Color Changing LED Bulbs with App-Controlled Sleep Routines
Discover the Best Color Changing LED Bulbs with App-Controlled Sleep Routines
Transform your home lighting experience with advanced color changing LED bulbs that offer seamless app control and customizable sleep routines. Whether you want to set the perfect ambiance for relaxation, energize your mornings, or create vibrant lighting scenes, these smart bulbs provide the ultimate convenience and versatility. Wyze offers a range of smart lighting solutions designed to fit your lifestyle, featuring millions of colors, tunable whites, and integration with popular voice assistants. Explore the top Wyze products that bring color, control, and comfort to your home.
Wyze Bulb Color: The Ultimate 16 Million Color Smart Bulb
Brilliant Color and Brightness Control
The Wyze Bulb Color is a standout smart bulb boasting an impressive 16 million colors and a wide color temperature range from warm 1800K to cool 6500K. With up to 1100 lumens of brightness, it can light up any room with vivid, customizable hues or soft, tunable white light.
App-Controlled Sleep Routines and Smart Features
Control your lighting effortlessly through the Wyze app, compatible with Android 9.0+ and iOS 15.0+. Set personalized sleep routines that gradually dim the light to help you unwind and fall asleep naturally. The bulb supports voice commands via Alexa, Google Assistant, and IFTTT, making it easy to integrate into your smart home ecosystem.
Durable and Energy Efficient
Rated for 25,000 hours of life expectancy and Energy Star certified, the Wyze Bulb Color is designed for long-lasting performance. It operates on 12 watts with a standard E26 base, fitting most fixtures, and is suitable for damp locations.
"Wyze Bulb Color is the greatest 16 million color smart bulb on earth."
Wyze Bulb Color in Living Room Experience vibrant, app-controlled lighting in your living space.
Wyze Bulb Color BR30: Perfect for Recessed Lighting Fixtures
Designed for Recessed Lighting
The Wyze Bulb Color BR30 is tailored for recessed lighting fixtures, offering the same 16 million color options and tunable white light as the A19 bulb but in a BR30 shape. It delivers a lumen range from 30 to 950, ideal for creating mood lighting or bright task lighting.
Sleep Routines and Smart Modes
This bulb supports app-controlled sleep routines, vacation mode, and music mode, allowing you to customize your lighting environment to match your lifestyle. Voice control compatibility with Alexa and Google Assistant adds hands-free convenience.
Reliable and Long-Lasting
With a life expectancy of 25,000 hours and a color rendering index of 90+, the BR30 bulb ensures accurate and vibrant colors. It operates at 11.5 watts and is suitable for damp locations but not for use with dimmer switches.
"Light up your life with a dimmable, color-changing smart BR30 bulb."
Smart Lighting Kits: Bulb Color + Light Strip Pro Bundles
Complete Color Lighting Solutions
For those looking to elevate their home lighting, Wyze offers smart lighting kits that bundle the Wyze Bulb Color or Bulb Color BR30 with the Wyze Light Strip Pro. These kits provide brilliant LED accent lighting with 16 million colors and customizable zones on the 16.4-foot light strip.
Enhanced Ambiance and Control
The Light Strip Pro features 16 customizable zones and supports multicolor lighting, perfect for accentuating rooms, furniture, or entertainment areas. Combined with the smart bulbs, you can create immersive lighting scenes controlled via the Wyze app or voice assistants.
Ideal for Indoor Use
Both the bulbs and light strips are designed for indoor use, with robust communication modes including Wi-Fi (802.11 b/g/n, 2.4 GHz) and Bluetooth. The kits come with a 1-year warranty, ensuring peace of mind.
"Color your world with brilliant LED accent lighting."
Cozy Bedroom with Color Changing Lighting Set relaxing sleep routines with smart color lighting.
Why Choose Wyze Smart Bulbs for Sleep Routines?
"App-controlled sleep routines help you wind down naturally."
  • Customizable Sleep Settings: Gradually dim lights or shift colors to promote relaxation and better sleep.
  • Voice and App Control: Easily adjust lighting without leaving your bed.
  • Energy Efficient: Save on electricity with long-lasting, low-power bulbs.
  • Wide Compatibility: Works with Android, iOS, Alexa, Google Assistant, and IFTTT.
  • Versatile Use: Suitable for bedrooms, living rooms, kitchens, and recessed lighting.
Conclusion
Upgrade your home lighting with Wyze’s color changing LED bulbs and smart lighting kits that offer app-controlled sleep routines and vibrant color options. Whether you prefer the classic A19 Wyze Bulb Color, the recessed lighting-friendly BR30, or a complete lighting kit with light strips, Wyze has the perfect smart lighting solution to enhance your comfort, convenience, and style.
FeatureWyze Bulb ColorWyze Bulb Color BR30Smart Lighting Kit - Bulb Color + Light Strip Pro Bundle
TypeSmart LightingConnected HomeSmart Lighting Bundle
Bulb ShapeA19BR30A19 Bulb + Light Strip Pro
Base TypeE26E26E26 (Bulb)
Lumen Output30 lm (dim) - 1100 lm (bright)30 lm (dim) - 950 lm (bright)30 lm - 1100 lm (Bulb)
Wattage Equivalent75W75W12 watts (Bulb)
Color Options16 million colors16 million colors16 million colors (Bulb and Light Strip Pro)
Color Temperature Range1800K - 6500K1800K - 6500K1800K - 6500K (Bulb)
Color Rendering Index (CRI)90+90+90+ (Bulb)
DimmableYes (but "takes offense" if used)Yes (not for use with dimmer switches)Yes (Bulb)
White Light Temperature ControlYesYesYes (Bulb)
Custom Presets & ScenesYesYesYes (Bulb)
Notifications & AutomationsYesYesYes (Bulb)
Sleep RoutinesYesYesYes (Bulb)
Music ModeYes (with grouping)Yes (with grouping)Yes (Bulb + Light Strip Pro)
Voice ControlAlexa, Google AssistantAlexa, Google AssistantAlexa, Google Assistant (Bulb)
Vacation ModeYesYesYes (Bulb)
GroupingYesYesYes (Bulb + Light Strip Pro)
Connectivity802.11 b/g/n, 2.4GHz, Bluetooth802.11 b/g/n, 2.4GHz, Bluetooth802.11 b/g/n, 2.4GHz, Bluetooth (Bulb and Light Strip Pro)
Phone CompatibilityAndroid 9.0+, iOS 15.0+Android 9.0+, iOS 15.0+Android 9.0+, iOS 15.0+ (Bulb)
Suitable for Damp LocationsYesNot specifiedYes (Bulb)
Life Expectancy25,000 HoursNot specified25,000 Hours (Bulb)
PowerNot specifiedNot specified12 watts (Bulb)
Light Strip LengthN/AN/A16.4 feet (Light Strip Pro)
Light Strip ColorsN/AN/A16 million colors (Light Strip Pro)
Light Strip Custom ZonesN/AN/A16 customizable zones (Light Strip Pro)
Price Range (USD)2 Pack: $26.26, 4 Pack: $44.44, 6 Pack: $64.982-Pack: $27.98, 4-Pack: $49.982 Pack Bulb + Light Strip Pro: $52.98, 4 Pack Bulb + Light Strip Pro: $74.97
What are the main features of Wyze color changing LED bulbs?Wyze color changing LED bulbs offer 16 million colors, tunable white light from 1800K to 6500K, app-controlled sleep routines, voice assistant compatibility (Alexa, Google Assistant, IFTTT), and energy efficiency with up to 25,000 hours of life expectancy.
How do I control Wyze smart bulbs and set sleep routines?You can control Wyze smart bulbs and set personalized sleep routines using the Wyze app, available for Android 9.0+ and iOS 15.0+. The app allows you to gradually dim lights or shift colors to help you relax and fall asleep naturally.
Are Wyze Bulb Color and Bulb Color BR30 compatible with voice assistants?Yes, both Wyze Bulb Color and Bulb Color BR30 are compatible with popular voice assistants, including Amazon Alexa, Google Assistant, and IFTTT, allowing for hands-free control of your lighting.
What is the difference between Wyze Bulb Color and Wyze Bulb Color BR30?Wyze Bulb Color is a standard A19 bulb suitable for most fixtures, while Wyze Bulb Color BR30 is designed specifically for recessed lighting fixtures. Both offer 16 million colors, tunable whites, and app-controlled features.
Can Wyze smart bulbs be used with dimmer switches?Wyze Bulb Color BR30 is not recommended for use with dimmer switches. For optimal performance, use the bulbs with standard on/off switches and control brightness through the Wyze app or voice assistants.
Are Wyze smart bulbs energy efficient?Yes, Wyze smart bulbs are Energy Star certified, operate at low wattages (12W for A19, 11.5W for BR30), and have a long life expectancy of up to 25,000 hours, making them energy efficient and cost-effective.
What is included in Wyze smart lighting kits?Wyze smart lighting kits bundle the Wyze Bulb Color or Bulb Color BR30 with the Wyze Light Strip Pro, providing a complete color lighting solution with 16 million colors, customizable zones, and app or voice control.
Where can Wyze color changing bulbs and light strips be used?Wyze color changing bulbs and light strips are designed for indoor use and are suitable for bedrooms, living rooms, kitchens, and recessed lighting fixtures. The bulbs are also rated for damp locations.
What connectivity options do Wyze smart lighting products offer?Wyze smart lighting products connect via Wi-Fi (802.11 b/g/n, 2.4 GHz) and Bluetooth, ensuring reliable communication and easy integration with your smart home ecosystem.
Do Wyze smart lighting products come with a warranty?Yes, Wyze smart bulbs and lighting kits come with a 1-year warranty, providing peace of mind and support for your purchase.
What features do the Wyze Bulb Color and BR30 have in common?Can I use the Wyze Bulb Color in damp locations?Do you have any deals, ongoing sales, discounts, or promotions?
