How to Adjust Wyze Chime Volume for Doorbell Alerts
How to Control Volume Levels for Wyze Chime Doorbell Alerts
If you own a Wyze Video Doorbell paired with a Wyze Chime, managing the volume of your doorbell alerts is simple and customizable. While the Wyze Video Doorbell itself does not allow volume adjustments for its built-in speaker, the Wyze Chime accessory offers multiple volume levels to ensure you never miss a visitor.
Understanding Wyze Chime and Doorbell Volume Settings
Wyze Chime Volume Control
The Wyze Chime is designed to work seamlessly with your Wyze Video Doorbell, sounding an alert whenever someone presses the doorbell button. You can easily adjust the volume of the chime through the Wyze app:
  • Open the Wyze app and tap on your Wyze Video Doorbell device.
  • Tap the Settings icon in the top right corner.
  • Navigate to Accessories > Your Chime > Tunes.
  • Next to Volume, drag the slider to your preferred level. There are 8 volume levels available.
  • The chime will sound immediately to confirm the volume setting.
This feature ensures you can set the alert volume to suit your environment, whether you need a louder chime for a noisy household or a softer tone for quieter settings.
Wyze Video Doorbell Volume Limitations
It’s important to note that the Wyze Video Doorbell’s own speaker volume cannot be adjusted. The doorbell’s speaker is primarily for two-way audio communication and notifications, but the alert sound volume is controlled exclusively through the Wyze Chime.
Setting Up Your Wyze Chime for Optimal Alerts
Initial Setup of Wyze Chime
After installing your Wyze Video Doorbell, you will be prompted to add a Wyze Chime:
  • Plug the Wyze Chime into a standard power outlet near your doorbell.
  • Press and hold the reset button on the bottom of the chime until the blue light flashes three times.
  • The chime will automatically pair with your doorbell.
  • Complete the setup in the Wyze app by tapping Finish.
This setup ensures your chime is ready to alert you with customizable sounds and volume.
Troubleshooting Volume Issues
If your Wyze Chime does not sound when the doorbell is pressed:
  • Verify the chime is plugged in and powered.
  • Check the volume slider in the Wyze app under Accessories > Your Chime and increase the volume if it’s set to zero.
  • If issues persist, contact Wyze support for assistance.
Additional Features to Enhance Your Doorbell Experience
Chime Tune Selection
The Wyze Chime offers 19 different chime tunes. You can select your preferred tune in the same Tunes menu where you adjust the volume. This allows you to personalize your doorbell alert sound.
Using Wyze Cams as Chimes
For Wyze Duo Cam Doorbell users, certain Wyze Cams (Wyze Cam OG, v3, and Pan v3) can act as chimes. You can control the volume and tune of these camera chimes through the Wyze app, providing flexible alert options throughout your home.
Summary
The Wyze Chime is your go-to accessory for controlling the volume of doorbell alerts. With 8 volume levels and 19 tune options, you can customize your alert sounds to fit your lifestyle. While the Wyze Video Doorbell’s speaker volume cannot be changed, pairing it with a Wyze Chime gives you full control over how loud your doorbell rings.
Family enjoying smart home security Alt text: Family using Wyze Video Doorbell and Chime for home security
Frequently Asked Questions
Q: Can I change the volume of the Wyze Video Doorbell itself? A: No, the doorbell’s speaker volume cannot be adjusted. Volume control is available only through the Wyze Chime. Q: How many volume levels does the Wyze Chime have? A: The Wyze Chime offers 8 distinct volume levels. Q: Can I use multiple Wyze Chimes with one doorbell? A: Yes, you can add multiple Wyze Chimes to a single Wyze Video Doorbell for alerts in different areas. Q: What if my Wyze Chime doesn’t ring? A: Check that it is plugged in, paired correctly, and the volume is not set to zero in the app.
Optimize your home’s alert system today by mastering the Wyze Chime volume settings and enjoy peace of mind with clear, customizable doorbell notifications.
FeatureWyze ChimeWyze Cam OG
TypeAccessoryCamera
CompatibilityWyze Video Doorbell (Wired) onlyStandalone camera, indoor/outdoor use
Not Compatible WithWyze Video Doorbell Pro, v2N/A
Price$13.99$29.98 (1 Pack) / $59.96 (2 Pack) / $89.94 (3 Pack)
Field of ViewN/A120° field of view
Video ResolutionN/A1920 x 1080 (1080p)
Night VisionN/AColor Night Vision
SpotlightN/ABuilt-in 40-lumen spotlight
AudioN/AUpgraded two-way audio with noise & echo cancellation
Weather ResistanceN/AIP65 (Indoor/outdoor)
Power Adapter OutputN/A5V/1A
DimensionsN/A1.89 in x 1.89 in x 1.89 in (48 mm x 48 mm x 48 mm)
WeightN/A4.1 oz (116 g)
ConnectivityN/AWi-Fi 2.4 GHz
Local Storage SupportN/ASupports microSD cards up to 256GB
NotificationsN/A3X faster motion notifications
WarrantyN/A1-Year
Return Policy30-day hassle-free returns30-day hassle-free returns
How do I adjust the volume on my Wyze Chime for doorbell alerts?To adjust the Wyze Chime volume, open the Wyze app, select your Wyze Video Doorbell, tap the Settings icon, navigate to Accessories > Your Chime > Tunes, and use the volume slider to choose from 8 available levels. The chime will sound immediately to confirm your selection.
Can I change the volume of the Wyze Video Doorbell itself?No, the Wyze Video Doorbell’s built-in speaker volume cannot be adjusted. Volume control for doorbell alerts is only available through the Wyze Chime accessory.
How many volume levels does the Wyze Chime offer?The Wyze Chime provides 8 distinct volume levels, allowing you to customize the alert sound to suit your environment.
How do I set up my Wyze Chime with the Wyze Video Doorbell?Plug the Wyze Chime into a standard outlet near your doorbell, press and hold the reset button until the blue light flashes three times, and complete the pairing process in the Wyze app by tapping Finish.
What should I do if my Wyze Chime does not ring when the doorbell is pressed?Ensure the chime is plugged in and powered, check the volume slider in the Wyze app under Accessories > Your Chime to make sure it’s not set to zero, and verify the chime is paired correctly. If issues persist, contact Wyze support.
Can I use multiple Wyze Chimes with one Wyze Video Doorbell?Yes, you can connect multiple Wyze Chimes to a single Wyze Video Doorbell, allowing you to receive alerts in different areas of your home.
How do I change the chime tune on my Wyze Chime?In the Wyze app, go to Accessories > Your Chime > Tunes, and select from 19 different chime tunes to personalize your doorbell alert sound.
Can Wyze Cams be used as chimes for doorbell alerts?Yes, if you have a Wyze Duo Cam Doorbell, certain Wyze Cams (Wyze Cam OG, v3, and Pan v3) can act as chimes. You can control their volume and tune through the Wyze app.
How do I set up my Wyze Chime after installing the Wyze Video Doorbell?What should I do if my Wyze Chime is not ringing when the doorbell is pressed?Can I select different tunes for my Wyze Chime alerts?
