Wyze Chime Controller Voltage Requirements & Installation Guide
Understanding Compatible Voltage Requirements for Wyze Chime Controller Installations
When installing the Wyze Doorbell Chime Controller, ensuring the correct voltage compatibility is crucial for optimal performance and to avoid issues such as the chime not ringing. This guide will walk you through the essential voltage requirements, compatibility checks, and installation tips to help you set up your Wyze Video Doorbell v2 with your existing mechanical chime system.
Voltage Requirements for Wyze Doorbell Chime Controller
Power Supply Specifications
The Wyze Video Doorbell v2 and its Chime Controller require a power input within a specific voltage range to function correctly:
  • Voltage Range: 16V to 24V AC
  • Power Output: Minimum 10VA transformer recommended, with 20-30VA preferred for reliable chime ringing
The minimum 16V 10VA transformer may power the doorbell but might not provide sufficient voltage to ring the chime effectively, especially if your home wiring is older or longer.
Transformer Considerations
  • Check Your Transformer: Locate the transformer near your chime box and verify its output voltage and VA rating.
  • Upgrade if Necessary: If your transformer is rated at 10VA and your chime does not ring after installation, consider upgrading to a 20-30VA transformer for better performance.
  • Consult a Licensed Electrician: Transformer replacement involves electrical work; always seek professional assistance to ensure safety and compliance.
Chime Compatibility with Wyze Doorbell Chime Controller
Mechanical vs. Battery-Powered Chimes
  • Compatible: Mechanical chimes powered by AC voltage within the 16-24V range.
  • Not Compatible: Battery-powered chimes or integrated chime systems that combine chime and transformer into one unit, especially those with complex circuitry or chip-controlled terminals.
Terminal Labels and Wiring
  • Typical chime terminals are labeled FRONT (F), BACK/REAR (R), and TRANS (T).
  • If your chime terminals are labeled differently (e.g., 0, 1, 2), refer to the Wyze Video Doorbell v2 Quick Start Guide for proper identification.
  • Chimes with terminals labeled COM or Computer indicate chip-controlled systems and are not compatible.
Chime Striking Type
  • Compatible: Standard mechanical chimes producing a short "ding" or "ding-dong" sound.
  • Not Compatible: Older chimes with long or slow series of strikes (e.g., “ding... ding... ding.”) or side-knocking round chimes and vintage long chimes.
If your chime is incompatible, consider the Wyze Video Doorbell Pro, which bypasses the existing chime and uses its own Bluetooth-enabled chime.
Installing the Wyze Doorbell Chime Controller
Installation Overview
1. Power Off: Turn off power to your existing mechanical doorbell at the electrical panel. 2. Open Chime Box: Take a photo of your current wiring for reference. 3. Wire the Chime Controller: Follow the Wyze app instructions to connect wires to the correct terminals based on your chime setup (2-wire, 3-wire, or more). 4. Secure Wiring: Use wire caps and ensure all connections are tight. 5. Restore Power: Turn power back on and test the doorbell and chime functionality. 6. Complete Setup: Close the chime box and proceed with mounting the doorbell.
Important Notes
  • Even if your existing chime is broken or non-functional, installing the Wyze Doorbell Chime Controller is recommended to protect your doorbell from power surges.
  • If you do not have an existing in-house chime or are unsure about wiring, stop and consult a licensed electrician.
  • The included fuse wire in the chime controller safeguards your doorbell from high voltage damage.
Troubleshooting Tips for Voltage and Chime Issues
  • Chime Not Ringing: Verify transformer voltage and VA rating; try alternate wiring instructions if comfortable.
  • Power Cycling: Power cycle your doorbell by turning off and on at the electrical panel to reset.
  • Firmware Updates: Ensure your Wyze Video Doorbell v2 firmware is up to date for optimal compatibility.
  • Wiring Check: Confirm all wires are connected to the correct terminals and that wire caps are secure.
Summary: Ensuring a Smooth Wyze Chime Controller Installation
  • Use a 16-24V AC transformer with at least 10VA, preferably 20-30VA.
  • Confirm your chime is a mechanical AC-powered chime with compatible terminal labels.
  • Follow the Wyze app installation guide carefully and consult a professional if unsure.
  • Install the Wyze Doorbell Chime Controller even if your chime is broken to protect your doorbell.
  • Upgrade your transformer or wiring if the chime does not ring after installation.
Proper voltage compatibility and wiring are key to enjoying the full benefits of your Wyze Video Doorbell v2 and its chime system.
Wyze Doorbell Installation Experience seamless integration of your Wyze Video Doorbell with your home’s existing chime system.
Additional Resources
  • Wyze Video Doorbell v2 Setup Guide
  • Alternate Wiring Instructions for Wyze Video Doorbell v2
  • Contact a Licensed Electrician for Transformer Upgrades
FeatureWyze Cam v4 Outdoor BundlePan v3 + Lamp Socket v2 BundleEssential Security BundleWyze Chime ControllerWyze Video Doorbell v2Wyze Video Doorbell Pro
Product TypeOutdoor Security Camera BundleCamera + Lamp Socket BundleSecurity Device BundleChime Controller AccessoryWired Video DoorbellWired/Wireless Video Doorbell
Price (USD)$69.99$53.96$199.99$17.99$44.98$99.98
Main ComponentsWyze Cam v4, Outdoor Power Adapter, 128GB microSDWyze Cam Pan v3, Lamp Socket v2Video Doorbell v2, Lock Bolt, Cam Pan v3, 2× Cam OG1x Chime Controller UnitVideo Doorbell v2 + Chime ControllerVideo Doorbell Pro + Chime
Camera Resolution2.5K QHD (2560x1440)Pan v3: Not specified (assumed 1080p)Doorbell: 1080p HD, Cam Pan v3: Not specifiedN/A2K (2048x1536)HD (exact resolution not specified)
Night VisionEnhanced Color Night VisionColor Night Vision (Pan v3)Color Night Vision (Cam Pan v3, Cam OG)N/AIR Night Vision (6 x 940nm IR lights)Motion-activated security light
AudioTwo-way audio (via app)Two-way audio (Pan v3)Two-way audio (Cam Pan v3)N/ATwo-way audioTwo-way audio
Power SourceWired (Outdoor Power Adapter included)Powered via Lamp Socket (no outlet needed)Mixed (varies per device)Wired (AC16V/AC24V)Wired (16V-24V AC)Wired or Battery
ConnectivityWi-Fi 6 supportWi-Fi 2.4GHz, BluetoothWi-Fi (varies per device)AC poweredWi-Fi 2.4GHz b/g/nDual-band Wi-Fi
Smart Home IntegrationAlexa, Google AssistantCompatible with Wyze appAlexa, Google Assistant (varies per device)Compatible with mechanical chimesAlexa, Google Assistant, IFTTTAlexa, Google Assistant
Motion DetectionYes, with motion-activated spotlightYes, motion-activated lightsYes, with motion-activated spotlights (Cam OG)N/AYesYes
Local Storage24/7 local recording with microSDN/ALocal and cloud recording (varies per device)N/AmicroSD up to 256GBCloud storage with Cam Plus
Cloud StorageOptional Cam Plus subscriptionN/AIncluded with subscription plansN/AOptional with Wyze Security PlanIncluded with Cam Plus subscription
Weather ResistanceOutdoor rated (with adapter)Lamp Socket not weatherproof, suitable for dampIP65 rating on camerasIndoor useIP65Not specified
Field of ViewNot specifiedPan v3: 360° horizontal, 180° vertical tiltCam Pan v3: 360° horizontal, 180° vertical tiltN/A135° horizontal, 103° vertical, 166.8° diagonalUltra-wide viewing angle
Special FeaturesMotion-activated spotlight, Enhanced Color Night Vision, Wi-Fi 6Powers camera via lamp socket, motion-activated lights, dusk to dawn schedulingIncludes smart lock with fingerprint sensor, multiple cameras, two-way audioCompatible with nearly every mechanical chimeMotion-activated voice deterrence, wedge includedBattery or wired, 20 unique chime tunes, quick install
WarrantyNot specified1 YearNot specifiedNot specified1 YearNot specified
What is the required voltage for installing the Wyze Doorbell Chime Controller?The Wyze Doorbell Chime Controller requires a transformer that supplies 16V to 24V AC. For optimal performance, a transformer with a minimum of 10VA is needed, but a 20-30VA transformer is preferred to ensure reliable chime ringing.
How do I check if my existing doorbell transformer is compatible with the Wyze Chime Controller?Locate your transformer, usually near the chime box, and check its output voltage and VA rating. The transformer should provide 16-24V AC and at least 10VA. If your chime does not ring after installation, consider upgrading to a 20-30VA transformer.
Are battery-powered chimes compatible with the Wyze Doorbell Chime Controller?No, battery-powered chimes and integrated chime systems with complex circuitry or chip-controlled terminals are not compatible with the Wyze Doorbell Chime Controller. Only mechanical chimes powered by AC voltage within the 16-24V range are supported.
What types of chimes work with the Wyze Video Doorbell v2 and Chime Controller?The Wyze Video Doorbell v2 and Chime Controller are compatible with standard mechanical chimes that produce a short 'ding' or 'ding-dong' sound and are powered by 16-24V AC. Chimes with long or slow series of strikes, side-knocking round chimes, or vintage long chimes are not compatible.
What should I do if my chime terminals are labeled differently than FRONT, REAR, or TRANS?If your chime terminals are labeled differently (such as 0, 1, 2), refer to the Wyze Video Doorbell v2 Quick Start Guide for proper identification. Chimes with terminals labeled COM or Computer indicate chip-controlled systems and are not compatible.
Can I install the Wyze Doorbell Chime Controller if my existing chime is broken?Yes, it is recommended to install the Wyze Doorbell Chime Controller even if your existing chime is broken or non-functional. The controller helps protect your doorbell from power surges and high voltage damage.
What are the steps to install the Wyze Doorbell Chime Controller?To install the Wyze Doorbell Chime Controller: 1) Turn off power at the electrical panel, 2) Open the chime box and take a photo of the wiring, 3) Connect the chime controller wires as instructed in the Wyze app, 4) Secure all connections with wire caps, 5) Restore power and test the system, 6) Complete setup and close the chime box.
What should I do if my Wyze doorbell chime is not ringing after installation?If your chime is not ringing, verify that your transformer provides the correct voltage (16-24V AC) and VA rating (preferably 20-30VA). Check all wiring connections, try alternate wiring instructions if comfortable, and ensure your doorbell firmware is up to date. If issues persist, consult a licensed electrician.
Is it necessary to consult a licensed electrician for Wyze Doorbell Chime Controller installation?It is recommended to consult a licensed electrician if you need to upgrade your transformer, are unsure about wiring, or do not have an existing in-house chime. Electrical work can be hazardous and should be performed safely and in compliance with local codes.
Why is the included fuse wire important in the Wyze Doorbell Chime Controller?The included fuse wire in the Wyze Doorbell Chime Controller safeguards your doorbell from high voltage damage and power surges, ensuring the longevity and safety of your device.
What should I do if my chime won't ring after installing the Wyze Doorbell Chime Controller?How can I power cycle my Wyze Video Doorbell v2?Are there alternate wiring instructions available for the Wyze Video Doorbell v2?
