Indoor Smart Plug for Lamps and Fans with Wyze App
Control your indoor lamps, fans, and other appliances effortlessly with the
Wyze Plug — a compact, reliable smart plug designed to bring convenience and automation to your home. Using the Wyze app, you can schedule, monitor, and control your devices from anywhere, making your living space smarter and more energy-efficient.
Wyze Plug: Your Indoor Smart Home Companion
- Compact and Sleek Design: The Wyze Plug fits discreetly into any outlet with its small white body (2.7" x 2.0" x 1.5"), blending seamlessly into your home decor.
- Easy App Control: Compatible with Android 5.0+ and iOS 9.0+, the Wyze app lets you turn devices on/off, set schedules, and create automation routines.
- Voice Assistant Integration: Works with Alexa, Google Assistant, and IFTTT for hands-free control.
- Reliable Connectivity: Connects via 2.4GHz WiFi for stable and responsive operation.
- Safe and Certified: ETL certified with a 15A max output, ensuring safe use with lamps, fans, and other household devices.
- Energy Monitoring: Track your device’s energy usage to optimize power consumption.
- Warranty: Comes with a 1-year warranty for peace of mind.
Whether you want to automate your bedside lamp or schedule your living room fan, the Wyze Plug makes it simple and smart.
Control lamps and fans easily with Wyze Plug and app
Outdoor Smart Plug for Versatile Control
If you want to extend smart control beyond your indoor devices, the
Wyze Plug Outdoor is the perfect companion. Designed to withstand weather conditions, it’s ideal for controlling outdoor lamps, fans, holiday lights, and more — all from the Wyze app.
Wyze Plug Outdoor: Smart Power for Your Outdoor Spaces
- Durable Weather-Resistant Build: Rated IP64, it handles rain, snow, and dust, making it perfect for patios, gardens, and porches.
- Dual Outlets: Control two devices independently with two outlets in one plug.
- Wide Operating Temperature: Works from -4°F to 120°F, suitable for most climates.
- Powerful Output: Supports up to 15A max with overload protection, including motors up to 1/2 HP.
- Connectivity: Uses 2.4GHz WiFi and Bluetooth V4.2 for reliable connection up to 300 feet.
- Energy Monitoring: Keep track of outdoor device power usage.
- Voice Control: Compatible with Alexa for convenient voice commands.
- Compact Size: Measures 4.0” x 2.8” x 1.4” and weighs 7.2 ounces.
- Warranty: 1-year warranty included.
With the Wyze Plug Outdoor, you can automate your garden lights, fans, or holiday decorations effortlessly, enhancing your outdoor living experience.
Smart control for outdoor lighting and devices
Why Choose Wyze Smart Plugs with the Wyze App?
"Make your normal ol' devices smart!" — Wyze Plug
The Wyze app is your centralized hub for managing all Wyze smart plugs, whether indoor or outdoor. It offers:
- Intuitive Scheduling: Set timers and schedules to automate lamps and fans based on your daily routine.
- Remote Access: Control your devices from anywhere, ensuring your home is always comfortable and energy-efficient.
- Group Control: Manage multiple plugs together for synchronized control.
- Energy Insights: Monitor power consumption to reduce waste and save on electricity bills.
- Seamless Integration: Works with popular voice assistants and smart home ecosystems.
Summary of Wyze Smart Plugs for Indoor and Outdoor Use
Feature | Wyze Plug (Indoor) | Wyze Plug Outdoor |
Use Case | Indoor lamps, fans, appliances | Outdoor lights, fans, holiday decor |
Connectivity | 2.4GHz WiFi | 2.4GHz WiFi + Bluetooth V4.2 |
Max Output | 15A | 15A with overload protection |
Weather Resistance | Indoor use only | IP64 rated for outdoor use |
Voice Assistant Support | Alexa, Google Assistant, IFTTT | Alexa |
Energy Monitoring | Yes | Yes |
Warranty | 1 Year | 1 Year |
Enhance your home automation with Wyze smart plugs and the Wyze app — the perfect duo for controlling lamps, fans, and more with ease and intelligence.
What is the Wyze Plug and how does it work?
The Wyze Plug is a compact indoor smart plug that allows you to control lamps, fans, and other appliances using the Wyze app. You can turn devices on or off, set schedules, and monitor energy usage from anywhere using your smartphone.Is the Wyze Plug compatible with voice assistants?
Yes, the Wyze Plug works with Alexa, Google Assistant, and IFTTT, allowing you to control your devices hands-free using voice commands.Can I use the Wyze Plug with both Android and iOS devices?
Yes, the Wyze Plug is compatible with Android devices running version 5.0 or higher and iOS devices running version 9.0 or higher.Does the Wyze Plug support energy monitoring?
Yes, the Wyze Plug features energy monitoring, allowing you to track your device’s power consumption and optimize energy usage.What is the maximum output of the Wyze Plug?
The Wyze Plug supports a maximum output of 15A, making it suitable for most household lamps, fans, and appliances.Is the Wyze Plug safe to use?
Yes, the Wyze Plug is ETL certified and designed for safe use with a 15A max output, ensuring reliable operation with your indoor devices.Can I control multiple Wyze Plugs at once?
Yes, the Wyze app allows you to group multiple Wyze Plugs together for synchronized control and automation.What is the difference between Wyze Plug Indoor and Wyze Plug Outdoor?
The Wyze Plug Indoor is designed for indoor use with a compact design and supports Alexa, Google Assistant, and IFTTT. The Wyze Plug Outdoor is weather-resistant (IP64 rated), has dual independently controlled outlets, supports Alexa, and is ideal for outdoor lights, fans, and holiday decorations.Is the Wyze Plug Outdoor weatherproof?
Yes, the Wyze Plug Outdoor is IP64 rated, making it resistant to rain, snow, and dust, and suitable for use in patios, gardens, and porches.How many devices can I control with the Wyze Plug Outdoor?
The Wyze Plug Outdoor features two independently controlled outlets, allowing you to manage two devices separately from the same plug.What is the warranty period for Wyze smart plugs?
Both the Wyze Plug Indoor and Wyze Plug Outdoor come with a 1-year warranty for peace of mind.How do I set up schedules and automation with Wyze smart plugs?
You can use the Wyze app to set timers, schedules, and automation routines for your Wyze smart plugs, making it easy to automate your lamps, fans, and other devices based on your daily routine.What type of WiFi does the Wyze Plug require?
Both Wyze Plug Indoor and Wyze Plug Outdoor connect via 2.4GHz WiFi for stable and responsive operation. The outdoor version also supports Bluetooth V4.2 for setup and connectivity.Can I monitor energy usage for outdoor devices with Wyze Plug Outdoor?
Yes, the Wyze Plug Outdoor includes energy monitoring, allowing you to track the power consumption of your outdoor devices.
