Best Refurbished Matte Black Smart Lock with Anti-Peep Keypad
Best Refurbished Matte Black Smart Lock with Anti-Peep Backlit Keypad
When it comes to securing your home with style and advanced technology, a matte black smart lock with an anti-peep backlit keypad is an ideal choice. These locks combine sleek aesthetics with cutting-edge security features, ensuring convenience and peace of mind. Among the top options available, the Wyze Lock Bolt stands out as the best refurbished matte black smart lock that perfectly fits this description.
Wyze Lock Bolt: The Ultimate Matte Black Smart Lock
Elegant Matte Black Design with Durable Build
The Wyze Lock Bolt in matte black offers a sophisticated, modern look that complements any exterior door. Crafted from solid metal, this smart lock is designed not only for security but also to blend seamlessly with your home’s style. Its luxurious backlit keypad ensures easy visibility in low light, making it perfect for nighttime use.
"Wyze Lock Bolt is a solid, no frills smart lock with perfect fingerprint scans."
Wyze Lock Bolt Lifestyle Secure your front door with style and convenience.
Advanced Security Features
  • Anti-Peep Technology: Enter your access code with confidence. The Wyze Lock Bolt allows you to add extra random digits before or after your actual code, preventing onlookers from guessing your combination.
  • Ultra-Fast Fingerprint Reader: Unlock your door instantly with a single touch of your finger. The fingerprint sensor is highly responsive, providing quick and secure access.
  • Backlit Keypad: Each button is illuminated for easy use in the dark, enhancing both security and convenience.
  • Pick-Proof and Weatherproof: The lock is completely keyless, eliminating lock picking risks, and features IPX5 weatherproofing to withstand outdoor elements.
Smart Features for Modern Living
  • Auto-Lock Function: Never worry about forgetting to lock your door. Set a customizable auto-lock timer via the Wyze app, and the lock will secure itself automatically after your chosen delay.
  • Long Battery Life: Powered by 4 AA batteries, the lock can last up to 12 months. A low battery indicator flashes red, and a USB-C port allows for emergency charging if needed.
  • App Control & Access Management: Use the Wyze app to lock/unlock remotely within Bluetooth range, create and manage up to 20 access codes, store up to 50 fingerprints, and monitor lock history including failed attempts.
  • Emergency One-Time Codes: Generate temporary access codes remotely for guests that expire automatically, enhancing security for short-term visitors.
Easy Installation & Compatibility
The Wyze Lock Bolt replaces your existing deadbolt and installs in about 20 minutes. It fits most exterior doors and requires no complicated wiring. This makes it an excellent choice for DIY enthusiasts and those upgrading from traditional locks. Wyze Lock Bolt Installation Simple installation replaces your deadbolt in minutes.
Enhance Your Security with the Front Porch Security Bundle
For those looking to create a comprehensive smart home security system, consider the Front Porch Security Bundle which includes the Wyze Lock Bolt in matte black paired with Wyze Video Doorbell Pro or Wyze Video Doorbell v2. This bundle offers:
  • 1080p HD video monitoring of your front porch with two-way audio.
  • Remote locking and unlocking of your door.
  • Real-time motion alerts and lock activity history.
  • Compatibility with Alexa and Google Assistant for voice control.
This bundle is perfect for homeowners who want to monitor and control access to their home from anywhere, adding an extra layer of security and convenience.
Replacement Parts for Wyze Lock Bolt
To keep your Wyze Lock Bolt functioning like new, Wyze offers a range of replacement parts including:
  • Interior Assembly Battery Cover: Protects the battery compartment inside the lock.
  • Interior Assembly Metal Plate: Anchors the interior assembly securely to your door.
  • Screws: Replacement screws for mounting and assembly.
These parts ensure your smart lock remains durable and reliable over time.
Why Choose Wyze Lock Bolt Matte Black?
  • Stylish matte black finish that fits modern home aesthetics.
  • Anti-peep backlit keypad for secure and discreet code entry.
  • Ultra-fast fingerprint sensor for keyless convenience.
  • Robust security features including pick-proof design and weather resistance.
  • Long-lasting battery with emergency USB-C charging.
  • Easy installation replacing your existing deadbolt.
  • Comprehensive app control with customizable access codes and lock history.
Secure your home with the best refurbished matte black smart lock that combines style, security, and smart technology — the Wyze Lock Bolt.
Wyze Lock Bolt Lifestyle with Phone Control your lock effortlessly from your smartphone.
FeatureWyze Lock BoltThe Front Porch Security BundleWyze Lock Bolt Interior Assembly Battery Cover
TypeConnected Home Smart LockSecurity Bundle (Lock + Video Doorbell + Chime)Replacement Part
DescriptionBluetooth smart lock replacing deadbolt with backlit keypad and fingerprint reader; auto-lock featureIncludes Wyze Lock, Wyze Video Doorbell, and Chime for front porch security with 1080p HD video and two-way audioInterior battery cover replacement for Wyze Lock Bolt
Key FeaturesUltra-fast fingerprint sensor, backlit keypad, anti-peep technology, auto-lock, pick-proof, weatherproof (IPX5), up to 12 months battery life, local Bluetooth connection, hardware encryption, two-factor authenticationRemote lock/unlock via app, lock history viewing, 1080p HD video doorbell with two-way audioReplacement battery cover for interior assembly
Components IncludedSmart lock unitWyze Lock + Wyze Video Doorbell + ChimeBattery cover only
CompatibilityReplaces existing deadboltWyze Lock Bolt or Wyze Lock with compatible video doorbellsCompatible with Wyze Lock Bolt only
Installation TimeAbout 20 minutesBundle components require individual installationN/A (replacement part)
Price$79.98$123.99 - $173.97 (varies by variant)$9.99
VariantsMatte Black, Satin NickelMultiple bundle variants including Wyze Lock Bolt + Video Doorbell Pro or v2Default Title
Battery LifeUp to 12 months (4x AA batteries)Included lock battery life same as Wyze Lock BoltN/A
App FeaturesLock/unlock history, create/store access codes and fingerprints, emergency one-time codes, auto-expiring codesLock/unlock remotely, view lock history, video doorbell live view and two-way audioN/A
Weather ResistanceIPX5Video Doorbell and Lock weather resistantN/A
Return Policy30-day hassle-free returns30-day hassle-free returns30-day hassle-free returns
What makes the Wyze Lock Bolt the best refurbished matte black smart lock?The Wyze Lock Bolt stands out as the best refurbished matte black smart lock due to its sleek design, advanced security features like anti-peep backlit keypad, ultra-fast fingerprint reader, pick-proof and weatherproof build, and easy installation. It combines style, convenience, and robust security, making it ideal for modern homes.
How does the anti-peep backlit keypad on the Wyze Lock Bolt work?The anti-peep backlit keypad allows you to enter your access code securely by adding random digits before or after your actual code. This prevents onlookers from guessing your code, while the backlit buttons ensure easy visibility in low-light conditions.
Is the Wyze Lock Bolt keyless and pick-proof?Yes, the Wyze Lock Bolt is completely keyless, eliminating the risk of lock picking. Its solid metal construction and keyless design provide enhanced security for your home.
What smart features does the Wyze Lock Bolt offer?The Wyze Lock Bolt offers smart features such as auto-lock function, long battery life (up to 12 months), app control within Bluetooth range, management of up to 20 access codes and 50 fingerprints, lock history monitoring, and emergency one-time codes for guests.
How is the Wyze Lock Bolt powered and what happens if the battery runs low?The Wyze Lock Bolt is powered by 4 AA batteries, lasting up to 12 months. A low battery indicator flashes red when power is low, and a USB-C port is available for emergency charging to ensure you’re never locked out.
Can I install the Wyze Lock Bolt myself?Yes, the Wyze Lock Bolt is designed for easy DIY installation. It replaces your existing deadbolt and can be installed in about 20 minutes without complicated wiring, fitting most exterior doors.
What is included in the Front Porch Security Bundle with the Wyze Lock Bolt?The Front Porch Security Bundle includes the Wyze Lock Bolt in matte black and a Wyze Video Doorbell Pro or Wyze Video Doorbell v2. This bundle provides 1080p HD video monitoring, two-way audio, remote locking/unlocking, real-time motion alerts, lock activity history, and compatibility with Alexa and Google Assistant.
Are replacement parts available for the Wyze Lock Bolt?Yes, Wyze offers replacement parts for the Lock Bolt, including the interior assembly battery cover, interior assembly metal plate, and mounting screws. These parts help maintain the lock’s durability and reliability.
How does the Wyze Lock Bolt enhance home security?The Wyze Lock Bolt enhances home security with features like anti-peep keypad, ultra-fast fingerprint sensor, pick-proof and weatherproof design, customizable auto-lock, and comprehensive app control for managing access codes, fingerprints, and lock history.
Is the Wyze Lock Bolt compatible with smart home systems?Yes, when paired with the Front Porch Security Bundle, the Wyze Lock Bolt is compatible with Alexa and Google Assistant, allowing for voice control and integration into your smart home ecosystem.
What are the advanced security features of the Wyze Lock Bolt?How does the anti-peep technology work on the Wyze Lock Bolt?Are there any ongoing sales or discounts for the Wyze Lock Bolt?
