Control Indoor Lamps, Fans & Appliances Remotely with Smart Plugs
Smart Plug Solutions for Remote Control of Lamps, Fans, and Appliances Indoors
Controlling your home devices remotely has never been easier with smart plugs designed for indoor use. Whether you want to automate your lamps, fans, or other appliances, smart plugs offer convenience, energy savings, and seamless integration with your smart home ecosystem. Below, explore the top Wyze smart plugs that empower you to control your indoor devices effortlessly from anywhere.
Wyze Plug: The Ultimate Indoor Smart Plug for Lamps, Fans, and Appliances
Key Features and Benefits
  • Compact and Sleek Design: The Wyze Plug fits discreetly into any indoor outlet with its small white form factor (2.7" x 2.0" x 1.5"), blending seamlessly into your home décor.
  • Remote Control via App: Turn your lamps, fans, and appliances on or off from anywhere using the Wyze app on Android or iOS devices.
  • Voice Assistant Compatibility: Works with Alexa, Google Assistant, and IFTTT for hands-free voice control.
  • Scheduling and Automation: Set schedules to automate your devices, perfect for waking up with a fan or turning off lamps at bedtime.
  • Energy Monitoring: Track energy usage to optimize power consumption and save on electricity bills.
  • Reliable Connectivity: Connects over 2.4GHz WiFi for stable and responsive control.
  • Safe and Certified: ETL certified with a 15A max output, ensuring safe operation for most household devices.
  • Warranty: Comes with a 1-year warranty for peace of mind.
Ideal Use Cases
  • Automate your living room lamps to create ambiance.
  • Control fans remotely to cool your room before you arrive.
  • Schedule appliances like coffee makers or air purifiers for daily routines.
"Start living in the future. Make your normal ol' devices smart!" – Wyze Plug
Wyze Plug controlling home appliances Alt text: Lifestyle image showing a smart plug controlling a coffee maker in a modern kitchen.
Why Choose Wyze Plug for Indoor Smart Control?
Easy Setup and User-Friendly App
The Wyze Plug is designed for quick installation—just plug it into any standard indoor outlet and connect it to your home WiFi. The intuitive Wyze app lets you control multiple plugs, create groups, and set schedules with ease.
Energy Efficiency and Safety
With built-in overload protection and energy monitoring, the Wyze Plug helps you keep tabs on your power usage and avoid electrical hazards, making it a smart choice for energy-conscious households.
Integration with Smart Home Ecosystem
Seamlessly integrate with Alexa and Google Assistant to control your devices with simple voice commands, enhancing your smart home experience.
Outdoor Smart Plug Option: Wyze Plug Outdoor
While your query focuses on indoor control, if you ever want to extend smart control to outdoor lamps or fans, the Wyze Plug Outdoor is a perfect companion.
Features of Wyze Plug Outdoor
  • Weather-Resistant (IP64 Rated): Designed to withstand rain, snow, and extreme temperatures (-4°F to 120°F).
  • Dual Outlets: Control two outdoor devices independently.
  • Energy Monitoring: Track outdoor device usage.
  • Voice Control: Compatible with Alexa.
  • Long WiFi Range: Up to 300 feet for reliable outdoor connectivity.
  • Robust Build: 15A max output with overload protection.
Though primarily for outdoor use, it can also be used indoors if desired.
Enhance Your Smart Home with Wyze Smart Plugs
Smart plugs like the Wyze Plug provide a simple yet powerful way to control your lamps, fans, and appliances remotely. They bring convenience, energy savings, and peace of mind to your daily life. Whether you want to automate your lighting, manage your fans, or schedule your appliances, Wyze smart plugs are designed to fit seamlessly into your connected home. Wyze Plug controlling a fan and lamp Alt text: Lifestyle image showing a smart plug controlling a house fan and lamp in a cozy living room.
Summary of Wyze Smart Plugs for Indoor Remote Control
Product NameIndoor/OutdoorOutletsVoice ControlEnergy MonitoringPrice Range
Wyze PlugIndoor1Alexa, Google, IFTTTYes$24.98 - $39.98
Wyze Plug OutdoorIndoor/Outdoor2AlexaYes$15.99 - $34.98
Take control of your home devices with Wyze smart plugs and enjoy the convenience of managing lamps, fans, and appliances remotely — all from the palm of your hand.
FeatureWyze PlugWyze Plug Outdoor
TypeIndoor Smart PlugOutdoor Smart Plug
ControlRemote on/off via Wyze appRemote on/off via Wyze app
Hub RequiredNoNo
SchedulingYesYes
Voice ControlAlexa, Google AssistantAlexa, Google Assistant
Special ModesVacation Mode (random on/off)Energy Monitoring, Usage Alerts
Outlets1 outlet per plug2 outlets per plug, independently controlled
WiFi RangeStandard WiFiExtended WiFi range (up to 300 ft open space)
Weather ResistanceNoIP64 (rain, dust, dirt, snow resistant)
Power OutputStandard15 AMP with overload protection
Sizes Available1 Pack, 2 Pack, 4 Pack1 Pack, 2 Pack
Price Range$12.98 - $39.98$15.99 - $34.98
Return Policy30-day hassle-free returns30-day hassle-free returns
What is the Wyze Plug and how does it work for indoor smart control?The Wyze Plug is a compact indoor smart plug that allows you to remotely control lamps, fans, and appliances using the Wyze app on your Android or iOS device. It connects to your home WiFi and can be managed from anywhere, offering convenience, automation, and energy savings.
How do I set up the Wyze Plug for my home devices?Setting up the Wyze Plug is simple. Plug it into any standard indoor outlet, connect it to your 2.4GHz WiFi network, and follow the instructions in the Wyze app to pair and control your devices. The app also lets you group plugs and set schedules easily.
Can I control Wyze Plug with voice assistants like Alexa or Google Assistant?Yes, the Wyze Plug is compatible with Alexa, Google Assistant, and IFTTT. You can use voice commands to turn your lamps, fans, and appliances on or off, making hands-free control effortless.
Does the Wyze Plug support scheduling and automation?Absolutely. The Wyze Plug allows you to set custom schedules and automate your devices. For example, you can schedule lamps to turn on at sunset or fans to turn off at bedtime, enhancing your daily routines.
Can I monitor energy usage with the Wyze Plug?Yes, the Wyze Plug features built-in energy monitoring. You can track the power consumption of connected devices through the Wyze app, helping you optimize energy use and save on electricity bills.
Is the Wyze Plug safe to use with household appliances?The Wyze Plug is ETL certified and supports a maximum output of 15A, making it safe for most household devices. It also includes overload protection to prevent electrical hazards.
What are the ideal use cases for Wyze Plug?Wyze Plug is perfect for automating living room lamps, remotely controlling fans, and scheduling appliances like coffee makers or air purifiers. It brings convenience and smart automation to your indoor devices.
Does Wyze offer a smart plug for outdoor use?Yes, Wyze offers the Wyze Plug Outdoor, which is weather-resistant (IP64 rated), features dual independently controlled outlets, and supports energy monitoring. It is designed for outdoor use but can also be used indoors if needed.
What is the warranty period for Wyze smart plugs?Wyze smart plugs come with a 1-year warranty, providing peace of mind and reliable support for your smart home devices.
How does the Wyze Plug help with energy efficiency?The Wyze Plug helps you monitor and manage your energy usage through its energy monitoring feature. By tracking consumption and automating device schedules, you can reduce unnecessary power use and lower your electricity bills.
How do I set up the Wyze Plug for remote control of my devices?Can the Wyze Plug be used with multiple devices at the same time?Do you have any ongoing sales or discounts for the Wyze Plug?
