Where to Buy Replacement Mounting Kits for Wyze Cam V2, V3, and V3 Pro
If you own a Wyze Cam V2, V3, or V3 Pro and are looking for replacement mounting kits, it’s important to choose accessories that perfectly fit your camera model to ensure secure installation and optimal performance. While Wyze does not list a dedicated "mounting kit" specifically for V2 or V3 in the current product lineup, the
Wyze Cam v3 Spotlight Kit is a highly compatible accessory designed to enhance your Wyze Cam V3 experience with a motion-activated spotlight and mounting options. Additionally, the mounting options included with the latest Wyze Cam v4 models provide versatile and durable mounting solutions that can inspire your replacement needs.
Wyze Cam v3 Spotlight Kit: The Perfect Accessory for V3 Mounting Needs
Key Features:
- Motion-Activated Spotlight: Bright 70 lumens with 5 LEDs and a 130-degree beam angle to illuminate your camera’s field of view.
- IP65 Weather Rating: Durable and weather-resistant, suitable for both indoor and outdoor use.
- Compact Dimensions: 21.5 x 55.8 x 34.4 mm, easy to mount alongside your Wyze Cam V3.
- Power Supply: Powered via 5V 1A through a Micro USB connection.
- Included in Box: Spotlight unit and USB cable splitter for easy power management.
- Warranty: 1-year coverage for peace of mind.
This kit is ideal if you want to upgrade your Wyze Cam V3 with enhanced lighting and a reliable mounting solution that withstands outdoor conditions.
Mounting Options Included with Wyze Cam v4 Models
While the Wyze Cam V2 and V3 are older models, the Wyze Cam v4 series offers a glimpse into the mounting versatility you can expect from Wyze accessories, which may be compatible or adaptable for your older cameras.
Mounting Features:
- Multiple Mounting Options: Stand, wall mount, ceiling mount, and magnetic wall mount with adhesive.
- Included Mounting Hardware: Wall mount plate, tape, and screw kit come standard with Wyze Cam v4.
- Compact and Lightweight: Dimensions of 2in x 2in x 2 3/8in and weight of 0.49 lb (222 g) make mounting easy and flexible.
- Weather Resistance: IP65 rating ensures durability in various environments.
- Cable Length: 6-foot flat micro USB to USB-A cable for flexible placement.
These mounting options provide a secure and adaptable setup for your camera, whether indoors or outdoors.
Why Choose Official Wyze Accessories for Mounting?
Using official Wyze mounting kits and accessories guarantees compatibility, durability, and optimal performance for your Wyze cameras. Non-official mounts may not fit perfectly or could compromise the camera’s weather resistance and stability.
- Designed for Wyze Cameras: Perfect fit and secure installation.
- Weatherproof Materials: Ensure your camera stays protected.
- Easy Installation: Comes with all necessary hardware and instructions.
- Enhanced Functionality: Some kits, like the Spotlight Kit, add extra features such as motion-activated lighting.
Lifestyle Image: Secure Your Home with Wyze Cam and Accessories
Enhance your home security with Wyze Cam and reliable mounting solutions.
Summary
If you need a replacement mounting kit for your Wyze Cam V2, V3, or V3 Pro, the
Wyze Cam v3 Spotlight Kit is a great accessory that includes mounting hardware and adds a powerful spotlight feature. For inspiration or alternative mounting solutions, the mounting options included with the Wyze Cam v4 models demonstrate the versatility and quality you can expect from Wyze accessories.
Investing in official Wyze mounting kits ensures your camera stays securely installed and protected, maintaining the high performance and reliability Wyze is known for.
Product Highlights
- Motion-activated 70-lumen spotlight
- IP65 weather-resistant
- Easy Micro USB power connection
- Compact and durable design
Wyze Cam v4 Mounting Options
- Stand, wall, ceiling, and magnetic mounts
- Includes wall mount plate, tape, and screws
- IP65 weather resistance
- 6-foot micro USB cable included
Where can I buy replacement mounting kits for Wyze Cam V2, V3, and V3 Pro?
While Wyze does not offer a dedicated replacement mounting kit specifically for the V2 or V3 models, the Wyze Cam v3 Spotlight Kit is a highly compatible accessory for the Wyze Cam V3. It includes mounting hardware and a motion-activated spotlight. For additional inspiration, the mounting options included with the Wyze Cam v4 models offer versatile solutions that may be adaptable for older cameras.What is included in the Wyze Cam v3 Spotlight Kit?
The Wyze Cam v3 Spotlight Kit includes a motion-activated spotlight unit, a USB cable splitter for easy power management, and mounting hardware. The spotlight is weather-resistant (IP65 rated), compact, and designed to enhance your Wyze Cam V3 with additional lighting and secure installation.Are Wyze Cam v4 mounting options compatible with Wyze Cam V2 or V3?
The mounting options included with Wyze Cam v4 models, such as stand, wall, ceiling, and magnetic mounts, are designed for the v4 but may be adaptable for use with Wyze Cam V2 or V3. However, compatibility is not officially guaranteed, so it is recommended to use official accessories designed for your specific camera model whenever possible.Why should I use official Wyze mounting kits and accessories?
Official Wyze mounting kits and accessories are specifically designed for Wyze cameras, ensuring a perfect fit, secure installation, and optimal performance. They are made from weatherproof materials, come with all necessary hardware, and often include enhanced features like motion-activated lighting. Using non-official mounts may compromise your camera’s stability and weather resistance.Is the Wyze Cam v3 Spotlight Kit weather-resistant?
Yes, the Wyze Cam v3 Spotlight Kit is IP65 weather-resistant, making it suitable for both indoor and outdoor use. This ensures your camera and spotlight remain protected in various weather conditions.What mounting options are available with Wyze Cam v4 models?
Wyze Cam v4 models come with multiple mounting options, including stand, wall mount, ceiling mount, and magnetic wall mount with adhesive. The package also includes a wall mount plate, tape, screw kit, and a 6-foot flat micro USB to USB-A cable for flexible placement.What are the benefits of upgrading to the Wyze Cam v3 Spotlight Kit?
Upgrading to the Wyze Cam v3 Spotlight Kit provides your camera with a motion-activated 70-lumen spotlight, enhanced security through better illumination, weather-resistant durability, and easy installation with included mounting hardware and power management accessories.
