automations: Set sleep routines, vacation mode, and visual notifications triggered by other Wyze devices.
  • Voice Control: Easily turn on/off, dim, or change colors using Alexa or Google Assistant.
  • Connectivity: Works on 2.4GHz Wi-Fi and Bluetooth, compatible with Android 9.0+ and iOS 15.0+.
  • Long Life: Rated for 25,000 hours of use.
Why Choose Wyze Bulb Color?
This bulb is designed for those who want more than just white light. Its rich color palette and smart features make it ideal for transforming your home environment with just your voice or a tap on the Wyze app.
Wyze Bulb White – Simple, Bright, and Voice-Enabled
Wyze Bulb White in Bedroom Alt: Warm white smart bulb lighting a cozy bedroom If you prefer classic white lighting with smart convenience, the Wyze Bulb White is your go-to option. It offers bright, dimmable white light with easy voice control via Alexa and Google Assistant.
Highlights:
  • Bright & Dimmable: Perfect for everyday use with adjustable brightness to suit your mood.
  • Voice Integration: Control your lighting hands-free with Alexa or Google Assistant.
  • Multiple Pack Options: Available in 2, 4, or 6 packs for whole-home lighting solutions.
  • Smart Features: Includes vacation mode and sleep routines for effortless automation.
  • Compatibility: Works with the Wyze app on Android and iOS devices.
This bulb is ideal for those who want reliable, bright white light with the added benefit of smart home integration.
Google Nest Audio + Wyze Bulb Color Bundles – Voice Control Made Easy
Enhance your smart home ecosystem with the Google Nest Audio + Wyze Bulb Color Bundles. These bundles combine the power of Google Nest Audio speakers with Wyze’s vibrant smart bulbs, allowing you to control your lighting and music with simple voice commands.
Bundle Benefits:
  • Google Assistant Built-In: Use voice commands to control your Wyze Bulb Color and play music seamlessly.
  • Adaptive Sound: Nest Audio adjusts to your environment for crisp, rich audio.
  • Multiple Color Options: Bundles available in Chalk, Grey, and White to match your home decor.
  • Convenient Control: Manage lighting scenes and music hands-free for a smarter living space.
This bundle is perfect for those looking to integrate smart lighting and voice-controlled audio in one package.
Why Choose Smart LED Bulbs with Alexa and Google Assistant?
Smart LED bulbs with voice integration offer unparalleled convenience, energy efficiency, and customization. Control your home lighting without lifting a finger, set schedules, and create the perfect atmosphere for any moment.
With Wyze’s smart bulbs and Google Nest Audio bundles, you get reliable, bright, and colorful lighting solutions that fit seamlessly into your smart home setup.
Summary of Featured Products
  • Wyze Bulb Color: 1100 lumens, 16 million colors, Alexa & Google compatible, dimmable, 25,000 hours lifespan.
  • Wyze Bulb White: Bright white light, dimmable, voice control, multiple pack sizes.
  • Google Nest Audio + Wyze Bulb Color Bundles: Voice-controlled smart speaker and bulb combo for enhanced smart home experience.
FeatureWyze Bulb Color - 1100 Lumens, 16M Color Smart BulbWyze Bulb WhiteGoogle Nest Audio + Wyze Bundles
TypeSmart LightingConnected HomeAudio + Connected Home Bundle
Lumens30 - 1100 lm30 - 800 lmN/A
Color Options16 million colors + tunable whiteTunable white (2700K - 6500K)N/A
Color Rendering Index (CRI)90+90+N/A
Power Consumption12 watts9.5 wattsN/A
ConnectivityWi-Fi 802.11 b/g/n 2.4GHz, BluetoothWi-Fi 802.11 b/g/n 2.4GHz, BluetoothWi-Fi 802.11 b/g/n/ac (2.4 GHz/5 GHz), Bluetooth 5.0
Voice Assistant IntegrationAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTGoogle Assistant built-in
Dimensions2.5” x 2.5” x 5”4.6” x 2.4” x 2.4”6.89” x 4.89” x 3.07”
Weight0.31 lbs0.31 lbs2.65 lbs (1.2 kg)
Base TypeE26E26N/A
Life Expectancy25,000 hours25,000 hoursN/A
Color Temperature Range1800K - 6500K2700K - 6500KN/A
Special Features- Brilliant notifications- Sun Match automatic color adjustment- Room-filling sound
- Sleep routines- Lightning fast setup- Stereo sound capability
- Music Mode sync with Wyze Light Strip- Sleep routines- Voice control for smart home devices
- Vacation Mode- Vacation Mode- Voice Match technology
Pack Variants & Prices2 Pack: $26.26, 4 Pack: $44.44, 6 Pack: $64.982 Pack: $23.99, 4 Pack: $39.99, 6 Pack: $59.99Bundles vary: $99.98 - $159.99 depending on included items
Suitable LocationsDamp locations, not for fully enclosed luminairesDamp locations, not for fully enclosed luminairesIndoor use
Operating Temperature Range-4°F to 104°F-4°F to 104°FN/A
What smart LED bulbs are compatible with Alexa and Google Assistant?Wyze Bulb Color and Wyze Bulb White are both smart LED bulbs that seamlessly integrate with Alexa and Google Assistant, allowing for hands-free voice control of your home lighting.
What are the key features of the Wyze Bulb Color?The Wyze Bulb Color offers 16 million colors, tunable white light, ultra-bright 1100 lumens, dimmable settings, 90+ CRI for vibrant color accuracy, smart automations like sleep routines and vacation mode, voice control via Alexa and Google Assistant, and compatibility with 2.4GHz Wi-Fi and Bluetooth. It is rated for 25,000 hours of use.
Can I control Wyze smart bulbs with my voice?Yes, both Wyze Bulb Color and Wyze Bulb White support voice control through Alexa and Google Assistant, allowing you to turn lights on or off, dim them, or change colors using simple voice commands.
What is the difference between Wyze Bulb Color and Wyze Bulb White?Wyze Bulb Color offers 16 million colors, tunable white light, and advanced smart features, making it ideal for creating different moods and ambiances. Wyze Bulb White provides bright, dimmable white light with voice control, perfect for those who prefer classic lighting with smart convenience.
Are Wyze smart bulbs energy efficient and long-lasting?Yes, Wyze smart bulbs are designed for energy efficiency and longevity. The Wyze Bulb Color, for example, is rated for 25,000 hours of use, providing reliable and cost-effective lighting.
What devices and platforms are Wyze smart bulbs compatible with?Wyze smart bulbs work with the Wyze app on Android (9.0+) and iOS (15.0+) devices. They connect via 2.4GHz Wi-Fi and Bluetooth, and are compatible with Alexa and Google Assistant for voice control.
What is included in the Google Nest Audio + Wyze Bulb Color Bundles?The Google Nest Audio + Wyze Bulb Color Bundles include a Google Nest Audio smart speaker and Wyze Bulb Color(s). This combination allows you to control your lighting and music with Google Assistant voice commands, offering adaptive sound and multiple color options to match your decor.
Can I buy Wyze Bulb White in multi-packs?Yes, Wyze Bulb White is available in 2, 4, or 6 pack options, making it easy to upgrade the lighting in multiple rooms throughout your home.
What smart features do Wyze bulbs offer for home automation?Wyze bulbs offer smart automations such as sleep routines, vacation mode, and visual notifications triggered by other Wyze devices, allowing you to customize your home lighting experience for convenience and security.
Why should I choose smart LED bulbs with Alexa and Google Assistant integration?Smart LED bulbs with Alexa and Google Assistant integration provide unparalleled convenience, energy efficiency, and customization. You can control your lighting hands-free, set schedules, and create the perfect atmosphere for any occasion, all while seamlessly integrating with your smart home ecosystem.
What are the key features of the Wyze Bulb Color?Can you tell me more about the Wyze Bulb White and its benefits?Do you have any deals, ongoing sales, discounts, or promotions for smart bulbs?
