Remote Control Smart Plugs with Scheduling and Vacation Mode
Looking to automate your home or outdoor devices effortlessly? Smart plugs with remote control, scheduling, and vacation mode features are the perfect solution to bring convenience, energy savings, and security to your everyday life. Below, we highlight the top Wyze smart plugs designed to meet your needs both indoors and outdoors.
Wyze Plug: Indoor Smart Plug with Scheduling & Vacation Mode
Experience the future of home automation with the
Wyze Plug, a compact and powerful indoor smart plug that transforms your regular devices into smart ones.
Key Features:
- Remote Control: Turn your devices on or off from anywhere using the Wyze app on your smartphone.
- Scheduling: Set custom schedules to automate your appliances, lights, or fans to fit your daily routine.
- Vacation Mode: Randomize your device activity to simulate occupancy when you're away, enhancing home security.
- Voice Assistant Integration: Compatible with Alexa, Google Assistant, and IFTTT for hands-free control.
- Compact Design: Small footprint that won’t block adjacent outlets.
- Connectivity: Reliable 2.4GHz WiFi connection.
- Power Output: Supports up to 15A max load.
- Operating Temperature: Works efficiently between -4°F to 104°F (-20°C to 40°C).
- Certifications & Warranty: ETL certified with a 1-year warranty for peace of mind.
Ideal For:
- Indoor lamps, coffee makers, fans, air purifiers, and more.
- Users who want to save energy and automate daily tasks effortlessly.
Control your home appliances remotely with Wyze Plug
Wyze Plug Outdoor: Weather-Resistant Smart Plug for Outdoor Use
Power your outdoor devices with confidence using the
Wyze Plug Outdoor, designed to withstand rain, snow, dust, and dirt while offering smart control features.
Key Features:
- Dual Outlets with Independent Control: Manage two outdoor devices separately, perfect for garden lights and holiday inflatables.
- Scheduling & Vacation Mode: Automate your outdoor lighting or decorations with custom schedules and simulate presence when away.
- Energy Monitoring: Track energy consumption and set alerts to optimize power usage.
- Extended WiFi Range: Up to 300 feet in open space, ensuring connectivity even in large yards.
- Weather Resistant: IP64 rating protects against water splashes and dust.
- High Power Output: 15 AMP with overload protection for heavy-duty outdoor devices.
- Voice Control: Compatible with Alexa for convenient hands-free operation.
Perfect For:
- Outdoor lighting, pond pumps, roof de-icers, holiday decorations, and backyard parties.
- Anyone wanting to automate and monitor outdoor power usage safely.
Enhance your outdoor space with smart control and scheduling
Why Choose Wyze Smart Plugs?
"Smart plugs with scheduling and vacation mode not only bring convenience but also enhance your home's security and energy efficiency."
Wyze smart plugs stand out by combining ease of use, robust app control, and smart features like vacation mode that simulate occupancy to deter intruders. Whether indoors or outdoors, Wyze plugs integrate seamlessly with popular voice assistants and offer reliable connectivity to keep your devices running on your terms.
Summary of Features
Feature | Wyze Plug (Indoor) | Wyze Plug Outdoor |
Remote App Control | Yes | Yes |
Scheduling | Yes | Yes |
Vacation Mode | Yes | Yes |
Voice Assistant | Alexa, Google, IFTTT | Alexa |
Energy Monitoring | No | Yes |
Weather Resistance | Indoor use only | IP64 Rated (Water & Dust) |
Power Output | 15A Max | 15A Max with Overload Protection |
WiFi Frequency | 2.4 GHz | Extended 2.4 GHz (up to 300 ft) |
Number of Outlets | 1 | 2 (independent control) |
Conclusion
For smart home enthusiasts seeking reliable remote control, scheduling, and vacation mode features, Wyze offers two excellent smart plug options tailored for indoor and outdoor use. The
Wyze Plug is perfect for automating your indoor appliances with ease, while the
Wyze Plug Outdoor brings smart control and energy monitoring to your outdoor devices, rain or shine.
Upgrade your home automation today with Wyze smart plugs and enjoy the convenience of managing your devices anytime, anywhere.
What are the main features of Wyze Plug indoor smart plug?
The Wyze Plug indoor smart plug offers remote control via the Wyze app, customizable scheduling, vacation mode to simulate occupancy, voice assistant integration with Alexa, Google Assistant, and IFTTT, a compact design, reliable 2.4GHz WiFi connectivity, support for up to 15A max load, and comes ETL certified with a 1-year warranty.How does vacation mode work on Wyze smart plugs?
Vacation mode on Wyze smart plugs randomizes the on/off activity of your connected devices to simulate occupancy when you are away, helping to enhance your home's security by deterring potential intruders.Can I control Wyze smart plugs remotely?
Yes, both Wyze Plug (indoor) and Wyze Plug Outdoor can be controlled remotely from anywhere using the Wyze app on your smartphone, allowing you to turn devices on or off even when you are not at home.Are Wyze smart plugs compatible with voice assistants?
Yes, Wyze Plug indoor is compatible with Alexa, Google Assistant, and IFTTT for hands-free control. Wyze Plug Outdoor supports Alexa for convenient voice operation.What is the difference between Wyze Plug indoor and Wyze Plug Outdoor?
Wyze Plug indoor is designed for indoor use, features a single outlet, and supports voice assistants like Alexa, Google Assistant, and IFTTT. Wyze Plug Outdoor is weather-resistant (IP64 rated), has two independently controlled outlets, offers energy monitoring, extended WiFi range up to 300 feet, and is ideal for outdoor devices.Does Wyze Plug Outdoor support energy monitoring?
Yes, Wyze Plug Outdoor includes energy monitoring, allowing you to track energy consumption and set alerts to optimize power usage for your outdoor devices.What devices can I automate with Wyze smart plugs?
Wyze Plug indoor is ideal for automating lamps, coffee makers, fans, air purifiers, and other indoor appliances. Wyze Plug Outdoor is perfect for outdoor lighting, pond pumps, roof de-icers, holiday decorations, and backyard party equipment.Is Wyze Plug Outdoor weather-resistant?
Yes, Wyze Plug Outdoor is IP64 rated, making it resistant to water splashes and dust, so it can be safely used in rain, snow, and outdoor environments.What is the maximum power output supported by Wyze smart plugs?
Both Wyze Plug indoor and Wyze Plug Outdoor support up to 15A maximum load, with the outdoor version also featuring overload protection for heavy-duty devices.How far can Wyze Plug Outdoor connect to WiFi?
Wyze Plug Outdoor offers an extended WiFi range of up to 300 feet in open space, ensuring reliable connectivity even in large yards or outdoor areas.Do Wyze smart plugs require a specific WiFi frequency?
Yes, both Wyze Plug indoor and Wyze Plug Outdoor operate on a 2.4GHz WiFi frequency for optimal connectivity.Are Wyze smart plugs easy to install and use?
Yes, Wyze smart plugs are designed for easy installation and user-friendly operation through the Wyze app, making it simple to automate and control your devices.
