Wireless Linking Lamp Sockets for Synchronized Outdoor Smart Lighting
Wireless Linking of Lamp Sockets for Synchronized Outdoor Smart Lighting
Creating a synchronized outdoor smart lighting system has never been easier with Wyze’s innovative lamp sockets and camera bundles. Whether you want to power your Wyze cameras without the hassle of outlets or link multiple lamp sockets wirelessly for coordinated lighting, these products offer seamless integration, smart control, and reliable performance.
Pan v3 + Lamp Socket v2 Bundle: Smart Power Without Outlets
Key Features
- Wireless Power Solution: Power your Wyze Cam Pan v3 directly through the lamp socket without needing an external outlet.
- Compatibility: Supports Wyze Cam v3, v3 Pro, v4, OG, and Pan v3 cameras.
- Connectivity: Utilizes 802.11 b/g/n Wi-Fi (2.4GHz) and Bluetooth for stable wireless linking.
- Compact & Durable: Made from polycarbonate and plastic, measuring 56.5mm x 56.5mm x 65mm, weighing only 80g.
- Power Specs: Supports up to 20W max lamp power; recommended use with CFL or LED bulbs.
- Operating Range: Works in temperatures from -4°F to 120°F (-20°C to 50°C), suitable for damp outdoor locations (not waterproof).
- Smart Control: Compatible with Android 7.0+ and iOS 12.0+ for app-based scheduling and control.
This bundle is perfect for those looking to upgrade their exterior lighting with smart cameras powered wirelessly, enabling synchronized lighting scenes without the clutter of cords.
Cam v4 + Lamp Socket v2 Bundle: Limitless Linkability for Outdoor Lighting
Highlights
- Unlimited Wireless Linking: Connect multiple lamp sockets to create a synchronized lighting network outdoors.
- Motion-Activated Lights: Automatically trigger lights with motion detection for enhanced security and convenience.
- Dusk to Dawn Scheduling: Set your outdoor lights to operate automatically based on natural light conditions.
- Device Compatibility: Works with Wyze Cam v3, v3 Pro, v4, OG, Pan v3, and Duo Cam Pan.
- Robust Connectivity: Supports 2.4GHz Wi-Fi and Bluetooth for reliable communication between devices.
- Weather-Ready: Suitable for damp locations, perfect for front yards, patios, and garden lighting.
- Compact Design: Same size and weight as the Pan v3 bundle, ensuring easy installation in standard E26 lamp sockets.
The Cam v4 + Lamp Socket v2 Bundle is ideal for users who want to build a flexible, scalable outdoor smart lighting system with synchronized control and motion-triggered automation.
Wyze Lamp Socket v2: The Latest in Smart Lamp Socket Technology
Product Overview
- Universal Power Solution: Powers Wyze Cam v3, v3 Pro, v4, Cam OG, Pan v3, and Duo Cam Pan without an outlet.
- Wireless Linking: Enables multiple lamp sockets to communicate and synchronize lighting effortlessly.
- Smart Features: Includes motion-activated lighting and dusk-to-dawn scheduling for energy efficiency and security.
- Durability: Made with polycarbonate and plastic, designed for damp outdoor environments.
- Connectivity: 802.11 b/g/n Wi-Fi (2.4GHz) and Bluetooth ensure seamless device integration.
- Power Handling: Supports bulbs up to 20W; incandescent bulbs are not recommended due to thermal limits.
- Warranty: Comes with a 1-year warranty for peace of mind.
This lamp socket is the backbone for creating a wireless, synchronized outdoor lighting system that integrates perfectly with Wyze smart cameras.
Wyze Lamp Socket: The Original Smart Lamp Socket for Outdoor Lighting
Features
- Smart Power: Powers Wyze Cam v3 and v4 without the need for a plug.
- Linkability: Supports wireless linking for synchronized lighting setups.
- Motion-Activated & Scheduled Lighting: Automate your outdoor lights with motion sensors and dusk-to-dawn timers.
- Compatibility: Works with Android 7.0+ and iOS 12.0+ devices.
- Power & Connectivity: Supports 30W max lamp power, 120V 60Hz input, and connects via 2.4GHz Wi-Fi and Bluetooth.
- Weather Suitability: Designed for damp locations but not fully waterproof.
- Certifications: ETL, CETL, and UL certified for safety and reliability.
The original Wyze Lamp Socket remains a reliable choice for those starting their journey into wireless outdoor smart lighting.
Enhance Your Outdoor Smart Lighting with Wyze Bulb Color
While lamp sockets provide the power and connectivity backbone, pairing them with
Wyze Bulb Color elevates your outdoor lighting experience:
- 16 Million Colors: Customize your outdoor ambiance with vibrant color options.
- Dimmable: Adjust brightness to suit any mood or occasion.
- High Brightness: Up to 1100 lumens for clear, bright illumination.
- Smart Integrations: Works with Alexa, Google Assistant, and IFTTT for voice and automation control.
- Energy Efficient: Rated for 25,000 hours of life and Energy Star certified.
- Suitable for Damp Locations: Perfect for outdoor use in covered or damp areas.
Combine Wyze Bulb Color with lamp sockets for a fully synchronized, colorful, and smart outdoor lighting system.
Create synchronized outdoor smart lighting with Wyze lamp sockets and cameras.
Why Choose Wyze Wireless Lamp Sockets for Outdoor Smart Lighting?
- Wireless Linking: Easily link multiple lamp sockets to synchronize lighting across your outdoor spaces without complex wiring.
- Smart Automation: Motion detection and dusk-to-dawn scheduling provide hands-free control and energy savings.
- Wide Compatibility: Supports a broad range of Wyze cameras and smart bulbs.
- Compact & Easy Installation: Fits standard E26 lamp sockets and installs quickly.
- Durable for Outdoors: Designed for damp locations, perfect for porches, patios, and gardens.
- App Control: Manage your lighting system conveniently from your smartphone.
With Wyze’s wireless lamp sockets, you can transform your outdoor lighting into a smart, synchronized system that enhances security, convenience, and ambiance.
Summary of Wyze Wireless Lamp Socket Products for Outdoor Smart Lighting
Product | Max Lamp Power | Compatible Cameras | Key Features | Price (USD) |
Pan v3 + Lamp Socket v2 Bundle | 20W | Wyze Cam v3, v3 Pro, v4, OG, Pan v3 | Wireless power, app control | $53.96 |
Cam v4 + Lamp Socket v2 Bundle | 20W | Wyze Cam v3, v3 Pro, v4, OG, Pan v3, Duo Cam Pan | Unlimited linking, motion-activated | $49.96 |
Wyze Lamp Socket v2 | 20W | Wyze Cam v3, v3 Pro, v4, OG, Pan v3, Duo Cam Pan | Latest model, wireless linking | $16.98 |
Wyze Lamp Socket (Original) | 30W | Wyze Cam v3, v4 | Motion-activated, dusk-to-dawn | $16.98 |
Wyze Bulb Color | 12W | Compatible with lamp sockets | 16M colors, dimmable, smart voice | From $26.26 |
Harness the power of wireless linking with Wyze lamp sockets to create a synchronized, smart outdoor lighting system that is easy to install, energy-efficient, and fully controllable from your smartphone.
Feature | Pan v3 + Lamp Socket v2 Bundle | Cam v4 + Lamp Socket v2 Bundle | Wyze Lamp Socket v2 | Wyze Lamp Socket |
Product Type | Bundle | Bundle | Accessory | Accessory |
Included Items | Wyze Cam Pan v3 + Lamp Socket v2 | Wyze Cam v4 + Lamp Socket v2 | Lamp Socket v2 | Lamp Socket |
Compatible Cameras | Wyze Cam v3/v3 Pro/v4, Cam OG/OG Tele, Pan v3 | Wyze Cam v3/v3 Pro/v4, Cam OG/OG Tele, Pan v3 | Wyze Cam v3/v3 Pro/v4, Cam OG, Pan v3 | Wyze Cam v3/v4 |
Price | $53.96 | $49.96 | $16.98 | $16.98 |
Color Variants | Black, White | Black, Grey, White | White | White |
Max Lamp Power | 20W | 20W | 20W | 30W |
Power Input | 120V~, 60Hz | 120V~, 60Hz | 120V~, 60Hz | 120V, 60Hz |
Socket Connector Type | E26 | E26 | E26 | E26 |
Connectivity | 802.11 b/g/n, 2.4GHz, Bluetooth | 802.11 b/g/n, 2.4GHz, Bluetooth | 802.11 b/g/n, 2.4GHz, Bluetooth | 802.11 b/g/n, 2.4GHz, Bluetooth |
Weather Resistance | Suitable for damp locations (not waterproof) | Suitable for damp locations (not waterproof) | Suitable for damp locations (not waterproof) | Suitable for damp locations (not waterproof) |
Operating Temperature | -4°F to 120°F (-20°C to 50°C) | -4°F to 120°F (-20°C to 50°C) | -4°F to 120°F (-20°C to 50°C) | -4°F to 120°F (-20°C to 50°C) |
Dimensions | Not specified (bundle) | Not specified (bundle) | 56.5mm x 56.5mm x 65mm | 56.5mm x 56.5mm x 65mm |
Weight | Not specified (bundle) | Not specified (bundle) | 80 g | 80 g |
Materials | Not specified (bundle) | Not specified (bundle) | Polycarbonate, Plastic | Polycarbonate, Plastic |
Features | Powers Pan v3 without outlet, smart lighting, motion-activated lights, dusk to dawn automation, easy installation | Powers Cam v4 without outlet, smart lighting, motion-activated lights, dusk to dawn automation, easy installation | Powers multiple Wyze cams, smart lighting, motion-activated lights, dusk to dawn automation, easy installation | Powers Wyze Cam v3/v4, motion-activated lights, linkability, dusk to dawn scheduling |
Note | Use CFL or LED bulbs under 20W; no incandescent bulbs | Use CFL or LED bulbs under 20W; no incandescent bulbs | Use CFL or LED bulbs under 20W; no incandescent bulbs | Use CFL or LED bulbs; incandescent bulbs not recommended due to thermal limits |
Warranty | Not specified | Not specified | 1-Year | Not specified |
What is Wyze wireless lamp socket and how does it work for outdoor smart lighting?
Wyze wireless lamp sockets are smart devices that allow you to power Wyze cameras and control outdoor lighting without the need for external outlets or complex wiring. They enable wireless linking between multiple sockets for synchronized lighting, support motion-activated and dusk-to-dawn scheduling, and can be managed via the Wyze app on Android or iOS devices.Which Wyze cameras are compatible with Wyze Lamp Socket v2?
Wyze Lamp Socket v2 is compatible with Wyze Cam v3, v3 Pro, v4, Cam OG, Pan v3, and Duo Cam Pan cameras, allowing you to power and control these devices directly through the lamp socket.Can I link multiple Wyze lamp sockets wirelessly for synchronized outdoor lighting?
Yes, Wyze lamp sockets support wireless linking, allowing you to connect multiple sockets together for synchronized outdoor lighting. This feature enables coordinated lighting scenes and automation across your outdoor spaces.Are Wyze lamp sockets suitable for outdoor use?
Wyze lamp sockets are designed for damp outdoor locations such as porches, patios, and gardens. However, they are not fully waterproof and should not be exposed directly to heavy rain or submerged in water.What types of bulbs can I use with Wyze lamp sockets?
Wyze lamp sockets support CFL or LED bulbs up to 20W (for v2) or 30W (for the original version). Incandescent bulbs are not recommended due to thermal limits. For enhanced features, you can pair them with Wyze Bulb Color for customizable, energy-efficient lighting.How do motion-activated and dusk-to-dawn features work with Wyze lamp sockets?
Wyze lamp sockets offer motion-activated lighting, which automatically turns on lights when motion is detected, enhancing security and convenience. The dusk-to-dawn scheduling feature allows your outdoor lights to operate automatically based on natural light conditions, saving energy and providing hands-free control.What wireless connectivity do Wyze lamp sockets use?
Wyze lamp sockets utilize 802.11 b/g/n Wi-Fi (2.4GHz) and Bluetooth for stable wireless communication and easy integration with Wyze cameras and the Wyze app.Can I control Wyze lamp sockets and bulbs with my smartphone?
Yes, Wyze lamp sockets and compatible bulbs can be controlled via the Wyze app, available for Android 7.0+ and iOS 12.0+ devices. The app allows you to schedule, automate, and manage your outdoor lighting system remotely.What is the difference between Wyze Lamp Socket v2 and the original Wyze Lamp Socket?
Wyze Lamp Socket v2 is the latest model, supporting up to 20W bulbs and a wider range of Wyze cameras, including the Duo Cam Pan. It features improved wireless linking and smart automation. The original Wyze Lamp Socket supports up to 30W bulbs and is compatible with Wyze Cam v3 and v4. Both models offer motion-activated and scheduled lighting.Is there a warranty for Wyze lamp sockets?
Yes, Wyze Lamp Socket v2 comes with a 1-year warranty, providing peace of mind and reliable support for your smart outdoor lighting system.How can I enhance my outdoor lighting with Wyze Bulb Color?
Pairing Wyze lamp sockets with Wyze Bulb Color allows you to customize your outdoor ambiance with 16 million colors, adjustable brightness, and smart integrations with Alexa, Google Assistant, and IFTTT. Wyze Bulb Color is energy-efficient, suitable for damp locations, and rated for up to 25,000 hours of use.Are Wyze lamp sockets easy to install?
Yes, Wyze lamp sockets are compact and designed to fit standard E26 lamp sockets, making installation quick and straightforward without the need for additional wiring.What certifications do Wyze lamp sockets have?
Wyze lamp sockets are ETL, CETL, and UL certified, ensuring safety and reliability for your outdoor smart lighting setup.
Can you explain how the wireless linking feature works with the lamp sockets?What are the benefits of using the Cam v4 + Lamp Socket v2 Bundle for outdoor lighting?Do you have any deals, ongoing sales, discounts, or promotions available?
