Easy to Install Smart Lock with Long-Lasting AA Battery Power
Looking for a smart lock that combines effortless installation, advanced security features, and long-lasting battery life? The
Wyze Lock Bolt is your perfect solution. Designed to replace your existing deadbolt in about 20 minutes, this smart lock offers keyless entry, fingerprint access, and up to 12 months of battery life powered by 4 AA batteries. Alongside, the
Wyze Switch complements your smart home ecosystem by turning regular lights into smart lights, controllable from anywhere.
Wyze Lock Bolt: Secure, Convenient, and Battery Efficient
Quick and Simple Installation
Replacing your deadbolt has never been easier. The Wyze Lock Bolt installs in just 20 minutes and fits almost all exterior doors. No complicated wiring or professional help needed — just a straightforward swap that upgrades your home security instantly.
Advanced Keyless Entry
Forget fumbling for keys. Unlock your door in less than a second with a tap on the ultra-fast fingerprint sensor or by entering your code on the luxurious backlit keypad. The fingerprint reader supports up to 50 fingerprints, making it perfect for family and frequent guests.
Long-Lasting Battery Life
Powered by 4 AA batteries, the Wyze Lock Bolt offers up to 12 months of battery life. When batteries run low, a red indicator flashes to remind you to replace them. In emergencies, a USB-C port allows a quick temporary charge so you can still enter your access code and get inside.
Smart Features for Peace of Mind
- Auto-lock timer: Set your preferred delay in the Wyze app, and the lock will automatically secure your door if you forget.
- Anti-peep technology: Enter extra digits before or after your code to keep your passcode private from prying eyes.
- Pick-proof and weatherproof: The lock is fully pick-proof and rated IPX5 for weather resistance, ensuring durability in all conditions.
- Local Bluetooth control: Manage lock/unlock history, create access codes, and generate emergency one-time codes directly from the Wyze app without cloud dependency.
Stylish and Durable Design
Crafted from solid metal with a sleek matte black or satin nickel finish, the Wyze Lock Bolt blends seamlessly with your home’s exterior while providing robust security.
Secure your home effortlessly with Wyze Lock Bolt.
Wyze Switch: Smart Lighting Control Made Easy
Transform Your Home Lighting
The Wyze Switch converts your standard light switches into smart switches, allowing you to control your lights from anywhere using the Wyze app. Whether you’re at home or away, you can turn lights on or off, set schedules, or create automations that fit your lifestyle.
Seamless Integration with Wyze Ecosystem
Control other Wyze devices like cameras, locks, and robot vacuums with multi-tap actions on the switch. For example, double-press to lock your Wyze Lock Bolt or triple-press to start your robot vacuum.
Reliable and User-Friendly
- Easy installation: Fits standard switch boxes and installs quickly.
- Power loss recovery: Automatically reconnects to Wi-Fi and restores previous settings after power outages.
- Vacation mode: Simulate occupancy by scheduling lights to turn on/off while you’re away for added security.
Control your home lighting smartly with Wyze Switch.
Replacement Parts for Wyze Lock Bolt
To keep your Wyze Lock Bolt functioning perfectly, a range of replacement parts is available:
- Wyze Lock Bolt Interior Assembly Metal Plate: Anchors the interior assembly securely to your door.
- Wyze Lock Bolt Interior Assembly Battery Cover: Replacement cover for the battery compartment.
- Wyze Lock Bolt Screws: Set of screws compatible with the lock for maintenance or reinstallation.
- Wyze Lock Replacement Part Kit: Comprehensive kit for Wyze Lock maintenance (note: only compatible with Wyze Lock, not Lock Bolt).
These parts ensure your smart lock remains reliable and easy to maintain over time.
"Wyze Lock Bolt is a solid, no frills smart lock with perfect fingerprint scans."
Experience the convenience of keyless entry combined with robust security and long-lasting battery power.
Why Choose Wyze Lock Bolt for Your Smart Home?
Easy installation in 20 minutes
Fingerprint and keypad access
Up to 12 months on 4 AA batteries
Auto-lock and anti-peep technology
Weatherproof and pick-proof design
Local Bluetooth control with no cloud dependency
Compatible with Wyze app for full control
Upgrade your home security effortlessly with Wyze Lock Bolt and enhance your smart home lighting with Wyze Switch for a connected, convenient lifestyle.
How easy is it to install the Wyze Lock Bolt smart lock?
The Wyze Lock Bolt is designed for quick and simple installation, allowing you to replace your existing deadbolt in about 20 minutes. It fits most exterior doors and does not require complicated wiring or professional help.What are the key features of the Wyze Lock Bolt?
The Wyze Lock Bolt offers advanced keyless entry with a fast fingerprint sensor and backlit keypad, up to 12 months of battery life on 4 AA batteries, auto-lock timer, anti-peep technology, pick-proof and weatherproof design, and local Bluetooth control via the Wyze app.How does the Wyze Lock Bolt provide keyless entry?
You can unlock the Wyze Lock Bolt using the ultra-fast fingerprint sensor, which supports up to 50 fingerprints, or by entering your code on the backlit keypad for convenient and secure access.How long does the Wyze Lock Bolt battery last and what happens if it runs low?
The Wyze Lock Bolt is powered by 4 AA batteries and offers up to 12 months of battery life. When the batteries are low, a red indicator flashes to remind you to replace them. In emergencies, you can use the USB-C port for a quick temporary charge to enter your access code.What security features does the Wyze Lock Bolt offer?
The Wyze Lock Bolt includes an auto-lock timer, anti-peep technology to protect your passcode, a pick-proof design, and IPX5 weather resistance for durability in all conditions.Can I control the Wyze Lock Bolt without an internet connection?
Yes, the Wyze Lock Bolt uses local Bluetooth control, allowing you to manage lock/unlock history, create access codes, and generate emergency one-time codes directly from the Wyze app without relying on the cloud.What replacement parts are available for the Wyze Lock Bolt?
Replacement parts for the Wyze Lock Bolt include the Interior Assembly Metal Plate, Interior Assembly Battery Cover, compatible screws, and a comprehensive Wyze Lock Replacement Part Kit (note: the kit is only compatible with Wyze Lock, not Lock Bolt).What finishes are available for the Wyze Lock Bolt?
The Wyze Lock Bolt is crafted from solid metal and is available in sleek matte black or satin nickel finishes to match your home’s exterior.What is the Wyze Switch and how does it work?
The Wyze Switch is a smart light switch that converts your standard switches into smart switches. It allows you to control your lights from anywhere using the Wyze app, set schedules, and create automations for your home lighting.How does the Wyze Switch integrate with other Wyze devices?
The Wyze Switch seamlessly integrates with the Wyze ecosystem, allowing you to control other Wyze devices like cameras, locks, and robot vacuums using multi-tap actions on the switch.Is the Wyze Switch easy to install and reliable?
Yes, the Wyze Switch fits standard switch boxes and installs quickly. It features power loss recovery, automatically reconnecting to Wi-Fi and restoring previous settings after outages, and offers a vacation mode to simulate occupancy for added security.
