How to Add Audible Alert to Wyze Wired Doorbell
If you own the
Wyze Video Doorbell v2, adding an audible alert to your wired doorbell system is straightforward and enhances your home security by ensuring you never miss a visitor. This guide will walk you through the process of installing the Wyze Doorbell Chime Controller, which enables audible chimes when your doorbell is pressed, and provide tips on optimizing your doorbell’s alert features.
Wyze Video Doorbell v2 Overview
The
Wyze Video Doorbell v2 is a powerful wired video doorbell designed to provide clear video and reliable alerts. It features:
- 2K HD Video Resolution (2048 x 1536) for crisp, detailed footage.
- Wide Field of View: 135° horizontal, 103° vertical, and 166.8° diagonal.
- Two-Way Audio: Built-in microphone and speaker allow you to hear and speak to visitors.
- Motion-Activated Voice Deterrence: Automatically warns unwanted visitors.
- Local and Cloud Storage: Supports microSD cards up to 256GB and optional cloud plans.
- Weather Resistant: IP65 rating ensures durability in various climates.
- Compatibility: Works with Alexa, Google Assistant, and IFTTT for smart home integration.
The doorbell comes with a
Wyze Chime Controller included, which is essential for adding audible alerts to your wired doorbell system.
Installing the Wyze Doorbell Chime Controller for Audible Alerts
What You Need
- Wyze Video Doorbell v2 (includes Chime Controller)
- Existing wired mechanical doorbell system with 16V-24V AC power and at least 10VA output
- Basic tools: Phillips screwdriver, wire caps (included)
Step-by-Step Installation
1.
Turn Off Power: Switch off the power to your existing doorbell at your electrical panel to ensure safety.
2.
Check Existing Doorbell: Press your current doorbell button to confirm power is off.
3.
Open Chime Box: Locate your mechanical chime box and take a photo of the wiring for reference.
4.
Select Wiring Configuration: In the Wyze app, choose your chime wiring setup (usually 2 or 3 wires).
5.
Connect Chime Controller:
- For 2-wire systems, connect the jump wire as instructed.
- For 3-wire or more, follow the app’s guidance to connect the correct wires.
6.
Close Chime Box: After wiring, close the chime box securely.
7.
Install Doorbell: Attach the Wyze Video Doorbell v2 to the wall plate or wedge, connect the wires, and secure the device.
8.
Restore Power: Turn the breaker back on. The doorbell’s status light should flash yellow, indicating proper wiring.
9.
Complete Setup: Use the Wyze app to finish setup and customize chime tones and volume.
Note: If you do not install the chime controller, you should bypass the house chime entirely to avoid unexpected sounds.
Customizing Audible Alerts and Notifications
Wyze Chime Tunes and Volume
The Wyze Chime Controller supports
19 different chime tunes. You can select your preferred tune and adjust the volume directly from the Wyze app:
- Open the Wyze app and tap your doorbell device.
- Go to Settings > Accessories > Your Chime > Tunes.
- Choose your favorite chime tone.
- Adjust the volume slider to your desired level.
- The chime will sound to confirm your selection.
Push Notifications
To ensure you never miss a visitor, enable push notifications:
- In the Wyze app, tap your doorbell.
- Navigate to Settings > Event Recording.
- Toggle Send push notification to ON.
- You will receive alerts on your phone whenever the doorbell is pressed or motion is detected.
Two-Way Audio Alerts
The Wyze Video Doorbell v2 also supports two-way audio, allowing you to speak to visitors remotely:
- Tap the Speak (microphone) icon in the live stream.
- Talk directly through the doorbell’s speaker.
- Use this feature to greet guests or deter unwanted visitors.
Troubleshooting Audible Alert Issues
If your Wyze doorbell chime does not ring after installation:
- Confirm the chime controller is properly installed and wired.
- Verify your existing mechanical chime is compatible and functional.
- Ensure power is supplied correctly (16V-24V AC, ≥10VA).
- Restart the doorbell by power cycling at the breaker.
- Check the Wyze app for firmware updates and install if available.
- If problems persist, consult a licensed electrician.
Why Choose Wyze Video Doorbell v2?
The Wyze Video Doorbell v2 is an excellent choice for adding audible alerts to your wired doorbell system because it combines:
- High-quality video and audio for security and communication.
- Easy installation with included chime controller and detailed app guidance.
- Customizable alerts with multiple chime tones and volume control.
- Smart home integration for seamless control.
- Reliable notifications to keep you informed anywhere.
Alt text: Homeowner using Wyze Video Doorbell v2 to answer door remotely
Summary
Adding an audible alert to your Wyze wired doorbell is simple with the included Wyze Doorbell Chime Controller. Follow the installation steps carefully, customize your chime tones and notifications in the Wyze app, and enjoy enhanced home security with clear audio and video communication.
For best results, always ensure your Wyze app and doorbell firmware are up to date, and consult a professional if you encounter wiring difficulties.
How do I add an audible alert to my Wyze Video Doorbell v2?
To add an audible alert to your Wyze Video Doorbell v2, install the included Wyze Doorbell Chime Controller with your existing wired mechanical doorbell system. Follow the step-by-step instructions in the Wyze app to connect the chime controller, restore power, and customize your chime tones and volume for optimal alerts.What features does the Wyze Video Doorbell v2 offer?
The Wyze Video Doorbell v2 offers 2K HD video resolution, a wide field of view, two-way audio, motion-activated voice deterrence, local and cloud storage options, weather resistance (IP65), and compatibility with Alexa, Google Assistant, and IFTTT for smart home integration.What do I need to install the Wyze Doorbell Chime Controller?
You need the Wyze Video Doorbell v2 (which includes the Chime Controller), an existing wired mechanical doorbell system with 16V-24V AC power and at least 10VA output, and basic tools such as a Phillips screwdriver and the included wire caps.How do I customize chime tunes and volume on the Wyze Video Doorbell v2?
Open the Wyze app, select your doorbell device, and go to Settings > Accessories > Your Chime > Tunes. From there, you can choose from 19 different chime tunes and adjust the volume slider to your preferred level. The chime will sound to confirm your selection.How can I enable push notifications for my Wyze Video Doorbell v2?
To enable push notifications, open the Wyze app, tap your doorbell, navigate to Settings > Event Recording, and toggle 'Send push notification' to ON. You will then receive alerts on your phone whenever the doorbell is pressed or motion is detected.Does the Wyze Video Doorbell v2 support two-way audio?
Yes, the Wyze Video Doorbell v2 supports two-way audio. You can use the Speak (microphone) icon in the live stream within the Wyze app to talk directly to visitors through the doorbell’s built-in speaker.What should I do if my Wyze doorbell chime does not ring after installation?
If your Wyze doorbell chime does not ring, check that the chime controller is properly installed and wired, verify your mechanical chime is compatible and functional, ensure correct power supply (16V-24V AC, at least 10VA), restart the doorbell by power cycling at the breaker, and check for firmware updates in the Wyze app. If issues persist, consult a licensed electrician.Why should I choose the Wyze Video Doorbell v2 for my wired doorbell system?
The Wyze Video Doorbell v2 is an excellent choice because it offers high-quality video and audio, easy installation with an included chime controller, customizable alerts with multiple chime tones and volume control, smart home integration, and reliable notifications to keep you informed wherever you are.Is the Wyze Video Doorbell v2 weather resistant?
Yes, the Wyze Video Doorbell v2 is IP65 weather resistant, making it durable and suitable for use in various climates.Can I use the Wyze Video Doorbell v2 with Alexa or Google Assistant?
Yes, the Wyze Video Doorbell v2 is compatible with Alexa, Google Assistant, and IFTTT, allowing for seamless smart home integration and control.
