Wyze Lock Bolt: Smart Deadbolt with Anti-Peep Keypad Codes
Discover the Smart Deadbolt with Anti-Peep Feature: Wyze Lock Bolt
When it comes to securing your home with smart technology, the Wyze Lock Bolt stands out as the premier choice for those seeking advanced security combined with convenience. If you're specifically looking for a smart deadbolt that offers an anti-peep feature on keypad codes, the Wyze Lock Bolt is the perfect solution.
Wyze Lock Bolt: Advanced Security Meets User-Friendly Design
Anti-Peep Technology for Secure Code Entry
One of the most innovative features of the Wyze Lock Bolt is its anti-peep technology. This feature allows you to enter your access code with extra random digits before or after the actual code, ensuring that anyone watching cannot guess your real code. For example, if your code is "1234," you can enter "987123456" or "1234987" and the lock will still recognize and unlock the door.
This anti-peep functionality provides peace of mind when entering your home in public or when someone might be nearby watching your keypad.
Key Features of Wyze Lock Bolt
  • Fingerprint Unlock: Unlock your door in less than a second with an ultra-fast fingerprint sensor, eliminating the need for keys or codes.
  • Backlit Keypad: The keypad is luxuriously backlit for easy use at night or in low-light conditions.
  • Auto-Lock: Never worry about forgetting to lock your door. The lock auto-locks after a customizable delay.
  • Pick-Proof & Weatherproof: With no keyhole, the lock is pick-proof and rated IPX5 for weather resistance.
  • Long Battery Life: Powered by 4 AA batteries lasting up to 12 months, with emergency USB-C charging if batteries run low.
  • App Control: Manage access codes, fingerprints, and view lock history via the Wyze app within Bluetooth range.
  • One-Time Emergency Codes: Generate temporary access codes remotely that expire every 4 hours for guests or service providers.
Easy Installation & Stylish Design
The Wyze Lock Bolt replaces your existing deadbolt and installs in about 20 minutes on most US doors. Its solid metal construction and sleek design complement any home exterior, blending security with style. Wyze Lock Bolt Lifestyle Secure your home effortlessly with Wyze Lock Bolt’s smart technology.
Why Choose Wyze Lock Bolt for Anti-Peep Smart Deadbolt?
Enhanced Security Without Compromise
Traditional locks can be picked or compromised, but Wyze Lock Bolt removes the keyhole entirely, making it pick-proof. The anti-peep keypad ensures your code remains confidential even if someone is watching.
Convenient Access for Everyone
Create up to 20 unique access codes and store up to 50 fingerprints for family and guests. You can also set schedules and auto-expiring codes to control when and how your lock is accessed.
Local Bluetooth Control with Strong Encryption
Wyze Lock Bolt operates primarily via local Bluetooth connection, ensuring your data is encrypted and secure without relying on cloud services. Two-factor authentication in the app adds an extra layer of protection.
Other Wyze Products (Not Featuring Anti-Peep)
While the Wyze Sense Keypad and Wyze Garage Door Controller are excellent smart home devices, they do not offer the anti-peep feature on keypad codes.
  • Wyze Sense Keypad: Designed for disarming Wyze Home Monitoring systems remotely, it requires the Wyze Sense Hub and does not function as a standalone smart lock keypad.
  • Wyze Garage Door Controller: Provides remote control and monitoring of your garage door with AI vision sensing but is unrelated to door deadbolt security or keypad anti-peep features.
Summary
If your priority is a smart deadbolt with an anti-peep keypad feature, the Wyze Lock Bolt is the clear choice. It combines cutting-edge security, ease of use, and stylish design, making it a top-rated smart lock for modern homes.
Protect your home with confidence — enter your code securely with Wyze Lock Bolt’s anti-peep technology.
Wyze Lock Bolt App Control Manage your lock and access codes easily through the Wyze app.
Product Details at a Glance
FeatureWyze Lock Bolt
Anti-Peep KeypadYes
Fingerprint UnlockYes
Auto-LockYes
Battery LifeUp to 12 months
Weatherproof RatingIPX5
Access CodesUp to 20 unique codes
Fingerprints StoredUp to 50
Emergency One-Time CodesYes, expires every 4 hours
Installation Time~20 minutes
What is the Wyze Lock Bolt and how does it enhance home security?The Wyze Lock Bolt is a smart deadbolt designed to provide advanced home security with features like anti-peep keypad technology, fingerprint unlock, auto-lock, and pick-proof construction. It replaces your existing deadbolt and offers convenient, keyless entry while ensuring your access codes remain confidential.
How does the anti-peep feature work on the Wyze Lock Bolt keypad?The anti-peep feature allows you to enter random digits before or after your actual access code on the keypad. For example, if your code is '1234', you can enter '987123456' or '1234987', and the lock will still recognize your code. This prevents anyone watching from guessing your real code, enhancing your security.
Can I unlock the Wyze Lock Bolt with my fingerprint?Yes, the Wyze Lock Bolt features an ultra-fast fingerprint sensor that allows you to unlock your door in less than a second, eliminating the need for keys or codes.
Is the Wyze Lock Bolt weatherproof and pick-proof?Yes, the Wyze Lock Bolt is rated IPX5 for weather resistance and is pick-proof because it has no keyhole, making it highly secure against traditional lock-picking methods.
How long does the Wyze Lock Bolt battery last and what happens if it runs low?The Wyze Lock Bolt is powered by 4 AA batteries that last up to 12 months. If the batteries run low, you can use emergency USB-C charging to temporarily power the lock and gain access.
How many access codes and fingerprints can I store on the Wyze Lock Bolt?You can store up to 20 unique access codes and up to 50 fingerprints, making it easy to provide secure access for family members and guests.
Does the Wyze Lock Bolt have an auto-lock feature?Yes, the Wyze Lock Bolt includes an auto-lock feature that automatically locks your door after a customizable delay, so you never have to worry about forgetting to lock up.
Can I control the Wyze Lock Bolt with my smartphone?Yes, you can manage access codes, fingerprints, and view lock history through the Wyze app when within Bluetooth range. The app also allows you to generate one-time emergency codes remotely.
What is a one-time emergency code and how does it work?A one-time emergency code is a temporary access code you can generate via the Wyze app. It expires every 4 hours, making it ideal for granting short-term access to guests or service providers.
How easy is it to install the Wyze Lock Bolt?The Wyze Lock Bolt is designed for easy installation, replacing your existing deadbolt in about 20 minutes on most US doors. No professional installation is required.
Does the Wyze Lock Bolt require an internet connection to operate?No, the Wyze Lock Bolt operates primarily via local Bluetooth connection, ensuring your data is encrypted and secure without relying on cloud services.
Is the anti-peep feature available on other Wyze products like the Wyze Sense Keypad or Wyze Garage Door Controller?No, the anti-peep keypad feature is exclusive to the Wyze Lock Bolt. The Wyze Sense Keypad and Wyze Garage Door Controller do not offer this functionality.
What makes the Wyze Lock Bolt a top choice for a smart deadbolt with anti-peep technology?The Wyze Lock Bolt combines anti-peep keypad security, fingerprint unlock, auto-lock, pick-proof design, and easy app management, making it a leading choice for homeowners seeking a secure and convenient smart deadbolt.
What are the key features of the Wyze Lock Bolt besides the anti-peep technology?How does the fingerprint unlock feature work on the Wyze Lock Bolt?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Lock Bolt?
