20ft Wyze Cam USB Extension Cable for Wide Area Surveillance
Extend Your Wyze Cam Reach with the 20ft USB Extension Cable
If you're looking to position your Wyze Cam for wide area surveillance, the Wyze Cam USB Extension Cable - 20ft is the perfect accessory to extend your camera's reach without compromising power or connectivity. This cable allows you to place your Wyze Cam farther from power outlets, enabling flexible installation options for both indoor and outdoor monitoring.
Key Features of the Wyze Cam USB Extension Cable - 20ft
  • Compatibility: Works seamlessly with Wyze Cam v2, v3, v4, v3 Pro, Cam Pan v2/v3, OG Standard, and OG Telephoto models.
  • Length: A generous 20-foot length provides ample distance to position your camera exactly where you need it.
  • Ease of Use: Simply plug in to extend your existing USB power cable without any complicated setup.
  • Reliable Power Delivery: Ensures stable power supply to your Wyze Cam for uninterrupted surveillance.
This extension cable is an affordable and practical solution to overcome the limitations of short USB cables, making it ideal for wide area surveillance setups such as monitoring large rooms, garages, porches, or backyards.
Enhance Your Surveillance Setup with Wyze Cam OG Telephoto
For users who want to capture detailed footage over a distance, the Wyze Cam OG Telephoto is an excellent choice. This camera features a powerful 3x telephoto lens, allowing you to zoom in on specific areas while maintaining crisp 1080p HD video quality.
Why Choose Wyze Cam OG Telephoto?
  • 3x Telephoto Lens: Get closer views of distant subjects without losing image clarity.
  • Improved Live Streaming: Experience quicker live video with 3x faster notifications.
  • Enhanced Two-Way Audio: Communicate clearly with built-in noise and echo cancellation.
  • Weather Resistant: Rated IP65, suitable for both indoor and outdoor use.
  • Flexible Mounting: Mount on walls, ceilings, or use the stand for versatile placement.
  • Local Storage Support: Supports up to 256GB microSD cards for continuous recording.
Pairing the Wyze Cam OG Telephoto with the 20ft USB extension cable allows you to position this camera in optimal locations for wide area coverage, even when power outlets are far away.
Smart Power Solutions with Cam v4 + Lamp Socket v2 Bundle
If you want to power your Wyze Cam v4 without relying on traditional outlets, the Cam v4 + Lamp Socket v2 Bundle offers a smart and convenient solution. This bundle lets you power your camera directly through a lamp socket, freeing you from outlet constraints.
Highlights of the Cam v4 + Lamp Socket v2 Bundle
  • Power Anywhere: Use existing lamp sockets to power your Wyze Cam v4.
  • Motion-Activated Lights: The lamp socket supports motion-activated lighting for added security.
  • Dusk to Dawn Scheduling: Automate lighting based on time of day.
  • Compact and Durable: Made from polycarbonate and plastic, suitable for damp locations (not fully weatherproof).
  • Wide Compatibility: Works with Wyze Cam v3, v3 Pro, v4, OG, and Cam Pan v3.
This bundle is ideal for outdoor or indoor areas where power outlets are limited but lamp sockets are available, enhancing your ability to position cameras for broad surveillance coverage.
Why Use a 20ft USB Extension Cable for Wyze Cam?
"Positioning your Wyze Cam for optimal coverage is crucial for effective surveillance. The 20ft USB extension cable provides the flexibility to place your camera in the best vantage points without being restricted by outlet locations."
Whether you want to monitor a large backyard, a wide garage, or multiple entry points, this extension cable ensures your Wyze Cam stays powered and connected, maximizing your security setup.
Summary
For wide area surveillance with Wyze Cam, the Wyze Cam USB Extension Cable - 20ft is an essential accessory that expands your installation possibilities. Combine it with advanced cameras like the Wyze Cam OG Telephoto for detailed zoomed-in views or the Cam v4 + Lamp Socket v2 Bundle for smart power options. Together, these products provide a versatile, powerful, and convenient surveillance system tailored to your needs.
Outdoor surveillance with Wyze Cam Position your Wyze Cam anywhere outdoors with extended cable reach Wyze Cam OG Telephoto zooming Capture distant details clearly with Wyze Cam OG Telephoto Smart lighting with Cam v4 and Lamp Socket Power your Wyze Cam v4 through lamp sockets for flexible placement
FeatureWyze Cam USB Extension Cable - 20ftWyze Cam OG TelephotoCam v4 + Lamp Socket v2 Bundle
TypeAccessoryCameraBundle (Camera + Lamp Socket)
Price$7.99$25.98 (1 Pack)$49.96 (Wyze Cam v4)
CompatibilityWyze Cam v2/v3/v4, v3 Pro, Pan v2/v3, OG Standard, OG TelephotoIndoor/outdoor cameraWyze Cam v3, v3 Pro, v4, OG, Pan v3
Description20ft USB extension cable for Wyze Cams2023 generation with 3x telephoto lens, faster streaming, improved 2-way audio, IP65 weather resistancePowers Wyze Cam v4 without outlet; smart lamp socket with motion-activated lights
Key FeaturesExtends USB cable length to 20ft3x telephoto lens, color night vision, 3x faster notifications, upgraded two-way audio, IP65 weatherproofConvenient power for Wyze Cams, motion-activated lights, dusk to dawn scheduling
Weather ResistanceN/AIP65Not weatherproof, suitable for damp locations
PowerUSB poweredPlug-inLamp socket: 120V~, 60Hz; max lamp power 20W
DimensionsN/AN/A56.5mm x 56.5mm x 65mm
WeightN/AN/A80 g
ConnectivityUSBWi-Fi 2.4 GHz (802.11 b/g/n)Wi-Fi 2.4 GHz (802.11 b/g/n), Bluetooth
Operating TemperatureN/A-4°F to 131°F (-20°C to 55°C)-4°F to 120°F (-20°C to 50°C)
Warranty30-day hassle-free returns1-Year1-Year
Included Items1 x 20ft USB extension cable1 x Wyze Cam OG Telephoto1 x Wyze Cam v4, 1 x Lamp Socket v2
What is the Wyze Cam USB Extension Cable - 20ft used for?The Wyze Cam USB Extension Cable - 20ft is designed to extend the reach of your Wyze Cam, allowing you to position your camera farther from power outlets for flexible indoor and outdoor surveillance setups.
Which Wyze Cam models are compatible with the 20ft USB Extension Cable?The 20ft USB Extension Cable is compatible with Wyze Cam v2, v3, v4, v3 Pro, Cam Pan v2/v3, OG Standard, and OG Telephoto models.
How long is the Wyze Cam USB Extension Cable?The Wyze Cam USB Extension Cable is 20 feet long, providing ample distance to position your camera exactly where you need it.
Does the 20ft USB Extension Cable affect the power supply to my Wyze Cam?No, the 20ft USB Extension Cable ensures reliable and stable power delivery to your Wyze Cam, so your surveillance remains uninterrupted.
Is the Wyze Cam USB Extension Cable easy to install?Yes, the extension cable is easy to use—simply plug it in to extend your existing USB power cable without any complicated setup.
What are the benefits of using the Wyze Cam OG Telephoto?The Wyze Cam OG Telephoto features a 3x telephoto lens for detailed zoomed-in views, 1080p HD video quality, faster live streaming and notifications, enhanced two-way audio, IP65 weather resistance, flexible mounting options, and support for up to 256GB microSD cards for continuous recording.
Can I use the Wyze Cam OG Telephoto outdoors?Yes, the Wyze Cam OG Telephoto is rated IP65, making it suitable for both indoor and outdoor use.
How can I power my Wyze Cam v4 if I don’t have a nearby outlet?You can use the Cam v4 + Lamp Socket v2 Bundle, which allows you to power your Wyze Cam v4 directly through an existing lamp socket, eliminating the need for a traditional power outlet.
What features does the Cam v4 + Lamp Socket v2 Bundle offer?The Cam v4 + Lamp Socket v2 Bundle offers motion-activated lighting, dusk to dawn scheduling, compatibility with multiple Wyze Cam models, and a compact, durable design suitable for damp locations.
Why should I use a 20ft USB extension cable for my Wyze Cam?Using a 20ft USB extension cable allows you to position your Wyze Cam in optimal locations for wide area surveillance, such as large rooms, garages, porches, or backyards, without being limited by the location of power outlets.
Can you tell me more about the compatibility of the 20ft USB extension cable with different Wyze Cam models?What are the benefits of using the Wyze Cam OG Telephoto for surveillance?Do you have any ongoing sales or promotions for the Wyze Cam accessories?
