Smart Plugs with No Hub Required and Effortless Setup
Smart Plugs with No Hub Control and Easy Setup
Looking for smart plugs that offer seamless no-hub control and effortless setup? Wyze provides top-notch smart plugs designed to simplify your smart home experience. Whether you want to automate indoor devices or control outdoor lighting, these smart plugs deliver reliable performance with easy app control and voice assistant compatibility.
Wyze Plug: Simple Indoor Smart Plug
Effortless Setup and Control
The Wyze Plug is perfect for anyone wanting to make their everyday devices smart without the hassle of a hub. It connects directly to your 2.4GHz WiFi network, allowing you to control it easily through the Wyze app on your smartphone. Setup is quick and intuitive, so you can start automating your home in minutes.
Key Features
  • No hub required: Connects directly to WiFi for instant control.
  • App & voice control: Compatible with Alexa, Google Assistant, and IFTTT.
  • Scheduling & automation: Set timers and schedules to automate your devices.
  • Compact design: Fits easily into any outlet without blocking adjacent sockets.
  • Indoor use: Designed for indoor environments with operating temperatures from -4°F to 104°F.
  • Energy efficient: Supports up to 15A max output with ETL certification.
Ideal Uses
Control lamps, fans, coffee makers, and more with a simple tap or voice command. The Wyze Plug is a smart, affordable way to start your smart home journey. Wyze Plug in Home Setting Wyze Plug offers easy app control for your indoor devices.
Wyze Plug Outdoor: Rugged Smart Plug for Outdoor Use
Weather-Resistant and Powerful
Take your smart control outside with the Wyze Plug Outdoor. Built to withstand rain, dust, dirt, and snow, this plug is IP64 rated for weather resistance, making it perfect for powering garden lights, holiday decorations, or pond pumps.
Highlights
  • No hub needed: Connects directly to your WiFi network.
  • Dual outlets: Two independently controlled outlets in one device.
  • Extended WiFi range: Up to 300 feet in open space for flexible placement.
  • Energy monitoring: Track energy usage and set consumption alerts via the Wyze app.
  • Voice control: Works with Alexa and Google Assistant for hands-free operation.
  • High output: 15 AMP with overload protection for heavy-duty outdoor devices.
Perfect For
Automating outdoor lighting, powering roof de-icers, or controlling backyard inflatables with ease and reliability. Outdoor Smart Plug Lifestyle Wyze Plug Outdoor keeps your garden and outdoor devices smart and connected.
Why Choose Wyze Smart Plugs for No Hub Control?
"Smart home automation should be simple, accessible, and reliable."
Wyze smart plugs are designed with user convenience in mind. No need for additional hubs or complicated setups—just connect to your existing WiFi and control your devices instantly. The Wyze app provides a unified platform to manage all your plugs, set schedules, monitor energy usage (outdoor plug), and integrate with popular voice assistants.
Benefits at a Glance
  • Hassle-free installation: Plug in and connect via app.
  • No extra hardware: No hub or bridge required.
  • Voice assistant integration: Alexa and Google Assistant compatible.
  • Energy monitoring (Outdoor Plug): Save on electricity bills by tracking usage.
  • Durability: Weatherproof design for outdoor use.
Summary
For smart plugs with no hub control and easy setup, Wyze offers two excellent options:
  • Wyze Plug: Ideal for indoor smart device control with simple app and voice commands.
  • Wyze Plug Outdoor: Rugged, weather-resistant plug with dual outlets and energy monitoring for outdoor automation.
Both plugs provide seamless integration into your smart home ecosystem, making automation effortless and affordable.
FeatureWyze PlugWyze Plug Outdoor
ColorWhiteBlack
Size Variants2 Pack, 4 Pack1 Pack, 2 Pack
Price$24.98 (2 Pack), $39.98 (4 Pack)$15.99 (1 Pack), $34.98 (2 Pack)
Dimensions2.7" x 2.0" x 1.5"4.0" x 2.8" x 1.4"
Weight5.3 oz7.2 oz
Weather ResistanceIndoor use onlyIP64 (Indoor & Outdoor)
Operating Temperature-4°F to 104°F (-20°C to 40°C)-4°F to 120°F
Input Voltage100-120 VAC, 60Hz120V~, 60Hz
Output15A Max15A Max with Overload Protection
Connectivity2.4GHz WiFi2.4GHz WiFi, Bluetooth V4.2
Compatibility (OS)Android 5.0+, iOS 9.0+Android 5.0+, iOS 9.0+
IntegrationsAlexa, Google Assistant, IFTTTAlexa
Number of Outlets12
Energy MonitoringNoYes
Max Motor LoadNot specified1/2 HP
WiFi RangeNot specifiedUp to 300 feet
Warranty1 Year1 Year
Do Wyze smart plugs require a hub for setup and control?No, Wyze smart plugs do not require a hub. Both the Wyze Plug and Wyze Plug Outdoor connect directly to your 2.4GHz WiFi network, allowing for easy setup and control without the need for additional hardware.
How do I set up a Wyze smart plug?Setting up a Wyze smart plug is simple. Just plug it into an outlet, connect it to your 2.4GHz WiFi network using the Wyze app, and follow the on-screen instructions. No hub or bridge is needed, making the process quick and intuitive.
Are Wyze smart plugs compatible with Alexa and Google Assistant?Yes, Wyze smart plugs work seamlessly with both Amazon Alexa and Google Assistant. You can control your devices using voice commands for hands-free convenience.
What devices can I control with the Wyze Plug indoor smart plug?The Wyze Plug is ideal for controlling indoor devices such as lamps, fans, coffee makers, and other small appliances. It supports up to 15A max output and fits easily into any standard outlet.
Is the Wyze Plug Outdoor weatherproof?Yes, the Wyze Plug Outdoor is IP64 rated for weather resistance, making it suitable for use in rain, dust, dirt, and snow. It's perfect for automating outdoor lighting, holiday decorations, and other outdoor devices.
Does the Wyze Plug Outdoor have energy monitoring features?Yes, the Wyze Plug Outdoor includes energy monitoring. You can track energy usage and set consumption alerts directly from the Wyze app to help manage your electricity bills.
Can I control multiple devices with the Wyze Plug Outdoor?Yes, the Wyze Plug Outdoor features two independently controlled outlets, allowing you to manage two devices separately from a single plug.
What is the WiFi range of the Wyze Plug Outdoor?The Wyze Plug Outdoor offers an extended WiFi range of up to 300 feet in open space, providing flexible placement options for your outdoor devices.
Is the Wyze Plug energy efficient?Yes, the Wyze Plug is energy efficient and supports up to 15A max output. The outdoor version also includes energy monitoring to help you track and reduce energy consumption.
What are the main benefits of using Wyze smart plugs?Wyze smart plugs offer hassle-free installation, no need for extra hardware or hubs, compatibility with Alexa and Google Assistant, energy monitoring (outdoor plug), and a durable, weatherproof design for outdoor use.
Can you tell me more about the Wyze Plug's energy monitoring features?How does the Wyze Plug Outdoor handle extreme weather conditions?Do you have any ongoing sales or discounts for smart plugs?
