20ft Wyze Cam USB Extension: Discreet Cable Routing Solutions
Subtle Cable Routing for Wyze Cam Behind Furniture and Along Walls
When setting up your Wyze Cam for home security, one common challenge is managing the USB cable discreetly, especially when placing the camera behind furniture or along walls. A neat and subtle cable route not only enhances the aesthetic of your space but also prevents accidental unplugging or damage to the cable.
Why Use a USB Extension Cable for Wyze Cam?
The standard Wyze Cam comes with a 6-foot USB cable, which may not always be long enough to reach your preferred mounting spot, especially if you want to hide the cable behind furniture or run it along baseboards. The Wyze Cam USB Extension Cable - 20ft is the perfect solution to extend your reach without compromising on power or connectivity.
  • Length: 20 feet of flexible USB extension cable gives you ample length to route cables discreetly.
  • Compatibility: Works seamlessly with Wyze Cam v2, v3, v4, Wyze Cam Pan v2/v3, and OG models.
  • Ease of Use: Simply plug it in between your Wyze Cam’s USB cable and the power adapter to gain extra length.
This extension cable allows you to run the cable along walls, tuck it behind furniture, or even under carpets without worrying about short cable length.
“Say goodbye to short cables and enjoy the freedom of a 20ft cable.”
Tips for Subtle Cable Routing
  • Use Cable Clips or Adhesive Hooks: Secure the cable along the baseboards or behind furniture legs to keep it out of sight.
  • Run Along Corners: Corners and edges of walls are natural hiding spots for cables.
  • Paintable Cable Covers: If you want an ultra-clean look, consider paintable cable covers that blend with your wall color.
  • Avoid Sharp Bends: Keep the cable gently curved to avoid damage and maintain signal integrity.
Wyze Cam Models Compatible with the USB Extension Cable
Wyze Cam v4 – Advanced Indoor/Outdoor Security
The Wyze Cam v4 is a versatile security camera that offers crystal-clear 2.5K QHD resolution and enhanced color night vision, making it ideal for both indoor and outdoor use. Its compact size and multiple mounting options (stand, wall, ceiling, magnetic adhesive) make it easy to position behind furniture or along walls.
  • Resolution: 2.5K QHD (2560x1440) for sharp, detailed video.
  • Night Vision: 4 IR LEDs plus 2 white spotlight LEDs for color night vision.
  • Connectivity: Supports Wi-Fi 6 for stable streaming.
  • Power: Comes with a 6-foot flat micro USB cable, extendable with the 20ft USB extension.
  • Mounting: Magnetic wall mount option allows easy repositioning without visible cables.
  • Weather Resistance: IP65 rating for outdoor durability.
With the 20ft USB extension cable, you can place the Wyze Cam v4 in the perfect spot, even if the power outlet is far behind furniture or along a long wall. Wyze Cam v4 installed discreetly in a modern living room Alt text: Wyze Cam v4 mounted subtly behind furniture in a living room
Wyze Cam OG – Reliable and Compact Security
The Wyze Cam OG is the previous generation but still a powerful option for home security. It features 1080p HD video, a built-in spotlight, and a 6-foot power cable that can be extended with the 20ft USB extension cable for flexible placement.
  • Resolution: 1080p Full HD video.
  • Field of View: 120° wide angle.
  • Night Vision: 4 IR LEDs for clear night footage.
  • Audio: Two-way audio with noise and echo cancellation.
  • Power: 6-foot USB cable, extendable with the 20ft extension.
  • Weather Resistance: IP65 for indoor/outdoor use.
The compact size and flexible mounting options make it easy to hide the camera and cable behind furniture or along walls, especially when paired with the longer USB extension cable.
Enhance Your Home Security Setup
For those looking to build a comprehensive security system, consider the Whole Home Security Kits that include Wyze Cam v4 and other devices. While these kits come with standard cables, adding the 20ft USB extension cable allows you to customize cable routing for a cleaner, more professional look.
Summary
Using the Wyze Cam USB Extension Cable - 20ft is the best way to achieve a subtle, neat cable route for your Wyze Cam behind furniture or along walls. It extends your camera’s reach, allowing flexible placement without visible or tangled cables. Compatible with multiple Wyze Cam models like the Wyze Cam v4 and Wyze Cam OG, this extension cable is an essential accessory for a clean and effective home security setup.
FeatureWyze Cam USB Extension Cable - 20ftWyze Cam v4Wyze Cam OG
TypeAccessoryCameraCamera
Price$7.99$35.98 (1 Pack)$29.98 (1 Pack)
CompatibilityWyze Cam v2/v3/v4, v3 Pro, Pan v2/v3, OG Standard, OG TelephotoStandalone cameraStandalone camera
ResolutionN/A2.5K QHD (2560x1440)1080p (1920x1080)
Field of ViewN/A115.9° (D) x 98.5° (H) x 53.1° (V)120°
Night VisionN/AEnhanced Color Night Vision4 IR LEDs (850nm)
Color Night VisionN/AYesNo
AudioN/AEnhanced Two-Way TalkBuilt-in Speaker & Microphone; Noise & Echo Cancellation
SpotlightN/AMotion-activated spotlightBuilt-in spotlight (40 Lumens)
SirenN/AYes (99 dB)Yes (90 dB)
Local StorageN/AmicroSD card up to 512 GBSupports up to 256 GB microSD
ConnectivityUSB extension cable2.4 GHz Wi-Fi, Wi-Fi 6, Bluetooth 5.2802.11 b/g/n, 2.4 GHz Wi-Fi
Weather ResistanceN/AIP65IP65
Power Cable Length20 ft USB extension cable6 ft flat micro USB to USB-A cable6 ft (1.8 m) power cable
Mounting OptionsN/AStand, Wall mount, Ceiling mount, Magnetic mountStand, Wall mount (M4 screw), Ceiling mount (M4 screw)
DimensionsN/A2in x 2in x 2 3/8in1.89in x 1.89in x 1.89in
WeightN/A0.49 lb (222 g)4.1 oz (116 g)
Operating TemperatureN/A-4ºF to 122ºF (-20ºC to 50ºC)-4ºF to 131ºF (-20ºC to 55ºC)
Additional FeaturesExtends USB cable length for compatible Wyze CamsWi-Fi 6 support, Alexa/Google Assistant compatible, 24/7 local recording, Motion detection zones, Smoke & CO alertsFaster live-streaming, 3X faster notifications, Improved 2-way audio, Custom detection zones, Smoke & CO alerts
Included in Box1 x 20ft USB extension cableWyze Cam v4, Quick Start Guide, Wall Mount Plate, Tape, Screw Kit, Power Adapter, 6-ft USB cableWyze Cam OG, Power Adapter (included with camera)
How can I hide Wyze Cam cables behind furniture or along walls?To hide Wyze Cam cables behind furniture or along walls, use a 20ft Wyze Cam USB Extension Cable. Secure the cable with cable clips or adhesive hooks along baseboards, run it along corners, or use paintable cable covers for a seamless look. Avoid sharp bends to prevent cable damage.
Why should I use a USB extension cable with my Wyze Cam?A USB extension cable, such as the Wyze Cam USB Extension Cable - 20ft, allows you to place your camera farther from power outlets, making it easier to route cables discreetly behind furniture or along walls. This helps maintain a neat appearance and prevents accidental unplugging or cable damage.
Which Wyze Cam models are compatible with the 20ft USB extension cable?The 20ft Wyze Cam USB Extension Cable is compatible with Wyze Cam v2, v3, v4, Wyze Cam Pan v2/v3, and Wyze Cam OG models. It works seamlessly to extend the reach of your camera’s power supply.
Does the Wyze Cam v4 support subtle cable routing?Yes, the Wyze Cam v4 supports subtle cable routing. Its compact size, multiple mounting options, and compatibility with the 20ft USB extension cable make it easy to hide cables behind furniture or along walls for a clean installation.
Can I use the 20ft USB extension cable with the Wyze Cam OG?Yes, the Wyze Cam OG comes with a 6-foot USB cable that can be extended using the 20ft USB extension cable. This allows for flexible placement and discreet cable management behind furniture or along walls.
What are the best tips for routing Wyze Cam cables discreetly?For discreet Wyze Cam cable routing, use cable clips or adhesive hooks to secure cables along baseboards, run cables along wall corners, use paintable cable covers to blend with your wall color, and avoid sharp bends to maintain cable integrity.
How does the 20ft USB extension cable improve my Wyze Cam setup?The 20ft USB extension cable extends your Wyze Cam’s reach, allowing you to place the camera in optimal locations even if the power outlet is far away. This results in a cleaner, more professional look with hidden or neatly routed cables.
Are Wyze Cam security kits compatible with the 20ft USB extension cable?Yes, Wyze Cam security kits, including those with Wyze Cam v4, are compatible with the 20ft USB extension cable. While kits come with standard cables, adding the extension cable allows for customized, subtle cable routing.
What are some tips for securing the USB cable along the walls or behind furniture?Can the 20ft USB extension cable be used with all Wyze Cam models?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Cam USB extension cable?
