Upgrade Wyze Doorbell: Adjustable Chime Volume & Smart Alerts
Upgrade Your Wyze Doorbell with Adjustable Chime Volume
If you're looking to enhance your Wyze doorbell experience by adding adjustable chime volume and more versatile alert options, the Wyze Universal Wi-Fi Chime is the perfect accessory to upgrade your setup. This page will guide you through the best Wyze products designed to improve your doorbell system, focusing on chime volume control, sound variety, and seamless integration with your existing Wyze devices.
Wyze Universal Wi-Fi Chime: Flexible Volume and Tone Control
Key Features
- Adjustable Volume: Easily control the chime volume to suit your home environment, ensuring you never miss a visitor or delivery.
- 17 Different Tones: Choose from a wide variety of chime sounds, including classic doorbell rings, modern tones, and even animal sounds.
- Simple Plug-and-Play Setup: No complicated wiring needed—just plug it into any standard power outlet and connect via Wi-Fi.
- Smart Automations: Set your chime to ring not only when someone presses your doorbell but also when your Wyze cameras detect motion or a person, such as your kitchen’s cookie cam.
- Compatibility: Works seamlessly with all Wyze Cams and doorbells, making it a versatile addition to your smart home.
Specifications
- Dimensions: 81 x 53 x 38 mm
- Speaker Size: 40mm
- Wi-Fi: IEEE802.11 b/g/n 2.4 GHz
- Power Input: 10-24V AC, 10VA 60Hz
- Operating Temperature: -4°F to 122°F (-20°C to 50°C)
- Bluetooth: BLE 5.0
- Certifications: FCC, IC, UL, CP65
The Wyze Universal Wi-Fi Chime is your hassle-free solution to customize your doorbell alerts with volume control and a variety of tones, enhancing your home’s security and convenience.
Wyze Video Doorbell v2: Crisp 2K Video with Chime Controller
Overview
Upgrade your doorbell with the Wyze Video Doorbell v2, which offers crystal-clear 2K video resolution and comes bundled with a dedicated Wyze Chime Controller for enhanced sound management.
Highlights
- 2K Video Quality: Capture every detail with 2048 x 1536 resolution and a wide 135° horizontal field of view.
- Two-Way Audio: Communicate with visitors through the built-in microphone and speaker featuring noise and echo cancellation.
- Weather Resistant: Rated IP65, suitable for all weather conditions.
- Chime Controller Included: The Wyze Chime Controller allows you to connect your doorbell to nearly any mechanical chime, giving you flexible volume and sound options.
- Motion-Activated Voice Deterrence: Automatically warn unwanted visitors with a customizable voice alert.
- Local and Cloud Storage: Supports microSD cards up to 256GB and optional cloud storage with Wyze Security Plan.
Technical Specs
- Dimensions: 4.3in x 1.7in x 0.9in (110mm x 44mm x 24mm)
- Power: 16V-24V AC, ≥10VA
- Frame Rate: 20 FPS (day), 15 FPS (night)
- Connectivity: Wi-Fi 2.4 GHz b/g/n
- Certifications: FCC, IC, UL, CA65, ROHS, REACH, IP65 Certified
With the Wyze Video Doorbell v2 and its chime controller, you get a complete solution for high-quality video monitoring and customizable chime volume, ensuring you hear every visitor loud and clear.
Wyze Chime Controller: Enhance Your Doorbell’s Sound System
What It Does
The Wyze Chime Controller is a standalone unit designed to work exclusively with the Wyze Video Doorbell v2 and Duo Cam Doorbell. It enables your doorbell to connect to almost any mechanical chime, giving you the ability to adjust volume and sound type beyond the default settings.
Features
- Easy Wiring Installation: Simple to install with a straightforward wiring process.
- Compact Design: Small footprint (47mm x 32mm x 15mm) fits easily behind your existing chime.
- Power: AC16V/AC24V, ≥10VA
- Temperature Range: Works reliably from -20°C to 50°C (-4°F to 122°F)
- Compatibility: Compatible with nearly every mechanical chime, expanding your options for chime sounds and volume control.
The Wyze Chime Controller is the perfect add-on for those who want to integrate their Wyze doorbell with traditional chime systems while gaining adjustable volume control.
Why Upgrade Your Wyze Doorbell Setup?
Upgrading your Wyze doorbell with the Universal Wi-Fi Chime or the Chime Controller paired with the Video Doorbell v2 offers several benefits:
- Customizable Volume: Adjust chime volume to fit your home’s noise level and personal preference.
- Variety of Sounds: Choose from multiple tones to match your style or alert needs.
- Smart Home Integration: Works with Alexa, Google Assistant, and IFTTT for voice control and automation.
- Easy Installation: No complex wiring or professional help needed for most setups.
- Enhanced Security: Get real-time alerts and two-way communication with visitors.
Enhance your home security and convenience with Wyze’s smart doorbell accessories.
Summary of Recommended Products for Adjustable Chime Volume
Product Name | Price (USD) | Key Benefit |
Wyze Universal Wi-Fi Chime | $19.98 | Adjustable volume, 17 tones |
Wyze Video Doorbell v2 | $44.98 | 2K video, chime controller included |
Wyze Chime Controller | $17.99 | Connects to mechanical chimes |
Upgrade your Wyze doorbell system today to enjoy customizable chime volume and enhanced smart home functionality.
Feature | Wyze Universal Wi-Fi Chime | Wyze Video Doorbell v2 | Wyze Chime Controller |
Type | Accessory | Camera (Video Doorbell) | Accessory (Chime Controller) |
Price | $19.98 | $44.98 | $17.99 |
Compatibility | All Wyze Cams and Doorbells | Wired Video Doorbell | Wyze Video Doorbell v2, Wyze Duo Cam Doorbell |
Installation | Plug-in, no wiring required | Wired installation (16V-24V AC, ≥10VA) | Easy wiring installation |
Dimensions | 81 x 53 x 38 mm | 110 x 44 x 24 mm (4.3" x 1.7" x 0.9") | 47 x 32 x 15 mm |
Power Input | 10-24V AC, 10VA 60Hz | 16V-24V AC, ≥10VA | AC16V/AC24V, ≥10VA |
Operating Temperature | -4°F to 122°F (-20°C to 50°C) | -4°F to 122°F (-20°C to 50°C) | -20°C to 50°C |
Indoor Use | Yes | Yes | Yes |
Wi-Fi | IEEE 802.11 b/g/n 2.4 GHz | IEEE 802.11 b/g/n 2.4 GHz | N/A |
Bluetooth | BLE 5.0 | N/A | N/A |
Speaker | Ø40mm speaker | 8Ω 1W speaker | N/A |
Tones | 17 different tones | Multiple chime sounds included | Compatible with nearly every mechanical chime |
Features | Works with all Wyze Cams, multiple devices | 2K video, two-way audio, motion alerts, local storage | Standalone chime controller |
Integrations | Alexa, Google Assistant, IFTTT | Alexa, Google Assistant, IFTTT | N/A |
Certifications | FCC, IC, UL, CP65 | FCC, IC, UL, CA65, ROHS, REACH, IP65 Certified | N/A |
Included in Box | 1x Wyze Wi-Fi Chime, 1x Quick Start Guide | 1x Wyze Video Doorbell v2, 1x Chime Controller, installation accessories | 1x Chime controller unit |
What is the Wyze Universal Wi-Fi Chime and how does it enhance my doorbell system?
The Wyze Universal Wi-Fi Chime is an accessory designed to upgrade your Wyze doorbell system by providing adjustable chime volume and a selection of 17 different tones. It features a simple plug-and-play setup, connects via Wi-Fi, and integrates seamlessly with all Wyze Cams and doorbells. The chime can also be set to ring when your Wyze cameras detect motion or a person, offering versatile alert options for your smart home.How do I adjust the chime volume on my Wyze doorbell?
With the Wyze Universal Wi-Fi Chime or the Wyze Chime Controller, you can easily adjust the chime volume to suit your home environment. The Universal Wi-Fi Chime allows you to control the volume directly through the Wyze app, while the Chime Controller lets you adjust the volume of your connected mechanical chime.What tones are available with the Wyze Universal Wi-Fi Chime?
The Wyze Universal Wi-Fi Chime offers 17 different tones, including classic doorbell rings, modern sounds, and even fun animal noises. This variety allows you to customize your doorbell alert to match your personal style or alert needs.Is the Wyze Universal Wi-Fi Chime compatible with all Wyze devices?
Yes, the Wyze Universal Wi-Fi Chime is compatible with all Wyze Cams and doorbells, making it a versatile addition to your existing Wyze smart home setup.What are the key features of the Wyze Video Doorbell v2?
The Wyze Video Doorbell v2 features crystal-clear 2K video resolution, a wide 135° field of view, two-way audio with noise and echo cancellation, weather resistance (IP65 rated), and comes bundled with a dedicated Wyze Chime Controller for enhanced sound management. It also supports motion-activated voice deterrence, local and cloud storage, and easy integration with smart home platforms.How does the Wyze Chime Controller work with my doorbell?
The Wyze Chime Controller is designed to work with the Wyze Video Doorbell v2 and Duo Cam Doorbell. It connects your doorbell to almost any mechanical chime, allowing you to adjust the volume and sound type beyond the default settings. Installation is straightforward, and the compact design fits easily behind your existing chime.Can I integrate Wyze doorbell products with Alexa or Google Assistant?
Yes, Wyze doorbell products, including the Universal Wi-Fi Chime and Video Doorbell v2, are compatible with Alexa, Google Assistant, and IFTTT. This allows for voice control and smart home automation, enhancing your home’s convenience and security.Is installation of Wyze doorbell accessories easy?
Yes, most Wyze doorbell accessories are designed for easy installation. The Wyze Universal Wi-Fi Chime requires no complicated wiring—just plug it into a standard outlet. The Wyze Chime Controller features a simple wiring process and a compact design for easy integration with existing mechanical chimes.What are the benefits of upgrading my Wyze doorbell with adjustable chime volume?
Upgrading your Wyze doorbell with adjustable chime volume offers several benefits: customizable volume to fit your home’s noise level, a variety of chime sounds, seamless smart home integration, easy installation, and enhanced security with real-time alerts and two-way communication.What are the technical specifications of the Wyze Universal Wi-Fi Chime?
The Wyze Universal Wi-Fi Chime measures 81 x 53 x 38 mm, features a 40mm speaker, supports Wi-Fi IEEE802.11 b/g/n 2.4 GHz, requires 10-24V AC power input, operates in temperatures from -4°F to 122°F (-20°C to 50°C), and is certified by FCC, IC, UL, and CP65.Which Wyze products are recommended for adjustable chime volume?
The recommended Wyze products for adjustable chime volume are the Wyze Universal Wi-Fi Chime ($19.98), Wyze Video Doorbell v2 with Chime Controller ($44.98), and the Wyze Chime Controller ($17.99) for connecting to mechanical chimes.
Can you tell me more about the features of the Wyze Universal Wi-Fi Chime?How does the Wyze Chime Controller work with the Video Doorbell v2?Do you have any ongoing promotions or discounts for the Wyze products?
