20ft Wyze Cam USB Extension Cable for Hidden, Unblocked Setup
Extend Your Wyze Cam Setup with the 20ft USB Extension Cable
If you're looking to position your Wyze Cam behind thick drapes without blocking the camera feed, the Wyze Cam USB Extension Cable - 20ft is the perfect solution. This long USB extension cable gives you the freedom to place your camera exactly where you want it, even if the power outlet is far away or hidden behind heavy curtains.
Key Features of the Wyze Cam USB Extension Cable - 20ft
  • Length: 20 feet of flexible USB extension cable to reach distant power sources.
  • Compatibility: Works seamlessly with Wyze Cam v2, v3, v4, v3 Pro, Pan v2/v3, OG Standard, and OG Telephoto models.
  • Easy Setup: Simply plug the extension cable between your Wyze Cam and its power adapter to extend the reach without any complicated installation.
  • Affordable: Priced at just $7.99, it’s a cost-effective way to enhance your camera placement options.
Say goodbye to short cables and enjoy the freedom to place your Wyze Cam behind thick drapes or in hard-to-reach spots without compromising your camera’s view or feed quality.
Wyze Cam v4 – The Ultimate Camera for Clear, Colorful Security
Pairing the 20ft USB extension cable with the Wyze Cam v4 offers a powerful home security setup that can be discreetly placed behind curtains or in other concealed locations while maintaining excellent video quality.
Why Choose Wyze Cam v4?
  • 2.5K Quad HD Resolution: Capture crystal-clear video with vibrant colors and sharp details.
  • Color Night Vision: See more at night with enhanced color night vision that reveals details traditional night vision misses.
  • Wide Dynamic Range (WDR): Enjoy balanced lighting and rich colors even in challenging lighting conditions.
  • Weather Resistant (IP65): Suitable for indoor or outdoor use, so you can place it anywhere.
  • Integrated Spotlight & Siren: Deter intruders with a motion-activated spotlight and a loud siren.
  • Advanced Audio: Enhanced two-way talk with clear sound quality.
  • Smart Features: Auto-zoom with AI tracking, motion and sound detection, and compatibility with Alexa, Google Assistant, and IFTTT.
  • Continuous Recording: Supports microSD cards up to 512GB for 24/7 local recording without subscription fees.
Ideal for Concealed Placement
Thanks to the 20ft USB extension cable, you can hide the Wyze Cam v4 behind thick drapes or in less obvious locations while still powering it reliably. This setup keeps your camera feed unobstructed and your home secure without compromising aesthetics. Wyze Cam v4 in Living Room Alt text: Wyze Cam v4 discreetly placed in a cozy living room behind curtains
Enhance Your Home Security Setup
For those wanting a comprehensive security solution, the Whole Home Security Starter Kit includes the Wyze Cam v4 along with other smart devices. Using the 20ft USB extension cable with the Wyze Cam v4 in this kit allows flexible camera placement behind drapes or in other strategic spots.
Whole Home Security Starter Kit Highlights
  • Includes 1x Wyze Cam v4 (available in White, Grey, or Black)
  • Wyze Video Doorbell v2 for front door monitoring
  • Wyze Home Monitoring Starter Kit for comprehensive protection
This kit is perfect for users who want to cover multiple angles of their home with smart, easy-to-install devices.
Summary
If you want to fix your Wyze Cam behind thick drapes without blocking the feed, the Wyze Cam USB Extension Cable - 20ft is an essential accessory. It extends your camera’s reach, allowing you to place it discreetly while maintaining a clear, uninterrupted video feed. Pair it with the Wyze Cam v4 for the best image quality, color night vision, and smart home integration.
With this combination, you get flexibility, clarity, and security — all without compromising your home’s style or your camera’s performance.
Product Highlights
FeatureWyze Cam USB Extension Cable - 20ftWyze Cam v4 Whole Home Security Starter Kit
Product TypeAccessory (USB Extension Cable)Security Kit
Price$7.99 USD$155.95 USD
Included Items1x 20ft USB extension cable1x Wyze Cam v4, 1x Wyze Video Doorbell v2, 1x Wyze Home Monitoring Starter Kit
CompatibilityWyze Cam v2/v3/v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, Wyze Cam OG Standard, Wyze Cam OG TelephotoWyze Cam v4, Wyze Video Doorbell v2, Wyze Home Monitoring Starter Kit
Cable Length20 feetN/A
Camera ResolutionN/A2.5K QHD (2560x1440)
Night VisionN/AEnhanced Color Night Vision
Motion-Activated SpotlightN/AYes
Local RecordingN/A24/7 local recording
Wi-Fi SupportN/AWi-Fi 6
Alexa & Google Assistant CompatibilityN/AYes
Weather ResistanceN/AIP65
Warranty30-day hassle-free returns1 Year
What is the Wyze Cam USB Extension Cable - 20ft used for?The Wyze Cam USB Extension Cable - 20ft is designed to extend the reach of your Wyze Cam’s power supply, allowing you to place your camera in hard-to-reach or concealed locations, such as behind thick drapes, without blocking the camera feed or compromising video quality.
Which Wyze Cam models are compatible with the 20ft USB Extension Cable?The 20ft USB Extension Cable is compatible with Wyze Cam v2, v3, v4, v3 Pro, Pan v2/v3, OG Standard, and OG Telephoto models.
How do I set up the Wyze Cam USB Extension Cable?Setting up the Wyze Cam USB Extension Cable is simple. Just plug the extension cable between your Wyze Cam and its power adapter to instantly extend the reach—no complicated installation required.
Can I use the Wyze Cam v4 behind curtains or drapes?Yes, by using the 20ft USB Extension Cable, you can easily place the Wyze Cam v4 behind curtains or drapes while maintaining a clear, unobstructed video feed and reliable power supply.
What are the key features of the Wyze Cam v4?The Wyze Cam v4 offers 2.5K Quad HD resolution, color night vision, wide dynamic range (WDR), weather resistance (IP65), an integrated spotlight and siren, advanced two-way audio, smart features like auto-zoom with AI tracking, motion and sound detection, compatibility with Alexa, Google Assistant, and IFTTT, and supports continuous recording with microSD cards up to 512GB.
Is the Wyze Cam v4 suitable for outdoor use?Yes, the Wyze Cam v4 is weather resistant with an IP65 rating, making it suitable for both indoor and outdoor use.
Does the Wyze Cam v4 support continuous recording?Yes, the Wyze Cam v4 supports continuous 24/7 local recording when you use a microSD card up to 512GB, with no subscription fees required.
What is included in the Whole Home Security Starter Kit?The Whole Home Security Starter Kit includes one Wyze Cam v4 (available in White, Grey, or Black), a Wyze Video Doorbell v2 for front door monitoring, and a Wyze Home Monitoring Starter Kit for comprehensive home protection.
How much does the Wyze Cam USB Extension Cable - 20ft cost?The Wyze Cam USB Extension Cable - 20ft is affordably priced at just $7.99.
Can I use the Wyze Cam USB Extension Cable to improve camera placement options?Yes, the 20ft USB Extension Cable allows you to place your Wyze Cam in more flexible and strategic locations, such as behind thick drapes or in hard-to-reach spots, without compromising your camera’s view or feed quality.
Can you tell me more about the compatibility of the Wyze Cam USB Extension Cable with different Wyze Cam models?What are the benefits of using the Wyze Cam v4 with the USB extension cable?Do you have any ongoing sales or discounts for the Wyze Cam or accessories?
