Smart Deadbolt Replacement with Auto Lock & Backlit Keypad
Smart Deadbolt Replacement with Auto Lock and Backlit Keypad
Upgrade your home security and convenience with the latest in smart deadbolt technology. If you're searching for a smart deadbolt replacement that features auto-lock capabilities and a luxurious backlit keypad, the Wyze Lock Bolt stands out as an exceptional choice. Designed to replace your existing deadbolt seamlessly, it combines advanced biometric access with smart app control, ensuring your home is both secure and easy to access.
Wyze Lock Bolt: The Ultimate Smart Deadbolt Replacement
Key Features and Benefits
Ultra-Fast Fingerprint Reader Unlock your door in less than a second with a simple touch of your finger. The Wyze Lock Bolt’s fingerprint sensor is designed for speed and accuracy, eliminating the need for fumbling with keys or codes. Luxurious Backlit Keypad The solid metal exterior features a backlit keypad, making it easy to enter your access code even in complete darkness. The keypad also incorporates anti-peep technology, allowing you to enter extra digits before or after your code to prevent onlookers from guessing your combination. Auto-Lock for Peace of Mind Never worry about leaving your door unlocked again. The Wyze Lock Bolt includes an auto-lock timer that you can customize via the Wyze app. After your set delay, the lock automatically secures your door. Robust Security and Durability This smart lock is fully pick-proof by design, removing the need for physical keys. It also boasts IPX5 weatherproofing, making it tough enough to withstand rain and other elements. Long Battery Life with Backup Charging Powered by 4 AA batteries, the lock can last up to 12 months on a single set. If the batteries run low or die, a USB-C port allows for a quick emergency charge so you can still enter your access code. Easy Installation The Wyze Lock Bolt replaces your existing deadbolt in about 20 minutes and fits almost all exterior doors. No complicated wiring or drilling is required.
Smart App Integration
The Wyze app acts as your command center, offering:
  • Real-time lock/unlock history and notifications
  • Creation and management of up to 20 unique access codes and 50 fingerprints
  • Emergency one-time access codes that expire automatically
  • Auto-expiring codes and scheduled access for guests or service providers
  • Local Bluetooth connection ensures your data stays private with hardware encryption and two-factor authentication
"Wyze Lock Bolt is a solid, no frills smart lock with perfect fingerprint scans."
Wyze Lock Bolt Lifestyle Experience seamless home security with Wyze Lock Bolt at your front door.
Replacement Parts for Wyze Lock Bolt
To keep your smart lock functioning flawlessly, Wyze offers essential replacement parts: Wyze Lock Bolt Interior Assembly Battery Cover A replacement cover to protect the battery compartment, ensuring your lock stays powered and secure. Wyze Lock Bolt Screws A set of screws compatible with the Wyze Lock Bolt for secure installation or maintenance. Wyze Lock Bolt Interior Assembly Metal Plate Metal plate to anchor the interior assembly firmly to your door for added stability. Wyze Lock Replacement Part Kit Comprehensive kit for Wyze Lock (note: compatible with Wyze Lock, not Lock Bolt) to replace worn or damaged components. These parts help extend the life of your smart lock and maintain its high performance.
Enhance Your Home Security with the Front Porch Security Bundle
For a complete smart home security solution, consider the Front Porch Security Bundle which pairs the Wyze Lock Bolt with the Wyze Video Doorbell and Chime. This bundle offers:
  • 1080p HD video monitoring of your front porch
  • Two-way audio to greet visitors remotely
  • Remote lock/unlock control and lock history viewing via the Wyze app
  • Compatibility with Alexa and Google Assistant for voice control
This all-in-one package ensures your front door is not only smartly secured but also actively monitored. Wyze Lock Bolt with Video Doorbell Secure and monitor your home effortlessly with Wyze Lock Bolt and Video Doorbell.
Why Choose Wyze Lock Bolt for Your Smart Deadbolt Replacement?
  • Fast and secure keyless entry with fingerprint and keypad
  • Auto-lock feature to prevent accidental door unlocking
  • Backlit keypad for easy nighttime access
  • Weatherproof and pick-proof design for reliable security
Long-lasting battery with emergency USB-C charging
  • Simple installation compatible with most exterior doors
  • Comprehensive app control with advanced security features
Upgrade your home with the Wyze Lock Bolt and enjoy the perfect blend of convenience, security, and smart technology. Wyze Lock Bolt Installation Easy installation replaces your existing deadbolt in minutes.
Summary
The Wyze Lock Bolt is the ideal smart deadbolt replacement featuring an auto-lock function and a backlit keypad. Its fingerprint sensor, anti-peep keypad, and app-controlled access codes provide a secure and convenient way to protect your home. With durable construction and weatherproofing, it’s built to last and keep your family safe.
ProductTypePrice (USD)DescriptionKey FeaturesCompatibilityNotes
Wyze Lock BoltConnected Home79.98Bluetooth smart lock replacing deadbolt with backlit keypad and fingerprint reader.Fingerprint unlock, backlit keypad, auto-lock, anti-peep tech, pick-proof, weatherproof, 12-month batteryReplaces existing deadboltInstalls in ~20 minutes
Wyze Lock Bolt Interior Assembly Battery CoverReplacement Parts9.99Replacement interior battery cover for Wyze Lock Bolt.Replacement partWyze Lock Bolt30-day hassle-free returns
Wyze Lock Bolt ScrewsReplacement Parts2.99Set of screws for Wyze Lock Bolt replacement.Replacement screwsWyze Lock Bolt30-day hassle-free returns
Wyze Lock Bolt Interior Assembly Metal PlateReplacement Parts4.99Metal plate to anchor the interior assembly to the door.Anchoring metal plateWyze Lock Bolt30-day hassle-free returns
Wyze Lock Replacement Part KitReplacement Parts4.99 - 19.99Replacement part kit compatible with Wyze Lock (not Lock Bolt).Replacement parts kitWyze Lock (not Lock Bolt)Two styles: Replacement Part Kit & Adapter Replacement Kit
The Front Porch Security BundleCameras123.99 - 173.97Smart home security bundle including Wyze Lock or Wyze Lock Bolt and Wyze Video Doorbell & ChimePorch video in 1080p HD, two-way audio, remote lock/unlock, lock history, Alexa/Google supportWyze Lock or Wyze Lock BoltMultiple bundle variants available
What is the Wyze Lock Bolt and how does it improve home security?The Wyze Lock Bolt is a smart deadbolt replacement designed to enhance home security and convenience. It features a fast fingerprint reader, a backlit keypad with anti-peep technology, auto-lock capabilities, and robust weatherproof construction. With app integration, you can manage access codes, monitor lock history, and control your lock remotely, making your home both secure and easy to access.
How does the auto-lock feature work on the Wyze Lock Bolt?The Wyze Lock Bolt’s auto-lock feature automatically secures your door after a customizable delay, which you can set through the Wyze app. This ensures your door is never accidentally left unlocked, providing peace of mind and enhanced security.
What are the benefits of the backlit keypad on the Wyze Lock Bolt?The backlit keypad on the Wyze Lock Bolt allows you to easily enter your access code even in complete darkness. It also includes anti-peep technology, enabling you to enter extra digits before or after your code to prevent others from guessing your combination.
Is the Wyze Lock Bolt easy to install?Yes, the Wyze Lock Bolt is designed for easy installation and can replace your existing deadbolt in about 20 minutes. It fits most exterior doors and does not require complicated wiring or drilling.
How secure is the Wyze Lock Bolt?The Wyze Lock Bolt is pick-proof by design and does not require physical keys, reducing the risk of unauthorized entry. It also features IPX5 weatherproofing for durability and uses hardware encryption and two-factor authentication for secure app control.
What is the battery life of the Wyze Lock Bolt and what happens if the battery dies?The Wyze Lock Bolt is powered by 4 AA batteries, which can last up to 12 months on a single set. If the batteries run low or die, you can use the built-in USB-C port for a quick emergency charge, allowing you to enter your access code and unlock the door.
Can I manage multiple access codes and fingerprints with the Wyze Lock Bolt?Yes, the Wyze Lock Bolt allows you to create and manage up to 20 unique access codes and 50 fingerprints through the Wyze app. You can also generate emergency one-time access codes and schedule access for guests or service providers.
What replacement parts are available for the Wyze Lock Bolt?Wyze offers several replacement parts for the Lock Bolt, including the interior assembly battery cover, screws, and interior assembly metal plate. There is also a Wyze Lock Replacement Part Kit, but it is only compatible with the Wyze Lock, not the Lock Bolt.
What is included in the Front Porch Security Bundle?The Front Porch Security Bundle includes the Wyze Lock Bolt, Wyze Video Doorbell, and Chime. This bundle provides 1080p HD video monitoring, two-way audio, remote lock/unlock control, lock history viewing via the Wyze app, and compatibility with Alexa and Google Assistant for voice control.
Does the Wyze Lock Bolt work with smart home assistants?Yes, when paired with the Wyze Video Doorbell in the Front Porch Security Bundle, the Wyze Lock Bolt is compatible with Alexa and Google Assistant, allowing for convenient voice control of your smart lock.
What are the installation requirements for the Wyze Lock Bolt?Can the Wyze Lock Bolt be used with any type of door?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Lock Bolt?
