Wyze Cam 20ft USB Extension Cable: Relocate for Better Wi-Fi
Extend Your Wyze Cam Reach with the 20ft USB Extension Cable
If you’re struggling with poor Wi-Fi spots limiting where you can place your Wyze Cam, the Wyze Cam USB Extension Cable - 20ft is the perfect solution. This accessory gives you the freedom to relocate your camera without worrying about short cables or limited power outlet access.
Key Features of the Wyze Cam USB Extension Cable - 20ft
  • Length: A generous 20 feet to extend your camera’s reach.
  • Compatibility: Works seamlessly with Wyze Cam v2, v3, v4, v3 Pro, Pan v2, Pan v3, OG Standard, and OG Telephoto models.
  • Flexibility: Enables you to position your camera in the best Wi-Fi spots for optimal connectivity and coverage.
  • Affordable: Priced at just $7.99, it’s a cost-effective way to enhance your home security setup.
Say goodbye to frustrating placement limitations and enjoy the freedom to monitor your home from the ideal vantage point.
Outdoor security camera mounted on a porch with extended cable Alt text: Wyze Cam mounted outdoors with USB extension cable for better Wi-Fi coverage
Enhance Outdoor Security with Wyze Cam + Lamp Socket Bundles
For those looking to power their Wyze Cams without relying on nearby outlets, the Cam v4 + Lamp Socket v2 Bundle and Pan v3 + Lamp Socket v2 Bundle offer smart, convenient solutions.
Cam v4 + Lamp Socket v2 Bundle Highlights
  • Smart Power: Powers Wyze Cam v4 using your existing outdoor light fixture—no extra wiring needed.
  • Compatibility: Supports Wyze Cam v3, v3 Pro, v4, OG, and Pan v3.
  • Smart Lighting: Turns your outdoor lights into motion-activated smart lights controlled via the Wyze app.
  • Easy Installation: Simply screw in the lamp socket like a lightbulb.
  • Energy Efficient: Compatible with CFL or LED bulbs under 20W (incandescent bulbs not recommended).
Pan v3 + Lamp Socket v2 Bundle Highlights
  • Flexible Power Source: Powers Wyze Cam Pan v3 without an outlet.
  • Smart Control: Automate your outdoor lighting with motion detection and app control.
  • Durability: Suitable for damp locations, perfect for outdoor use.
  • Compact Design: Measures 56.5mm x 56.5mm x 65mm and weighs only 80g.
  • Connectivity: Supports 2.4GHz Wi-Fi and Bluetooth for seamless integration.
These bundles not only power your cameras but also upgrade your outdoor lighting to smart, motion-activated illumination, enhancing security and convenience.
Home exterior with smart outdoor lighting and security camera Alt text: Smart outdoor lighting powered by Wyze Cam and lamp socket bundle
Why Use a USB Extension Cable for Your Wyze Cam?
Relocating your Wyze Cam to a better Wi-Fi spot can dramatically improve video quality and reliability. The 20ft USB extension cable allows you to:
  • Avoid Wi-Fi dead zones by placing your camera closer to your router or a Wi-Fi extender.
  • Maintain power supply without needing to install new outlets or use bulky adapters.
  • Keep your setup neat and flexible with a cable long enough to reach ideal locations indoors or outdoors.
This simple accessory is essential for anyone wanting to maximize their Wyze Cam’s performance and coverage.
Summary
When it comes to optimizing your Wyze Cam placement and power options, the Wyze Cam USB Extension Cable - 20ft stands out as an affordable, practical accessory. For outdoor setups, the Cam v4 + Lamp Socket v2 Bundle and Pan v3 + Lamp Socket v2 Bundle provide smart power solutions that integrate lighting and security seamlessly. Investing in these accessories ensures your Wyze Cam operates at its best, delivering reliable security footage from the perfect spot in your home or yard.
FeatureWyze Cam USB Extension Cable - 20ftCam v4 + Lamp Socket v2 BundlePan v3 + Lamp Socket v2 Bundle
Product TypeAccessoryBundleBundle
Price$7.99$49.96$53.96
Compatible DevicesWyze Cam v2, v3, v3 Pro, v4, Pan v2, Pan v3, OG, OG TeleWyze Cam v3, v3 Pro, v4, Cam OG, OG Tele, Pan v3Wyze Cam v3, v3 Pro, v4, Cam OG, OG Tele, Pan v3
Cable Length20ftN/AN/A
Power SourceUSB 5V 2APowered via Lamp Socket v2Powered via Lamp Socket v2
Lamp Socket IncludedNoYesYes
Camera IncludedNoWyze Cam v4Wyze Cam Pan v3
Camera ResolutionN/A2.5K QHD1080p
Night VisionN/AEnhanced Color Night Vision4 IR LEDs (850 nm)
Motion-Activated LightingN/AYesYes
Smart Lighting ControlN/AYes, via Wyze appYes, via Wyze app
Installation EasePlug and play USB extensionScrew in lamp socket (like a lightbulb)Screw in lamp socket (like a lightbulb)
Weather ResistanceIP67Compatible with outdoor use (camera IP65)Compatible with outdoor use (camera IP65)
Cable Connector TypeUSB Type A Male to FemaleN/AN/A
Operating Temperature-30°C to 50°C (-22°F to 122°F)Compatible with outdoor temperature rangesCompatible with outdoor temperature ranges
Additional FeaturesWeatherproof cableDusk to dawn automation, motion-activated lightsDusk to dawn automation, motion-activated lights
Return Policy30-day hassle-free returns30-day hassle-free returns30-day hassle-free returns
What is the Wyze Cam USB Extension Cable - 20ft used for?The Wyze Cam USB Extension Cable - 20ft is designed to extend the reach of your Wyze Cam, allowing you to place your camera in optimal locations for better Wi-Fi connectivity and coverage without worrying about short cables or limited power outlet access.
Which Wyze Cam models are compatible with the 20ft USB Extension Cable?The 20ft USB Extension Cable is compatible with Wyze Cam v2, v3, v4, v3 Pro, Pan v2, Pan v3, OG Standard, and OG Telephoto models.
How long is the Wyze Cam USB Extension Cable and what is its price?The Wyze Cam USB Extension Cable is 20 feet long and is affordably priced at $7.99.
Can I use the Wyze Cam USB Extension Cable outdoors?Yes, the 20ft USB Extension Cable can be used to position your Wyze Cam in both indoor and outdoor locations, helping you avoid Wi-Fi dead zones and maintain a reliable power supply.
What are the benefits of using a USB extension cable with my Wyze Cam?Using a USB extension cable allows you to place your Wyze Cam closer to your Wi-Fi router or extender, avoid Wi-Fi dead zones, maintain a consistent power supply without installing new outlets, and keep your setup neat and flexible.
What is the Cam v4 + Lamp Socket v2 Bundle?The Cam v4 + Lamp Socket v2 Bundle is a smart solution that powers your Wyze Cam v4 using your existing outdoor light fixture, eliminating the need for extra wiring. It also turns your outdoor lights into motion-activated smart lights controlled via the Wyze app.
Which Wyze Cam models are supported by the Lamp Socket v2?The Lamp Socket v2 supports Wyze Cam v3, v3 Pro, v4, OG, and Pan v3 models.
How does the Pan v3 + Lamp Socket v2 Bundle enhance outdoor security?The Pan v3 + Lamp Socket v2 Bundle powers your Wyze Cam Pan v3 without needing an outlet and automates your outdoor lighting with motion detection and app control, making it ideal for enhancing outdoor security and convenience.
Is the Lamp Socket v2 suitable for outdoor use?Yes, the Lamp Socket v2 is designed for durability and is suitable for damp locations, making it perfect for outdoor use.
What types of bulbs are compatible with the Lamp Socket v2?The Lamp Socket v2 is compatible with CFL or LED bulbs under 20W. Incandescent bulbs are not recommended.
How do I install the Lamp Socket v2 for my Wyze Cam?Installation is easy—simply screw the Lamp Socket v2 into your existing outdoor light fixture like a regular lightbulb, then connect your Wyze Cam for smart power and lighting control.
Can you tell me more about the compatibility of the Wyze Cam USB Extension Cable with different Wyze Cam models?How does the USB extension cable improve the video quality of the Wyze Cam?Do you have any deals, ongoing sales, discounts, or promotions available for the Wyze Cam accessories?
