Weatherproof Smart Lock with Battery Indicator & Auto Charge
Weatherproof Smart Lock with Battery Indicator and Auto Charge
Upgrade your home security with the Wyze Lock Bolt, a cutting-edge weatherproof smart lock designed for convenience, safety, and seamless access management. This smart lock combines advanced fingerprint technology, a battery life indicator, and an emergency USB-C charging port to ensure you never get locked out—even when the battery runs low. Perfect for modern homes, it offers robust protection against weather elements and unauthorized access.
Wyze Lock Bolt: The Ultimate Weatherproof Smart Lock
Key Features and Benefits
  • Weatherproof Durability: Rated IPX5, the Wyze Lock Bolt withstands rain, snow, and dust, making it ideal for outdoor installation on your front door.
  • Battery Life Indicator: Equipped with a clear battery status indicator that flashes red when power is low, so you know exactly when to replace the 4 AA batteries.
  • Emergency Auto Charge: If the batteries die while you’re away, simply use the USB-C port for a quick emergency charge to unlock your door instantly.
  • Ultra-Fast Fingerprint Reader: Unlock your door in less than a second with a single fingerprint or a tap on the backlit keypad.
  • Auto-Lock Feature: Never worry about forgetting to lock your door again. Set a customizable auto-lock timer via the Wyze app.
  • Anti-Peep Technology: Enter your access code with extra digits before or after to prevent onlookers from guessing your code.
  • Local Bluetooth Control: Manage your lock securely through the Wyze app with Bluetooth connectivity, including lock/unlock history and access management.
  • Robust Security: Fully pick-proof design with hardware encryption and two-factor authentication for peace of mind.
Specifications
  • Power Source: 4 AA batteries (up to 12 months battery life)
  • Connectivity: Bluetooth
  • Weather Resistance: IPX5 rated
  • Fingerprint Capacity: Up to 50 fingerprints
  • Access Codes: Up to 20 unique codes
  • Auto-Lock Delay: Customizable via app
  • Material: Solid metal exterior with backlit keypad
  • Installation: Replaces existing deadbolt in about 20 minutes
  • Colors Available: Matte Black, Satin Nickel
"Wyze Lock Bolt is a solid, no frills smart lock with perfect fingerprint scans."
Wyze Lock Bolt Lifestyle Secure your home with Wyze Lock Bolt’s weatherproof design.
Seamless Battery Management and Emergency Access
One of the standout features of the Wyze Lock Bolt is its intelligent battery management system. The lock’s battery indicator alerts you well in advance when the batteries are running low, preventing unexpected lockouts. In the rare event that the batteries die completely, the USB-C emergency charging port allows you to power the lock temporarily to gain entry using your access code. This feature ensures that your home remains accessible and secure at all times, even during power interruptions or extended absences.
Easy Installation and Stylish Design
The Wyze Lock Bolt is designed to replace your existing deadbolt effortlessly, with installation taking approximately 20 minutes. Its sleek metal finish and backlit keypad complement any exterior door, blending security with style.
  • Installation: Compatible with most exterior doors.
  • Design: Luxurious metal construction with a modern aesthetic.
  • User-Friendly: Backlit keypad for easy nighttime use.
Wyze Lock Bolt Installation Quick and easy installation replaces your deadbolt in minutes.
Enhance Your Smart Home Security
Pair the Wyze Lock Bolt with other Wyze smart home devices for a comprehensive security solution. For example, the Front Porch Security Bundle combines the Wyze Lock Bolt with a Wyze Video Doorbell and Chime, allowing you to monitor your front door in 1080p HD, communicate with visitors via two-way audio, and control your lock remotely—all from the Wyze app. This integration offers:
  • Remote lock/unlock capabilities
  • Real-time video monitoring
  • Motion detection alerts
  • Voice assistant compatibility (Alexa, Google Assistant)
Replacement Parts for Wyze Lock Bolt
To keep your Wyze Lock Bolt functioning perfectly, Wyze offers essential replacement parts:
  • Wyze Lock Bolt Interior Assembly Battery Cover: Protects the battery compartment, priced at $9.99.
  • Wyze Lock Bolt Interior Assembly Metal Plate: Anchors the interior assembly securely to your door, priced at $4.99.
  • Wyze Lock Bolt Screws: Replacement screws set for installation, priced at $2.99.
  • Wyze Lock Replacement Part Kit: Includes various components compatible with Wyze Lock, priced at $4.99 to $19.99 depending on the kit.
These parts ensure your smart lock remains durable and reliable over time.
Why Choose Wyze Lock Bolt?
"A fingerprint away from secure, weatherproof convenience."
  • Weatherproof and durable for outdoor use
  • Long-lasting battery with clear indicator
  • Emergency USB-C charging for peace of mind
  • Fast, secure fingerprint and keypad access
  • Auto-lock feature to prevent accidental unlocks
  • Easy installation and stylish design
Secure your home with the Wyze Lock Bolt — the smart lock that combines weatherproof reliability with intelligent battery management and effortless access control. Wyze Lock Bolt App Control Control your lock remotely with the Wyze app.
ProductTypeDescriptionPrice (USD)Key FeaturesCompatibilityReturn Policy
Wyze Lock BoltConnected HomeBluetooth smart lock replacing deadbolt with backlit keypad, fingerprint reader, auto-lock79.98Fingerprint unlock, backlit keypad, auto-lock, pick-proof, weatherproof, up to 12 months battery lifeReplaces existing deadbolt30-day hassle-free returns
Wyze Lock Bolt Interior Assembly Battery CoverReplacement PartsReplacement interior battery cover9.99Replacement part for battery coverWyze Lock Bolt30-day hassle-free returns
Wyze Lock Bolt Interior Assembly Metal PlateReplacement PartsMetal plate to anchor the interior assembly to the door4.99Anchors interior assemblyWyze Lock Bolt30-day hassle-free returns
Wyze Lock Bolt ScrewsReplacement PartsSet of screws for Wyze Lock Bolt2.99Replacement screw setWyze Lock Bolt30-day hassle-free returns
Wyze Lock Replacement Part KitReplacement PartsReplacement part kit (only compatible with Wyze Lock, not Lock Bolt)4.99 - 19.99Replacement parts kit, includes adapter replacement kit optionWyze Lock (not Lock Bolt)30-day hassle-free returns
What is the Wyze Lock Bolt and how does it enhance home security?The Wyze Lock Bolt is a weatherproof smart lock designed for modern home security. It features advanced fingerprint technology, a battery life indicator, emergency USB-C charging, and robust protection against weather and unauthorized access. Its seamless access management and durable design make it ideal for securing your front door.
Is the Wyze Lock Bolt weatherproof?Yes, the Wyze Lock Bolt is rated IPX5 for weather resistance, making it suitable for outdoor installation. It can withstand rain, snow, and dust, ensuring reliable performance in various weather conditions.
How does the battery indicator work on the Wyze Lock Bolt?The Wyze Lock Bolt is equipped with a clear battery status indicator that flashes red when the battery is low. This feature alerts you in advance so you can replace the 4 AA batteries before they run out, preventing unexpected lockouts.
What happens if the Wyze Lock Bolt’s batteries die?If the batteries die, you can use the emergency USB-C charging port to temporarily power the lock. This allows you to unlock your door instantly using your access code, ensuring you never get locked out.
How fast is the fingerprint reader on the Wyze Lock Bolt?The Wyze Lock Bolt features an ultra-fast fingerprint reader that unlocks your door in less than a second, providing quick and secure access.
Can I set the Wyze Lock Bolt to auto-lock?Yes, the Wyze Lock Bolt has a customizable auto-lock feature. You can set the auto-lock timer via the Wyze app, so your door automatically locks after a specified period.
What is anti-peep technology on the Wyze Lock Bolt?Anti-peep technology allows you to enter extra digits before or after your access code on the keypad. This prevents onlookers from guessing your code, enhancing your security.
How do I control and manage the Wyze Lock Bolt?You can manage the Wyze Lock Bolt securely through the Wyze app using Bluetooth connectivity. The app allows you to lock or unlock the door, view lock/unlock history, and manage access codes and fingerprints.
How many fingerprints and access codes can the Wyze Lock Bolt store?The Wyze Lock Bolt can store up to 50 fingerprints and up to 20 unique access codes, making it easy to manage access for family members and trusted guests.
How long does the Wyze Lock Bolt’s battery last?The Wyze Lock Bolt is powered by 4 AA batteries, which can last up to 12 months depending on usage.
Is the Wyze Lock Bolt easy to install?Yes, the Wyze Lock Bolt is designed for easy installation and can replace your existing deadbolt in about 20 minutes. It is compatible with most exterior doors.
What materials and finishes are available for the Wyze Lock Bolt?The Wyze Lock Bolt features a solid metal exterior with a backlit keypad. It is available in Matte Black and Satin Nickel finishes to complement your home’s style.
Can the Wyze Lock Bolt be integrated with other Wyze smart home devices?Yes, the Wyze Lock Bolt can be paired with other Wyze smart home devices, such as the Wyze Video Doorbell and Chime, for a comprehensive security solution. This integration allows for remote lock/unlock, real-time video monitoring, motion detection alerts, and voice assistant compatibility.
Are replacement parts available for the Wyze Lock Bolt?Yes, Wyze offers essential replacement parts for the Lock Bolt, including the interior assembly battery cover, metal plate, screws, and replacement part kits. These parts help maintain the lock’s durability and reliability.
What security features does the Wyze Lock Bolt offer?The Wyze Lock Bolt offers robust security with a pick-proof design, hardware encryption, and two-factor authentication. These features ensure your home remains protected against unauthorized access.
Does the Wyze Lock Bolt support remote control?Yes, when paired with other Wyze devices and the Wyze app, you can control the Wyze Lock Bolt remotely, monitor your front door, and receive real-time alerts.
What are the installation requirements for the Wyze Lock Bolt?How does the emergency USB-C charging feature work for the Wyze Lock Bolt?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Lock Bolt?
