Keep Wyze Cam Powered Anywhere with 20ft USB Extension Cable
Keep Your Wyze Cam Powered During Repositioning in a Shared Household
When using Wyze Cams in a shared household, maintaining continuous power while repositioning your cameras can be a challenge. The solution lies in extending your camera’s reach and flexibility without compromising on power supply. The Wyze Cam USB Extension Cable - 20ft is the perfect accessory to keep your Wyze Cam powered seamlessly during repositioning, giving you freedom to place your cameras exactly where you need them.
Wyze Cam USB Extension Cable - 20ft: Freedom to Reposition Anywhere
Extend Your Camera’s Reach with Ease
Say goodbye to the frustration of short cables limiting your Wyze Cam placement. The Wyze Cam USB Extension Cable - 20ft offers a generous length that allows you to move your camera freely around your home without unplugging or losing power.
  • Compatibility: Works with Wyze Cam v2, v3, v4, v3 Pro, Pan v2/v3, OG Standard, and OG Telephoto models.
  • Length: 20 feet of durable USB extension cable.
  • Convenience: Ideal for shared households where cameras need to be repositioned frequently.
  • Price: Affordable at $7.99, making it an easy upgrade for any Wyze Cam user.
This cable ensures your camera stays powered continuously, even when you want to adjust angles or move it to a different room temporarily.
Wyze Cam v4: Advanced Security with Flexible Power Options
High-Performance Camera with Smart Mounting and Power
The Wyze Cam v4 is a top-tier security camera offering crystal-clear 2.5K QHD video resolution and enhanced color night vision. It comes with a 6-foot flat micro USB to USB-A cable, but when paired with the 20ft USB extension cable, you gain unmatched flexibility in camera placement.
  • Video Quality: 2.5K QHD (2560x1440) resolution with 8x digital zoom.
  • Field of View: Wide 115.8° diagonal, 98.5° horizontal, and 53.1° vertical.
  • Night Vision: 4 IR LEDs plus 2 white spotlight LEDs for color night vision.
  • Mounting Options: Stand, wall mount, ceiling mount, and magnetic adhesive mount.
  • Connectivity: Supports Wi-Fi 6 and Bluetooth 5.2.
  • Power: Comes with a 6-foot cable; extend with the 20ft USB extension for more placement freedom.
  • Weather Resistance: Rated IP65 for indoor/outdoor use.
  • Additional Features: Built-in siren, two-way talk, noise cancellation, and Alexa/Google Assistant integration.
Using the USB extension cable with Wyze Cam v4 allows you to position your camera in hard-to-reach or shared spaces without worrying about power outlets. Wyze Cam v4 in Living Room
Cam v4 + Lamp Socket v2 Bundle: Power Without Outlets
Innovative Power Solution for Wyze Cam v4
For households where power outlets are limited or inconveniently located, the Cam v4 + Lamp Socket v2 Bundle offers a smart alternative. This bundle lets you power your Wyze Cam v4 directly from a lamp socket, eliminating the need for a nearby outlet.
  • Compatibility: Works with Wyze Cam v3, v3 Pro, v4, OG, and Pan v3.
  • Features: Motion-activated lights, dusk-to-dawn scheduling, and unlimited linkability.
  • Power Input: Standard E26 lamp socket, supports up to 20W CFL or LED bulbs.
  • Installation: Easy to install in any standard lamp socket.
  • Weather Suitability: Suitable for damp locations (not fully weatherproof).
This bundle is perfect for shared households where repositioning cameras is frequent, and power access is limited. Combined with the USB extension cable, it maximizes your camera’s placement flexibility and power reliability.
Why Use a USB Extension Cable with Wyze Cams in Shared Households?
In shared living environments, cameras often need to be moved or adjusted to accommodate different users’ needs. The Wyze Cam USB Extension Cable - 20ft provides the freedom to reposition your camera without unplugging it, ensuring continuous monitoring and security.
  • Avoid Power Interruptions: Keep your camera powered even when moving it.
  • Flexible Placement: Extend beyond the standard 6-foot cable length.
  • Easy Setup: Plug-and-play compatibility with multiple Wyze Cam models.
  • Cost-Effective: Affordable accessory that enhances your existing setup.
Summary: Best Products to Keep Wyze Cam Powered During Repositioning
Product NameKey BenefitPrice
Wyze Cam USB Extension Cable - 20ftExtends power cable length for flexible camera placement$7.99
Wyze Cam v4High-resolution camera with versatile mounting and power options$35.98+
Cam v4 + Lamp Socket v2 BundlePowers Wyze Cam v4 via lamp socket, no outlet needed$49.96
By combining these products, you can ensure your Wyze Cam stays powered and positioned exactly where you need it in a shared household environment.
FeatureWyze Cam USB Extension Cable - 20ftWyze Cam v4Cam v4 + Lamp Socket v2 Bundle
TypeAccessoryCameraBundle (Camera + Lamp Socket)
Price$7.99$35.98$49.96
CompatibilityWyze Cam v2/v3/v4, v3 Pro, Pan v2/v3, OG Standard, OG TelephotoStandalone cameraWyze Cam v3, v3 Pro, v4, OG, Pan v3
Cable Length20 ft USB extension cable6-Foot Flat micro USB to USB-A cableIncluded with camera (6-Foot Flat micro USB to USB-A)
ResolutionN/A2.5K QHD (2560x1440)2.5K QHD (2560x1440)
Night VisionN/AEnhanced Color Night VisionEnhanced Color Night Vision
Power SourceN/AWiredWired
Weather ResistanceN/AIP65Not weatherproof or waterproof (Lamp Socket)
Motion DetectionN/AYesYes
Sound DetectionN/AYesYes
SpotlightN/AMotion-activated spotlightMotion-activated spotlight
MicroSD Card SupportN/AUp to 256GB (sold separately)Up to 256GB (sold separately)
Additional FeaturesExtends USB cable length for Wyze CamsWi-Fi 6 support, Alexa & Google Assistant compatible, 24/7 local recording, Wide Dynamic Range (WDR), SirenPowers Wyze Cam without outlet, Motion-activated lights, Dusk to Dawn Scheduling
DimensionsN/A2in x 2in x 2 3/8inLamp Socket: 56.5mm x 56.5mm x 65mm
WeightN/A0.49 lb (222 g)Lamp Socket: 80 g
Warranty30-day hassle-free returns1 Year1 Year
What is the Wyze Cam USB Extension Cable - 20ft and how does it help with camera placement?The Wyze Cam USB Extension Cable - 20ft is a durable, 20-foot USB cable designed to extend the reach of your Wyze Cam’s power supply. It allows you to reposition your camera anywhere in your home without unplugging it or losing power, making it ideal for shared households where camera placement needs to be flexible.
Which Wyze Cam models are compatible with the 20ft USB Extension Cable?The Wyze Cam USB Extension Cable - 20ft is compatible with Wyze Cam v2, v3, v4, v3 Pro, Pan v2/v3, OG Standard, and OG Telephoto models.
How does the Wyze Cam v4 benefit from using the USB extension cable?The Wyze Cam v4 comes with a 6-foot power cable, but using the 20ft USB extension cable allows you to place the camera in hard-to-reach or shared spaces without worrying about power outlet locations, ensuring continuous power and flexible placement.
What are the key features of the Wyze Cam v4?The Wyze Cam v4 offers 2.5K QHD video resolution, enhanced color night vision, a wide field of view, multiple mounting options, Wi-Fi 6 and Bluetooth 5.2 connectivity, IP65 weather resistance, built-in siren, two-way talk, noise cancellation, and integration with Alexa and Google Assistant.
How can I power my Wyze Cam v4 if there are no nearby outlets?You can use the Cam v4 + Lamp Socket v2 Bundle, which allows you to power your Wyze Cam v4 directly from a standard E26 lamp socket. This solution is perfect for areas with limited or inconveniently located power outlets.
Is the Cam v4 + Lamp Socket v2 Bundle compatible with other Wyze Cam models?Yes, the Cam v4 + Lamp Socket v2 Bundle is compatible with Wyze Cam v3, v3 Pro, v4, OG, and Pan v3 models.
Can I use the Wyze Cam USB Extension Cable and Lamp Socket v2 together?Yes, combining the Wyze Cam USB Extension Cable with the Lamp Socket v2 maximizes your camera’s placement flexibility and ensures reliable power, even in shared households with frequent camera repositioning.
Why is a USB extension cable recommended for Wyze Cams in shared households?In shared living environments, cameras often need to be moved or adjusted. The Wyze Cam USB Extension Cable - 20ft allows you to reposition your camera without unplugging it, ensuring continuous monitoring and security while avoiding power interruptions.
How much does the Wyze Cam USB Extension Cable - 20ft cost?The Wyze Cam USB Extension Cable - 20ft is affordably priced at $7.99, making it an easy and cost-effective upgrade for any Wyze Cam user.
Is the Lamp Socket v2 suitable for outdoor use?The Lamp Socket v2 is suitable for damp locations but is not fully weatherproof, so it should not be used in areas exposed directly to the elements.
How does the Wyze Cam USB Extension Cable help in shared households?What models are compatible with the Wyze Cam USB Extension Cable?Are there any ongoing promotions or discounts available for Wyze products?
