Wyze Voice Controlled Smart LED Bulbs—No Hub Needed
Voice Controlled Smart LED Bulb Setup No Hub Required
Discover the ultimate convenience and vibrant lighting options with Wyze’s voice-controlled smart LED bulbs that require no hub. Whether you want to brighten your living room, set the perfect mood in your bedroom, or add colorful accents to your home, Wyze smart bulbs offer seamless setup, rich features, and compatibility with popular voice assistants like Alexa and Google Assistant — all without the need for an additional hub.
Wyze Bulb Color: The Ultimate 16 Million Color Smart Bulb
Experience the brilliance of the Wyze Bulb Color, a smart LED bulb that delivers up to 1100 lumens of brightness and an astonishing 16 million colors to choose from. This bulb is perfect for those who want to customize their home lighting with vibrant hues or soft whites, tunable from 1800K warm to 6500K daylight.
  • Brightness: Extra bright at 1100 lumens, perfect for living rooms and kitchens.
  • Color Range: 16 million colors with tunable white light.
  • Dimmable: Yes, with precise control via the Wyze app or voice commands.
  • Connectivity: Works over 2.4GHz WiFi and Bluetooth, no hub required.
  • Voice Control: Compatible with Alexa, Google Assistant, and IFTTT.
  • Life Expectancy: Long-lasting 25,000 hours.
  • Suitable for Damp Locations: Yes, ideal for bathrooms and covered outdoor areas.
  • Easy Setup: Screw in the bulb, connect to your Wyze app, and start controlling with your voice.
“Wyze Bulb Color is the greatest 16 million color smart bulb on earth,” perfect for creating any ambiance you desire.
Wyze Bulb Color in Living Room Vibrant color-changing smart bulb lighting up a cozy living room
Wyze Bulb Color BR30: Smart Recessed Lighting with Voice Control
If you have recessed lighting fixtures, the Wyze Bulb Color BR30 is designed to fit perfectly and bring smart lighting to your ceiling. It offers the same 16 million colors and dimmable features as the standard Wyze Bulb Color but in a BR30 shape for recessed cans.
  • Brightness: Up to 950 lumens, with a wide lumen range from 30 to 950.
  • Color Temperature: 1800K to 6500K tunable white.
  • Dimmable & Color-Changing: Yes, with custom lighting scenes and music sync modes.
  • Voice Control: Works with Alexa and Google Assistant.
  • Connectivity: 2.4GHz WiFi and Bluetooth, no hub needed.
  • Life Expectancy: 25,000 hours.
  • Installation: Fits standard E26 sockets in recessed fixtures.
  • Special Features: Sleep routines, vacation mode, and music mode for immersive lighting experiences.
This bulb is not compatible with dimmer switches but offers full app and voice control for effortless lighting adjustments.
Wyze Bulb White: Bright, Dimmable White Light with Voice Control
For those who prefer classic white lighting, the Wyze Bulb White delivers bright, clean light with dimmable controls and voice assistant compatibility.
  • Brightness: Up to 800 lumens.
  • Color Temperature: Adjustable between 2700K warm white and 6500K cool white.
  • Dimmable: Yes, easily controlled via app or voice.
  • Connectivity: 2.4GHz WiFi and Bluetooth, no hub required.
  • Suitable for Damp Locations: Yes.
  • Easy Setup: Screw in, connect to the Wyze app, and control hands-free.
Perfect for bedrooms, offices, or any space where you want reliable white lighting with smart features. Wyze Bulb White in Bedroom Warm, dimmable white lighting creating a cozy bedroom atmosphere
Smart Lighting Kits: Bulb Color + Light Strip Pro Bundles
Take your smart lighting to the next level with Wyze’s Smart Lighting Kits that bundle the Wyze Bulb Color or Wyze Bulb Color BR30 with the Wyze Light Strip Pro. These kits provide brilliant LED accent lighting with full color customization and voice control — all without a hub.
  • Includes Wyze Bulb Color (2 or 4 pack) plus a 16.4-foot Wyze Light Strip Pro.
  • Light Strip Pro features 16 million colors with 16 customizable zones.
  • Perfect for accent lighting in living rooms, gaming setups, or entertainment areas.
  • Voice control via Alexa and Google Assistant.
  • Connectivity: 2.4GHz WiFi and Bluetooth.
  • Indoor use only, with a 1-year warranty.
Bulb Color BR30 + Light Strip Pro Bundle
  • Includes Wyze Bulb Color BR30 (2 or 4 pack) plus a 16.4-foot Wyze Light Strip Pro.
  • Ideal for recessed lighting plus colorful accent lighting.
  • Same advanced features as the Bulb Color bundle.
  • Easy voice control and app management.
These bundles offer a complete smart lighting solution for immersive, customizable home lighting without the hassle of a hub. Wyze Smart Lighting Lifestyle Colorful smart lighting enhancing a modern home office and entertainment space
Why Choose Wyze Voice Controlled Smart LED Bulbs?
“Set up your smart lighting in minutes with no hub required, and control your home lighting with just your voice.”
  • No Hub Needed: Connect directly to your home WiFi and control bulbs via the Wyze app or voice assistants.
  • Voice Assistant Integration: Works seamlessly with Alexa, Google Assistant, and IFTTT for hands-free control.
  • Wide Compatibility: Supports Android 9.0+ and iOS 15.0+ devices.
  • Energy Efficient: All bulbs are Energy Star certified with long life expectancy.
  • Versatile Use: Suitable for damp locations and various fixtures including recessed lighting.
  • Customizable Lighting: Choose from millions of colors or tunable white light to match any mood or occasion.
Upgrade your home lighting today with Wyze’s smart LED bulbs and enjoy effortless voice-controlled illumination without the complexity of hubs or extra devices.
Summary of Wyze Voice Controlled Smart LED Bulbs
ProductColor OptionsBrightness (Lumens)ShapeVoice ControlHub RequiredSpecial Features
Wyze Bulb Color16 million colorsUp to 1100A19YesNoDimmable, tunable white, IFTTT
Wyze Bulb Color BR3016 million colorsUp to 950BR30YesNoRecessed fixture compatible
Wyze Bulb WhiteWhite (2700K-6500K)Up to 800A19YesNoDimmable, bright white
Smart Lighting Kits (Bulb + Strip)16 million colorsVariesA19/BR30 + StripYesNoAccent lighting, customizable zones
Embrace smart lighting that’s easy to install, easy to control, and designed to fit your lifestyle perfectly.
FeatureWyze Bulb ColorWyze Bulb Color BR30Wyze Bulb WhiteSmart Lighting Kit - Bulb Color + Light Strip Pro BundleSmart Lighting Kit - Bulb Color BR30 + Light Strip Pro Bundle
TypeSmart LightingConnected HomeConnected HomeSmart LightingSmart Lighting
Shape/BaseA19 / E26BR30 / E26A19 / E26A19 / E26 (Bulb Color) + Light Strip ProBR30 / E26 (Bulb Color BR30) + Light Strip Pro
Pack Variants2 Pack, 4 Pack, 6 Pack2-Pack, 4-Pack2 Pack, 4 Pack, 6 Pack2 Pack, 4 Pack (Bulb Color) + 16.4 ft Light Strip ProBulb 2-Pack + 16.4 ft Light Strip Pro, Bulb 4-Pack + 16.4 ft Light Strip Pro
Price Range$26.26 - $64.98$27.98 - $49.98$23.99 - $59.99$52.98 - $74.97$53.98 - $77.97
Lumen Output30 lm (dim) - 1100 lm (bright)30 lm (dim) - 950 lm (bright)30 - 800 lm30 - 1100 lm (Bulb Color)30 - 950 lm (Bulb Color BR30)
Color Options16 million colors16 million colorsWhite light only16 million colors + Light Strip Pro16 million colors + Light Strip Pro
Color Temperature Range1800K - 6500K1800K - 6500K2700K - 6500K1800K - 6500K1800K - 6500K
CRI Rating90+90+90+90+90+
Power Consumption12 W11.5 W9.5 W12 W (Bulb Color)11.5 W (Bulb Color BR30)
Life Expectancy25,000 hours25,000 hours25,000 hours25,000 hours25,000 hours
Connectivity802.11 b/g/n, 2.4 GHz, Bluetooth802.11 b/g/n, 2.4 GHz, Bluetooth802.11 b/g/n, 2.4 GHz, Bluetooth802.11 b/g/n, 2.4 GHz, Bluetooth802.11 b/g/n, 2.4 GHz, Bluetooth
App CompatibilityAndroid 9.0+, iOS 15.0+Android 9.0+, iOS 15.0+Android 9.0+, iOS 15.0+Android 9.0+, iOS 15.0+Android 9.0+, iOS 15.0+
Voice Assistant IntegrationAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
DimmableYes (but "takes offense" humorously)Yes (not for use with dimmer switches)YesYesYes
Special FeaturesCustom presets, white light control, notifications, sleep routines, music modeSun Match, custom scenes, notifications, sleep routines, music modeDimmable white light onlyIncludes Wyze Light Strip Pro (16.4 ft), multicolor zones (16)Includes Wyze Light Strip Pro (16.4 ft), multicolor zones (16)
Suitable for Damp LocationsYesYesYesYesYes
Operating Temperature-4°F to 104°F-4°F to 104°F-4°F to 104°F-4°F to 104°F-4°F to 104°F
WarrantyNot specifiedNot specifiedNot specified1 Year1 Year
Do Wyze smart LED bulbs require a hub for setup?No, Wyze smart LED bulbs do not require a hub. They connect directly to your home WiFi (2.4GHz) and can be controlled via the Wyze app or voice assistants like Alexa and Google Assistant.
Are Wyze smart bulbs compatible with voice assistants?Yes, Wyze smart bulbs are compatible with popular voice assistants including Amazon Alexa, Google Assistant, and IFTTT, allowing for hands-free voice control.
What color options are available with Wyze Bulb Color and Wyze Bulb Color BR30?Both Wyze Bulb Color and Wyze Bulb Color BR30 offer 16 million color options, including tunable white light from 1800K warm to 6500K daylight, for complete customization of your home lighting.
Can Wyze smart bulbs be used in damp locations like bathrooms or covered outdoor areas?Yes, Wyze Bulb Color and Wyze Bulb White are suitable for damp locations, making them ideal for use in bathrooms and covered outdoor spaces.
How bright are Wyze smart LED bulbs?Wyze Bulb Color delivers up to 1100 lumens, Wyze Bulb Color BR30 provides up to 950 lumens, and Wyze Bulb White offers up to 800 lumens of brightness.
Are Wyze smart bulbs dimmable?Yes, all Wyze smart bulbs are dimmable and can be adjusted precisely using the Wyze app or through voice commands.
What is the life expectancy of Wyze smart LED bulbs?Wyze smart LED bulbs have a long life expectancy of up to 25,000 hours, making them a durable and energy-efficient lighting solution.
Can Wyze Bulb Color BR30 be used with dimmer switches?No, Wyze Bulb Color BR30 is not compatible with dimmer switches. However, you can control brightness and color through the Wyze app or voice assistants.
What special features do Wyze smart bulbs offer?Wyze smart bulbs offer features such as customizable lighting scenes, music sync modes, sleep routines, vacation mode, and accent lighting with the Light Strip Pro in smart lighting kits.
What is included in Wyze Smart Lighting Kits?Wyze Smart Lighting Kits include either Wyze Bulb Color or Wyze Bulb Color BR30 (in 2 or 4 packs) bundled with a 16.4-foot Wyze Light Strip Pro, providing full color customization and voice control for immersive accent lighting.
Are Wyze smart bulbs energy efficient?Yes, all Wyze smart LED bulbs are Energy Star certified, ensuring energy efficiency and cost savings over their long lifespan.
What devices are compatible with the Wyze app for controlling smart bulbs?The Wyze app supports Android devices running version 9.0 or higher and iOS devices running version 15.0 or higher.
How easy is it to set up Wyze smart LED bulbs?Wyze smart LED bulbs are easy to set up. Simply screw in the bulb, connect it to your 2.4GHz WiFi using the Wyze app, and start controlling your lighting with your smartphone or voice assistant.
Can I use Wyze smart bulbs for accent lighting and entertainment setups?Yes, Wyze smart bulbs and Light Strip Pro are perfect for accent lighting in living rooms, gaming setups, and entertainment areas, offering millions of colors and customizable zones.
How do I set up the Wyze Bulb Color with my voice assistant?Can the Wyze Bulb Color be used in damp locations?Do you have any deals, ongoing sales, discounts, or promotions?
