20ft Wyze Cam USB Extension Cable: Best Cord Solution for Large Spaces
Best Cord Solution for Wyze Cam While Rearranging Furniture in Large Spaces
When rearranging furniture in a large space, maintaining the perfect placement of your Wyze Cam without worrying about power limitations is essential. The Wyze Cam USB Extension Cable - 20ft is the ideal accessory to extend your camera’s reach, providing flexibility and freedom to position your Wyze Cam exactly where you need it.
Wyze Cam USB Extension Cable - 20ft: Freedom to Move Your Camera
The Wyze Cam USB Extension Cable - 20ft is designed to solve the common problem of short power cables when setting up Wyze cameras in larger rooms or open spaces.
Key Features:
  • Length: 20 feet of durable USB Type A Male to Female cable, allowing you to place your camera far from the nearest power outlet.
  • Compatibility: Works seamlessly with Wyze Cam v2, v3, v3 Pro, v4, Pan v2, Pan v3, Wyze Cam OG, and Wyze Cam OG Telephoto.
  • Durability: Rated IP67 for weather resistance, making it suitable for both indoor and outdoor use.
  • Build: AWG 18# wire thickness ensures stable power delivery (5V 2A output).
  • Operating Temperature: Reliable performance from -30°C to 50°C (-22°F to 122°F).
This extension cable is perfect for users who want to rearrange their furniture or change camera angles without being limited by the original cable length.
Wyze Cam OG: Reliable Wired Camera with Enhanced Features
The Wyze Cam OG is a versatile wired camera that benefits greatly from the 20ft USB extension cable, allowing you to place it optimally in large spaces.
Highlights:
  • 120° Field of View: Capture a wide area with a broad viewing angle.
  • Built-in Spotlight & Mini-Siren: Deter intruders with a 40-lumen spotlight and a 90-decibel siren.
  • Indoor/Outdoor Use: IP65 weather resistance for reliable outdoor monitoring.
  • 3X Faster Notifications: Stay informed instantly with improved motion detection.
  • Upgraded Two-Way Audio: Clear communication with enhanced microphone and speaker.
  • Quick Live HD Streaming: Stream video 50% faster than previous models.
  • Supports microSD Cards: Local storage up to 256GB for continuous recording.
Using the 20ft USB extension cable with the Wyze Cam OG means you can place the camera in the perfect spot without worrying about proximity to power sources, especially useful when rearranging furniture or redecorating. Living room with Wyze Cam monitoring
Wyze Cam OG Telephoto: Zoomed-In Security with Flexible Placement
For those who want a more focused view, the Wyze Cam OG Telephoto offers a 3x telephoto lens with the same reliable wired connection.
Features:
  • 3X Telephoto Lens: Narrow 27° field of view for detailed monitoring.
  • 1080p Full HD Video: Crisp and clear video quality.
  • Night Vision: 4 IR LEDs for clear night-time footage.
  • IP65 Weatherproof: Suitable for indoor and outdoor use.
  • 8X Digital Zoom: Zoom in on important details.
  • Two-Way Audio: Built-in speaker and microphone with noise cancellation.
  • Flexible Mounting: Stand, wall, or ceiling mount options.
Pairing this camera with the 20ft USB extension cable allows you to position it exactly where you need detailed surveillance, even in large or awkward spaces.
Why Use a USB Extension Cable with Your Wyze Cam?
Rearranging furniture or redecorating a large room often means your camera’s original cable length can limit placement options. The Wyze Cam USB Extension Cable - 20ft provides the freedom to move your camera without compromising on power or connectivity.
This cable is a simple, cost-effective solution to extend your camera’s reach, ensuring continuous power supply and uninterrupted security coverage.
Summary
  • Wyze Cam USB Extension Cable - 20ft: Extends your camera’s power cable for flexible placement.
  • Wyze Cam OG: Wide-angle, wired camera with spotlight and siren.
  • Wyze Cam OG Telephoto: Wired camera with telephoto lens for detailed zoomed-in views.
Together, these products offer a comprehensive solution for maintaining security and monitoring while rearranging furniture or managing large spaces. Home security setup with Wyze Cam
Optimize Your Wyze Cam Setup Today
Maximize your Wyze Cam’s potential by pairing it with the 20ft USB extension cable. Whether you have the Wyze Cam OG or the Telephoto version, this cable ensures you never have to compromise on camera placement or security coverage. Flexible Wyze Cam placement
FeatureWyze Cam OGWyze Cam USB Extension Cable - 20ftWyze Cam OG Telephoto
TypeCameraAccessoryCamera
Price$29.98 (1 Pack)$7.99$25.98 (1 Pack)
Color VariantsBlack, WhiteN/AWhite
Pack Variants1, 2, 3 PacksSingle1, 2 Packs
Field of View120°N/A27° (DFOV), 23.6° (HFOV), 13.6° (VFOV)
Video Resolution1920 x 1080 (1080p)N/A1920 x 1080 (1080p)
Video FPSNot specifiedN/ADaytime 20 FPS, Nighttime 10 FPS
Night VisionColor Night VisionN/AColor Night Vision, 4 IR LEDs (850nm)
AudioBuilt-in Speaker & Microphone; Noise & Echo CancellationN/ABuilt-in Speaker & Microphone; Noise & Echo Cancellation
SpotlightBuilt-in 40-lumen spotlightN/ANo spotlight
Weather ResistanceIP65 (Indoor/Outdoor)N/AIP65 (Indoor/Outdoor)
Power Adapter Output5V/1AN/A5V/1A
Power Cable LengthNot specifiedN/A6 ft (1.8 m)
ConnectivityWi-Fi 2.4 GHzUSB extension cableWi-Fi 2.4 GHz
Local Storage SupportUp to 256 GB microSDN/AUp to 256 GB microSD
Dimensions1.89 in x 1.89 in x 1.89 in (48 mm)N/A1.89 in x 1.89 in x 1.89 in (48 mm)
Weight4.1 oz (116 g)N/A4.1 oz (116 g)
Two-Way AudioYesN/AYes
Additional Features3X faster notifications, improved 2-way audio, built-in spotlight, IP65 weatherproofExtends USB cable length to 20ft3X telephoto lens, improved 2-way audio
Compatible WithN/AWyze Cam v2/v3/v4, v3 Pro, Pan v2/v3, OG Standard, OG TelephotoN/A
What is the best way to extend the power cable for my Wyze Cam in a large room?The Wyze Cam USB Extension Cable - 20ft is the ideal solution for extending your camera’s power cable in large spaces. It allows you to position your Wyze Cam far from the nearest power outlet, providing flexibility and freedom when rearranging furniture or redecorating.
Which Wyze Cam models are compatible with the 20ft USB extension cable?The 20ft USB extension cable is compatible with Wyze Cam v2, v3, v3 Pro, v4, Pan v2, Pan v3, Wyze Cam OG, and Wyze Cam OG Telephoto models.
Is the Wyze Cam USB Extension Cable suitable for outdoor use?Yes, the Wyze Cam USB Extension Cable - 20ft is rated IP67 for weather resistance, making it suitable for both indoor and outdoor use.
How does the Wyze Cam OG benefit from using a 20ft USB extension cable?Using the 20ft USB extension cable with the Wyze Cam OG allows you to place the camera in the optimal location for wide-area monitoring, even in large rooms or open spaces, without worrying about the distance to a power outlet.
What are the key features of the Wyze Cam OG?The Wyze Cam OG features a 120° field of view, built-in 40-lumen spotlight, 90-decibel mini-siren, IP65 weather resistance, 3X faster notifications, upgraded two-way audio, quick live HD streaming, and support for microSD cards up to 256GB.
What makes the Wyze Cam OG Telephoto ideal for detailed monitoring?The Wyze Cam OG Telephoto offers a 3X telephoto lens with a narrow 27° field of view, 1080p Full HD video, night vision with 4 IR LEDs, IP65 weatherproof rating, 8X digital zoom, two-way audio with noise cancellation, and flexible mounting options.
Why should I use a USB extension cable with my Wyze Cam?A USB extension cable allows you to move your Wyze Cam to the perfect spot for monitoring, especially when rearranging furniture or redecorating large rooms. It ensures a continuous power supply and uninterrupted security coverage without being limited by the original cable length.
What is the wire thickness and power output of the Wyze Cam USB Extension Cable?The Wyze Cam USB Extension Cable uses AWG 18# wire thickness and supports a stable power delivery of 5V 2A output, ensuring reliable performance for your camera.
What is the operating temperature range for the Wyze Cam USB Extension Cable?The Wyze Cam USB Extension Cable operates reliably in temperatures ranging from -30°C to 50°C (-22°F to 122°F), making it suitable for various environments.
How can I optimize my Wyze Cam setup in a large space?To optimize your Wyze Cam setup in a large space, use the 20ft USB extension cable to place your camera exactly where you need it, ensuring maximum coverage and security without being restricted by power outlet locations.
What are the key features of the Wyze Cam OG?Can the Wyze Cam OG be used outdoors?Are there any discounts or promotions currently available for Wyze products?
