WiFi Smart Plugs for Remote Control & Energy Saving Appliances
Looking to transform your home appliances into smart devices that save energy and offer remote control convenience? Discover the power of WiFi smart plugs designed to optimize your energy usage, automate your daily routines, and give you control from anywhere using your smartphone or voice assistant. Below, explore the top Wyze smart plugs tailored for indoor and outdoor use, perfect for energy-conscious households.
Wyze Plug: Smart Indoor WiFi Plug for Energy Efficiency
Make your everyday appliances smarter with the Wyze Plug, a compact and reliable indoor smart plug that lets you control devices remotely and save energy effortlessly.
Key Features:
  • Remote Control & Scheduling: Turn your appliances on/off from anywhere using the Wyze app on Android or iOS.
  • Energy Saving: Automate your devices to run only when needed, reducing unnecessary power consumption.
  • Compatibility: Works seamlessly with Alexa, Google Assistant, and IFTTT for voice commands and smart home integration.
  • Compact Design: Small footprint (2.7" x 2.0" x 1.5") fits easily into any outlet without blocking adjacent sockets.
  • Safe & Certified: ETL certified with a max output of 15A, suitable for most household appliances.
  • Operating Range: Supports 2.4GHz WiFi networks, operating between -4°F to 104°F, ideal for indoor environments.
  • Available Packs: Choose from 2-pack or 4-pack options to cover multiple devices.
Start living in the future by making your normal devices smart and energy-efficient with Wyze Plug.
Wyze Plug in Lifestyle Use Control your coffee maker or fan remotely with Wyze Plug
Wyze Plug Outdoor: Weather-Resistant Smart Plug for Outdoor Appliances
Extend smart control and energy savings to your outdoor devices with the Wyze Plug Outdoor, designed to withstand the elements while providing powerful remote management.
Key Features:
  • Weatherproof Design: IP64 rating ensures protection against rain and dust, perfect for garden lights, holiday inflatables, and outdoor appliances.
  • Dual Outlets: Two smart outlets allow simultaneous control of multiple devices.
  • Energy Monitoring: Track power usage to optimize energy consumption and reduce costs.
  • Long WiFi Range: Connects up to 300 feet away on 2.4GHz WiFi with Bluetooth V4.2 support.
  • Voice Control: Compatible with Alexa for hands-free operation.
  • Robust Output: Supports up to 15A with overload protection and can handle motors up to 1/2 HP.
  • Operating Temperature: Works reliably from -4°F to 120°F, suitable for various climates.
  • Available Packs: Offered in 1-pack or 2-pack configurations.
Power up your outdoor space rain or shine, and manage your devices with ease from your smartphone.
Outdoor Smart Plug in Garden Setting Manage outdoor lighting and appliances effortlessly with Wyze Plug Outdoor
Why Choose Wyze Smart Plugs for Energy Saving?
Wyze smart plugs are designed with your convenience and energy savings in mind. By enabling remote control, scheduling, and energy monitoring, these plugs help you reduce wasted electricity and lower your utility bills. Whether you want to automate your indoor appliances or control outdoor devices safely, Wyze offers reliable, affordable, and easy-to-use solutions.
“Smart plugs are a simple yet powerful way to make your home more energy-efficient and connected.”
Summary of Wyze Smart Plugs for Energy Saving Appliances
ProductIndoor/OutdoorKey BenefitsConnectivityVoice Assistant SupportEnergy MonitoringPrice Range
Wyze PlugIndoorCompact, scheduling, app control2.4GHz WiFiAlexa, Google, IFTTTNo$24.98 - $39.98
Wyze Plug OutdoorOutdoorWeatherproof, dual outlets, energy monitoring2.4GHz WiFi, BluetoothAlexaYes$15.99 - $34.98
Enhance Your Smart Home with Wyze
Integrate Wyze smart plugs into your connected home ecosystem to enjoy seamless control, energy savings, and peace of mind. Whether it’s turning off your coffee maker remotely or scheduling your garden lights, Wyze smart plugs empower you to manage your appliances efficiently and effortlessly.
FeatureWyze PlugWyze Plug Outdoor
TypeIndoor Smart PlugOutdoor Smart Plug
ControlRemote on/off via Wyze appRemote on/off via Wyze app
Hub RequiredNoNo
SchedulingYesYes
Voice ControlAlexa, Google AssistantAlexa, Google Assistant
Special ModesVacation Mode (random on/off)Energy Monitoring, Usage Alerts
Outlets1 outlet per plug2 outlets per plug, independently controlled
Weather ResistanceNot specified (indoor use)IP64 Weather Resistant
WiFi RangeStandard WiFiExtended WiFi Range (up to 300 ft open space)
Power OutputStandard15 AMP Output with Overload Protection
Price (1 Pack)$12.98$15.99
Price (2 Pack)$24.98 (Sold Out)$34.98
Price (4 Pack)$39.98 (Sold Out)N/A
Energy MonitoringNoYes
Suitable UseIndoor devices (lamps, fans)Outdoor devices (garden lights, inflatables, pond pumps)
Return Policy30-day hassle-free returns30-day hassle-free returns
What are WiFi smart plugs and how do they help save energy?WiFi smart plugs are devices that connect your regular appliances to your home WiFi network, allowing you to control them remotely via a smartphone app or voice assistant. By scheduling appliances to run only when needed and monitoring energy usage, smart plugs help reduce unnecessary power consumption and lower your electricity bills.
What is the Wyze Plug and what are its main features?The Wyze Plug is a compact indoor smart plug that enables remote control and scheduling of your appliances through the Wyze app. Key features include compatibility with Alexa, Google Assistant, and IFTTT, energy-saving automation, a small design that doesn't block adjacent outlets, ETL certification, and support for 2.4GHz WiFi networks.
Can I control Wyze smart plugs with my voice?Yes, Wyze smart plugs are compatible with popular voice assistants such as Amazon Alexa and Google Assistant, allowing you to control your appliances hands-free using simple voice commands.
Are Wyze smart plugs suitable for outdoor use?Yes, the Wyze Plug Outdoor is specifically designed for outdoor use. It features a weatherproof IP64 rating, dual outlets for controlling multiple devices, and operates reliably in temperatures from -4°F to 120°F, making it ideal for garden lights, holiday decorations, and other outdoor appliances.
Does the Wyze Plug Outdoor offer energy monitoring?Yes, the Wyze Plug Outdoor includes energy monitoring capabilities, allowing you to track power usage and optimize your energy consumption to reduce costs.
What is the difference between Wyze Plug and Wyze Plug Outdoor?The Wyze Plug is designed for indoor use, offering compact scheduling and app control without energy monitoring. The Wyze Plug Outdoor is weatherproof, features dual outlets, supports energy monitoring, and is built to withstand outdoor conditions. Both support remote control and voice assistant integration.
What appliances can I control with Wyze smart plugs?Wyze smart plugs can control a wide range of household and outdoor appliances, such as coffee makers, fans, lamps, garden lights, and holiday inflatables. The plugs support devices up to 15A and, for outdoor use, motors up to 1/2 HP.
How do I set up and use Wyze smart plugs?To set up Wyze smart plugs, simply plug them into a standard outlet, connect them to your 2.4GHz WiFi network using the Wyze app on your Android or iOS device, and follow the in-app instructions. Once set up, you can control, schedule, and monitor your appliances remotely.
Are Wyze smart plugs safe to use?Yes, Wyze smart plugs are ETL certified and include safety features such as overload protection, ensuring safe operation for most household and outdoor appliances.
What pack sizes are available for Wyze smart plugs?Wyze Plug (indoor) is available in 2-pack and 4-pack options, while Wyze Plug Outdoor is offered in 1-pack and 2-pack configurations, allowing you to cover multiple devices as needed.
What are the key features of the Wyze Plug for indoor use?How does the energy monitoring feature work on the Wyze Plug Outdoor?Are there any ongoing sales or discounts for Wyze smart plugs?
